path: root/drivers/char/drm/drm_irq.c
2006-02-02sem2mutex: drivers/char/drm/Dave Airlie
From: Arjan van de Ven <arjan@infradead.org> Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-09-25drm: lindent the drm directory.Dave Airlie
I've been threatening this for a while, so no point hanging around. This lindents the DRM code which was always really bad in tabbing department. I've also fixed some misnamed files in comments and removed some trailing whitespace. Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-07-07drm: misc cleanupDave Airlie
This patch contains the following cleanups: - make needlessly global functions static - remove the following unused global functions: - drm_fops.c: drm_read - i915_dma.c: i915_do_cleanup_pageflip Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
