In 3245d460 (regmap: cache: Fall back to register by register read for
cache defaults) non-readable registers are skipped when initializing
reg_defaults, but are still included in num_reg_defaults. So there can
be uninitialized entries at the end of reg_defaults, which can cause
problems when the register cache initializes from the full array.
Fixed it by excluding non-readable registers from the count as well.
Signed-off-by: Maarten ter Huurne <maarten@treewalker.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
Setting the flag 'cache_bypass' will bypass the cache not the hardware.
Fix this comment here.
Fixes: 0eef6b0415f5 ("regmap: Fix doc comment")
Signed-off-by: Andrew F. Davis <afd@ti.com>
If we are unable to read the cache defaults for a regmap then fall back
on attempting to read them word by word. This is going to be painfully
slow for large regmaps but might be adequate for smaller ones.
[maciej: Use cache_bypass around read and skipping of unreadable regs]
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
regcache_hw_init() uses regmap_raw_read() to initialize cache
when reg_defaults_raw isn't provided.
The last parameter to regmap_raw_read() is buffer size in bytes,
however regcache_hw_init() called it with number of registers
to read instead, which cause problem if they aren't one byte
wide in cache.
This wasn't triggered by any of current in-tree drivers
since they either have one-byte registers or provide
reg_defaults_raw explicitly.
'regmap/topic/irq-type' into regmap-next
If the register defaults are provided by the driver without the
number by mistake, it should just return an error with one promotion.
This should be as early as possible, then there is no need to verify
the register defaults' stride and the other code followed.
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
If there is no cache used for the drivers, the register defaults
or the register defaults raw are not need any more. This patch
will check this and print a warning.
Since the mmio has support the 64-bit has been supported for the
64-bit platform, so should the regcache core too.
There will be some warning like the following when checking new
patches near this code:
"WARNING: Missing a blank line after declarations"
This patch will suppress this warning.
Its a bit odd that debugfs_create_bool() takes 'u32 *' as an argument,
when all it needs is a boolean pointer.
It would be better to update this API to make it accept 'bool *'
instead, as that will make it more consistent and often more convenient.
Over that bool takes just a byte.
That required updates to all user sites as well, in the same commit
updating the API. regmap core was also using
debugfs_{read|write}_file_bool(), directly and variable types were
updated for that to be bool as well.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
use_single_rw currently reflects the capabilities of the connected
device. The capabilities of the bus are currently missing for this
variable.
As there are read only and write only buses we need seperate values for
use_single_rw to also reflect tha capabilities of the bus.
This patch splits use_single_rw into use_single_read and
use_single_write. The initialization is changed to check the
configuration for use_single_rw and to check the capabilities of the
used bus.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Existing regmap users call regcache_mark_dirty() as part of the
suspend/resume sequence, to tell regcache that non-default values need to
be resynced post-resume. Add an internal "no_sync_defaults" regmap flag
to remember this state, so that regcache_sync() can differentiate between
these two cases:
1) HW was reset, so any cache values that match map->reg_defaults can be
safely skipped. On some chips there are a lot of registers in the
reg_defaults list, so this optimization speeds things up quite a bit.
2) HW was not reset (maybe it was just clock-gated), so if we cached
any writes, they should be sent to the hardware regardless of whether
they match the HW default. Currently this will write out all values in
the regcache, since we don't maintain per-register dirty bits.
Suggested-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
We're going to add another "does this register need syncing?" check, so
rather than repeating it in three places, we'll separate all of the
relevant logic into a helper function.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap update from Mark Brown:
"Just one patch for regmap this time around, a change from Steven
Rostedt to prettify the way we're making the regmap internal header
available to the trace events (it turns out that the trace subsystem
doesn't actually need to be in trace/events)"
* tag 'regmap-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: Move tracing header into drivers/base/regmap
Pull regmap fix from Mark Brown:
"This patch fixes a bad interaction between the support that was added
for having regmaps without devices for early system controller
initialization and the trace support.
There's a very good analysis of the actual issue in the commit message
for the change"
* tag 'regmap-fix-v4.0-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: introduce regmap_name to fix syscon regmap trace events
The tracing events for regmap are confined to the regmap subsystem. It
also requires accessing an internal header. Instead of including the
internal header from a generic file location, move the tracing file
into the regmap directory.
Also rename the regmap tracing header to trace.h, as it is redundant to
keep the regmap.h name when it is in the regmap directory.
This patch fixes a NULL pointer dereference when enabling regmap event
tracing in the presence of a syscon regmap, introduced by commit bdb0066df96e
("mfd: syscon: Decouple syscon interface from platform devices").
