path: root/drivers/char/tpm/tpm.c
2007-02-12[PATCH] Char: timers cleanupJiri Slaby
- Use timer macros to set function and data members and to modify expiration time. - Use DEFINE_TIMER for global timers and do not init them at run-time in these cases. - del_timer_sync is common in most cases -- we want to wait for timer function if it's still running. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Wim Van Sebroeck <wim@iguana.be> Acked-by: Dmitry Torokhov <dtor@mail.ru> (Input bits) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Correct misc_register return code handling in several driversNeil Horman
Clean up several code points in which the return code from misc_register is not handled properly. Several modules failed to deregister various hooks when misc_register fails, and this patch cleans them up. Also there are a few modules that legitimately don't care about the failure status of misc register. These drivers however unilaterally call misc_deregister on module unload. Since misc_register doesn't initialize the list_head in the init_routine if it fails, the deregister operation is at risk for oopsing when list_del is called. The initial solution was to manually init the list in the miscdev structure in each of those modules, but the consensus in this thread was to consolodate and do that universally inside misc_register. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Olaf Hering <olh@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-01Driver core: change misc class_devices to be real devicesGreg Kroah-Hartman
This also ment that some of the misc drivers had to also be fixed up as they were assuming the device was a class_device. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-11[PATCH] tpm: fix error handlingJeff Garzik
- handle sysfs error - handle driver model errors - de-obfuscate platform_device_register_simple() call, which included an assignment in between two function calls, in the same C statement. Signed-off-by: Jeff Garzik <jeff@garzik.org> Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] TPM: fix failure path leakRandy Dunlap
kfree(devname) on the misc_register() failure path. Otherwise it is lost forever. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: use clear_bitKylene Jo Hall
Use set_bit() and clear_bit() for dev_mask manipulation. Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: msecs_to_jiffies cleanupsKylene Jo Hall
The timeout and duration values used in the tpm driver are not exposed to userspace. This patch converts the storage units to jiffies with msecs_to_jiffies. They were always being used in jiffies so this simplifies things removing the need for calculation all over the place. The change necessitated a type change in the tpm_chip struct to hold jiffies. Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: driver for next generation TPM chipsLeendert van Doorn
The driver for the next generation of TPM chips version 1.2 including support for interrupts. The Trusted Computing Group has written the TPM Interface Specification (TIS) which defines a common interface for all manufacturer's 1.2 TPM's thus the name tpm_tis. Signed-off-by: Leendert van Doorn <leendert@watson.ibm.com> Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: new 1.2 sysfs filesKylene Jo Hall
Many of the sysfs files were calling the TPM_GetCapability command with array. Since for 1.2 more sysfs files of this type are coming I am generalizing the array so there can be one array and the unique parts can be filled in just before the command is called. This updated version of the patch breaks the multi-value sysfs file into separate files pointed out by Greg. It also addresses the code redundancy and ugliness in the tpm_show_* functions pointed out on another patch by Dave Hansen. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: command duration updateKylene Jo Hall
With the TPM 1.2 Specification, each command is classified as short, medium or long and the chip tells you the maximum amount of time for a response to each class of command. This patch provides and array of the classifications and a function to determine how long the response should be waited for. Also, it uses that information in the command processing to determine how long to poll for. The function is exported so the 1.2 driver can use the functionality to determine how long to wait for a DataAvailable interrupt if interrupts are being used. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: return chip from tpm_register_hardwareKylene Jo Hall
Changes in the 1.2 TPM Specification make it necessary to update some fields of the chip structure in the initialization function after it is registered with tpm.c thus tpm_register_hardware was modified to return a pointer to the structure. This patch makes that change and the associated changes in tpm_atmel and tpm_nsc. The changes to tpm_infineon will be coming in a patch from Marcel Selhorst. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: chip struct updateKylene Jo Hall
To assist with chip management and better support the possibility of having multiple TPMs in the system of the same kind, the struct tpm_vendor_specific member of the tpm_chip was changed from a pointer to an instance. This patch changes that declaration and fixes up all accesses to the structure member except in tpm_infineon which is coming in a patch from Marcel Selhorst. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: reorganize sysfs filesKylene Jo Hall
Many of the sysfs files were calling the TPM_GetCapability command with array. Since for 1.2 more sysfs files of this type are coming I am generalizing the array so there can be one array and the unique parts can be filled in just before the command is called. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: spacing cleanupsKylene Jo Hall
The following patch set contains numerous changes to the base tpm driver (tpm.c) to support the next generation of TPM chips. The changes include new sysfs files because of more relevant data being available, a function to access the timeout and duration values for the chip, and changes to make use of those duration values. Duration in the TPM specification is defined as the maximum amount of time the chip could take to return the results. Commands are in one of three categories short, medium and long. Also included are cleanups of how the commands for the sysfs files are composed to reduce a bunch of redundant arrays. This patch: Fix minor spacing issues. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tpm: add bios measurement logKylene Jo Hall
