'regmap/topic/smbus' into regmap-next
We'll need to call it from regmap-i2c.c, which can be built as module.
Signed-off-by: Mark Brown <broonie@kernel.org>
This patch move struct regmap.spinlock_flags into the union of
spinlock, so that we can shrink struct regmap size.
Signed-off-by: Yalin Wang <yalin.wang@sonymobile.com>
this patch change struct regmap->mutex and struct regmap->spinlock
as an union, because these 2 members are only used one of them,
we change it to shrink the struct size.
Commit 6cfec04bcc05 ("regmap: Separate regmap dev initialization") moved the
regmap debugfs initialization after regcache initialization. This means
that the regmap debugfs directory is not created yet when the cache
initialization runs and so any debugfs files registered by the regcache are
created in the debugfs root directory rather than the debugfs directory of
the regmap instance. Fix this by adding a separate callback for the
regcache debugfs initialization which will be called after the parent
debugfs entry has been created.
Fixes: 6cfec04bcc05 (regmap: Separate regmap dev initialization)
Signed-off-by: Mark Brown <broonie@linaro.org>
Cc: stable@vger.kernel.org
This is the implementation of regmap_multi_reg_write()
There is a new capability 'can_multi_write' that device drivers
must set in order to use this multi reg write mode.
This replaces the first definition, which just defined the API.
Signed-off-by: Anthony Olech <anthony.olech.opensource@diasemi.com>
Rather than passing a flag around through the entire call stack store it
in the regmap struct and read it when required. This minimises the
visibility of the feature through the API, minimising the code updates
needed to use it more widely.
Rather than allocating and deallocating the structures used to manage async
transfers each time we do one keep the structures around as long as the
regmap is around. This should provide a small performance improvement.
Current Linux kernel is supporting regmap_field method
and it is very useful feature.
It needs one regmap_filed for one register access.
OTOH, there is multi port device which
has many same registers in the market.
The difference for each register access is
only its address offset.
Current API needs many regmap_field for such device,
but it is not good.
This patch adds new regmap_fileds API which can care
about multi port/offset access via regmap.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
With devices which have a dense and small register map but placed at a large
offset the global cache_present bitmap imposes a huge memory overhead. Making
the cache_present per rbtree node avoids the issue and easily reduces the memory
footprint by a factor of ten. For devices with a more sparse map or without a
large base register offset the memory usage might increase slightly by a few
bytes, but not significantly. E.g. for a device which has ~50 registers at
offset 0x4000 the memory footprint of the register cache goes down form 2496
bytes to 175 bytes.
Moving the bitmap to a per node basis means that the handling of the bitmap is
now cache implementation specific and can no longer be managed by the core. The
regcache_sync_block() function is extended by a additional parameter so that the
cache implementation can tell the core which registers in the block are set and
which are not. The parameter is optional and if NULL the core assumes that all
registers are set. The rbtree cache also needs to implement its own drop
callback instead of relying on the core to handle this.
In the initial case when no reg_defaults values are
provided and no register value was added to the cache
yet, the cache_present bitmap is NULL. If this function
is invoked for any register it should return false
(i.e. the register is not cached) instead of true.
Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com>
It is common to access regmap registers at bit level, using
regmap_update_bits or regmap_read functions, however the end user has to
take care of a mask or shifting. This becomes overhead when such use
cases are high. Having a common function to do this is much convenient
and less error prone.
The idea of regmap_field is simple, regmap_field gives a logical
structure to bits of the regmap register, and the driver can use this
logical entity without the knowledge of the bit positions and masks all
over the code. This way code looks much neat and it need not handle the
masks, shifts every time it access the those entities.
With this new regmap_field_read/write apis the end user can setup a
regmap field using regmap_field_init and use the return regmap_field to
read write the register field without worrying about the masks or
shifts.
Also this apis will be useful for drivers which are based on regmaps,
like some clocks or pinctrls which can work on the regmap_fields
directly without having to worry about bit positions.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
regmap-mmio uses a spinlock with spin_lock() and spin_unlock() for locking.
To be able to use the regmap API from different contexts (atomic vs non-atomic),
without the risk of race conditions, we need to use spin_lock_irqsave() and
spin_lock_irqrestore() instead. A new field, the spinlock_flags field, is added
to regmap struct to store the flags between regmap_{,un}lock_spinlock(). The
spinlock_flags field itself is also protected by the spinlock.
Thanks to Stephen Warren for the suggestion of this particular solution.
Allow drivers to discard parts of the register cache, for example if part
of the hardware has been reset.
The idea of holding blocks of registers in device format is shared between
at least rbtree and lzo cache formats so split out the loop that does the
sync from the rbtree code so optimisations on it can be reused.
Reviewed-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
The idea of maintaining a bitmap of present registers is something that
can usefully be used by other cache types that maintain blocks of cached
registers so move the code out of the rbtree cache and into the generic
regcache code.
Refactor the interface slightly as we go to wrap the set bit and enlarge
bitmap operations (since we never do one without the other) and make it
more robust for reads of uncached registers by bounds checking before we
look at the bitmap.
Provide a helper to do the size based index into a block of registers and
use it when reading a value.
This allows the cache to sync values directly to the device when stored
in native format and also allows asynchronous I/O.
