path: root/drivers/atm/iphase.c
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/ethtool.c
2010-10-11ATM: iphase, remove sleep-inside-atomicJiri Slaby
Stanse found that ia_init_one locks a spinlock and inside of that it calls ia_start which calls: * request_irq * tx_init which does kmalloc(GFP_KERNEL) Both of them can thus sleep and result in a deadlock. I don't see a reason to have a per-device spinlock there which is used only there and inited right before the lock location. So remove it completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-16drivers/atm: Adjust confusing if indentationJulia Lawall
Indent the branch of an if. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-13drivers/atm: Correct code taking the size of a pointerJulia Lawall
sizeof(TstSchedTbl) is just the size of the pointer. Change it to the size of the referenced data. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21atm: fix non-const printk argumentStephen Hemminger
Change printk() argument to fix compiler warning. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08generic swap(): iphase: rename swap() to swap_byte_order()Wu Fengguang
In preparation for the introduction of a generic swap() macro. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30atm: fix direct casts of pointers to u32 in the InterPhase driverDavid Howells
Fix direct casts of pointers to u32 in the InterPhase ATM driver. These are all arguments being passed to printk() calls. So drop the cast and change the %x to a %p. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17atm: [iphase] 64-bit cleanupAlan Cox
This fixes the most obvious 64-bit problems, but it is still very very broken in other aspects. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17atm: [iphase] move struct suni_priv to suni.hJorge Boncompte [DTI2]
Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16atm: [iphase] doesn't call phy->start due to a bogus #ifndefJorge Boncompte [DTI2]
This causes the suni driver to oops if you try to use sonetdiag to get the statistics. Also add the corresponding phy->stop call to fix another oops if you try to remove the module. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16atm: [iphase] set drvdata before enabling interruptsJorge Boncompte [DTI2]
2008-04-19drivers/atm: use time_before, time_before_eq, etcJulia Lawall
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the semantic patch making this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ change_compare_np @ expression E; @@ ( - jiffies <= E + time_before_eq(jiffies,E) | - jiffies >= E + time_after_eq(jiffies,E) | - jiffies < E + time_before(jiffies,E) | - jiffies > E + time_after(jiffies,E) ) @ include depends on change_compare_np @ @@ #include <linux/jiffies.h> @ no_include depends on !include && change_compare_np @ @@ #include <linux/...> + #include <linux/jiffies.h> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-02[ATM] drivers/atm/iphase.c: compilation warning fixLeonardo Potenza
Removed the warning messages: drivers/atm/iphase.c:961: warning: 'tcnter' defined but not used drivers/atm/iphase.c:963: warning: 'xdump' defined but not used tcnter and xdump() are used only in debug build Signed-off-by: Leonardo Potenza <lpotenza@inwind.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-13[ATM] drivers/atm/iphase.c: mostly kmalloc + memset conversion to kzallocMariusz Kozlowski
drivers/atm/iphase.c | 111508 -> 111431 (-77 bytes) drivers/atm/iphase.o | 254740 -> 254260 (-480 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[ATM]: [iphase] should be __devinit not __initChas Williams
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