According to the TCG specifications measurements or hashes of the BIOS code and data are extended into TPM PCRS and a log is kept in an ACPI table of these extensions for later validation if desired. This patch exports the values in the ACPI table through a security-fs seq_file. Signed-off-by: Seiji Munetoh <munetoh@jp.ibm.com> Signed-off-by: Stefan Berger <stefanb@us.ibm.com> Signed-off-by: Reiner Sailer <sailer@us.ibm.com> Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[PATCH] tpm: use flush_scheduled_work()Kylene Jo Hall
Add the necessary flush_schedule_work calls when canceling the timer. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: locking fixKylene Jo Hall
Use schedule_work() to avoid down()-in-timer-handler problem. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: dev_mask handling fixKylene Jo Hall
- Use ~, not ! - Remove unneeded cast Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] tpm-tidiesAndrew Morton
- Various whitespace fixes - Use kzalloc() Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] tpm: change from pci_dev to dev power management functionsKylene Jo Hall
This patch is in support of moving away from the lpc bus pci_dev. The power management prototypes used by platform drivers is different but the functionality remains the same. Signed-off-by: Kylene Hall <kjhall@us.ibm.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] tpm: remove pci dependencyKylene Jo Hall
Since the tpm does not have it's own pci id we have been consuming the lpc bus. This is not correct and causes problems to support non lpc bus chips. This patch removes the dependency on pci_dev from tpm.c The subsequent patches will stop the supported chips from registering as pci drivers. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] tpm: add status function to allow non-lpc bus chipsKylene Jo Hall
This patch is in preparation of supporting chips that are not necessarily on the lpc bus and thus are not accessed with inb's and outb's. The patch replaces the call to get the chip's status in the tpm.c file with a vendor specific status function. The patch also defines the function for each of the current supported devices. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] tpm: fix bug introduced by the /proc/miscKylene Jo Hall
In fixing the /proc/misc problem that was reported last week where the tpm module name was being obfuscated in /proc/misc I introduced a bug in the module unloading code. This patch fixes the problem. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] tpm: fix misc name memory problemKylene Jo Hall
I was using invalid memory for the miscdevice.name. This patch fixes the problem which was manifested by an ugly entry in /proc/misc. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] tpm: Fix pubek parsingKylene Jo Hall
Fix parsing of the PUBEK for display which was leading to showing the wrong modulus length and modulus. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: improve output in sysfs files when the TPM failsKylene Jo Hall
Since after reconsideration this is more debug output than an error (the TPM is operating correctly given the current state) I have changed the statements to dbg rather than err. Also this patch corrects a memory leak if the error path is taken in the tpm_show_pubek function. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: add debugging outputKylene Hall
2005-06-24[PATCH] tpm: replace odd LPC init functionKylene Hall
Realized the tpm_lpc_init function isn't really necessary. Replaced it with vendor specific logic to find out the address the BIOS mapped the TPM to. This patch removes the tpm_lpc_init function, enums associated with it and calls to it. The patch also implements the replacement functionality. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: locking fixesKylene Hall
Add a missing lock in the register hardware and fix a misplaced lock release release. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: add cancel functionKylene Hall
This patch provides the logic to check if an operation has been canceled while waiting for the response to arrive. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: sysfs owernship changesKylene Hall
In the current driver all sysfs files end up owned by the base driver module rather than the module that actually owns the device this is a problem if the module is unloaded and the file is open. This patch fixes all that and lumps the files into an attribute_group. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: remove unnecessary __forceKylene Hall
Remove the unnecessary use of __force. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: use to_pci_devKylene Hall
Changes the container_of calls to 'to_pci_dev' as suggested previously. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: fix timer initializationKylene Hall
Fix the timer to be inited and modified properly. This work depends on the fixing of the msleep stuff which in patch 1 of this set. Signed-of-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: large stack objectsKylene Hall
Remove some large objects be declared on the the stack. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: read return code issueKylene Hall
Replace an erroneous return code for the read function when no data is available. Signed-of-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: remove unnecessary module stuffKylene Hall
Description: Remove unnecessary (empty) module definitions. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: address missing const defsKylene Hall
Add "const" to several static arrays that were missing it in their definitions. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: Fix concerns with TPM driver -- use enumsKylene Hall
Convert #defines to named enums where that preference has been indicated by other kernel developers. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] char/tpm: use msleep(), clean-up timers,Nishanth Aravamudan
The TPM driver unnecessarily uses timers when it simply needs to maintain a maximum delay via time_before(). msleep() is used instead of schedule_timeout() to guarantee the task delays as expected. While compile-testing, I found a typo in the driver, using tpm_chp instead of tpm_chip. Remove the now unused timer callback function and change TPM_TIMEOUT's units to milliseconds. Patch is compile-tested. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/base - drivers/i2c/chips/adm1026.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-26[PATCH] tpm 64bit fixes (size_t)Al Viro
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix u32 vs. pm_message_t in drivers/charPavel Machek
Here are fixes for drivers/char. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
