path: root/drivers/char/tpm/tpm.c
2011-09-23TPM: Zero buffer after copying to userspacePeter Huewe
Since the buffer might contain security related data it might be a good idea to zero the buffer after we have copied it to userspace. This got assigned CVE-2011-1162. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-23TPM: Call tpm_transmit with correct sizePeter Huewe
This patch changes the call of tpm_transmit by supplying the size of the userspace buffer instead of TPM_BUFSIZE. This got assigned CVE-2011-1161. [The first hunk didn't make sense given one could expect way less data than TPM_BUFSIZE, so added tpm_transmit boundary check over bufsiz instead The last parameter of tpm_transmit() reflects the amount of data expected from the device, and not the buffer size being supplied to it. It isn't ideal to parse it directly, so we just set it to the maximum the input buffer can handle and let the userspace API to do such job.] Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-07-12tpm: Fix a typoStefan Berger
This patch fixes a typo. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Fix display of data in pubek sysfs entryStefan Berger
This patch fixes the TPM's pubek sysfs entry that is accessible as long as the TPM doesn't have an owner. It was necessary to shift the access to the data by -10 -- the first byte immediately follows the 10 byte header. The line data = tpm_cmd.params.readpubek_out_buffer; sets it at the offset '10' in the packet, so we can read the data array starting at offset '0'. Before: Algorithm: 00 0C 00 00 Encscheme: 08 00 Sigscheme: 00 00 Parameters: 00 00 00 00 01 00 AC E2 5E 3C A0 78 Modulus length: -563306801 Modulus: 28 21 08 0F 82 CD F2 B1 E7 49 F7 74 70 BE 59 8C 43 78 B1 24 EA 52 E2 FE 52 5C 3A 12 3B DC 61 71 [...] After: Algorithm: 00 00 00 01 Encscheme: 00 03 Sigscheme: 00 01 Parameters: 00 00 08 00 00 00 00 02 00 00 00 00 Modulus length: 256 Modulus: AC E2 5E 3C A0 78 DE 6C 9E CF 28 21 08 0F 82 CD F2 B1 E7 49 F7 74 70 BE 59 8C 43 78 B1 24 EA 52 [...] Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Add timeouts sysfs entryStefan Berger
Display the TPM's interface timeouts in a 'timeouts' sysfs entry. Display the entries as having been adjusted when they were scaled due to their values being reported in milliseconds rather than microseconds. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Adjust interface timeouts if they are too smallStefan Berger
Adjust the interface timeouts if they are found to be too small, i.e., if they are returned in milliseconds rather than microseconds as we heared from Infineon that some (old) Infineon TPMs do. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Use interface timeouts returned from the TPMStefan Berger
The TPM driver currently discards the interface timeout values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 4 interface timeout indicators of type u32. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm_tis: Introduce durations sysfs entryStefan Berger
Display the TPM's command timeouts in a 'durations' sysfs entry. Display the entries as having been adjusted when they were scaled due to their values being reported in milliseconds rather than microseconds. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Adjust the durations if they are too smallStefan Berger
Adjust the durations if they are found to be too small, i.e., if they are returned in milliseconds rather than microseconds as some Infineon TPMs are reported to do. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-07-12tpm: Use durations returned from TPMStefan Berger
The TPM driver currently discards the durations values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 3 timeout indicators of type u32. v4: - sysfs entry 'durations' is now a patch of its own - the work-around for TPMs reporting durations in milliseconds is now in a patch of its own v3: - sysfs entry now called 'durations' to resemble TPM-speak (previously was called 'timeouts') v2: - adjusting all timeouts for TPM devices reporting timeouts in msec rather than usec - also displaying in sysfs whether the timeouts are 'original' or 'adjusted' Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-03-29char/tpm: Fix unitialized usage of data bufferPeter Huewe
This patch fixes information leakage to the userspace by initializing the data buffer to zero. Reported-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> [ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way deeper problems than a simple multiplication can fix. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-01Revert "TPM: Long default timeout fix"Linus Torvalds
