path: root/drivers/char/hw_random/omap-rng.c
2008-01-11[HWRNG]: move status polling loop to data_present callbacksPatrick McHardy
Handle waiting for new random within the drivers themselves, this allows to use better suited timeouts for the individual rngs. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-06[PATCH] omap-rng build fixDavid Brownell
Seems like the omap-rng driver in the main tree predates the switch from <asm/hardware/clock.h> to <linux/clk.h> ... now it builds OK. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Add TI OMAP CPU family HW RNG driverMichael Buesch
Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
