path: root/drivers/char/tpm
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-12-11Merge tag 'char-misc-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull Char/Misc driver merge from Greg Kroah-Hartman: "Here is the "big" char/misc driver patches for 3.8-rc1. I'm starting to put random driver subsystems that I had previously sent you through the driver-core tree in this tree, as it makes more sense to do so. Nothing major here, the various __dev* removals, some mei driver updates, and other random driver-specific things from the different maintainers and developers. Note, some MFD drivers got added through this tree, and they are also coming in through the "real" MFD tree as well, due to some major mis-communication between me and the different developers. If you have any merge conflicts, take the ones from the MFD tree, not these ones, sorry about that. All of this has been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflict in drivers/mmc/host/Kconfig due to new drivers having been added (both at the end, as usual..) * tag 'char-misc-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (84 commits) MAINTAINERS: remove drivers/staging/hv/ misc/st_kim: Free resources in the error path of probe() drivers/char: for hpet, add count checking, and ~0UL instead of -1 w1-gpio: Simplify & get rid of defines w1-gpio: Pinctrl-fy extcon: remove use of __devexit_p extcon: remove use of __devinit extcon: remove use of __devexit drivers: uio: Only allocate new private data when probing device tree node drivers: uio_dmem_genirq: Allow partial success when opening device drivers: uio_dmem_genirq: Don't use DMA_ERROR_CODE to indicate unmapped regions drivers: uio_dmem_genirq: Don't mix address spaces for dynamic region vaddr uio: remove use of __devexit uio: remove use of __devinitdata uio: remove use of __devinit uio: remove use of __devexit_p char: remove use of __devexit char: remove use of __devinitconst char: remove use of __devinitdata char: remove use of __devinit ...
2012-11-28tpm_infineon: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Acked-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28tpm: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Acked-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21char: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Olof Johansson <olof@lixom.net> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-arm-kernel@lists.infradead.org Cc: openipmi-developer@lists.sourceforge.net Cc: platform-driver-x86@vger.kernel.org Cc: tpmdd-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21char: remove use of __devinitdataBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinitdata is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: David Airlie <airlied@linux.ie> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: openipmi-developer@lists.sourceforge.net Cc: tpmdd-devel@lists.sourceforge.net Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-01drivers/char/tpm: remove tasklet and cleanupAshley Lai
This patch removed the tasklet and moved the wait queue into the private structure. It also cleaned up the response CRQ path. Signed-off-by: Ashley Lai <adlai@us.ibm.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-10-11Merge branch 'tpmdd-next-v3.6' of git://github.com/shpedoikal/linux into ↵James Morris
for-linus
2012-10-10tpm: Propagate error from tpm_transmit to fix a timeout hangPeter Huewe
tpm_write calls tpm_transmit without checking the return value and assigns the return value unconditionally to chip->pending_data, even if it's an error value. This causes three bugs. So if we write to /dev/tpm0 with a tpm_param_size bigger than TPM_BUFSIZE=0x1000 (e.g. 0x100a) and a bufsize also bigger than TPM_BUFSIZE (e.g. 0x100a) tpm_transmit returns -E2BIG which is assigned to chip->pending_data as -7, but tpm_write returns that TPM_BUFSIZE bytes have been successfully been written to the TPM, altough this is not true (bug #1). As we did write more than than TPM_BUFSIZE bytes but tpm_write reports that only TPM_BUFSIZE bytes have been written the vfs tries to write the remaining bytes (in this case 10 bytes) to the tpm device driver via tpm_write which then blocks at /* cannot perform a write until the read has cleared either via tpm_read or a user_read_timer timeout */ while (atomic_read(&chip->data_pending) != 0) msleep(TPM_TIMEOUT); for 60 seconds, since data_pending is -7 and nobody is able to read it (since tpm_read luckily checks if data_pending is greater than 0) (#bug 2). After that the remaining bytes are written to the TPM which are interpreted by the tpm as a normal command. (bug #3) So if the last bytes of the command stream happen to be a e.g. tpm_force_clear this gets accidentally sent to the TPM. This patch fixes all three bugs, by propagating the error code of tpm_write and returning -E2BIG if the input buffer is too big, since the response from the tpm for a truncated value is bogus anyway. Moreover it returns -EBUSY to userspace if there is a response ready to be read. Signed-off-by: Peter Huewe <peter.huewe@infineon.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-10-10driver/char/tpm: fix regression causesd by ppiGang Wei
