path: root/drivers/base/topology.c
2009-01-07topology: Fix sparc64 build.David Miller
Due to changeset ba84be2338d3a2b6020d39279335bb06fcd332e1 ("remove linux/hardirq.h from asm-generic/local.h") the sparc64 build started failing on drivers/base/topology.c: drivers/base/topology.c: In function ‘show_physical_package_id’: drivers/base/topology.c:103: error: implicit declaration of function ‘cpu_data’ drivers/base/topology.c:103: error: request for member ‘proc_id’ in something not a structure or union drivers/base/topology.c: In function ‘show_core_id’: drivers/base/topology.c:106: error: request for member ‘core_id’ in something not a structure or union Adding the obvious fix of including asm/cpudata.h into asm/topology.h on sparc64 doesn't fix it, in fact it makes things worse because of the header file dependency chain: linux/gfp.h --> linux/mmzone.h --> linux/topology.h --> asm/topology.h --> asm/cpudata.h --> linux/percpu.h --> linux/slab.h which results in: include/linux/slub_def.h: In function ‘kmalloc_large’: include/linux/slub_def.h:209: error: implicit declaration of function ‘__get_free_pages’ include/linux/slub_def.h:209: error: ‘__GFP_COMP’ undeclared (first use in this function) include/linux/slub_def.h:209: error: (Each undeclared identifier is reported only once include/linux/slub_def.h:209: error: for each function it appears in.) include/linux/slub_def.h:209: warning: cast to pointer from integer of different size The simplest thing to do is to add yet another one-off hack like parts of the guilty changeset did, by putting an explicit linux/hardirq.h include into drivers/base/topology.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge branch 'core/topology' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/topology' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: cputopology: always define CPU topology information, clean up cpu topology: always define CPU topology information
2008-07-08x86: cleanup early per cpu variables/accesses v4Mike Travis
* Introduce a new PER_CPU macro called "EARLY_PER_CPU". This is used by some per_cpu variables that are initialized and accessed before there are per_cpu areas allocated. ["Early" in respect to per_cpu variables is "earlier than the per_cpu areas have been setup".] This patchset adds these new macros: DEFINE_EARLY_PER_CPU(_type, _name, _initvalue) EXPORT_EARLY_PER_CPU_SYMBOL(_name) DECLARE_EARLY_PER_CPU(_type, _name) early_per_cpu_ptr(_name) early_per_cpu_map(_name, _idx) early_per_cpu(_name, _cpu) The DEFINE macro defines the per_cpu variable as well as the early map and pointer. It also initializes the per_cpu variable and map elements to "_initvalue". The early_* macros provide access to the initial map (usually setup during system init) and the early pointer. This pointer is initialized to point to the early map but is then NULL'ed when the actual per_cpu areas are setup. After that the per_cpu variable is the correct access to the variable. The early_per_cpu() macro is not very efficient but does show how to access the variable if you have a function that can be called both "early" and "late". It tests the early ptr to be NULL, and if not then it's still valid. Otherwise, the per_cpu variable is used instead: #define early_per_cpu(_name, _cpu) \ (early_per_cpu_ptr(_name) ? \ early_per_cpu_ptr(_name)[_cpu] : \ per_cpu(_name, _cpu)) A better method is to actually check the pointer manually. In the case below, numa_set_node can be called both "early" and "late": void __cpuinit numa_set_node(int cpu, int node) { int *cpu_to_node_map = early_per_cpu_ptr(x86_cpu_to_node_map); if (cpu_to_node_map) cpu_to_node_map[cpu] = node; else per_cpu(x86_cpu_to_node_map, cpu) = node; } * Add a flag "arch_provides_topology_pointers" that indicates pointers to topology cpumask_t maps are available. Otherwise, use the function returning the cpumask_t value. This is useful if cpumask_t set size is very large to avoid copying data on to/off of the stack. * The coverage of CONFIG_DEBUG_PER_CPU_MAPS has been increased while the non-debug case has been optimized a bit. * Remove an unreferenced compiler warning in drivers/base/topology.c * Clean up #ifdef in setup.c For inclusion into sched-devel/latest tree. Based on: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git + sched-devel/latest .../mingo/linux-2.6-sched-devel.git Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-06-13cputopology: always define CPU topology information, clean upBen Hutchings
simplify drivers/base/topology.c a bit. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-13cpu topology: always define CPU topology informationBen Hutchings
