path: root/drivers/char/tpm
2011-09-23TPM: Zero buffer after copying to userspacePeter Huewe
Since the buffer might contain security related data it might be a good idea to zero the buffer after we have copied it to userspace. This got assigned CVE-2011-1162. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-23TPM: Call tpm_transmit with correct sizePeter Huewe
This patch changes the call of tpm_transmit by supplying the size of the userspace buffer instead of TPM_BUFSIZE. This got assigned CVE-2011-1161. [The first hunk didn't make sense given one could expect way less data than TPM_BUFSIZE, so added tpm_transmit boundary check over bufsiz instead The last parameter of tpm_transmit() reflects the amount of data expected from the device, and not the buffer size being supplied to it. It isn't ideal to parse it directly, so we just set it to the maximum the input buffer can handle and let the userspace API to do such job.] Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-23TPM: tpm_nsc: Fix a double free of pdev in cleanup_nscAxel Lin
platform_device_unregister() will release all resources and remove it from the subsystem, then drop reference count by calling platform_device_put(). We should not call kfree(pdev) after platform_device_unregister(pdev). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-23TPM: TCG_ATMEL should depend on HAS_IOPORTGeert Uytterhoeven
On m68k, I get: drivers/char/tpm/tpm_atmel.h: In function ‘atmel_get_base_addr’: drivers/char/tpm/tpm_atmel.h:129: error: implicit declaration of function ‘ioport_map’ drivers/char/tpm/tpm_atmel.h:129: warning: return makes pointer from integer without a cast The code in tpm_atmel.h supports PPC64 (using the device tree and ioremap()) and "anything else" (using ioport_map()). However, ioportmap() is only available on platforms that set HAS_IOPORT. Although PC64 seems to have HAS_IOPORT, a "depends on HAS_IOPORT" should work, but I think it's better to expose the special PPC64 handling explicit using "depends on PPC64 || HAS_IOPORT". Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-08-03tpm_tis: fix build when ACPI is not enabledRandy Dunlap
Fix tpm_tis.c build when CONFIG_ACPI is not enabled by providing a stub function. Fixes many build errors/warnings: drivers/char/tpm/tpm_tis.c:89: error: dereferencing pointer to incomplete type drivers/char/tpm/tpm_tis.c:89: warning: type defaults to 'int' in declaration of 'type name' drivers/char/tpm/tpm_tis.c:89: error: request for member 'list' in something not a structure or union ... Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Leendert van Doorn <leendert@watson.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26tpm_nsc: Fix bug when loading multiple TPM driversStefan Berger
This patch fixes kernel bugzilla 34572. https://bugzilla.kernel.org/show_bug.cgi?id=34572 Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Tested-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: James Morris <jmorris@namei.org>
2011-07-22tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP blockStefan Berger
This patch moves the tpm_tis_reenable_interrupts function out of the CONFIG_PNP-surrounded #define block. This solves a compilation error in case CONFIG_PNP is not defined. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-07-21tpm: Fix compilation warning when CONFIG_PNP is not definedStefan Berger
The is_itpm() function is only accessed from a block surrounded by #ifdef CONFIG_PNP. Therefore, also surround it with #ifdef CONFIG_PNP and remove the #else branch causing the warning. http://lxr.linux.no/#linux+v2.6.39/drivers/char/tpm/tpm_tis.c#L622 v2: - fixes a previous typo Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-07-12tpm: Fix a typoStefan Berger
This patch fixes a typo. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Probing function for Intel iTPM bugStefan Berger
This patch introduces a function for automatic probing for the Intel iTPM STS_DATA_EXPECT flaw. The patch splits the current tpm_tis_send function into 2 parts where the 1st part is now called tpm_tis_send_data() and merely sends the data to the TPM. This function is then used for probing. The new tpm_tis_send function now first calls tpm_tis_send_data and if that succeeds has the TPM process the command and waits until the response is there. The probing for the Intel iTPM is only invoked if the user has not passed itpm=1 as parameter for the module *or* if such a TPM was detected via ACPI. Previously it was necessary to pass itpm=1 when also passing force=1 to the module when doing a 'modprobe'. This function is more general than the ACPI test function and the function relying on ACPI could probably be removed. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Fix the probing for interruptsStefan Berger