This reverts commit c4ff4b829ef9e6353c0b133b7adb564a68054979. Ted Ts'o reports: "TPM is working for me so I can log into employer's network in 2.6.37. It broke when I tried 2.6.38-rc6, with the following relevant lines from my dmesg: [ 11.081627] tpm_tis 00:0b: 1.2 TPM (device-id 0x0, rev-id 78) [ 25.734114] tpm_tis 00:0b: Operation Timed out [ 78.040949] tpm_tis 00:0b: Operation Timed out This caused me to get suspicious, especially since the _other_ TPM commit in 2.6.38 had already been reverted, so I tried reverting commit c4ff4b829e: "TPM: Long default timeout fix". With this commit reverted, my TPM on my Lenovo T410 is once again working." Requested-and-tested-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-20Revert "tpm_tis: Use timeouts returned from TPM"Linus Torvalds
This reverts commit 9b29050f8f75916f974a2d231ae5d3cd59792296. It has caused hibernate regressions, for example Juri Sladby's report: "I'm unable to hibernate 2.6.37.1 unless I rmmod tpm_tis: [10974.074587] Suspending console(s) (use no_console_suspend to debug) [10974.103073] tpm_tis 00:0c: Operation Timed out [10974.103089] legacy_suspend(): pnp_bus_suspend+0x0/0xa0 returns -62 [10974.103095] PM: Device 00:0c failed to freeze: error -62" and Rafael points out that some of the new conditionals in that commit seem to make no sense. This commit needs more work and testing, let's revert it for now. Reported-by: Norbert Preining <preining@logic.at> Reported-and-requested-by: Jiri Slaby <jirislaby@gmail.com> Cc: Stefan Berger <stefanb@linux.vnet.ibm.com> Cc: Guillaume Chazarain <guichaz@gmail.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-11tpm_tis: Use timeouts returned from TPMStefan Berger
The current TPM TIS driver in git discards the timeout values returned from the TPM. The check of the response packet needs to consider that the return_code field is 0 on success and the size of the expected packet is equivalent to the header size + u32 length indicator for the TPM_GetCapability() result + 3 timeout indicators of type u32. I am also adding a sysfs entry 'timeouts' showing the timeouts that are being used. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2011-01-24TPM: Long default timeout fixRajiv Andrade
If duration variable value is 0 at this point, it's because chip->vendor.duration wasn't filled by tpm_get_timeouts() yet. This patch sets then the lowest timeout just to give enough time for tpm_get_timeouts() to further succeed. This fix avoids long boot times in case another entity attempts to send commands to the TPM when the TPM isn't accessible. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-24tpm: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush chip->work instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
2010-11-29key: add tpm_send commandMimi Zohar
Add internal kernel tpm_send() command used to seal/unseal keys. Changelog: - replaced module_put in tpm_send() with new tpm_chip_put() wrapper (suggested by David Howells) - Make tpm_send() cmd argument a 'void *' (suggested by David Howells) Signed-off-by: David Safford <safford@watson.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29tpm: add module_put wrapperMimi Zohar
For readability, define a tpm_chip_put() wrapper to call module_put(). Replace existing module_put() calls with the wrapper. (Change based on trusted/encrypted patchset review by David Howells.) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-21tpm: change 'tpm_suspend_pcr' to be module parameterDmitry Torokhov
Fix the following warning: drivers/char/tpm/tpm.c:1085: warning: `tpm_suspend_setup' defined but not used and make the workaround operable in case when TPM is compiled as a module. As a side-effect the option will be called tpm.suspend_pcr. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: David Safford <safford@watson.ibm.com> Cc: James Morris <jmorris@namei.org> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06Merge branch 'master' into nextJames Morris
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26TPM: workaround to enforce PCR updates across suspendsRajiv Andrade
Add a workaround for TPM's which fail to flush last written PCR values in a TPM_SaveState, in preparation for suspend. Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-01TPM: fix pcrreadRajiv Andrade
The previously sent patch: http://marc.info/?l=tpmdd-devel&m=125208945007834&w=2 Had its first hunk cropped when merged, submitting only this first hunk again. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Marcel Selhorst <m.selhorst@sirrix.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Tested-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-30Merge branch 'master' into nextJames Morris