That patch introduced syscon regmaps that have their dev field set to NULL.
The regmap trace events expect it to point to a valid struct device and feed
it to dev_name():
$ echo 1 > /sys/kernel/debug/tracing/events/regmap/enable
Unable to handle kernel NULL pointer dereference at virtual address 0000002c
pgd = 80004000
[0000002c] *pgd=00000000
Internal error: Oops: 17 [#1] SMP ARM
Modules linked in: coda videobuf2_vmalloc
CPU: 0 PID: 304 Comm: kworker/0:2 Not tainted 4.0.0-rc2+ #9197
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
Workqueue: events_freezable thermal_zone_device_check
task: 9f25a200 ti: 9f1ee000 task.ti: 9f1ee000
PC is at ftrace_raw_event_regmap_block+0x3c/0xe4
LR is at _regmap_raw_read+0x1bc/0x1cc
pc : [<803636e8>] lr : [<80365f2c>] psr: 600f0093
sp : 9f1efd78 ip : 9f1efdb8 fp : 9f1efdb4
r10: 00000004 r9 : 00000001 r8 : 00000001
r7 : 00000180 r6 : 00000000 r5 : 9f00e3c0 r4 : 00000003
r3 : 00000001 r2 : 00000180 r1 : 00000000 r0 : 9f00e3c0
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 2d91004a DAC: 00000015
Process kworker/0:2 (pid: 304, stack limit = 0x9f1ee210)
Stack: (0x9f1efd78 to 0x9f1f0000)
fd60: 9f1efda4 9f1efd88
fd80: 800708c0 805f9510 80927140 800f0013 9f1fc800 9eb2f490 00000000 00000180
fda0: 808e3840 00000001 9f1efdfc 9f1efdb8 80365f2c 803636b8 805f8958 800708e0
fdc0: a00f0013 803636ac 9f16de00 00000180 80927140 9f1fc800 9f1fc800 9f1efe6c
fde0: 9f1efe6c 9f732400 00000000 00000000 9f1efe1c 9f1efe00 80365f70 80365d7c
fe00: 80365f3c 9f1fc800 9f1fc800 00000180 9f1efe44 9f1efe20 803656a4 80365f48
fe20: 9f1fc800 00000180 9f1efe6c 9f1efe6c 9f732400 00000000 9f1efe64 9f1efe48
fe40: 803657bc 80365634 00000001 9e95f910 9f1fc800 9f1efeb4 9f1efe8c 9f1efe68
fe60: 80452ac0 80365778 9f1efe8c 9f1efe78 9e93d400 9e93d5e8 9f1efeb4 9f72ef40
fe80: 9f1efeac 9f1efe90 8044e11c 80452998 8045298c 9e93d608 9e93d400 808e1978
fea0: 9f1efecc 9f1efeb0 8044fd14 8044e0d0 ffffffff 9f25a200 9e93d608 9e481380
fec0: 9f1efedc 9f1efed0 8044fde8 8044fcec 9f1eff1c 9f1efee0 80038d50 8044fdd8
fee0: 9f1ee020 9f72ef40 9e481398 00000000 00000008 9f72ef54 9f1ee020 9f72ef40
ff00: 9e481398 9e481380 00000008 9f72ef40 9f1eff5c 9f1eff20 80039754 80038bfc
ff20: 00000000 9e481380 80894100 808e1662 00000000 9e4f2ec0 00000000 9e481380
ff40: 800396f8 00000000 00000000 00000000 9f1effac 9f1eff60 8003e020 80039704
ff60: ffffffff 00000000 ffffffff 9e481380 00000000 00000000 9f1eff78 9f1eff78
ff80: 00000000 00000000 9f1eff88 9f1eff88 9e4f2ec0 8003df30 00000000 00000000
ffa0: 00000000 9f1effb0 8000eb60 8003df3c 00000000 00000000 00000000 00000000
ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
Backtrace:
[<803636ac>] (ftrace_raw_event_regmap_block) from [<80365f2c>] (_regmap_raw_read+0x1bc/0x1cc)
r9:00000001 r8:808e3840 r7:00000180 r6:00000000 r5:9eb2f490 r4:9f1fc800
[<80365d70>] (_regmap_raw_read) from [<80365f70>] (_regmap_bus_read+0x34/0x6c)
r10:00000000 r9:00000000 r8:9f732400 r7:9f1efe6c r6:9f1efe6c r5:9f1fc800
r4:9f1fc800
[<80365f3c>] (_regmap_bus_read) from [<803656a4>] (_regmap_read+0x7c/0x144)
r6:00000180 r5:9f1fc800 r4:9f1fc800 r3:80365f3c
[<80365628>] (_regmap_read) from [<803657bc>] (regmap_read+0x50/0x70)
r9:00000000 r8:9f732400 r7:9f1efe6c r6:9f1efe6c r5:00000180 r4:9f1fc800
[<8036576c>] (regmap_read) from [<80452ac0>] (imx_get_temp+0x134/0x1a4)
r6:9f1efeb4 r5:9f1fc800 r4:9e95f910 r3:00000001
[<8045298c>] (imx_get_temp) from [<8044e11c>] (thermal_zone_get_temp+0x58/0x74)
r7:9f72ef40 r6:9f1efeb4 r5:9e93d5e8 r4:9e93d400
[<8044e0c4>] (thermal_zone_get_temp) from [<8044fd14>] (thermal_zone_device_update+0x34/0xec)
r6:808e1978 r5:9e93d400 r4:9e93d608 r3:8045298c
