path: root/drivers/base/class.c
2008-04-19driver core: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: PPC: Fix powerpc vio_find_name to not use devices_subsys Driver core: add bus_find_device_by_name function Module: check to see if we have a built in module with the same name x86: fix runtime error in arch/x86/kernel/cpu/mcheck/mce_amd_64.c Driver core: Fix up build when CONFIG_BLOCK=N
2008-01-31docbook: fix drivers/base/class warningRandy Dunlap
Fix kernel-doc empty line warning: Warning(linux-2.6.24-git8//drivers/base/class.c:866): bad line: Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27Driver core: Fix up build when CONFIG_BLOCK=NGreg Kroah-Hartman
This fixes up the driver core build errors when CONFIG_BLOCK=N Thanks to Alexander van Heukelum <heukelum@mailshack.com> for the basis of this patch, and to Jeremy Fitzhardinge <jeremy@goop.org> for reporting the problem. Cc: Alexander van Heukelum <heukelum@mailshack.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: coding style fixesGreg Kroah-Hartman
Fix up a number of coding style issues in the drivers/base/ directory that have annoyed me over the years. checkpatch.pl is now very happy. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver Core: add class iteration apiDave Young
Add the following class iteration functions for driver use: class_for_each_device class_find_device class_for_each_child class_find_child Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: rename kobject_init_ng() to kobject_init()Greg Kroah-Hartman
Now that the old kobject_init() function is gone, rename kobject_init_ng() to kobject_init() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: rename kobject_add_ng() to kobject_add()Greg Kroah-Hartman
Now that the old kobject_add() function is gone, rename kobject_add_ng() to kobject_add() to clean up the namespace. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: convert block from raw kobjects to core devicesKay Sievers
This moves the block devices to /sys/class/block. It will create a flat list of all block devices, with the disks and partitions in one directory. For compatibility /sys/block is created and contains symlinks to the disks. /sys/class/block |-- sda -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda |-- sda1 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda1 |-- sda10 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda10 |-- sda5 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda5 |-- sda6 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda6 |-- sda7 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda7 |-- sda8 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda8 |-- sda9 -> ../../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/sda9 `-- sr0 -> ../../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 /sys/block/ |-- sda -> ../devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda `-- sr0 -> ../devices/pci0000:00/0000:00:1f.2/host1/target1:0:0/1:0:0:0/block/sr0 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: convert drivers/base/class.c to use kobject_init/add_ng()Greg Kroah-Hartman
This converts the code to use the new kobject functions, cleaning up the logic in doing so. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove subsystem_(un)register functionsGreg Kroah-Hartman
These functions are no longer used and are the last remants of the old subsystem crap. So delete them for good. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: remove decl_subsys macroGreg Kroah-Hartman
This macro is no longer used. ksets should be created dynamically with a call to kset_create_and_add() not declared statically. Yes, there are 5 remaining static struct kset usages in the kernel tree, but they will be fixed up soon. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert drivers/base/class.c to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. The class_obj subsystem is not yet converted as it is more complex and should be going away soon with the removal of class_device from the kernel tree. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-31Revert "Driver core: remove class_device_*_bin_file"Greg Kroah-Hartman
This reverts commit fcd239d3d5575e5cc63aab5c33cf6dc66904f6d6. I messed up, ia64 still uses these files in the current tree, and now can not build the pci code, which all ia64 boxes seem to require :) This fixes that mistake. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-30Driver core: remove class_device_*_bin_fileGreg Kroah-Hartman
These functions are not used by anyone, so remove them from the tree. The class_device code will be removed soon anyway, so no future users will ever be possible. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: rename ktype_classGreg Kroah-Hartman
This makes it a bit more sane when trying to figure out how to clean up the ktype mess. Based on a larger patch from Kay Sievers Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12driver core: remove subsystem_init()Greg Kroah-Hartman
There is only one user of it, and it is only a wrapper for kset_init(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: remove subsys_get()Greg Kroah-Hartman
There are no more subsystems, it's a kset now so remove the function and the only two users, which are in the driver core. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: remove subsys_put()Greg Kroah-Hartman
2007-10-12Driver core: remove subsys_set_ksetGreg Kroah-Hartman
This macro is only used by the driver core and is held over from when we had subsystems. It is not needed anymore. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11driver-core: make devt_attr and uevent_attr staticTejun Heo
devt_attr and uevent_attr are either allocated dynamically with or embedded in device and class_device as they needed their owner field set to the module implementing the driver. Now that sysfs implements immediate disconnect and owner field removed from struct attribute, there is no reason to do this. Remove these attributes from [class_]device and use static attribute structures instead. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-08Driver core: keep PHYSDEV for old struct class_deviceKay Sievers