2009-09-24TPM: increase default TPM bufferRajiv Andrade
The TPM Working Group requested this communication buffer increase given that a particular TPM vendor can support a TPM_SHA1Start command input bigger than the current size. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: do not destroy the avc_cache_nodep KEYS: Have the garbage collector set its timer for live expired keys tpm-fixup-pcrs-sysfs-file-update creds_are_invalid() needs to be exported for use by modules: include/linux/cred.h: fix build Fix trivial BUILD_BUG_ON-induced conflicts in drivers/char/tpm/tpm.c
2009-09-23tpm-fixup-pcrs-sysfs-file-updateJason Gunthorpe
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <m.selhorst@sirrix.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-23BUILD_BUG_ON(): fix it and a couple of bogus uses of itJan Beulich
gcc permitting variable length arrays makes the current construct used for BUILD_BUG_ON() useless, as that doesn't produce any diagnostic if the controlling expression isn't really constant. Instead, this patch makes it so that a bit field gets used here. Consequently, those uses where the condition isn't really constant now also need fixing. Note that in the gfp.h, kmemcheck.h, and virtio_config.h cases MAYBE_BUILD_BUG_ON() really just serves documentation purposes - even if the expression is compile time constant (__builtin_constant_p() yields true), the array is still deemed of variable length by gcc, and hence the whole expression doesn't have the intended effect. [akpm@linux-foundation.org: make arch/sparc/include/asm/vio.h compile] [akpm@linux-foundation.org: more nonsensical assertions in tpm.c..] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-06TPM: integrity fixRajiv Andrade
Fix to function which is called by IMA, now tpm_chip_find_get() considers the case in which the machine doesn't have a TPM or, if it has, its TPM isn't enabled. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-03TPM: integrity interfaceRajiv Andrade
This patch adds internal kernel support for: - reading/extending a pcr value - looking up the tpm_chip for a given chip number Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-03TPM: sysfs functions consolidationRajiv Andrade
According to Dave Hansen's comments on the tpm_show_*, some of these functions present a pattern when allocating data[] memory space and also when setting its content. A new function was created so that this pattern could be consolidated. Also, replaced the data[] command vectors and its indexes by meaningful structures as pointed out by Matt Helsley too. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20tpm: don't export static functionsStephen Rothwell
Today's linux-next build (powerpc_allyesconfig) failed like this: drivers/char/tpm/tpm.c:1162: error: __ksymtab_tpm_dev_release causes a section type conflict Caused by commit 253115b71fa06330bd58afbe01ccaf763a8a0cf1 ("The tpm_dev_release function is only called for platform devices, not pnp") which exported a static function. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16drivers/char/tpm/tpm.c: fix error-path memory leakAndrew Morton
tpm_register_hardware() leaks devname on an error path. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11425 Reported-by: Daniel Marjamki <danielm77@spray.se> Cc: Debora Velarde <debora@linux.vnet.ibm.com> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: work around bug in Broadcom BCM0102 chipsetValdis Kletnieks
Patch tpm-correct-tpm-timeouts-to-jiffies-conversion reveals a bug in the Broadcom BCM0102 TPM chipset used in the Dell Latitude D820 - although most of the timeouts are returned in usecs as per the spec, one is apparently returned in msecs, which results in a too-small value leading to a timeout when the code treats it as usecs. To prevent a regression, we check for the known too-short value and adjust it to a value that makes things work. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16tpm: correct tpm timeouts to jiffies conversionMarcin Obara
This patch fixes timeouts conversion to jiffies, by replacing msecs_to_jiffies() calls with usecs_to_jiffies(). According to TCG TPM Specification Version 1.2 Revision 103 (pages 166, 167) TPM timeouts and durations are returned in microseconds (usec) not in miliseconds (msec). This fixes a long hang while loading TPM driver, if TPM chip starts in "Idle" state instead of "Ready" state. Without this patch - 'modprobe' may hang for 30 seconds or more. Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-11As pointed out by Jonathan Corbet, the timer must be deleted beforeRajiv Andrade
