path: root/drivers/char/pty.c
2009-01-12pty: Fix documentationAlan Cox
The pty changes and updates for window sizing forgot to correct the kerneldoc Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08Make various things staticRoel Kluin
Building an allnoconfig kernel, sparse asked whether these could be static, so I checked, and they are only used in the file where they are declared. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02tty: PTYs set TTY_DO_WRITE_WAKEUP when they don't need toAlan Cox
The write wakeup is done anyway for the poll while DO_WRITE_WAKUP is cleared, set and managed by the ldisc layer and is no business of the pty code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02pty: simplify resizeAlan Cox
We have special case logic for resizing pty/tty pairs. We also have a per driver resize method so for the pty case we should use it. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: simplify unix98 allocationAlan Cox
We need both termios and termios_locked so allocate them as one Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: Fix allocation failure double freeAlan Cox
The updating and moving around of the pty code added a bug where both the helper and caller free the main tty struct (the pty driver must free the o_tty pair itself however). Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13pty: Coding style and polishAlan Cox
We've done the heavy lifting now its time to mop up a bit Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13Add an instance parameter devpts interfacesSukadev Bhattiprolu
Pass-in 'inode' or 'tty' parameter to devpts interfaces. With multiple devpts instances, these parameters will be used in subsequent patches to identify the instance of devpts mounted. The parameters also help simplify devpts implementation. Changelog[v3]: - minor changes due to merge with ttydev updates - rename parameters to emphasize they are ptmx or pts inodes - pass-in tty_struct * to devpts_pty_kill() (this will help cleanup the get_node() call in a subsequent patch) Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: extract the pty init time special casesAlan Cox
The majority of the remaining init_dev code is pty special cases. We refactor this code into the driver->install method. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Finish fixing up the init_dev interface to use ERR_PTRAlan Cox
Original suggestion and proposal from Sukadev Bhattiprolu. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: More driver operationsAlan Cox
We have the lookup operation abstracted which is nice for pty cleanup but we really want to abstract the add/remove entries as well so that we can pull the pty code out of the tty core and create a clear defined interface for the tty driver table. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: kref the tty driver objectAlan Cox
2008-10-13tty: Clean up the tty_init_dev changes furtherAlan Cox
Fix up the naming, style and extract some bits of code into the driver specific code Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Remove more special casing and out of place codeAlan Cox
Carry on pushing code out of tty_io when it belongs to other drivers. I'm not 100% happy with some of this and it will be worth revisiting some of the exports later when the restructuring work is done. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: shutdown methodAlan Cox
Right now there are various drivers that try to use tty->count to know when they get the final close. Aristeau Rozanski showed while debugging the vt sysfs race that this isn't entirely safe. Instead of driver side tricks to work around this introduce a shutdown which is called when the tty is being destructed. This also means that the shutdown method is tied into the refcounting. Use this to rework the console close/sysfs logic. Remove lots of special case code from the tty core code. The pty code can now have a shutdown() method that replaces the special case hackery in the tree free up paths. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pty: prepare for tty->ops changesAlan Cox
We are about to change the tty layer to avoid keeping private copies of all the methods in each tty. We have to update the pty layer first as it currently patches the ioctl method according to the tty type. Use multiple tty operations sets instead. Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: BKL pushdownAlan Cox
- Push the BKL down into the line disciplines - Switch the tty layer to unlocked_ioctl - Introduce a new ctrl_lock spin lock for the control bits - Eliminate much of the lock_kernel use in n_tty - Prepare to (but don't yet) call the drivers with the lock dropped on the paths that historically held the lock BKL now primarily protects open/close/ldisc change in the tty layer [jirislaby@gmail.com: a couple of fixes] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: simplify the pty sysctl logicEric W. Biederman
Instead of having a bunch of ifdefs in sysctl.c move all of the pty sysctl logic into drivers/char/pty.c As well as cleaning up the logic this prevents sysctl_check_table from complaining that the root table has a NULL data pointer on something with generic methods. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12PTY: add kernel parameter to overwrite legacy pty countKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-28[PATCH] remove TTY_DONT_FLIPPaul Fulghum
Remove TTY_DONT_FLIP tty flag. This flag was introduced in 2.1.X kernels to prevent the N_TTY line discipline functions read_chan() and n_tty_receive_buf() from running at the same time. 2.2.15 introduced tty->read_lock to protect access to the N_TTY read buffer, which is the only state requiring protection between these two functions. The current TTY_DONT_FLIP implementation is broken for SMP, and is not universally honored by drivers that send data directly to the line discipline receive_buf function. Because TTY_DONT_FLIP is not necessary, is broken in implementation, and is not universally honored, it is removed. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_dir() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_dir() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] pty_chars_in_buffer oops fixJason Baron
The idea of this patch is to lock both sides of a ptmx/pty pair during line discipline changing. This is needed to ensure that say a poll on one side of the pty doesn't occur while the line discipline is actively being changed. This resulted in an oops reported on lkml, see: http://marc.theaimsgroup.com/?l=linux-kernel&m=111342171410005&w=2 A 'hacky' approach was previously implmemented which served to eliminate the poll vs. line discipline changing race. However, this patch takes a more general approach to the issue. The patch only adds locking on a less often used path, the line-discipline changing path, as opposed to locking the ptmx/pty pair on read/write/poll paths. The patch below, takes both ldisc locks in either order b/c the locks are both taken under the same spinlock(). I thought about locking the ptmx/pty separately, such as master always first but that introduces a 3 way deadlock. For example, process 1 does a blocking read on the slave side. Then, process 2 does an ldisc change on the slave side, which acquires the master ldisc lock but not the slave's. Finally, process 3 does a write which blocks on the process 2's ldisc reference. This patch does introduce some changes in semantics. For example, a line discipline change on side 'a' of a ptmx/pty pair, will now wait for a read/write to complete on the other side, or side 'b'. The current behavior is to simply wait for any read/writes on only side 'a', not both sides 'a' and 'b'. I think this behavior makes sense, but I wanted to point it out. I've tested the patch with a bunch of read/write/poll while changing the line discipline out from underneath. This patch obviates the need for the above "hide the problem" patch. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