[<8044fce0>] (thermal_zone_device_update) from [<8044fde8>] (thermal_zone_device_check+0x1c/0x20)
r5:9e481380 r4:9e93d608
[<8044fdcc>] (thermal_zone_device_check) from [<80038d50>] (process_one_work+0x160/0x3d4)
[<80038bf0>] (process_one_work) from [<80039754>] (worker_thread+0x5c/0x4f4)
r10:9f72ef40 r9:00000008 r8:9e481380 r7:9e481398 r6:9f72ef40 r5:9f1ee020
r4:9f72ef54
[<800396f8>] (worker_thread) from [<8003e020>] (kthread+0xf0/0x108)
r10:00000000 r9:00000000 r8:00000000 r7:800396f8 r6:9e481380 r5:00000000
r4:9e4f2ec0
[<8003df30>] (kthread) from [<8000eb60>] (ret_from_fork+0x14/0x34)
r7:00000000 r6:00000000 r5:8003df30 r4:9e4f2ec0
Code: e3140040 1a00001a e3140020 1a000016 (e596002c)
---[ end trace 193c15c2494ec960 ]---
Fixes: bdb0066df96e (mfd: syscon: Decouple syscon interface from platform devices)
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Cc: stable@vger.kernel.org
regcache_sync() spews warnings when a value was cached for a read-only
register as it tries to write all registers no matter whether they are
writable or not. This patch adds regmap_wrtieable() checks for
avoiding it in regcache_sync_block_single() and regcache_block_raw().
'regmap/topic/headers' into regmap-next
If the inlcude headers aren't sorted alphabetically, then the
logical choice is to append new ones, however that creates a
lot of potential for conflicts or duplicates because every change
will then add new includes in the same location.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
When all the registers are volatile(unlikely, but logically and mostly
will happen for some 'device' who has very few registers), then the
count will be euqal to 0, then kmalloc() will return ZERO_SIZE_PTR,
which equals to ((void *)16).
So this patch fix this with just doing the zero check before calling
kmalloc(). If the count == 0, so we can make sure that all the registers
are volatile, so no cache is need.
This patch fixes checkpatch.pl warning for regmap cache.
WARNING : prefer kmalloc_array over kmalloc with multiply
This may speed regcache_hw_init() up for some cases that there
has volatile registers.
When kmalloc() fails, we should return -ENOMEM.
Remove the redundant code for regmap cache.
Call stack of regcache_sync calls may not emit any error message even if
operation was cancelled due an error in I/O driver. One such a silent error
is for instance if I2C bus driver doesn't receive ACK from the I2C device
and returns -EREMOTEIO.
Since many users of regcache_sync() don't check and print the error there is
no any indication that HW registers are potentially out of sync.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
If the device can't support block writes then don't attempt to use raw
syncing which will automatically generate block writes for adjacent
registers, use the existing _single() block syncing implementation.
Reported-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
'regmap/topic/lock', 'regmap/topic/mmio', 'regmap/topic/nodev', 'regmap/topic/parse-val' and 'regmap/topic/patch' into regmap-next
In the regcache_default_sync, if a register isn't writeable, then
_regmap_write will return an error and the rest of the sync will be
aborted. Avoid this by checking if a register is writeable before
trying to sync it.
Signed-off-by: Dylan Reid <dgreid@chromium.org>
The default sync operation was still assuming a stride of one, fix it
to respect the reg_stride set in the map.
Currently, we check the registers in the patch are aligned to the
register stride everytime we sync the cache and the first time the patch
is written out is unchecked.