This patch fixes several aspects of the probing for interrupts. This patch reads the TPM's timeouts before probing for the interrupts. The tpm_get_timeouts() function is invoked in polling mode and gets the proper timeouts from the TPM so that we don't need to fall back to 2 minutes timeouts for short duration commands while the interrupt probing is happening. This patch introduces a variable probed_irq into the vendor structure that gets the irq number if an interrupt is received while the the tpm_gen_interrupt() function is run in polling mode during interrupt probing. Previously some parts of tpm_gen_interrupt() were run in polling mode, then the irq variable was set in the interrupt handler when an interrupt was received and execution of tpm_gen_interrupt() ended up switching over to interrupt mode. tpm_gen_interrupt() execution ended up on an event queue where it eventually timed out since the probing handler doesn't wake any queues. Before calling into free_irq() clear all interrupt flags that may have been set by the TPM. The reason is that free_irq() will call into the probing interrupt handler and may otherwise fool us into thinking that a real interrupt happened (because we see the flags as being set) while the TPM's interrupt line is not even connected to anything on the motherboard. This solves a problem on one machine I did testing on (Thinkpad T60). If a TPM claims to use a specifc interrupt, the probing is done as well to verify that the interrupt is actually working. If a TPM indicates that it does not use a specific interrupt (returns '0'), probe all interrupts from 3 to 15. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Delay ACPI S3 suspend while the TPM is busyStefan Berger
This patch delays the (ACPI S3) suspend while the TPM is busy processing a command and the TPM TIS driver is run in interrupt mode. This is the same behavior as we already have it for the TPM TIS driver in polling mode. Reasoning: Some of the TPM's commands advance the internal state of the TPM. An example would be the extending of one of its PCR registers. Upper layers, such as IMA or TSS (TrouSerS), would certainly want to be sure that the command succeeded rather than getting an error code (-62 = -ETIME) that may not give a conclusive answer as for what reason the command failed. Reissuing such a command would put the TPM into the wrong state, so waiting for it to finish is really the only option. The downside is that some commands (key creation) can take a long time and actually prevent the machine from entering S3 at all before the 20 second timeout of the power management subsystem arrives. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Re-enable interrupts upon (S3) resumeStefan Berger
This patch makes sure that if the TPM TIS interface is run in interrupt mode (rather than polling mode) that all interrupts are enabled in the TPM's interrupt enable register after a resume from ACPI S3 suspend. The registers may either have been cleared by the TPM loosing its state during device sleep or by the BIOS leaving the TPM in polling mode (after sending a command to the TPM for starting it up again) You may want to check if your TPM runs with interrupts by doing cat /proc/interrupts | grep -i tpm and see whether there is an entry or otherwise for it to use interrupts: modprobe tpm_tis interrupts=1 [add 'itpm=1' for Intel TPM ] v2: - the patch was adapted to work with the pnp and platform driver implementations in tpm_tis.c Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Fix display of data in pubek sysfs entryStefan Berger
This patch fixes the TPM's pubek sysfs entry that is accessible as long as the TPM doesn't have an owner. It was necessary to shift the access to the data by -10 -- the first byte immediately follows the 10 byte header. The line data = tpm_cmd.params.readpubek_out_buffer; sets it at the offset '10' in the packet, so we can read the data array starting at offset '0'. Before: Algorithm: 00 0C 00 00 Encscheme: 08 00 Sigscheme: 00 00 Parameters: 00 00 00 00 01 00 AC E2 5E 3C A0 78 Modulus length: -563306801 Modulus: 28 21 08 0F 82 CD F2 B1 E7 49 F7 74 70 BE 59 8C 43 78 B1 24 EA 52 E2 FE 52 5C 3A 12 3B DC 61 71 [...] After: Algorithm: 00 00 00 01 Encscheme: 00 03 Sigscheme: 00 01 Parameters: 00 00 08 00 00 00 00 02 00 00 00 00 Modulus length: 256 Modulus: AC E2 5E 3C A0 78 DE 6C 9E CF 28 21 08 0F 82 CD F2 B1 E7 49 F7 74 70 BE 59 8C 43 78 B1 24 EA 52 [...] Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Add timeouts sysfs entryStefan Berger
Display the TPM's interface timeouts in a 'timeouts' sysfs entry. Display the entries as having been adjusted when they were scaled due to their values being reported in milliseconds rather than microseconds. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Adjust interface timeouts if they are too smallStefan Berger
Adjust the interface timeouts if they are found to be too small, i.e., if they are returned in milliseconds rather than microseconds as we heared from Infineon that some (old) Infineon TPMs do. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Use interface timeouts returned from the TPMStefan Berger
The TPM driver currently discards the interface timeout values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 4 interface timeout indicators of type u32. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Introduce durations sysfs entryStefan Berger
Display the TPM's command timeouts in a 'durations' sysfs entry. Display the entries as having been adjusted when they were scaled due to their values being reported in milliseconds rather than microseconds. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Adjust the durations if they are too smallStefan Berger
Adjust the durations if they are found to be too small, i.e., if they are returned in milliseconds rather than microseconds as some Infineon TPMs are reported to do. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Use durations returned from TPMStefan Berger
