path: root/drivers/ata/libata-scsi.c
2010-06-02libata: implement on-demand HPA unlockingTejun Heo
Implement ata_scsi_unlock_native_capacity() which will be called through SCSI layer when block layer notices that partitions on a device extend beyond the end of the device. It requests EH to unlock HPA, waits for completion and returns the current device capacity. This allows libata to unlock HPA on demand instead of having to decide whether to unlock upfront. Unlocking on demand is safer than unlocking by upfront because some BIOSes write private data to the area beyond HPA limit. This was suggested by Ben Hutchings. Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-17libata: kill ATA_FLAG_DISABLEDTejun Heo
ATA_FLAG_DISABLED is only used by drivers which don't use ->error_handler framework and is largely broken. Its only meaningful function is to make irq handlers skip processing if the flag is set, which is largely useless and even harmful as it makes those ports more likely to cause IRQ storms. Kill ATA_FLAG_DISABLED and makes the callers disable attached devices instead. ata_port_probe() and ata_port_disable() which manipulate the flag are also killed. This simplifies condition check in IRQ handlers. While updating IRQ handlers, remove ap NULL check as libata guarantees consecutive port allocation (unoccupied ports are initialized with dummies) and long-obsolete ATA_QCFLAG_ACTIVE check (checked by ata_qc_from_tag()). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-04libata-scsi passthru: fix bug which truncated LBA48 return valuesDouglas Gilbert
Fix assignment which overwrote SAT ATA PASS-THROUGH command EXTEND bit setting (ATA_TFLAG_LBA48) Signed-off-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-17libata: use the WRITE_SAME_16 defineChristoph Hellwig
Now that the scsi tree has hit mainline we can use the newly added WRITE_SAME_16 define. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-03libata: Clarify ata_set_lba_range_entries functionMartin K. Petersen
ata_set_lba_range_entries used the variable max for two different things which was confusing. Make the function take a buffer size in bytes as argument and return the used buffer size upon completion. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: Report zeroed read after TRIM and max discard sizeMartin K. Petersen
Our current TRIM payload is a single sector that can accommodate 64 * 65535 blocks being unmapped. Report this value in the Block Limits Maximum Unmap LBA count field. If a storage device supports TRIM and the DRAT and RZAT bits are set, report TPRZ=1 in Read Capacity(16). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: add translation for SCSI WRITE SAME (aka TRIM support)Christoph Hellwig
Add support for the ATA TRIM command in libata. We translate a WRITE SAME 16 command with the unmap bit set into an ATA TRIM command and export enough information in READ CAPACITY 16 and the block limits EVPD page so that the new SCSI layer discard support will driver this for us. Note that I hardcode the WRITE_SAME_16 opcode for now as the patch to introduce the symbolic is not in 2.6.32 yet but only in the SCSI tree - as soon as it is merged we can fix it up to properly use the symbolic name. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03ata: Don't require newlines for link_power_management_policyMatthew Garrett
sysfs attributes shouldn't require newlines. Make it possible to set the link power management policy without a trailing newline. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-08libata: unbreak TPM filtering by reorganizing ata_scsi_pass_thru()Tejun Heo
ata_scsi_pass_thru() was checking for input sanity and disallowed commands while initializaing qc from scmd. TPM filtering was added right after protocol check at which point tf wasn't initialized properly. This means that TPM filtering has never really worked. This patch fixes the bug by reorganizing ata_scsi_pass_thru() such that qc is fully initialized before checking for invalid conditions which is way less error prone. Discovered while Thilo-Alexander Ginkel was trying debug patches for bko#13416. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Thilo-Alexander Ginkel <thilo@ginkel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: Delegate nonrot flag setting to SCSIMartin K. Petersen
Now that the SCSI disk driver correctly handles non-rotational devices we can move setting the queue flag to SCSI. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: remove spindown skipping and warningTejun Heo
This was a hack to give userland shutdown tools time to drop manual spindown. All popular distros updated quite some time ago and the due is well passed. Drop it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-15libata: Media rotation rate and form factor heuristicsMartin K. Petersen
This patch provides new heuristics for parsing both the form factor and media rotation rate ATA IDENFITY words. The reported ATA version must be 7 or greater and the device must return values defined as valid in the standard. Only then are the characteristics reported to SCSI via the VPD B1 page. This seems like a reasonable compromise to me considering that we have been shipping several kernel releases that key off the rotation rate bit without any version checking whatsoever. With no complaints so far. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-15libata: Report disk alignment and physical block sizeMartin K. Petersen
For disks with 4KB sectors, report the correct block size and alignment when filling out the READ CAPACITY(16) response. This patch is based upon code from Matthew Wilcox' 4KB ATA tree. I fixed the bug I reported a while back caused by ATA and SCSI using different approaches to describing the alignment. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-11Avoid world-writable sysfs files in libata driver.Vitaly Mayatskikh
Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-11block: cleanup rq->data_len usagesTejun Heo
With recent unification of fields, it's now guaranteed that rq->data_len always equals blk_rq_bytes(). Convert all non-IDE direct users to accessors. IDE will be converted in a separate patch. Boaz: spotted incorrect data_len/resid_len conversion in osd. [ Impact: convert direct rq->data_len usages to blk_rq_bytes() ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-16ata: Report 16/32bit PIO as best we canAlan Cox
The legacy old IDE ioctl API for this is a bit primitive so we try and map stuff sensibly onto it. - Set PIO over DMA devices to report 32bit - Add ability to change the PIO32 settings if the controller permits it - Add that functionality into the sff drivers - Add that functionality into the VLB legacy driver - Turn on the 32bit PIO on the ninja32 and add support there Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02libata: fix kernel-doc warningsRandy Dunlap
Fix libata kernel-doc warnings: Warning(linux-next-20090120//drivers/ata/libata-core.c:4720): Excess function parameter 'dev' description in 'ata_qc_new' Warning(linux-next-20090120//drivers/ata/libata-scsi.c:428): No description found for parameter 'ap' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA: Blacklisting of systems that spin off disks during ACPI power offRafael J. Wysocki
Introduce new libata flags ATA_FLAG_NO_POWEROFF_SPINDOWN and ATA_FLAG_NO_HIBERNATE_SPINDOWN that, if set, will prevent disks from being spun off during system power off and hibernation, respectively (to handle the hibernation case we need the new system state SYSTEM_HIBERNATE_ENTER that can be checked against by libata, in analogy with SYSTEM_POWER_OFF). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16[libata] get-identity ioctl: Fix use of invalid memory pointerJeff Garzik
for SAS drivers. Caught by Ke Wei (and team?) at Marvell. Also, move the ata_scsi_ioctl export to libata-scsi.c, as that seems to be the general trend. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-06libata: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (104 commits) [SCSI] fcoe: fix configuration problems [SCSI] cxgb3i: fix select/depend problem [SCSI] fcoe: fix incorrect use of struct module [SCSI] cxgb3i: remove use of skb->sp [SCSI] cxgb3i: Add cxgb3i iSCSI driver. [SCSI] zfcp: Remove unnecessary warning message [SCSI] zfcp: Add support for unchained FSF requests [SCSI] zfcp: Remove busid macro [SCSI] zfcp: remove DID_DID flag [SCSI] zfcp: Simplify mask lookups for incoming RSCNs [SCSI] zfcp: Remove initial device data from zfcp_data [SCSI] zfcp: fix compile warning [SCSI] zfcp: Remove adapter list [SCSI] zfcp: Simplify SBAL allocation to fix sparse warnings [SCSI] zfcp: register with SCSI layer on ccw registration [SCSI] zfcp: Fix message line break [SCSI] qla2xxx: changes in multiq code [SCSI] eata: fix the data buffer accessors conversion regression [SCSI] ibmvfc: Improve async event handling [SCSI] lpfc : correct printk types on PPC compiles ...
2008-12-29[SCSI] add residual argument to scsi_execute and scsi_execute_reqFUJITA Tomonori
scsi_execute() and scsi_execute_req() discard the residual length information. Some callers need it. This adds residual argument (optional) to scsi_execute and scsi_execute_req. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-10libata: revert convert-to-block-tagging patchesTejun Heo
This patch reverts the following three commits which convert libata to use block layer tagging. 43a49cbdf31e812c0d8f553d433b09b421f5d52c e013e13bf605b9e6b702adffbe2853cfc60e7806 2fca5ccf97d2c28bcfce44f5b07d85e74e3cd18e Although using block layer tagging is the right direction, due to the tight coupling among tag number, data structure allocation and hardware command slot allocation, libata doesn't work correctly with the current conversion. The biggest problem is guaranteeing that tag 0 is always used for non-NCQ commands. Due to the way blk-tag is implemented and how SCSI starts and finishes requests, such guarantee can't be made. I'm not sure whether this would actually break any low level driver but it doesn't look like a good idea to break such assumption given the frailty of ATA controllers. So, for the time being, keep using the old dumb in-libata qc allocation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axobe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-04libata: Fix a potential race condition in ata_scsi_park_show()Elias Oltmanns
Peter Moulder has pointed out that there is a slight chance that a negative value might be passed to jiffies_to_msecs() in ata_scsi_park_show(). This is fixed by saving the value of jiffies in a local variable, thus also reducing code since the volatile variable jiffies is accessed only once. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Tejun Heo <tj.kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27libata: fix NCQ devices behind port multipliersJens Axboe
For devices behind sata port multipliers, we have to make sure that they share a tag map since all tags for that PMP must be unique. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-24libata: fix bug with non-ncq devicesJens Axboe
