path: root/drivers/base/class.c
2006-06-21[PATCH] Driver core: add generic "subsystem" link to all devicesKay Sievers
Like the SUBSYTEM= key we find in the environment of the uevent, this creates a generic "subsystem" link in sysfs for every device. Userspace usually doesn't care at all if its a "class" or a "bus" device. This provides an unified way to determine the subsytem of a device, regardless of the way the driver core has created it. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: allow struct device to have a dev_tGreg Kroah-Hartman
This is the first step in moving class_device to being replaced by struct device. It allows struct device to export a dev_t and makes it easy to dynamically create and destroy struct device as long as they are associated with a specific class. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: change make_class_name() to take kobjectsGreg Kroah-Hartman
This is needed for a future patch for the device code to create the proper symlinks for devices that are "class devices". Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver Core: remove unused exportsGreg Kroah-Hartman
Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: class_device_add needs error checksStephen Hemminger
class_device_add needs to check the return value of all the setup it does. It doesn't handle out of memory well. This is not complete, probably more needs to be done. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-06[CLASS DEVICE]: add attribute_group creationStephen Hemminger
Extend the support of attribute groups in class_device's to allow groups to be created as part of the registration process. This allows network device's to avoid race between registration and creating groups. Note that unlike attributes that are a property of the class object, the groups are a property of the class_device object. This is done because there are different types of network devices (wireless for example). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[PATCH] driver core: fix unnecessary NULL check in drivers/base/class.cJayachandran C
This patch tries to fix an issue in drivers/base/class.c, please review and apply if correct. Patch Description: "parent_class" is checked for NULL already, so removed the unnecessary check. Signed-off-by: Jayachandran C. <c.jayachandran@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] Driver Core: add the ability for class_device structures to be nestedGreg Kroah-Hartman
This patch allows struct class_device to be nested, so that another struct class_device can be the parent of a new one, instead of only having the struct class be the parent. This will allow us to (hopefully) fix up the input and video class subsystem mess. But please people, don't go crazy and start making huge trees of class devices, you should only need 2 levels deep to get everything to work (remember to use a class_interface to get notification of a new class device being added to the system.) Oh, this also allows us to have the possibility of potentially, someday, moving /sys/block into /sys/class. The main hindrance is that pesky /dev numberspace issue... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] add sysfs attr to re-emit device hotplug eventKay Sievers
A "coldplug + udevstart" can be simple like this: for i in /sys/block/*/*/uevent; do echo 1 > $i; done for i in /sys/class/*/*/uevent; do echo 1 > $i; done for i in /sys/bus/*/devices/*/uevent; do echo 1 > $i; done Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] Driver core: pass interface to class interface methodsDmitry Torokhov
Driver core: pass interface to class intreface methods Pass interface as argument to add() and remove() class interface methods. This way a subsystem can implement generic add/remove handlers and then call interface-specific ones. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] Driver core: send hotplug event before adding class interfacesDmitry Torokhov
Move call to kobject_hotplug() above code that adds interfaces to a class device, otherwise children's hotplug events may reach userspace first. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-22[PATCH] fix class symlinks in sysfsBill Nottingham
The class symlinks in sysfs don't properly handle changing device names. To demonstrate, rename your network device from eth0 to eth1. Your pci (or usb, or whatever) device will still have a 'net:eth0' link, except now it points to /sys/class/net/eth1. The attached patch makes sure the class symlink name changes when the class device name changes. It isn't 100% correct, it should be using sysfs_rename_link. Unfortunately, sysfs_rename_link doesn't exist. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] drivers/base/*: use kzalloc instead of kmalloc+memsetJiri Slaby
Fixes a bunch of memset bugs too. Signed-off-by: Lion Vollnhals <webmaster@schiggl.de> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] Driver core: small cleanup; remove check for NULL before kfree() in ↵Jesper Juhl
driver core Remove needless checking of variable for NULL before calling kfree() on it. Applies to 2.6.13-rc6-git9 Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] Driver core: link device and all class devices derived from it.Dmitry Torokhov
Driver core: link device and all class devices derived from it. To ease the task of locating class devices derived from a certain device create symlinks from parent device to its class devices. Change USB host class device name from usbX to usb_hostX to avoid conflict when creating aforementioned links. Tweaked by Greg to have the symlink be "class_name:class_device_name" in order to prevent duplicate links. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-16[PATCH] Driver core: potentially fix use after free in class_device_attr_showManeesh Soni
This moves the code to free devt_attr from class_device_del() to class_dev_release() which is called after the last reference to the corresponding kobject() is gone. This allows us to keep the devt_attr alive while the corresponding sysfs file is open. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] class: add kerneldoc for the new class functions.gregkh@suse.de
2005-06-20[PATCH] CLASS: move a "simple" class logic into the class core.gregkh@suse.de
One step on improving the class api so that it can not be used incorrectly. This also fixes the module owner issue with the dev files that happened when the devt logic moved to the class core. Based on a patch originally written by Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] sysfs: (driver/base) if show/store is missing return -EIODmitry Torokhov
sysfs: fix drivers/base so if an attribute doesn't implement show or store method read/write will return -EIO instead of 0. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] kset_hotplug_ops->name shoudl return const char *Dmitry Torokhov
kobject: change name() method in kset_hotplug_ops return const char * since users shoudl not try to modify returned data. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] kobject/hotplug split - class corekay.sievers@vrfy.org
kobject_add() and kobject_del() don't emit hotplug events anymore. Do it ourselves if we are finished populating the device directory. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