The TPM driver currently discards the durations values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 3 timeout indicators of type u32. v4: - sysfs entry 'durations' is now a patch of its own - the work-around for TPMs reporting durations in milliseconds is now in a patch of its own v3: - sysfs entry now called 'durations' to resemble TPM-speak (previously was called 'timeouts') v2: - adjusting all timeouts for TPM devices reporting timeouts in msec rather than usec - also displaying in sysfs whether the timeouts are 'original' or 'adjusted' Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-03-29char/tpm: Fix unitialized usage of data bufferPeter Huewe
This patch fixes information leakage to the userspace by initializing the data buffer to zero. Reported-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> [ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way deeper problems than a simple multiplication can fix. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01Revert "TPM: Long default timeout fix"Linus Torvalds
This reverts commit c4ff4b829ef9e6353c0b133b7adb564a68054979. Ted Ts'o reports: "TPM is working for me so I can log into employer's network in 2.6.37. It broke when I tried 2.6.38-rc6, with the following relevant lines from my dmesg: [ 11.081627] tpm_tis 00:0b: 1.2 TPM (device-id 0x0, rev-id 78) [ 25.734114] tpm_tis 00:0b: Operation Timed out [ 78.040949] tpm_tis 00:0b: Operation Timed out This caused me to get suspicious, especially since the _other_ TPM commit in 2.6.38 had already been reverted, so I tried reverting commit c4ff4b829e: "TPM: Long default timeout fix". With this commit reverted, my TPM on my Lenovo T410 is once again working." Requested-and-tested-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-20Revert "tpm_tis: Use timeouts returned from TPM"Linus Torvalds
This reverts commit 9b29050f8f75916f974a2d231ae5d3cd59792296. It has caused hibernate regressions, for example Juri Sladby's report: "I'm unable to hibernate 2.6.37.1 unless I rmmod tpm_tis: [10974.074587] Suspending console(s) (use no_console_suspend to debug) [10974.103073] tpm_tis 00:0c: Operation Timed out [10974.103089] legacy_suspend(): pnp_bus_suspend+0x0/0xa0 returns -62 [10974.103095] PM: Device 00:0c failed to freeze: error -62" and Rafael points out that some of the new conditionals in that commit seem to make no sense. This commit needs more work and testing, let's revert it for now. Reported-by: Norbert Preining <preining@logic.at> Reported-and-requested-by: Jiri Slaby <jirislaby@gmail.com> Cc: Stefan Berger <stefanb@linux.vnet.ibm.com> Cc: Guillaume Chazarain <guichaz@gmail.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-11tpm_tis: Use timeouts returned from TPMStefan Berger
The current TPM TIS driver in git discards the timeout values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 3 timeout indicators of type u32. I am also adding a sysfs entry 'timeouts' showing the timeouts that are being used. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-01-24tpm: fix panic caused by "tpm: Autodetect itpm devices"Olof Johansson
commit 3f0d3d016d89a5efb8b926d4707eb21fa13f3d27 adds a check for PNP device id to the common tpm_tis_init() function, which in some cases (force=1) will be called without the device being a member of a pnp_dev. Oopsing and panics ensue. Move the test up to before the call to tpm_tis_init(), since it just modifies a global variable anyway. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24TPM: Long default timeout fixRajiv Andrade
If duration variable value is 0 at this point, it's because chip->vendor.duration wasn't filled by tpm_get_timeouts() yet. This patch sets then the lowest timeout just to give enough time for tpm_get_timeouts() to further succeed. This fix avoids long boot times in case another entity attempts to send commands to the TPM when the TPM isn't accessible. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2010-12-24tpm: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush chip->work instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2010-11-30tpm: Autodetect itpm devicesMatthew Garrett
Some Lenovos have TPMs that require a quirk to function correctly. This can be autodetected by checking whether the device has a _HID of INTC0102. This is an invalid PNPid, and as such is discarded by the pnp layer - however it's still present in the ACPI code, so we can pull it out that way. This means that the quirk won't be automatically applied on non-ACPI systems, but without ACPI we don't have any way to identify the chip anyway so I don't think that's a great concern. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Tested-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29key: add tpm_send commandMimi Zohar
Add internal kernel tpm_send() command used to seal/unseal keys. Changelog: - replaced module_put in tpm_send() with new tpm_chip_put() wrapper (suggested by David Howells) - Make tpm_send() cmd argument a 'void *' (suggested by David Howells) Signed-off-by: David Safford <safford@watson.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29tpm: add module_put wrapperMimi Zohar
For readability, define a tpm_chip_put() wrapper to call module_put(). Replace existing module_put() calls with the wrapper. (Change based on trusted/encrypted patchset review by David Howells.) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-21tpm: change 'tpm_suspend_pcr' to be module parameterDmitry Torokhov
Fix the following warning: drivers/char/tpm/tpm.c:1085: warning: `tpm_suspend_setup' defined but not used and make the workaround operable in case when TPM is compiled as a module. As a side-effect the option will be called tpm.suspend_pcr. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: David Safford <safford@watson.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-26tpm_tis: fix subsequent suspend failuresRajiv Andrade
