If we have a good resync rate, we will frequently update the on-disk
bitmap, which, if not accounted for as resync io, may let an otherwise
idle device appear to be "busy", and cause us to throttle resync.
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
The last commit, drbd: add missing spinlock to bitmap receive,
introduced a cond_resched_lock(), where the lock in question is taken
with irqs disabled.
As we must not schedule with IRQs disabled,
and cond_resched_lock_irq() does not exist, yet,
we re-aquire the spin_lock_irq() for each bitmap page processed in turn.
During bitmap exchange, when using the RLE bitmap compression scheme,
we have a code path that can set the whole bitmap at once.
To avoid holding spin_lock_irq() for too long, we used to lock out other
bitmap modifications during bitmap exchange by other means, and then,
knowing we have exclusive access to the bitmap, modify it without
the spinlock, and with IRQs enabled.
Since we now allow local IO to continue, potentially setting additional
bits during the bitmap receive phase, this is no longer true, and we get
uncoordinated updates of bitmap members, causing bm_set to no longer
accurately reflect the total number of set bits.
To actually see this, you'd need to have a large bitmap, use RLE bitmap
compression, and have busy IO during sync handshake and bitmap exchange.
Fix this by taking the spin_lock_irq() in this code path as well, but
calling cond_resched_lock() after each page worth of bits processed.
Found these with the help of ispell -l.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
In commit 95a0f10cddbf ("drbd: store in-core bitmap little endian,
regardless of architecture") drbd had made the sane choice to use
little-endian bitmap functions everywhere. However, it used the
horrible old functions names from <asm-generic/bitops/le.h>, that were
never really meant to be exported.
In the meantime, things got cleaned up, and in commit c4945b9ed472
("asm-generic: rename generic little-endian bitops functions") we
renamed the LE bitops to something sane, exactly so that they could be
used in random code without people gouging their eyes out when seeing
the crazy jumble of letters that were the old internal names.
As a result the drbd thing merged cleanly (commit 8d49a77568d1: "Merge
branch 'for-2.6.39/drivers' of git://git.kernel.dk/linux-2.6-block"),
since there was no data conflict - but the end result obviously doesn't
actually compile.
Reported-and-tested-by: Ingo Molnar <mingo@elte.hu>
Cc: Jens Axboe <jaxboe@fusionio.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Now that we do no longer in-place endian-swap the bitmap, we allow
selected bitmap operations (testing bits, sometimes even settting bits)
during some bulk operations.
This caused us to hit a lot of FIXME asserts similar to
FIXME asender in drbd_bm_count_bits,
bitmap locked for 'write from resync_finished' by worker
Which now is nonsense: looking at the bitmap is perfectly legal
as long as it is not being resized.
This cosmetic patch defines some flags to describe expectations in finer
detail, so the asserts in e.g. bm_change_bits_to() can be skipped if
appropriate.
I run into something declaring itself as "spinlock deadlock",
BUG: spinlock lockup on CPU#1, kjournald/27816, ffff88000ad6bca0
Pid: 27816, comm: kjournald Tainted: G W 2.6.34.6 #2
Call Trace:
<IRQ> [<ffffffff811ba0aa>] do_raw_spin_lock+0x11e/0x14d
[<ffffffff81340fde>] _raw_spin_lock_irqsave+0x6a/0x81
[<ffffffff8103b694>] ? __wake_up+0x22/0x50
[<ffffffff8103b694>] __wake_up+0x22/0x50
[<ffffffffa07ff661>] bm_async_io_complete+0x258/0x299 [drbd]
but the call traces do not fit at all,
all other cpus are cpu_idle.
I think it may be this race:
drbd_bm_write_page
wait_queue_head_t io_wait;
atomic_t in_flight;
bm_async_io
submit_bio
if (atomic_dec_and_test(in_flight))
wait_event(io_wait,
atomic_read(in_flight) == 0)
return
wake_up(io_wait)
The wake_up now accesses the wait_queue_head_t spinlock, which is no
longer valid, since the stack frame of drbd_bm_write_page has been
clobbered now.
Fix this by using struct completion, which does both the condition test
as well as the wake_up inside its spinlock, so this race cannot happen.
We expect changes to a bitmap page in drbd_bm_write_page,
that's why we submit a copy page.
If a page changes during global writeout, that would be unexpected,
and reason to warn, though.
Also, often page writeout can be skipped (on activity log transactions
during normal operation, for example), no need to log that everytime.
Long time ago, we had paranoia code in the bitmap that allocated one
extra word, assigned a magic value, and checked on every occasion that
the magic value was still unchanged.
That debug code is unused, the extra long word complicates code a bit.
Get rid of it.
When we set or clear bits in a bitmap page,
also set a flag in the page->private pointer.
This allows us to skip writes of unchanged pages.
Our on-disk bitmap is a little endian bitstream.
Up to now, we have stored the in-core copy of that in
native endian, applying byte order conversion when necessary.
Instead, keep the bitmap pages little endian, as they are read from disk,
and use the generic_*_le_bit family of functions.
We trusted the on-disk bitmap to have unused bits cleared.
In case that is not true for whatever reason,
and we take a code path where the unused bits don't get cleared
elsewhere (bm_clear_surplus is not called), we may miscount the bits,
and get confused during resync, waiting for bits to get cleared that we
don't even use: the resync process would not terminate.
Fix this by masking out unused bits in __bm_count_bits.
The FAULT_ACTIVE macro just wraps the drbd_insert_fault macro for no
apparent reason.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
When the complete device is marked as out of sync, we can disable
updates of the on disk AL. Currently AL updates are only disabled
if one uses the "invalidate-remote" command on an unconnected,
primary device, or when at attach time all bits in the bitmap are
set.
As of now, AL updated do not get disabled when a all bits becomes
set due to application writes to an unconnected DRBD device.
While this is a missing feature, it is not considered important,
and might get added later.
BTW, after initializing a "one legged" DRBD device
drbdadm create-md resX
drbdadm -- --force primary resX
AL updates also get disabled, until the first connect.
The "surplus" bits of the old (smaller) bitmap must be clean
in case of online-grow without resync.
Note: Reverted 67ae8b80d4a116ab3b7094eb3723506b20c06dff as
well, since the lines added by this patch are redundant. The
bits get set by the bm_set_surplus(b) call before that.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits)
cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch
loop: Update mtime when writing using aops
block: expose the statistics in blkio.time and blkio.sectors for the root cgroup
backing-dev: Handle class_create() failure
Block: Fix block/elevator.c elevator_get() off-by-one error
drbd: lc_element_by_index() never returns NULL
cciss: unlock on error path
cfq-iosched: Do not merge queues of BE and IDLE classes
cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging
i2o: Remove the dangerous kobj_to_i2o_device macro
block: remove 16 bytes of padding from struct request on 64bits
cfq-iosched: fix a kbuild regression
block: make CONFIG_BLK_CGROUP visible
Remove GENHD_FL_DRIVERFS
block: Export max number of segments and max segment size in sysfs
block: Finalize conversion of block limits functions
block: Fix overrun in lcm() and move it to lib
vfs: improve writeback_inodes_wb()
paride: fix off-by-one test
drbd: fix al-to-on-disk-bitmap for 4k logical_block_size
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The bm_change semaphore is semantically a mutex. Convert it to a real
mutex.
