path: root/drivers/bluetooth/hci_ath.c
2015-04-07Bluetooth: hci_uart: Provide generic H:4 receive frameworkMarcel Holtmann
Future H:4 based UART drivers require custom packet types and custom receive functions. To support this, extended the h4_recv_buf function with a packet definition table. For the default H:4 packets types of ACL data, SCO data and events, provide helpers to reduce the amount of code duplication. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-04-07Bluetooth: hci_uart: Remove the manual protocol init messageMarcel Holtmann
The init function for each HCI UART protocol prints the same on success and failure. This information is so generic, remove it and let the main HCI UART handling print it instead. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-04-07Bluetooth: hci_uart: Add name information to hci_uart_proto structMarcel Holtmann
This adds an extra name field to the hci_uart_proto struct that provides a simple way of adding a string identifier to the protocol. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-04-07Bluetooth: hci_uart: Make struct hci_uart_proto always constMarcel Holtmann
The usage of struct hci_uart_proto should always be const. Change the function headers and individual protocol drivers. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-04-07Bluetooth: hci_uart: Use h4_recv_buf helper for Atheros AR300xMarcel Holtmann
Instead of using hci_recv_stream_fragment, use the local available h4_recv_buf helper function. To ensure that the function is available select BT_HCIUART_H4. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-04-07Bluetooth: hci_uart: Use const data pointer for received dataMarcel Holtmann
The TTY layer provides its data pointers as const, but the HCI UART callbacks expect them as general data pointers. This is of course wrong and instead of casting them, just fix the individual drivers to actually take a const data pointer. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2015-02-02tty: Remove external interface for tty_set_termios()Peter Hurley
tty_set_termios() is an internal helper intended for file scope use. UART drivers which are capable of driving the RTS pin must properly handle the tiocmset() method, regardless of termios settings. A failure to do so is a UART driver bug and should be fixed there. Do not use this interface to workaround UART driver bugs. Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: <linux-bluetooth@vger.kernel.org> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-11Bluetooth: hci-uart-ath: Correct the comments in this driverFugang Duan
Correct the comments in this driver. Set the CRTSCTS flag means automatic flow control is enabled. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-13Bluetooth: hci-uart-ath: Use GFP_ATOMIC in open()David Herrmann
The uart_proto open() callback is not called in atomic context so we can safely sleep here. The caller hci_uart_set_proto() in hci_ldisc.c is an ioctl-handler and therefore can sleep. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2011-04-13Bluetooth: hci_uart: check the return value of recv()Jiejing Zhang
Check the return value of hu->proto->recv() in hci_uart_tty_receive() the recv() may return error, check it, not add this to statistics. Signed-off-by: Jiejing Zhang <jiejing.zhang@freescale.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-17hci_ath: Fix the mess in this driverAlan Cox
Was this exploitable - who knows, but it was certainly totally broken Signed-of-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-27Bluetooth: Fix kfree() => kfree_skb() in hci_ath.cDan Carpenter
sk_buffs have to be freed with kfree_skb() instead of kfree(). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-07-27Bluetooth: Add __init and __exit marks to UART driversGustavo F. Padovan
Those marks are useful to save space in the binary and in the memory. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-07-27Bluetooth: Fix permission of hci_ath.cGustavo F. Padovan
.c file shall not have the 'x' permission. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-07-21Bluetooth: Support for Atheros AR300x serial chipSuraj Sumangala
Implements Atheros AR300x serial HCI protocol. This protocol extends H4 serial protocol to implement enhanced power management features supported by Atheros AR300x serial Bluetooth chipsets. Signed-off-by: Suraj Sumangala <suraj@atheros.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