This can result in an empty topology directory in sysfs, and requires in-kernel users to protect all uses with #ifdef - see <http://marc.info/?l=linux-netdev&m=120639033904472&w=2>. The documentation of CPU topology specifies what the defaults should be if only partial information is available from the hardware. So we can provide these defaults as a fallback. This patch: - Adds default definitions of the 4 topology macros to <linux/topology.h> - Changes drivers/base/topology.c to use the topology macros unconditionally and to cope with definitions that aren't lvalues - Updates documentation accordingly [ From: Andrew Morton <akpm@linux-foundation.org> - fold now-duplicated code - fix layout ] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Mike Travis <travis@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: John Hawkes <hawkes@sgi.com> Cc: Zhang, Yanmin <yanmin.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpumask: use new cpus_scnprintf functionMike Travis
* Cleaned up references to cpumask_scnprintf() and added new cpulist_scnprintf() interfaces where appropriate. * Fix some small bugs (or code efficiency improvments) for various uses of cpumask_scnprintf. * Clean up some checkpatch errors. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18cpu hotplug: topology: remove topology_dev_mapAkinobu Mita
By previous cpu hotplug notifier change, we don't need to track topology_dev existence for each cpu by topology_dev_map. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01cpu topology: consider sysfs_create_group return valueHeiko Carstens
Take return value of sysfs_create_group() into account. That function got called in case of CPU_ONLINE notification. Since callbacks are not allowed to fail on CPU_ONLINE notification do the sysfs group creation on CPU_UP_PREPARE notification. Also remember if creation succeeded in a bitmask. So it's possible to know whether it's legal to call sysfs_remove_group or not. In addition some other minor stuff: - since CPU_UP_PREPARE might fail add CPU_UP_CANCELED handling as well. - use hotcpu_notifier instead of register_hotcpu_notifier. - #ifdef code that isn't needed in the !CONFIG_HOTPLUG_CPU case. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18driver core fixes: sysfs_create_group() retval in topology.cCornelia Huck
Return the return value of sysfs_create_group() in topology_add_dev(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] cpu hotplug: use hotplug version of registration in late initsChandra Seetharaman
Use hotplug version of register_cpu_notifier in late init functions. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: make cpu_notifier related notifier blocks __cpuinit onlyChandra Seetharaman
Make notifier_blocks associated with cpu_notifier as __cpuinitdata. __cpuinitdata makes sure that the data is init time only unless CONFIG_HOTPLUG_CPU is defined. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Export cpu topology in sysfsZhang, Yanmin
The patch implements cpu topology exportation by sysfs. Items (attributes) are similar to /proc/cpuinfo. 1) /sys/devices/system/cpu/cpuX/topology/physical_package_id: represent the physical package id of cpu X; 2) /sys/devices/system/cpu/cpuX/topology/core_id: represent the cpu core id to cpu X; 3) /sys/devices/system/cpu/cpuX/topology/thread_siblings: represent the thread siblings to cpu X in the same core; 4) /sys/devices/system/cpu/cpuX/topology/core_siblings: represent the thread siblings to cpu X in the same physical package; To implement it in an architecture-neutral way, a new source file, driver/base/topology.c, is to export the 5 attributes. If one architecture wants to support this feature, it just needs to implement 4 defines, typically in file include/asm-XXX/topology.h. The 4 defines are: #define topology_physical_package_id(cpu) #define topology_core_id(cpu) #define topology_thread_siblings(cpu) #define topology_core_siblings(cpu) The type of **_id is int. The type of siblings is cpumask_t. To be consistent on all architectures, the 4 attributes should have deafult values if their values are unavailable. Below is the rule. 1) physical_package_id: If cpu has no physical package id, -1 is the default value. 2) core_id: If cpu doesn't support multi-core, its core id is 0. 3) thread_siblings: Just include itself, if the cpu doesn't support HT/multi-thread. 4) core_siblings: Just include itself, if the cpu doesn't support multi-core and HT/Multi-thread. So be careful when declaring the 4 defines in include/asm-XXX/topology.h. If an attribute isn't defined on an architecture, it won't be exported. Thank Nathan, Greg, Andi, Paul and Venki. The patch provides defines for i386/x86_64/ia64. Signed-off-by: Zhang, Yanmin <yanmin.zhang@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