This patch try to fix the S3 regression https://lkml.org/lkml/2012/10/5/433, which includes below line: [ 1554.684638] sysfs: cannot create duplicate filename '/devices/pnp0/00:0c/ppi' The root cause is that ppi sysfs teardown code is MIA, so while S3 resume, the ppi kobject will be created again upon existing one. To make the tear down code simple, change the ppi subfolder creation from using kobject_create_and_add to just using a named ppi attribute_group. Then ppi sysfs teardown could be done with a simple sysfs_remove_group call. Adjusted the name & return type for ppi sysfs init function. Reported-by: Ben Guthro <ben@guthro.net> Signed-off-by: Gang Wei <gang.wei@intel.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-09-12tpm: fix tpm_acpi sparse warning on different address spacesKent Yoder
acpi_os_map_memory expects its return value to be in the __iomem address space. Tag the variable we're using as such and use memcpy_fromio to avoid further sparse warnings. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-09-04driver/char/tpm: declare internal symbols as staticXiaoyan Zhang
This patch declares the internal struct and functions as static to provide more security. Signed-off-by: Xiaoyan Zhang <xiaoyan.zhang@intel.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Reviewed-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-08-22driver: add PPI support in tpm driverXiaoyan Zhang
The Physical Presence Interface enables the OS and the BIOS to cooperate and provides a simple and straightforward platform user experience for administering the TPM without sacrificing security. V2: separate the patch out in a separate source file, add #ifdef CONFIG_ACPI so it compiles out on ppc, use standard error instead of ACPI error as return code of show/store fns. V3: move #ifdef CONFIG_ACPI from .c file to .h file. V4: move tpm_ppi code from tpm module to tpm_bios module. V5: modify sys_add_ppi() so that ppi_attr_grp doesn't need to be exported Signed-off-by: Xiaoyan Zhang <xiaoyan.zhang@intel.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22tpm: Do not dereference NULL pointer if acpi_os_map_memory() fails.Jesper Juhl
In drivers/char/tpm/tpm_acpi.c::read_log() we call acpi_os_map_memory(). That call may fail for a number of reasons (invalid address, out of memory etc). If the call fails it returns NULL and we just pass that to memcpy() unconditionally, which will go bad when it tries to dereference the pointer. Unfortunately we just get NULL back, so we can't really tell the user exactely what went wrong, but we can at least avoid crashing and return an error (-EIO seemed more generic and more suitable here than -ENOMEM or something else, so I picked that). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22drivers/char/tpm: Add securityfs support for event logAshley Lai
This patch retrieves the event log data from the device tree during file open. The event log data will then displayed through securityfs. Signed-off-by: Ashley Lai <adlai@us.ibm.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22drivers/char/tpm: Add new device driver to support IBM vTPMAshley Lai
This patch adds a new device driver to support IBM virtual TPM (vTPM) for PPC64. IBM vTPM is supported through the adjunct partition with firmware release 740 or higher. With vTPM support, each lpar is able to have its own vTPM without the physical TPM hardware. This driver provides TPM functionalities by communicating with the vTPM adjunct partition through Hypervisor calls (Hcalls) and Command/Response Queue (CRQ) commands. Signed-off-by: Ashley Lai <adlai@us.ibm.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22tpm: compile out unused code in the PNP and PM casesKent Yoder
The tpm_tis driver doesn't use tpm_tis_resume except when PM is configured and doesn't make use of tpm_tis_reenable_interrupts except when PM or PNP is configured. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22tpm: fix double write race and tpm_release free issueKent Yoder
Moved the atomic_set of the data_pending variable until after the tpm_read has completed processing. The existing code had a window of time where a second write to the driver could clobber the tpm command buffer. Also fixed an issue where if close was called on the tpm device before a read completed, the tpm command buffer would be returned to the OS, which could contain sensitive information. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22tpm: Move tpm_get_random api into the TPM device driverKent Yoder
Move the tpm_get_random api from the trusted keys code into the TPM device driver itself so that other callers can make use of it. Also, change the api slightly so that the number of bytes read is returned in the call, since the TPM command can potentially return fewer bytes than requested. Acked-by: David Safford <safford@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22tpm: modularize event log collectionKent Yoder
Break ACPI-specific pieces of the event log handling into their own file and create tpm_eventlog.[ch] to store common event log handling code. This will be required to integrate future event log sources on platforms without ACPI tables. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-22char/tpm: Add new driver for Infineon I2C TIS TPMPeter Huewe
