Drivers that register a ->fault handler, but do not range-check the
offset argument, must set VM_DONTEXPAND in the vm_flags in order to
prevent an expanding mremap from overflowing the resource.
I've audited the tree and attempted to fix these problems (usually by
adding VM_DONTEXPAND where it is not obvious).
Signed-off-by: Nick Piggin <npiggin@suse.de>
Upstream as 7fc86860cf73e060ab8ed9763010dfe5b5389b1c
This code relied on the CPU and GPU address for the aperture being the same,
On some r5xx hardware I was playing with I noticed that this isn't always true.
This fixes issues seen on some r400 cards. (bugs.freedesktop.org 9957)
This is upstream as 54583bf4efda79388fc13163e35c016c8bc5de81
Oops...
Signed-off-by: Dave Airlie <airlied@linux.ie>
This code is ported from the DRM git tree and allows the vblank interrupts
to function on the i965 hw. It also requires a change in Mesa's 965 driver
to actually use them.
[ Without this patch, my 965GM drops vblank interrupts - Jesse ]
Acked-by: Jesse Barnes <jesse.barnes@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: ioremap return value checks
drm/via: Fix dmablit when blit queue is full
drm_rmmap_ioctl(): remove dead code
Signed-off-by: Scott Thompson <postfail <at> hushmail.com>
This 965G and above chipsets moved the batch buffer non-secure bits to
another place. This means that previous drm's allowed in-secure batchbuffers
to be submitted to the hardware from non-privileged users who are logged
into X and and have access to direct rendering.
fd.o bug 11542
Acked-by: Thomas Hellstrom
This patch removes some obviously dead code spotted by the Coverity
checker.
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Brown paper bag for me this patch chunk didn't make it in the first application
Reported by: Avuton Olrich <avuton@gmail.com>
This converts the code for allocating drawables to the Linux idr,
Fixes from: Michel Dänzer <michel@tungstengraphics.com>, Kristian Høgsberg <krh@redhat.com>
This converts the drm context allocator to an idr, using the new idr
interface features from Kristian.
Fixes from Kristian Hoegsberg <krh@redhat.com>
Leave the userspace typedefs in place
some drivers still todo.
This moves a bunch of typedefs into a !defined __KERNEL__ to keep userspace
API compatiblity, it changes all internal usages to structs/enum/unions.
This updates the R300 register names and allows the VAP_PVS_WAITIDLE register
to be written.
This adds support for CRTC2 vblank on radeon similiar to the i915.
This makes the drms use of the list handling macros a lot cleaner
and more along the lines of how they should be used and uses them
in some more places.
This adds support for some of the XGI Volari family that are based on the
SiS.
Commit 9b01bd5b284bbf519b726b39f1352023cb5e9e69 introduced a
compat_ioctl handler for RADEON_SETPARAM, the sole purpose of which was
to handle the fact that on i386, alignof(uint64_t)==4.
Unfortunately, this handler was installed for _all_ 64-bit
architectures, instead of only x86_64 and ia64. And thus it breaks
32-bit compatibility on every other arch, where 64-bit integers are
aligned to 8 bytes in 32-bit mode just the same as in 64-bit mode.
Arnd has a cunning plan to use 'compat_u64' with appropriate alignment
attributes according to the 32-bit ABI, but for now let's just make the
compat_radeon_cp_setparam routine entirely disappear on 64-bit machines
whose 32-bit compat support isn't for i386. It would be a no-op with
compat_u64 anyway.
Cc: Dave Airlie <airlied@gmail.com>
The alignment on 64-bit is different for 64-bit values.
These require that the status page be referenced by a pointer in GTT, rather
than phsyical memory. So, we have the X Server allocate that memory and tell
us the address, instead.
ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: make sure the drawable code doesn't call malloc(0).
drm/radeon: add more IGP chipset pci ids
drm: Spinlock initializer cleanup
The DRM code depends on an atomic version of cmpxchg(), which is not
available on sparc32. Since other platforms besides sparc32 have this
issue a KCONFIG option is added for it.
Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk>
Signed-off-by: Michel Dänzer <michel@tungstengraphics.com>
Add more IGP chipset PCI IDs
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
Bump driver date and patchlevel.
There can still be other contexts that may use page flipping later on, so do
just unilaterally 'clean it up', which could lead to the wrong page being
displayed, e.g. when running 3D apps with a GLX compositing manager such as
compiz using page flipping.
radeon: make PCI GART aperture size variable, but making table size variable
This is precursor to getting a TTM backend for this stuff, and also
allows the PCI table to be allocated at fb 0
radeon: add support for reverse engineered xpress200m
The IGPGART setup code was traced using mmio-trace on fglrx by myself
and Phillip Ezolt <phillipezolt@gmail.com> on dri-devel.
This code doesn't let the 3D driver work properly as the card has no
vertex shader support.
Thanks to Matthew Garrett + Ubuntu for providing me some hardware to do this
work on.
master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/i915: Add 965GM pci id update
drm: just use io_remap_pfn_range on all archs..
drm: fix DRM_CONSISTENT mapping
drm: fix up mmap locking in preparation for ttm changes
drm: fix driver deadlock with AIGLX and reclaim_buffers_locked
drm: fix warning in drm_fops.c
drm: allow for more generic drm ioctls
drm: fix alpha domain handling
via: fix CX700 pci id
drm: make drm_io_prot static.
drm: remove via_mm.h
drm: add missing NULL assignment
drm/radeon: Fix u32 overflows when determining AGP base address in card space.
drm: port over use_vmalloc code from git hashtab
drm: fix crash with fops lock and fixup sarea/page size locking
drm: bring bufs code from git tree.
drm: move protection stuff into separate function
drm: Use ARRAY_SIZE macro when appropriate
drm: update README.drm (bugzilla #7933)
drm: remove unused exports