This patch checks the register patch when we first register it so the
first writes are no longer unchecked and then doesn't check on
subsequent syncs as the patch will be unchanged.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
regcache_sync_block_raw_flush takes the address of the base register
and the address of one past the last register to write to. "count" is
the number of registers in the range, not the number of bytes, it
should be (end addr - start addr) / stride. Without accounting for
strides greater than one, registers past the end might be synced or
the writeable_reg callback at the beginning of _regmap_raw_write will
fail and nothing will be written.
Try to speed up I/O a little by not synchronising until we are finished
scheduling writes. A brief survey of existing users suggests we have none
that would currently benefit from an async cache sync.
Rather than passing a flag around through the entire call stack store it
in the regmap struct and read it when required. This minimises the
visibility of the feature through the API, minimising the code updates
needed to use it more widely.
With devices which have a dense and small register map but placed at a large
offset the global cache_present bitmap imposes a huge memory overhead. Making
the cache_present per rbtree node avoids the issue and easily reduces the memory
footprint by a factor of ten. For devices with a more sparse map or without a
large base register offset the memory usage might increase slightly by a few
bytes, but not significantly. E.g. for a device which has ~50 registers at
offset 0x4000 the memory footprint of the register cache goes down form 2496
bytes to 175 bytes.
Moving the bitmap to a per node basis means that the handling of the bitmap is
now cache implementation specific and can no longer be managed by the core. The
regcache_sync_block() function is extended by a additional parameter so that the
cache implementation can tell the core which registers in the block are set and
which are not. The parameter is optional and if NULL the core assumes that all
registers are set. The rbtree cache also needs to implement its own drop
callback instead of relying on the core to handle this.
The regmap_writeable() check should not be done in
regcache_write() because this prevents read-only
registers to be cached. After a read on a read-only
register its value will not be stored in the cache
and the next time someone will try to read it the
value will be read from the bus instead of the
cache.
Instead the regmap_writeable() check should be done
in _regmap_write() to prevent callers from writing
to read-only registers.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
regcache_sync_block_raw_flush() expects the address of the register after last
register that needs to be synced as its parameter. But the last call to
regcache_sync_block_raw_flush() in regcache_sync_block_raw() passes the address
of the last register in the block. This effectively always skips over the last
register in a block, even if it needs to be synced. In order to fix it increase
the address by one register.
The issue was introduced in commit 75a5f89 ("regmap: cache: Write consecutive
registers in a single block write").
Cc: stable@vger.kernel.org # 3.10+
This can be used for cache types for which syncing values one by one is
equally efficient as syncing a range, such as the flat cache.
The parameter passed to the regmap lock/unlock callbacks needs to be
map->lock_arg, regcache passes just map. This works fine in the case that no
custom locking callbacks are used, since in this case map->lock_arg equals map,
but will break when custom locking callbacks are used. The issue was introduced
in commit 0d4529c5 ("regmap: make lock/unlock functions customizable") and is
fixed by this patch.
Allow drivers to discard parts of the register cache, for example if part
of the hardware has been reset.
Fix format specifier in dev_dbg and suppress the following warning
drivers/base/regmap/regcache.c: In function
‘regcache_sync_block_raw_flush’:
drivers/base/regmap/regcache.c:593:2: warning: format ‘%d’ expects
argument of type ‘int’, but argument 4 has type ‘size_t’ [-Wformat]
Signed-off-by: Stratos Karafotis <stratosk@semaphore.gr>
regcache_sync_block_raw is used only in this file. Hence make it static.
Silences the following warning:
drivers/base/regmap/regcache.c:608:5: warning:
symbol 'regcache_sync_block_raw' was not declared. Should it be static?
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
When syncing blocks of data using raw writes combine the writes into a
single block write, saving us bus overhead for setup, addressing and
teardown.
Currently the block write is done unconditionally as it is expected that
hardware which has a register format which can support raw writes will
support auto incrementing writes, this decision may need to be revised in
future.
Reviewed-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
For code clarity after implementing block writes split out the raw and
non-raw I/O sync implementations.
The idea of holding blocks of registers in device format is shared between
at least rbtree and lzo cache formats so split out the loop that does the
sync from the rbtree code so optimisations on it can be reused.
The idea of maintaining a bitmap of present registers is something that
can usefully be used by other cache types that maintain blocks of cached
registers so move the code out of the rbtree cache and into the generic
regcache code.
Refactor the interface slightly as we go to wrap the set bit and enlarge
bitmap operations (since we never do one without the other) and make it
more robust for reads of uncached registers by bounds checking before we
look at the bitmap.
