* 'for-linus' of git://opensource.wolfsonmicro.com/regmap: (62 commits)
mfd: Enable rbtree cache for wm831x devices
regmap: Support some block operations on cached devices
regmap: Allow caches for devices with no defaults
regmap: Ensure rbtree syncs registers set to zero properly
regmap: Allow rbtree to cache zero default values
regmap: Warn on raw I/O as well as bulk reads that bypass cache
regmap: Return a sensible error code if we fail to read the cache
regmap: Use bsearch() to search the register defaults
regmap: Fix doc comment
regmap: Optimize the lookup path to use binary search
regmap: Ensure we scream if we enable cache bypass/only at the same time
regmap: Implement regcache_cache_bypass helper function
regmap: Save/restore the bypass state upon syncing
regmap: Lock the sync path, ensure we use the lockless _regmap_write()
regmap: Fix apostrophe usage
regmap: Make _regmap_write() global
regmap: Fix lock used for regcache_cache_only()
regmap: Grab the lock in regcache_cache_only()
regmap: Modify map->cache_bypass directly
regmap: Fix regcache_sync generic implementation
No longer used as users link directly with the bus types so the core
module infrastructure does refcounting for us.
Commit b33f9cbd67ba ("regmap: Specify a module license") added a
MODULES_LICENSE to this file without adding an include of module.h.
module.h should have been included anyway, since this file has
EXPORT_SYMBOLs as well. With the pending module.h split up, this would
probably have caused build problems.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_REGMAP_I2C/SPI are set to m when selected by a tristate config
option that's set to m. The regmap modules don't specify a license, so
fail to link to regmap_init at load time, since that is EXPORT_SYMBOL_GPL.
Fix this by specifying a license for the regmap modules.
We no longer enumerate the bus types, we rely on the driver telling us
this on init.
Acked-by: Liam Girdwood <lrg@ti.com>
