path: root/drivers/base/firmware_class.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-19driver-core: fix missing kernel-doc in firmware_classRandy Dunlap
Fix kernel-doc warning in firmware_class.c: Warning(drivers/base/firmware_class.c:94): No description found for parameter 'attr' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-19sysfs: use sysfs_bin_attr_init in firmware class driverJiri Kosina
Annotate dynamic sysfs attribute in fw_setup_device(). This gets rid of the following lockdep warning: bnx2 0000:08:00.0: firmware: requesting bnx2/bnx2-mips-06-5.0.0.j6.fw BUG: key ffff880008293470 not in .data! ------------[ cut here ]------------ WARNING: at kernel/lockdep.c:2706 lockdep_init_map+0x562/0x620() Modules linked in: bnx2(+) sg tpm_bios floppy rtc_lib usb_storage i2c_piix4 joydev button container shpchp i2c_core sr_mod cdrom pci_hotplug usbhid hid ohci_hcd ehci_hcd sd_mod usbcore edd ext3 mbcache jbd fan ata_generic sata_svw pata_serverworks libata scsi_mod thermal processor Pid: 1915, comm: work_for_cpu Not tainted 2.6.34-rc1-default #81 Call Trace: [<ffffffff8107c1d2>] ? lockdep_init_map+0x562/0x620 [<ffffffff81049fd8>] warn_slowpath_common+0x78/0xd0 [<ffffffff8104a03f>] warn_slowpath_null+0xf/0x20 [<ffffffff8107c1d2>] lockdep_init_map+0x562/0x620 [<ffffffff8117a236>] ? sysfs_new_dirent+0x76/0x120 [<ffffffff8126edb2>] ? put_device+0x12/0x20 [<ffffffff811797cc>] sysfs_add_file_mode+0x6c/0xd0 [<ffffffff8117983c>] sysfs_add_file+0xc/0x10 [<ffffffff8117bf61>] sysfs_create_bin_file+0x21/0x30 [<ffffffff81279c61>] _request_firmware+0x2f1/0x650 [<ffffffff8127a04e>] request_firmware+0xe/0x10 [<ffffffffa01ec19e>] bnx2_init_one+0x8f5/0x177e [bnx2] [<ffffffff81389eab>] ? _raw_spin_unlock_irq+0x2b/0x40 [<ffffffff81040ed9>] ? finish_task_switch+0x69/0x100 [<ffffffff81040e70>] ? finish_task_switch+0x0/0x100 [<ffffffff81064b40>] ? do_work_for_cpu+0x0/0x30 [<ffffffff811e6302>] local_pci_probe+0x12/0x20 [<ffffffff81064b53>] do_work_for_cpu+0x13/0x30 [<ffffffff81064b40>] ? do_work_for_cpu+0x0/0x30 [<ffffffff81068c56>] kthread+0x96/0xa0 [<ffffffff81003e64>] kernel_thread_helper+0x4/0x10 [<ffffffff8138a350>] ? restore_args+0x0/0x30 [<ffffffff81068bc0>] ? kthread+0x0/0xa0 [<ffffffff81003e60>] ? kernel_thread_helper+0x0/0x10 ---[ end trace a2ecee9c9602d195 ]--- Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Driver core: Fix first line of kernel-doc for a few functionsBen Hutchings
The function name must be followed by a space, hypen, space, and a short description. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07driver-core: firmware_class: remove base.h header inclusionLuis R. Rodriguez
base.h is used by base drivers for sharing internal structures. Turns out firmware_class does not depend on it at all so remove it. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07driver-core: Add attribute argument to class_attribute show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. This makes the class attributes the same as sysdev_class attributes and plain attributes. This will allow further cleanups in drivers. Full tree sweep converting all users. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11firmware_class: make request_firmware_nowait more usefulJohannes Berg
Unfortunately, one cannot hold on to the struct firmware that request_firmware_nowait() hands off, which is needed in some cases. Allow this by requiring the callback to free it (via release_firmware). Additionally, give it a gfp_t parameter -- all the current users call it from a GFP_KERNEL context so the GFP_ATOMIC isn't necessary. This also marks an API break which is useful in a sense, although that is obviously not the primary purpose of this change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Abhay Salunke <abhay_salunke@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28driver core: firmware_class:fix memory leak of page pointers arrayMing Lei
The page pointers array is allocated in fw_realloc_buffer() called by firmware_data_write(), and should be freed in release function of firmware device. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reported-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12Firmware: firmware_class, fix lock imbalanceJiri Slaby
Add omitted unlock in firmware_data_read. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-08Free struct device in fw_dev_release()Catalin Marinas
The f_dev in _request_firmware() is allocated via the fw_setup_device() and fw_register_device() calls and its class set to firmware_class (the class release function is fw_dev_release). Commit 6acf70f078ca replaced the kfree(dev) in fw_dev_release() with a put_device() call but my understanding is that the release function is called via put_device -> kobject_put -> kref_put -> koject_release etc. and it should call kfree since it's the last to see this device structure alive. Because of that, the _request_firmware() function on its -ENOENT error path only calls device_unregister(f_dev) which would eventually call fw_dev_release() but there is no kfree (the subsequent put_device call would just make the kref negative). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15driver core: fix gcc 4.3.3 warnings about string literalsGreg Kroah-Hartman
This removes the warning: format not a string literal and no format arguments warnings in the driver core that gcc 4.3.3 complains about. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15firmware: allocate firmware id dynamicallySamuel Ortiz