This patch adds a driver to support Infineon's SLB 9635 TT 1.2 Soft I2C TPMs which follow the TGC TIS 1.2 TPM specification[1] and Infineon's I2C Protocol Stack Specification 0.20. The I2C Protocol Stack Specification is a simple adaption of the LPC TIS Protocol to the I2C Bus. The I2C TPMs can be used when LPC Bus is not available (i.e. non x86 architectures like ARM). The driver is based on the tpm_tis.c driver by Leendert van Dorn and Kyleen Hall and has quite similar functionality. Tested on Nvidia ARM Tegra2 Development Platform and Beagleboard (ARM OMAP) Tested with the Trousers[2] TSS API Testsuite v 0.3 [3] Compile-tested on x86 (32/64-bit) Updates since version 2.1.4: - included "Lock the I2C adapter for a sequence of requests", by Bryan Freed - use __i2c_transfer instead of own implementation of unlocked i2c_transfer - use struct dev_pm_ops for power management via SIMPLE_DEV_PM_OPS Updates since version 2.1.3: - use proper probing mechanism * either add the tpm using I2C_BOARD_INFO to your board file or probe it * during runtime e.g on BeagleBoard using : * "echo tpm_i2c_infineon 0x20 > /sys/bus/i2c/devices/i2c-2/new_device" - fix possible endless loop if hardware misbehaves - improved return codes - consistent spelling i2c/tpm -> I2C/TPM - remove hardcoded sleep values and msleep usage - removed debug statements - added check for I2C functionality - renaming to tpm_i2c_infineon Updates since version 2.1.2: - added sysfs entries for duration and timeouts - updated to new tpm_do_selftest Updates since version 2.1.0: - improved error handling - implemented workarounds needed by the tpm - fixed typos References: [1] http://www.trustedcomputinggroup.org/resources/pc_client_work_group_pc_client_ specific_tpm_interface_specification_tis_version_12/ [2] http://trousers.sourceforge.net/ [3] http://sourceforge.net/projects/trousers/files/TSS%20API%20test%20suite/0.3/ Reviewed-by: Andi Shyti <andi.shyti@gmail.com> Acked-by: Marcel Selhorst <tpmdd@selhorst.net> Signed-off-by: Peter Huewe <peter.huewe@infineon.com> Signed-off-by: Bryan Freed <bfreed@chromium.org> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-08-10tpm_tis / PM: Fix unused function warning for CONFIG_PM_SLEEPRafael J. Wysocki
According to a compiler warning, the tpm_tis_resume() function is not used for CONFIG_PM_SLEEP unset, so add a #ifdef to prevent it from being built in that case. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing groundbreaking for this kernel, just cleanups and fixes, and a couple of Smack enhancements." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) Smack: Maintainer Record Smack: don't show empty rules when /smack/load or /smack/load2 is read Smack: user access check bounds Smack: onlycap limits on CAP_MAC_ADMIN Smack: fix smack_new_inode bogosities ima: audit is compiled only when enabled ima: ima_initialized is set only if successful ima: add policy for pseudo fs ima: remove unused cleanup functions ima: free securityfs violations file ima: use full pathnames in measurement list security: Fix nommu build. samples: seccomp: add .gitignore for untracked executables tpm: check the chip reference before using it TPM: fix memleak when register hardware fails TPM: chip disabled state erronously being reported as error MAINTAINERS: TPM maintainers' contacts update Merge branches 'next-queue' and 'next' into next Remove unused code from MPI library Revert "crypto: GnuPG based MPI lib - additional sources (part 4)" ...
2012-07-10tpm_nsc: Use struct dev_pm_ops for power managementRafael J. Wysocki
Make the tpm_nsc driver define its PM callbacks through a struct dev_pm_ops object rather than by using legacy PM hooks in struct platform_driver. This allows the driver to use tpm_pm_suspend() and tpm_pm_resume() as its PM callbacks directly, without defining its own PM callback routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-10tpm_tis: Use struct dev_pm_ops for power managementRafael J. Wysocki
Make the tpm_tis driver define its PM callbacks through a struct dev_pm_ops object rather than by using legacy PM hooks in struct platform_driver. This allows the driver to use tpm_pm_suspend() as its suspend callback directly, without defining its own suspend callback routine. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-10tpm_atmel: Use struct dev_pm_ops for power managementRafael J. Wysocki
Make the tpm_atmel driver define its PM callbacks through a struct dev_pm_ops object rather than by using legacy PM hooks in struct platform_driver. This allows the driver to use tpm_pm_suspend() and tpm_pm_resume() as its PM callbacks directly, without defining its own PM callback routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-10PM / TPM: Drop unused pm_message_t argument from tpm_pm_suspend()Rafael J. Wysocki
The tpm_pm_suspend()'s second argument of type pm_message_t is not used, so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-06-12tpm: check the chip reference before using itAndi Shyti
If a driver calls tpm_dev_vendor_release for a device already released then the driver will oops. Signed-off-by: Andi Shyti <andi.shyti@gmail.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-06-12TPM: fix memleak when register hardware failsWanlong Gao
Adding proper kfree() before returning. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-06-12TPM: chip disabled state erronously being reported as errorRajiv Andrade