Fix subsequent suspends by issuing tpm_continue_selftest during resume. Otherwise, the tpm chip seems to be not fully initialized and will reject the save state command during suspend, thus preventing the whole system to suspend. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16256 Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: David Safford <safford@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-06-15TPM: ReadPubEK output struct fixRajiv Andrade
This patch adds a missing element of the ReadPubEK command output, that prevents future overflow of this buffer when copying the TPM output result into it. Prevents a kernel panic in case the user tries to read the pubek from sysfs. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-17TPM: ACPI/PNP dependency removalRajiv Andrade
This patch pushes the ACPI dependency into the device driver code itself. Now, even without ACPI/PNP enabled, the device can be registered using the TIS specified memory space. This will however result in the lack of access to the BIOS event log, being the only implication of such ACPI removal. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-07Revert "TPM: ACPI/PNP dependency removal"James Morris
This reverts commit b89e66e1e396f7b5436af154e58209320cc08aed. > > When CONFIG_PM is not set: > > > > drivers/built-in.o: In function `acpi_init': > > bus.c:(.init.text+0x2d84): undefined reference to `pm_flags' > > bus.c:(.init.text+0x2d91): undefined reference to `pm_flags' > > CONFIG_ACPI depends on CONFIG_PM, > so acpi/bus.c should not be compiled for CONFIG_PM=n > > Hmm, is is somebody doing something strange, like "select ACPI" > without guaranteeing that all of ACPI's dependencies are satisfied? Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06Merge branch 'master' into nextJames Morris
2010-05-05TPM: ACPI/PNP dependency removalRajiv Andrade
This patch pushes the ACPI dependency into the device driver code itself. Now, even without ACPI/PNP enabled, the device can be registered using the TIS specified memory space. This will however result in the lack of access to the bios event log, being the only implication of such ACPI removal. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26TPM: workaround to enforce PCR updates across suspendsRajiv Andrade
Add a workaround for TPM's which fail to flush last written PCR values in a TPM_SaveState, in preparation for suspend. Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-11tpm_infineon: fix suspend/resume handler for pnp_driverMarcel Selhorst
When suspending, tpm_infineon calls the generic suspend function of the TPM framework. However, the TPM framework does not return and the system hangs upon suspend. When sending the necessary command "TPM_SaveState" directly within the driver, suspending and resuming works fine. Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: <stable@kernel.org> [2.6.32.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-03tpm: autoload tpm_tis based on system PnP IDsMatt Domsch
The tpm_tis driver already has a list of supported pnp_device_ids. This patch simply exports that list as a MODULE_DEVICE_TABLE() so that the module autoloader will discover and load the module at boottime. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-02tpm_tis: TPM_STS_DATA_EXPECT workaroundRajiv Andrade
Some newer Lenovo models are shipped with a TPM that doesn't seem to set the TPM_STS_DATA_EXPECT status bit when sending it a burst of data, so the code understands it as a failure and doesn't proceed sending the chip the intended data. In this patch we bypass this bit check in case the itpm module parameter was set. This patch is based on Andy Isaacson's one: http://marc.info/?l=linux-kernel&m=124650185023495&w=2 It was heavily discussed how should we deal with identifying the chip in kernel space, but the required patch to do so was NACK'd: http://marc.info/?l=linux-kernel&m=124650186423711&w=2 This way we let the user choose using this workaround or not based on his observations on this code behavior when trying to use the TPM. Fixed a checkpatch issue present on the previous patch, thanks to Daniel Walker. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Eric Paris <eparis@redhat.com> Tested-by: Seiji Munetoh <seiji.munetoh@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-01TPM: fix pcrreadRajiv Andrade
The previously sent patch: http://marc.info/?l=tpmdd-devel&m=125208945007834&w=2 Had its first hunk cropped when merged, submitting only this first hunk again. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Marcel Selhorst <m.selhorst@sirrix.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Tested-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-30Merge branch 'master' into nextJames Morris
2009-09-24TPM: increase default TPM bufferRajiv Andrade
The TPM Working Group requested this communication buffer increase given that a particular TPM vendor can support a TPM_SHA1Start command input bigger than the current size. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: do not destroy the avc_cache_nodep KEYS: Have the garbage collector set its timer for live expired keys tpm-fixup-pcrs-sysfs-file-update creds_are_invalid() needs to be exported for use by modules: include/linux/cred.h: fix build Fix trivial BUILD_BUG_ON-induced conflicts in drivers/char/tpm/tpm.c
