path: root/drivers/base/sys.c
2009-07-28driver core: sysdev: do not send KOBJ_ADD uevent if kobject_init_and_add failsXiaotian Feng
If kobject_init_and_add fails, sysdev_register should not send KOBJ_ADD uevent to userspace. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15driver core: fix gcc 4.3.3 warnings about string literalsGreg Kroah-Hartman
This removes the warning: format not a string literal and no format arguments warnings in the driver core that gcc 4.3.3 complains about. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15driver-core: make sysdev_class_register check kobject_set_name return valueDave Young
sysdev_class_register should check the kobject_set_name return value. Add the return value checking code. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12PM: Warn if interrupts are enabled during suspend-resume of sysdevsRafael J. Wysocki
Sysdevs have to be suspended and resumed with interrupts disabled and things usually break in a way that's difficult to debug if one of sysdev drivers enables interrupts by mistake during suspend or resume. Add extra checks that will generate warnings in such cases. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-30PM: Rework handling of interrupts during suspend-resumeRafael J. Wysocki
Use the functions introduced in by the previous patch, suspend_device_irqs(), resume_device_irqs() and check_wakeup_irqs(), to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). In addition, since the device interrups are now disabled before the CPU has turned all interrupts off and the CPU will ACK the interrupts setting the IRQ_PENDING bit for them, check in sysdev_suspend() if any wake-up interrupts are pending and abort suspend if that's the case. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-03-30trivial: fix typo "thier" -> "their"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24Driver core: some cleanup on drivers/base/sys.cZhenwen Xu
do some cleanup on drivers/base/sys.c Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-22PM: Split up sysdev_[suspend|resume] from device_power_[down|up], fixIngo Molnar
Impact: module build fix Fix: ERROR: "sysdev_resume" [arch/x86/kernel/apm.ko] undefined! ERROR: "sysdev_suspend" [arch/x86/kernel/apm.ko] undefined! As these APIs are now used by the APM driver, which can be built as a module. Also fix a few extra (and inconsistent) newlines in comment blocks preceding these functions. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-29sysfs: Fix return values for sysdev_store_{ulong,int}Andi Kleen
SYSFS: Fix return values for sysdev_store_{ulong,int} Always return the full size instead of the consumed length of the string in sysdev_store_{ulong,int} This avoids EINVAL errors in some echo versions. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-29driver core: drivers/base/sys.c: update commentsQinghuang Feng
There are no functions named sys_device_shutdown or sys_device_suspend in the kernel. They should be fixed to sysdev_shutdown and sysdev_suspend respectively. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26Use WARN() in drivers/base/Arjan van de Ven
Use WARN() instead of a printk+WARN_ON() pair; this way the message becomes part of the warning section for better reporting/collection. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21sysdev: Add utility functions for simple int/ulong variable sysdev attributesAndi Kleen
This adds a new sysdev_ext_attribute that stores a pointer to the variable it manages and some utility functions/macro to easily use them. Previously all users wrote custom macros to generate show/store functions for each variable, with this it is possible to avoid that in many cases. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: fix debugging statements in registration code.Ben Dooks
The systdev_class_register() and sysdev_register() functions have pr_debug() statements which are enabled when the user selects the driver core debug. Both of these routines do not produce the correct output, as they make assumptions about data which has not been initialised. In sysdev_class_register() the code uses the kobject_name(&cls->kset.kobj) at the start of the function, but this is not setup until later in the same call. Change this to use cls->name which is passed in from the caller. The sysdev_register() function tries to get the name of the sysdev by kobject_name(&sysdev->kobj), but that isn't setup until later in the same function so change this message to use the name of the sysdev's class and add another message once the name is initialised. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-06Fix bogus warning in sysdev_driver_register()OGAWA Hirofumi
if ((drv->entry.next != drv->entry.prev) || (drv->entry.next != NULL)) { warns list_empty(&drv->entry). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Greg KH <gregkh@suse.de> Cc: Len Brown <lenb@kernel.org> [ Version 2 totally redone based on suggestions from Linus & Greg ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19driver core: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19sysdev: detect multiple driver registrationsBen Dooks
I've just found how easy it is to accidentally register a sysdev_driver for two different classes. When this happens, bad things happen as the sysdev_driver structure keeps has the list entry for the driver registration. The following patch makes a WARN_ON() if this happens, although I think BUG_ON or returning -EAGAIN could also be valid responses to this. Signed-off-by: Ben Dooks <ben@fluff.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10sysdev: fix problem with sysdev_class being re-registeredGreg Kroah-Hartman
We need to initialize the kobject for a sysdev_class as it could have been recycled (stupid static kobjects...) We also do the same thing in case sysdev devices are being re-registered. Thanks to Balaji Rao <balajirrao@gmail.com> for pointing out the problem. Signed-off-by: Balaji Rao <balajirrao@gmail.com> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change drivers/base/sys.c to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/devices/system to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/devices to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename devices_subsys to devices_kset to catch all users of the variable. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12sysdev: remove global sysdev drivers listAkinobu Mita
No one uses sysdev_drivers. Because no one calls sysdev_driver_register with NULL class. And it is difficult to imagine that someone want to implement a global sysdev driver which is called with all sys_device on any kind of sysdev_class. So this patch removes global sysdev_drivers list and update comments for this change. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: remove kset_set_kset_sGreg Kroah-Hartman
This macro is only used by the driver core and is held over from when we had subsystems. It is not needed anymore. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysdev: use mutex instead of semaphoreMatthias Kaehlcke
The sysdev code use a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver Core: Allow sysdev_class have attributesShaohua Li
allow sysdev_class adding attribute. Next patch will use the new API to add an attribute under /sys/device/system/cpu/. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] drivers/base/: proper prototypesAdrian Bunk
This patch contains the following changes: - move prototypes to base.h - sys.c should #include "base.h" for getting the prototype of it's global function system_bus_init() Note that hidden in this patch there's a bugfix: Caller and callee disagreed regarding the return type of sysdev_shutdown(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] Driver core: hande sysdev suspend failureShaohua Li
This patch adds the return value check for sysdev suspend and does restore in failure case. Send the patch to pm-list, but seems lost, so I resend it. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] ACPI poweroff fixAlexey Starikovskiy
Register an "acpi" system device to be notified of shutdown preparation. This depends on CONFIG_PM http://bugzilla.kernel.org/show_bug.cgi?id=4041 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-06-20[PATCH] sysfs: (driver/base) if show/store is missing return -EIODmitry Torokhov
sysfs: fix drivers/base so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-16[PATCH] pm_message_t: more fixes in common and i386Pavel Machek
I thought I'm done with fixing u32 vs. pm_message_t ... unfortunately that turned out not to be the case as Russel King pointed out. Here are fixes for Documentation and common code (mainly system devices). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
