path: root/drivers/char/misc.c
2009-06-15Driver Core: misc: add nodename support for misc devices.Kay Sievers
This adds support for misc devices to report their requested nodename to userspace. It also updates a number of misc drivers to provide the needed subdirectory and device name to be used for them. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16device create: char: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: char: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-20misc: cdev lock_kernel() pushdownJonathan Corbet
misc_open() looks fine, but who knows what all of the misc drivers are doing in their open() functions? Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-29drivers: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19PM: Remove destroy_suspended_device()Rafael J. Wysocki
After 2.6.24 there was a plan to make the PM core acquire all device semaphores during a suspend/hibernation to protect itself from concurrent operations involving device objects. That proved to be too heavy-handed and we found a better way to achieve the goal, but before it happened, we had introduced the functions device_pm_schedule_removal() and destroy_suspended_device() to allow drivers to "safely" destroy a suspended device and we had adapted some drivers to use them. Now that these functions are no longer necessary, it seems reasonable to remove them and modify their users to use the normal device unregistration instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-05Misc: Add possibility to remove misc devices during suspend/resumeRafael J. Wysocki
Make it possible to unregister a misc device object in a safe way during a suspend/resume cycle. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Michael Buesch <mb@bu3sch.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make /proc/misc use seq_list_xxx helpersPavel Emelianov
Simple and stupid - just use the helpers. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use mutex instead of semaphore for misc char devicesMatthias Kaehlcke
The misc character device driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Correct misc_register return code handling in several driversNeil Horman
Clean up several code points in which the return code from misc_register is not handled properly. Several modules failed to deregister various hooks when misc_register fails, and this patch cleans them up. Also there are a few modules that legitimately don't care about the failure status of misc register. These drivers however unilaterally call misc_deregister on module unload. Since misc_register doesn't initialize the list_head in the init_routine if it fails, the deregister operation is at risk for oopsing when list_del is called. The initial solution was to manually init the list in the miscdev structure in each of those modules, but the consensus in this thread was to consolodate and do that universally inside misc_register. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Olaf Hering <olh@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01Driver core: change misc class_devices to be real devicesGreg Kroah-Hartman
This also ment that some of the misc drivers had to also be fixed up as they were assuming the device was a class_device. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-03[PATCH] make more file_operation structs staticArjan van de Ven
Mark the static struct file_operations in drivers/char as const. Making them const prevents accidental bugs, and moves them to the .rodata section so that they no longer do any false sharing; in addition with the proper debug option they are then protected against corruption.. [akpm@osdl.org: build fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-07[PATCH] move m68k rtc drivers over to initcallsChristoph Hellwig
this gets rid of the last two explicit initializations in misc.c Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] I8K: initialization code cleanup; formattingDmitry Torokhov
I8K: use module_{init|exit} instead of old style #ifdef MODULE code, some formatting changes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Toshiba driver cleanupDmitry Torokhov
Toshiba legacy driver cleanup: - use module_init/module_exit for initialization instead of using #ifdef MODULE and calling tosh_init manually from drivers/char/misc.c - do not explicitly initialize static variables - some whitespace and formatting cleanups Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] class: convert drivers/char/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
