path: root/drivers/base/devtmpfs.c
2009-12-23devtmpfs: unlock mutex in case of string allocation errorKay Sievers
Reported-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-23devtmpfs: Convert dirlock to a mutexThomas Gleixner
devtmpfs has a rw_lock dirlock which serializes delete_path and create_path. This code was obviously never tested with the usual set of debugging facilities enabled. In the dirlock held sections the code calls: - vfs functions which take mutexes - kmalloc(, GFP_KERNEL) In both code pathes the might sleep warning triggers and spams dmesg. Convert the rw_lock to a mutex. There is no reason why this needs to be a rwlock. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Driver-Core: devtmpfs - set root directory mode to 0755Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mark Rosenstand <rosenstand@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11Driver Core: devtmpfs: do not remove non-kernel-created directoriesKay Sievers
2009-12-11Driver Core: devtmpfs: use sys_mount()Kay Sievers
2009-12-11Driver core: devtmpfs: prevent concurrent subdirectory creation and removalKay Sievers
2009-12-11Driver Core: devtmpfs: ignore umask while setting file modeKay Sievers
2009-09-19Driver-Core: extend devnode callbacks to provide permissionsKay Sievers
This allows subsytems to provide devtmpfs with non-default permissions for the device node. Instead of the default mode of 0600, null, zero, random, urandom, full, tty, ptmx now have a mode of 0666, which allows non-privileged processes to access standard device nodes in case no other userspace process applies the expected permissions. This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Driver Core: devtmpfs - kernel-maintained tmpfs-based /devKay Sievers
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs very early at kernel initialization, before any driver-core device is registered. Every device with a major/minor will provide a device node in devtmpfs. Devtmpfs can be changed and altered by userspace at any time, and in any way needed - just like today's udev-mounted tmpfs. Unmodified udev versions will run just fine on top of it, and will recognize an already existing kernel-created device node and use it. The default node permissions are root:root 0600. Proper permissions and user/group ownership, meaningful symlinks, all other policy still needs to be applied by userspace. If a node is created by devtmps, devtmpfs will remove the device node when the device goes away. If the device node was created by userspace, or the devtmpfs created node was replaced by userspace, it will no longer be removed by devtmpfs. If it is requested to auto-mount it, it makes init=/bin/sh work without any further userspace support. /dev will be fully populated and dynamic, and always reflect the current device state of the kernel. With the commonly used dynamic device numbers, it solves the problem where static devices nodes may point to the wrong devices. It is intended to make the initial bootup logic simpler and more robust, by de-coupling the creation of the inital environment, to reliably run userspace processes, from a complex userspace bootstrap logic to provide a working /dev. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Tested-By: Harald Hoyer <harald@redhat.com> Tested-By: Scott James Remnant <scott@ubuntu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
