path: root/drivers/bluetooth/hci_usb.h
2007-07-11[Bluetooth] Use hci_recv_fragment() within HCI USB driverMarcel Holtmann
This patch modifies the HCI USB driver to use the new helper function for reassembling HCI data packets and events. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-07-03[Bluetooth] Correct SCO buffer size on requestMarcel Holtmann
This patch introduces a quirk that allows the drivers to tell the host to correct the SCO buffer size values. Signed-off-by: Olivier Galibert <galibert@pobox.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-09-13[Bluetooth] Add ignore parameters to the HCI USB driverMarcel Holtmann
This patch adds the module parameters ignore_csr and ignore_sniffer to the HCI USB driver. This allows an easier use of CSR ROM chips that need an additional initialization routine and the Frontline sniffers. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