tpm_do_selftest() attempts to read a PCR in order to decide if one can rely on the TPM being used or not. The function that's used by __tpm_pcr_read() does not expect the TPM to be disabled or deactivated, and if so, reports an error. It's fine if the TPM returns this error when trying to use it for the first time after a power cycle, but it's definitely not if it already returned success for a previous attempt to read one of its PCRs. The tpm_do_selftest() was modified so that the driver only reports this return code as an error when it really is. Reported-and-tested-by: Paul Bolle <pebolle@tiscali.nl> Cc: Stable <stable@vger.kernel.org> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-06-12MAINTAINERS: TPM maintainers' contacts updateRajiv Andrade
Usual contact update, Debora Velarde role resign, and the new co-maintainer inclusion, Kent Yoder. He's accepted to contribute more actively to this driver's maintainership given the current maintainer's slight career change that will affect his contribution time. [Replacing Debora Velarde by Kent Yoder] Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-03-05tpm_tis: fix tis_lock with respect to RCUJiri Kosina
cleanup_tis() -> tpm_remove_hardware() -> syncrhonize_rcu() is being called in an atomic context (tis_lock spinlock held), which is not allowed. Convert tis_lock to mutex. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-02-14TPM: Zero buffer whole after copying to userspaceTim Gardner
Commit 3321c07ae5068568cd61ac9f4ba749006a7185c9 correctly clears the TPM buffer if the user specified read length is >= the TPM buffer length. However, if the user specified read length is < the TPM buffer length, then part of the TPM buffer is left uncleared. Reported-by: Seth Forshee <seth.forshee@canonical.com> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <m.selhorst@sirrix.com> Cc: tpmdd-devel@lists.sourceforge.net Cc: stable@vger.kernel.org Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-02-14tpm_tis: Clean up after module_param cleanupStefan Berger
Commit 90ab5ee94171b3e28de6bb42ee30b527014e0be7 changed the itpm module parameter from int to bool. Some other changes need to be done to clean up after this change. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-02-14tpm_tis: Only probe iTPMsStefan Berger
Detect iTPMs through the vendor ID on the hardware interface and only probe the device if the manufacturer is found to be Intel. This obsoletes a previously added delay necessary for some TPMs but not iTPMs. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2012-02-09Merge branch 'next-queue' into nextJames Morris
2012-01-19ima: fix Kconfig dependenciesFabio Estevam
Fix the following build warning: warning: (IMA) selects TCG_TPM which has unmet direct dependencies (HAS_IOMEM && EXPERIMENTAL) Suggested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-01-18tpm: fix (ACPI S3) suspend regressionStefan Berger
This patch fixes an (ACPI S3) suspend regression introduced in commit 68d6e6713fcb ("tpm: Introduce function to poll for result of self test") and occurring with an Infineon TPM and tpm_tis and tpm_infineon drivers active. The suspend problem occurred if the TPM was disabled and/or deactivated and therefore the TPM_PCRRead checking the result of the (asynchronous) self test returned an error code which then caused the tpm_tis driver to become inactive and this then seemed to have negatively influenced the suspend support by the tpm_infineon driver... Besides that the tpm_tis drive may stay active even if the TPM is disabled and/or deactivated. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-17Merge branch 'for-james' of git://github.com/srajiv/tpm into nextJames Morris
2011-11-16TPM: fix transmit_cmd error logicRajiv Andrade
It's incorrect to assume that buffers returned by the TPM 10 bytes long are always error reports. This patches parses the error field in its header instead. The error report is now being printed using dev_err() instead of dev_dbg(), making it easier for users to provide more detailed bug reports. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-11-16TPM: NSC and TIS drivers X86 dependency fixRajiv Andrade
A previous commit removed its PNP dependency, that in fact wasn't necessary, but also allowed it be built for other architectures not supported by it. This then caused kernel oops on PPC based machines. I'm placing a x86 dependency back correctly. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-11-16TPM: Export wait_for_stat for other vendor specific driversRajiv Andrade
Moved wait_for_stat to tpm.c so that other drivers can use it. Also renamed it to avoid future namespace conflicts. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-11-16TPM: Use vendor specific function for status probeRajiv Andrade
Moved from using tpm_tis_status() to the vendor specific one in wait_for_stat(). This way other TPM drivers can use it instead of reimplementing another. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-11-16tpm_tis: add delay after aborting commandStefan Berger
This patch adds a delay after aborting a command. Some TPMs need this and will not process the subsequent command correctly otherwise. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com>
2011-11-16tpm_tis: Check return code from getting timeouts/durationsStefan Berger
Check the return code from getting the TPM's timeouts and durations and reject the driver if they could not be read. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com>