The firmware loader has a statically allocated 30 bytes long string for the firmware id (a.k.a. the firmware file name). There is no reason why we couldnt allocate it dynamically, and avoid having restrictions on the firmware names lengths. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Cc: Marcel Holtmann <holtmann@linux.intel.com> Cc: Zhu Yi <yi.zhu@intel.com>, Cc: John Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15driver core: fix documentation of request_firmware_nowaitMing Lei
request_firmware_nowait declares it can be called in non-sleep contexts, but kthead_run called by request_firmware_nowait may sleep. So fix its documentation and comment to make callers clear about it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15driver core: firmware_class: replace kfree(dev) with put_device(dev)Ming Lei
against v2.6.30-rc3-next tree. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-15firmware: speed up request_firmware(), v3David Woodhouse
Rather than calling vmalloc() repeatedly to grow the firmware image as we receive data from userspace, just allocate and fill individual pages. Then vmap() the whole lot in one go when we're done. A quick test with a 337KiB iwlagn firmware shows the time taken for request_firmware() going from ~32ms to ~5ms after I apply this patch. [v2: define PAGE_KERNEL_RO as PAGE_KERNEL where necessary, use min_t()] [v3: kunmap() takes the struct page *, not the virtual address] Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Tested-by: Sachin Sant <sachinp@in.ibm.com>
2009-03-24Driver core: implement uevent suppress in kobjectMing Lei
This patch implements uevent suppress in kobject and removes it from struct device, based on the following ideas: 1,Uevent sending should be one attribute of kobject, so suppressing it in kobject layer is more natural than in device layer. By this way, we can do it for other objects embedded with kobject. 2,It may save several bytes for each instance of struct device.(On my omap3(32bit ARM) based box, can save 8bytes per device object) This patch also introduces dev_set|get_uevent_suppress() helpers to set and query uevent_suppress attribute in case to help kobject as private part of struct device in future. [This version is against the latest driver-core patch set of Greg,please ignore the last version.] Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-06driver core: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16firmware: use dev_printk when possibleBjorn Helgaas
Convert printks to use dev_printk(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25firmware: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10firmware: allow firmware files to be built into kernel imageDavid Woodhouse
Some drivers have their own hacks to bypass the kernel's firmware loader and build their firmware into the kernel; this renders those unnecessary. Other drivers don't use the firmware loader at all, because they always want the firmware to be available. This allows them to start using the firmware loader. A third set of drivers already use the firmware loader, but can't be used without help from userspace, which sometimes requires an initrd. This allows them to work in a static kernel. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10firmware: make fw->data constDavid Woodhouse
In preparation for supporting firmware files linked into the static kernel, make fw->data const to ensure that users aren't modifying it (so that we can pass a pointer to the original in-kernel copy, rather than having to copy it). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-29firmware loader: printk when requesting firmwareCiaran McCreesh
Before requesting firmware, printk a message saying what we're requesting. This makes it easier to see what's going on, and provides an explanation for the huge silent delay that one would otherwise get after accidentally building ipw2200 as a non-module. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19driver core: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-07Driver core: Revert "Fix Firmware class name collision"Michael E Brown
This reverts commit 109f0e93b6b728f03c1eb4af02bc25d71b646c59. The original patch breaks BIOS updates on all Dell machines. The path to the firmware file for the dell_rbu driver changes, which breaks all of the userspace tools which rely on it. Note that this patch re-introduces a problem with i2c name collision that was previously fixed by this patch. Signed-off-by: Michael E Brown <michael_e_brown@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Fix Firmware class name collisionMarkus Rechberger
following patch fixes the i2c name collision with i2c-dev. http://mcentral.de/wiki/index.php/Bugtracker#i2c_core_problem This issue has been experienced with em28xx and saa7133 based devices. I discussed that problem with Jean Delvare a while ago and he proposed to add a prefix to the class name. Signed-off-by: Markus Rechberger <markus.rechberger@amd.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30kernel-doc fixes for PCI and drivers/base/Randy Dunlap
Fix undocumented function parameters in PCI and drivers/base. Warning(linux-2.6.23-rc1//drivers/pci/pci.c:1526): No description found for parameter 'rq' Warning(linux-2.6.23-rc1//drivers/base/firmware_class.c:245): No description found for parameter 'bin_attr' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-08firmware: remove orphaned EmailMarkus Rechberger