flushing the work queue in order to avoid a job being submitted after the chip had been released. Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11The tpm_dev_release function is only called for platform devices, not pnpRajiv Andrade
devices, so we implemented the .remove function for pnp ones. Since it's code is very similar to the one inside tpm_dev_release, we've created a helper function tpm_dev_vendor_release, which is called by both. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Protect tpm_chip_list when transversing it.Rajiv Andrade
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Renames num_open to is_open, as only one process can open the file at a time.Rajiv Andrade
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-11Remove the BKL calls from the TPM driver, which were added in the overallRajiv Andrade
misc-char-dev-BKL-pushdown.patch, as they are not needed. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-26tpm: Use correct data types for sizes in tpm_write() and tpm_read()Michael Halcrow
Use the correct data types for the size parameters in tpm_write() and tpm_read(). Note that rw_verify_area() makes sure that this bug cannot be exploited to produce a buffer overrun. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26tpm: increase size of internal TPM response buffersMarcin Obara
This patch increases size of driver internal response buffers. Some TPM responses defined in TCG TPM Specification Version 1.2 Revision 103 have increased size and do not fit previously defined buffers. Some TPM responses do not have fixed size, so bigger response buffers have to be allocated. 200B buffers should be enough. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Marcin Obara <marcin_obara@users.sourceforge.net> Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02tpm-tpm: BKL pushdownArnd Bergmann
2008-02-06tpm.c: fix crash during device removalRichard MUSIL
The clean up procedure now uses platform device "release" callback to handle memory clean up. For this purpose "release" function callback was added to struct tpm_vendor_specific, so hw device driver provider can get called when it is safe to remove all allocated resources. This is supposed to fix a bug in device removal, where device while in receive function (waiting on timeout) was prone to segfault, if the tpm_chip struct was unallocated before the timeout expired (in tpm_remove_hardware). Acked-by: Marcel Selhorst <tpm@selhorst.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-14TPM: fix suspend and resume failureDavid Smith
The savestate command structure was being overwritten by the result of running the TPM_SaveState command after one run, so make it a local variable to the function instead of a global variable that gets overwritten. Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Kent Yoder <shpedoikal@gmail.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22tpmdd maintainersKent Yoder
Fix up the maintainers info in the tpm drivers. Kylene will be out for some time, so copying the sourceforge list is the best way to get some attention. Cc: Marcel Selhorst <tpm@selhorst.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use mutex instead of semaphore in TPM driverMatthias Kaehlcke
The TPM driver uses two semaphores as mutexes. Use the mutex API instead of the (binary) semaphores. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: Kylene Hall <kjhall@us.ibm.com> Cc: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tpm: fix sleep-in-spinlockParag Warudkar
flush_scheduled_work() can sleep, and we're calling it under spinlock. AFAICS, moving flush_scheduled_work before spin_lock() should not cause any problems. Reason being - The only thing that can race against tpm_release is tpm_open (tpm_release is called when last reference to the file is closed and only thing that can happen after that is tpm_open??) and tpm_open acquires driver_lock and more over it bails out with EBUSY if chip->num_opens is greater than 0. I also moved chip->num_pending-- to after deleting timer and setting data pending as it looks more correct for the paranoid although it probably doesn't matter as it is guarded by driver_lock. None the less this change should not cause problems. While I was at it I noticed a missing NULL check in tpm_register_hardware which is fixed with this patch as well. Signed-off-by: Parag Warudkar <parag.warudkar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
