path: root/drivers/char/mmtimer.c
2006-12-07[PATCH] Correct misc_register return code handling in several driversNeil Horman
Clean up several code points in which the return code from misc_register is not handled properly. Several modules failed to deregister various hooks when misc_register fails, and this patch cleans them up. Also there are a few modules that legitimately don't care about the failure status of misc register. These drivers however unilaterally call misc_deregister on module unload. Since misc_register doesn't initialize the list_head in the init_routine if it fails, the deregister operation is at risk for oopsing when list_del is called. The initial solution was to manually init the list in the miscdev structure in each of those modules, but the consensus in this thread was to consolodate and do that universally inside misc_register. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Olaf Hering <olh@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: drivers/char: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25[PATCH] mm: remove VM_LOCKED before remap_pfn_range and drop VM_SHMChristoph Lameter
Remove VM_LOCKED before remap_pfn range from device drivers and get rid of VM_SHM. remap_pfn_range() already sets VM_IO. There is no need to set VM_SHM since it does nothing. VM_LOCKED is of no use since the remap_pfn_range does not place pages on the LRU. The pages are therefore never subject to swap anyways. Remove all the vm_flags settings before calling remap_pfn_range. After removing all the vm_flag settings no use of VM_SHM is left. Drop it. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-07[IA64] SGI SN drivers: don't report !sn2 hardware as an errorBjorn Helgaas
This stuff is all in the generic ia64 kernel, and the new initcall error reporting complains about them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-06[PATCH] shrink mmtimer memory sizeDimitri Sivanich
This greatly reduces the amount of memory used by mmtimer on smaller machines with large values of MAX_COMPACT_NODES. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-15[IA64] Two more uses of cpuid_to_cnodeid() must go.Tony Luck
s/cpuid_to_cnodeid/cpu_to_node/ Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-16[PATCH] mmtimer build fixChristoph Lameter
Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