Manuel Estrada Sainz passed away on May 9th 2004, his email account got deactivated. He was in charge of the firmware_class code, and still got CC'ed in recent discussions about it. Signed-off-by: Markus Rechberger <markus.rechberger@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27Driver core: switch firmware_class to uevent_suppress.Cornelia Huck
Use uevent_suppress instead of returning an error code in firmware_uevent(). Get rid of the now unneeded FW_STATUS_READY and FW_STATUS_READY_NOHOTPLUG. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Driver Core: Increase the default timeout value of the firmware subsystemDave Jones
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=174589 The ipw driver sometimes takes a long time to load its firmware. Whilst the ipw driver should be using the async interface of the firmware loader to make this a non-issue, this is a minimal fix. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01Driver core: convert firmware code to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-29[PATCH] kthread: drivers/base/firmware_class.cSukadev Bhattiprolu
Replace kernel_thread() call in drivers/base/firmware_class.c with kthread_create() since kernel_thread() is deprecated in drivers. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Manuel Estrada Sainz <ranty@debian.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] x86 microcode: using request_firmware to pull microcodeShaohua Li
Using request_firmware to pull ucode from userspace, so we don't need the application 'microcode_ctl' to assist. We name each ucode file according to CPU's info as intel-ucode/family-model-stepping. In this way we could split ucode file as small one. This has a lot of advantages such as selectively update and validate microcode for specific models, better manage microcode file, easily write tools for administerators and so on. with the changes, we should put all intel-ucode/xx-xx-xx microcode files into the firmware dir (I had a tool to split previous big data file into small one and later we will release new style data file). The init script should be changed to just loading the driver without unloading Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Tigran Aivazian <tigran@veritas.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-21[PATCH] firmware_class: s/semaphores/mutexesLaura Garcia
Hi, this patch converts semaphores to mutexes for Randy's firmware_class. Signed-off-by: Laura Garcia Liebana <nevola@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-21[PATCH] drivers/base/firmware_class.c: cleanupsAdrian Bunk
- remove the following global function that is both unused and unimplemented: - register_firmware() - make the following needlessly global function static: - firmware_class_uevent() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[PATCH] firmware: fix BUG: in fw_realloc_bufferJeff Moyer
The fw_realloc_buffer routine does not handle an increase in buffer size of more than 4k. It's not clear to me why it expects that it will only get an extra 4k of data. The attached patch modifies fw_realloc_buffer to vmalloc as much memory as is requested, instead of what we previously had + 4k. I've tested this on my laptop, which would crash occaisionally on boot without the patch. With the patch, it hasn't crashed, but I can't be certain that this code path is exercised. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-13[PATCH] fix leaks in request_firmware_nowaitmatthieu castet
Wasn't checking return error and forgot to free in some case. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] firmware: fix all kernel-doc warningsRandy Dunlap
Convert existing function docs to kernel-doc format. Eliminate all kernel-doc warnings. Fix some doc typos and a little whitespace cleanup. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] drivers/base/*: use kzalloc instead of kmalloc+memsetJiri Slaby
Fixes a bunch of memset bugs too. Signed-off-by: Lion Vollnhals <webmaster@schiggl.de> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] modified firmware_class.c to support no hotplugAbhay Salunke
Upgrade the request_firmware_nowait function to not start the hotplug action on a firmware update. This patch is tested along with dell_rbu driver on i386 and x86-64 systems. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] request_firmware(): avoid race conditionsStanislaw W. Gruszka
Avoid race occurs when some process have open file descriptor for class device attributes and already firmware allocated memory are freed. Don't allow negative loading timeout. Signed-off-by: Stanislaw W. Gruszka <stf_xl@wp.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] add TIMEOUT to firmware_class hotplug eventkay.sievers@vrfy.org
On Tue, 2005-03-15 at 09:25 +0100, Hannes Reinecke wrote: > The current implementation of the firmware class breaks a fundamental > assumption in udevd: that the physical device can be initialised fully > prior to executing the next event for that device. Here we add a TIMEOUT value to the hotplug environment of the firmware requesting event. I will adapt udevd not to wait for anything else, if it finds a TIMEOUT key. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