This file lists the register ranges in the register map. The condition
to split the range is based on whether the block is readable or not.
Ensure that we lock the `debugfs_off_cache' list whenever we access
and modify the list. There is a possible race otherwise between the
read() operations of the `registers' file and the `range' file.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Currently the value parsing operations both return the parsed value and
modify the passed buffer. This precludes their use in places like the cache
code so split out the in place modification into a new parse_inplace()
operation.
It's more idiomatic to pass the map structure around and this means we
can use other bits of information from the map.
We are keeping track of the maximum register as well, this will make
things easier for us in sharing this code with the code implementing
the register ranges functionality. It also simplifies a bit the
calculations when looking for the relevant block:offset from within
the cache.
Some use cases like firmware download can transfer a lot of data in quick
succession. With high speed buses these use cases can benefit from having
multiple transfers scheduled at once since this allows the bus to minimise
the delay between transfers.
Support this by adding regmap_raw_write_async(), allowing raw transfers to
be scheduled, and regmap_async_complete() to wait for them to finish.
This commit adds provision for "no-bus" usage of the regmap API. In
this configuration user can provide API with two callbacks 'reg_read'
and 'reg_write' which are to be called when reads and writes to one of
device's registers is performed. This is useful for devices that
expose registers but whose register access sequence does not fit the 'bus'
abstraction.
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
This commit is a preparatory commit to provide "no-bus" configuration
option for regmap API. It adds necessary plumbing needed to have the
ability to provide user define register write function.
ability to provide user define register read function.
While for I2C and SPI devices the overhead of using rbtree for devices with
only one block of registers is negligible the same isn't always going to
be true for MMIO devices where the I/O costs are very much lower. Cater
for these devices by adding a simple flat array type for them where the
lookups are simple array accesses, taking us right back to the original
ASoC cache implementation.
Thanks to Magnus Damm for the discussion which prompted this.
Avoid doing a linear scan of the entire register map for each read() of
the debugfs register dump by recording the offsets where valid registers
exist when we first read the registers file. This assumes the set of
valid registers never changes, if this is not the case invalidation of
the cache will be required.
This could be further improved for large blocks of contiguous registers
by calculating the register we will read from within the block - currently
we do a linear scan of the block. An rbtree may also be worthwhile.
No point in calculating them every time.
Many of the regmap enabled drivers implementing one or more of the
readable, writeable, volatile and precious methods use the same code
pattern:
return ((reg >= X && reg <= Y) || (reg >= W && reg <= Z) || ...)
Switch to a data driven approach, using tables to describe
readable/writeable/volatile and precious registers ranges instead.
The table based check can still be overridden by passing the usual function
pointers via struct regmap_config.
Signed-off-by: Davide Ciminaghi <ciminaghi@gnudd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into regmap-table
It is sometimes convenient for a regmap user to override the standard
regmap lock/unlock functions with custom functions.
For instance this can be useful in case an already existing spinlock
or mutex has to be used for locking a set of registers instead of the
internal regmap spinlock/mutex.
Note that the fast_io field of struct regmap_bus is ignored in case
custom locking functions are used.
If a register range is named then provide a debugfs file showing the
contents of the range separately.
For more useful diagnostics.
Devices with register paging or indirectly accessed registers can configure
register mapping to map those on virtual address range. During access to
virtually mapped register range, indirect addressing is processed
automatically, in following steps:
1. selector for page or indirect register is updated (when needed);
2. register in data window is accessed.
Configuration should provide minimum and maximum register for virtual range,
details of selector field for page selection, minimum and maximum register of
data window for indirect access.
Virtual range registers are managed by cache as well as direct access
registers. In order to make indirect access more efficient, selector register
should be declared as non-volatile, if possible.
struct regmap_config is extended with the following:
struct regmap_range_cfg *ranges;
unsigned int n_ranges;
[Also reordered debugfs init to later on since the cleanup code was
conflicting with the new cleanup code for ranges anyway -- broonie]
Signed-off-by: Krystian Garbaciak <krystian.garbaciak@diasemi.com>
'regmap-irq' into regmap-next
Use devres to implement dev_get_regmap(). This should mean that in almost
all cases devices wishing to take advantage of framework features based on
regmap shouldn't need to explicitly pass the regmap into the framework.
This simplifies device setup a bit.
Some devices does not support bulk read and write operations, for them
we have series of single write and read operations.
Signed-off-by: Anthony Olech <Anthony.Olech@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
[Fixed coding style, don't check use_single_rw before assign --broonie ]
regmap_config.reg_stride is introduced. All extant register addresses
are a multiple of this value. Users of serial-oriented regmap busses will
typically set this to 1. Users of the MMIO regmap bus will typically set
this based on the value size of their registers, in bytes, so 4 for a
32-bit register.
Throughout the regmap code, actual register addresses are used. Wherever
the register address is used to index some array of values, the address
is divided by the stride to determine the index, or vice-versa. Error-
checking is added to all entry-points for register address data to ensure
that register addresses actually satisfy the specified stride. The MMIO
bus ensures that the specified stride is large enough for the register
size.
regmap-stride
Commit 79c64d5 "regmap: allow regmap instances to be named" changed the
prototype of regmap_debugfs_init, but didn't update the dummy inline used
when !CONFIG_DEBUGFS. Fix this.