Class-devices created by "struct class_device" are going to be replaced by "struct device". Keep the deprecated PHYSDEV* variables for the already "deprecated" struct class_device" devices. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27driver core: fix namespace issue with devices assigned to classesKay Sievers
- uses a kset in "struct class" to keep track of all directories belonging to this class - merges with the /sys/devices/virtual logic. - removes the namespace-dir if the last member of that class leaves the directory. There may be locking or refcounting fixes left, I stopped when it seemed to work with network and sound modules. :) From: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23Driver core: remove class_device_renameGreg Kroah-Hartman
No one uses it, and it wasn't exported to modules, so remove it. The only other user of it was the network code, which is now converted to use struct device instead. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16Driver: remove redundant kobject_unregister checksMariusz Kozlowski
Here is a patch that removes all redundant kobject_unregister argument checks. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07driver core fixes: make_class_name() retval checksCornelia Huck
Make make_class_name() return NULL on error and fixup callers in the driver core. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-13driver core: delete virtual directory on class_unregister()Akinobu Mita
Class virtual directory is created as the need arises. But it is not deleted when the class is unregistered. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01CONFIG_SYSFS_DEPRECATED - class symlinksKay Sievers
Turn off class symlinks CONFIG_SYSFS_DEPRECATED is enabled. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01Driver Core: Move virtual_device_parent() to core.cGreg Kroah-Hartman
It doesn't need to be global or in device.h Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18driver core fixes: sysfs_create_link() retval check in class.cCornelia Huck
Check for return value of sysfs_create_link() in class_device_add(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-29[PATCH] Fix parameter names in drivers/base/class.cRolf Eike Beer
Change parameter names to match arguments of functions. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: Martin Waitz <tali@admingilde.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25Class: add support for class interfaces for devicesGreg Kroah-Hartman
When moving class_device usage over to device, we need to handle class_interfaces properly with devices. This patch adds that support. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25Driver core: create devices/virtual/ treeGreg Kroah-Hartman
This change creates a devices/virtual/CLASS_NAME tree for struct devices that belong to a class, yet do not have a "real" struct device for a parent. It automatically creates the directories on the fly as needed. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25Driver core: add const to class_createMiguel Ojeda Sandonis
Adds const to class_create second parameter, because: struct class { const char * name; /*...*/ } Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25class_device_create(): make fmt argument 'const char *'Dmitry Torokhov
Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25deprecate PHYSDEV* keysKay Sievers
deprecate PHYSDEV* values in the uevent environment These values are no longer needed and inconsistent with the stacking of class devices. The event environment should not carry properties of a parent device. The key PHYSDEVDRIVER is available as DRIVER, PHYDEVBUS is indentical SUBSYSTEM. Class devices should not carry any of these values. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: add generic "subsystem" link to all devicesKay Sievers
Like the SUBSYTEM= key we find in the environment of the uevent, this creates a generic "subsystem" link in sysfs for every device. Userspace usually doesn't care at all if its a "class" or a "bus" device. This provides an unified way to determine the subsytem of a device, regardless of the way the driver core has created it. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: allow struct device to have a dev_tGreg Kroah-Hartman
This is the first step in moving class_device to being replaced by struct device. It allows struct device to export a dev_t and makes it easy to dynamically create and destroy struct device as long as they are associated with a specific class. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: change make_class_name() to take kobjectsGreg Kroah-Hartman
This is needed for a future patch for the device code to create the proper symlinks for devices that are "class devices". Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver Core: remove unused exportsGreg Kroah-Hartman
Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] Driver core: class_device_add needs error checksStephen Hemminger
class_device_add needs to check the return value of all the setup it does. It doesn't handle out of memory well. This is not complete, probably more needs to be done. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-06[CLASS DEVICE]: add attribute_group creationStephen Hemminger
Extend the support of attribute groups in class_device's to allow groups to be created as part of the registration process. This allows network device's to avoid race between registration and creating groups. Note that unlike attributes that are a property of the class object, the groups are a property of the class_device object. This is done because there are different types of network devices (wireless for example). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[PATCH] driver core: fix unnecessary NULL check in drivers/base/class.cJayachandran C
This patch tries to fix an issue in drivers/base/class.c, please review and apply if correct. Patch Description: "parent_class" is checked for NULL already, so removed the unnecessary check. Signed-off-by: Jayachandran C. <c.jayachandran@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
