path: root/drivers/char/hw_random/omap-rng.c
2011-06-30hwrng: omap - add missing clk_putJulia Lawall
Convert a return to a jump to an existing label that calls clk_put. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-02-16hwrng: omap - Convert release_resource to release_region/release_mem_regionJulia Lawall
Request_region should be used with release_region, not release_resource. The local variable mem, storing the result of request_mem_region, is dropped and instead the pointer res is stored in the drvdata field of the platform device. This information is retrieved in omap_rng_remove to release the region. The drvdata field is not used elsewhere. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,E; @@ ( *x = request_region(...) | *x = request_mem_region(...) ) ... when != release_region(x) when != x = E * release_resource(x); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-24omap: rng: Use resource_size instead of manual calculationTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one-errors. Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
2009-06-02hwrng: omap - Move probe function to .devinit.textUwe Kleine-König
A pointer to omap_rng_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Jan Engelhardt <jengelh@gmx.de> Cc: Michael Buesch <mb@bu3sch.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-08[ARM] omap: convert omap RNG clocks to match by devid and conidRussell King
2009-01-24[ARM] omap: ensure OMAP drivers pass a struct device to clk_get()Russell King
2008-09-05[ARM] omap: convert OMAP drivers to use ioremap()Russell King
2008-04-21[HWRNG] omap: Minor updatesDavid Brownell
Minor cleanups to the OMAP RNG: - Comment update re RNG status: * yes, it works on 16xx; "rngtest" is quite happy * it's fast enough that polling vs IRQ is a non-issue - Get rid of BUG_ON - Help GCC not be stupid about inlining (object code shrink) - Remove "sparse" warning - Cope with new hotplug rule requiring "platform:" modalias And make the file header match kernel conventions. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[HWRNG]: move status polling loop to data_present callbacksPatrick McHardy
Handle waiting for new random within the drivers themselves, this allows to use better suited timeouts for the individual rngs. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-06[PATCH] omap-rng build fixDavid Brownell
Seems like the omap-rng driver in the main tree predates the switch from <asm/hardware/clock.h> to <linux/clk.h> ... now it builds OK. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Add TI OMAP CPU family HW RNG driverMichael Buesch
Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