The recent commit 2fca5ccf97d2c28bcfce44f5b07d85e74e3cd18e ("libata: switch to using block layer tagging support") to enable support for block layer tagging in libata was broken for non-NCQ devices The block layer initializes the tag field to -1 to detect invalid uses of a tag, and if the libata devices does NOT support NCQ, we just used that field to index the internal command list. So we need to check for -1 first and only use the tag field if it's valid. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Tested-by: Paul Mundt <lethal@linux-sh.org> Tested-by: Dave Young <hidave.darkstar@gmail.com> Tested-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23libata: switch to using block layer tagging supportJens Axboe
libata currently has a pretty dumb ATA_MAX_QUEUE loop for finding a free tag to use. Instead of fixing that up, convert libata to using block layer tagging - gets rid of code in libata, and is also much faster. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10libata: WIN_* -> ATA_CMD_*Bartlomiej Zolnierkiewicz
Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10Merge branch 'for-2.6.28' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.28' of git://git.kernel.dk/linux-2.6-block: (132 commits) doc/cdrom: Trvial documentation error, file not present block_dev: fix kernel-doc in new functions block: add some comments around the bio read-write flags block: mark bio_split_pool static block: Find bio sector offset given idx and offset block: gendisk integrity wrapper block: Switch blk_integrity_compare from bdev to gendisk block: Fix double put in blk_integrity_unregister block: Introduce integrity data ownership flag block: revert part of d7533ad0e132f92e75c1b2eb7c26387b25a583c1 bio.h: Remove unused conditional code block: remove end_{queued|dequeued}_request() block: change elevator to use __blk_end_request() gdrom: change to use __blk_end_request() memstick: change to use __blk_end_request() virtio_blk: change to use __blk_end_request() blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structure block: add lld busy state exporting interface block: Fix blk_start_queueing() to not kick a stopped queue include blktrace_api.h in headers_install ...
2008-10-09libata: set queue SSD flag for SSD devicesJens Axboe
SSD devices should give an RPM setting of 1 in word 217 of the ID page. If we see such a device, tell the block layer about it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-29libata: Implement disk shock protection supportElias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). In fact, the whole port stops processing commands until the timeout has expired in order to avoid any resets due to failed commands on another device. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-31libata: update atapi disable handlingTejun Heo
Global and per-LLD ATAPI disable checks were done in the command issue path probably because it was left out during EH conversion. On affected machines, this can cause lots of warning messages. Move them to where they belong - the probing path. Reported by Chunbo Luo. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Chunbo Luo <chunbo.luo@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-15Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: AHCI: Remove an unnecessary flush from ahci_qc_issue AHCI: speed up resume [libata] Add support for VPD page b1 ata: endianness annotations in pata drivers libata-eh: update atapi_eh_request_sense() to take @dev instead of @qc [libata] sata_svw: update code comments relating to data corruption libata/ahci: enclosure management support libata: improve EH internal command timeout handling libata: use ULONG_MAX to terminate reset timeout table libata: improve EH retry delay handling libata: consistently use msecs for time durations
2008-07-14[libata] Add support for VPD page b1Matthew Wilcox
SCSI VPD page b1 reports the nominal rotation speed and physical size of the device. Devices that conform to ATA-8 can return this information in words 217 and 168 of the identify data. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-14libata/ahci: enclosure management supportKristen Carlson Accardi
Add Enclosure Management support to libata and ahci. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04block: add blk_queue_update_dma_padFUJITA Tomonori
This adds blk_queue_update_dma_pad to prevent LLDs from overwriting the dma pad mask wrongly (we added blk_queue_update_dma_alignment due to the same reason). This also converts libata to use blk_queue_update_dma_pad instead of blk_queue_dma_pad. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-18libata: don't check whether to use DMA or not for no data commandsTejun Heo
There's no reason to check whether to use DMA or not for no data commands. Don't do it. While at it, make local variable using_pio in atapi_xlat() set iff ATAPI_PROT_PIO is going to be used and rename ata_check_atapi_dma() to atapi_check_dma() for consistency. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30libata: fix libata-scsi kernel-doc notationRandy Dunlap
Fix libata-scsi kernel-doc notation: Warning(linux-2.6.25-git15//drivers/ata/libata-scsi.c:1659): No description found for parameter 'cmd' Warning(linux-2.6.25-git15//drivers/ata/libata-scsi.c:1971): No description found for parameter 'buf' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-19libata: ignore SIMG4726 config pseudo deviceTejun Heo
I was hoping ATA_HORKAGE_NODMA | ATA_HORKAGE_SKIP_PM could keep it happy but no even this doesn't work under certain configurations and it's not like we can do anything useful with the cofig device anyway. Replace ATA_HORKAGE_SKIP_PM with ATA_HORKAGE_DISABLE and use it for the config device. This makes the device completely ignored by libata. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29libata-scsi: improve rbuf handling for simulated commandsTejun Heo
Buffer length handling in simulated commands is error-prone and full of bugs. There are a number of places where necessary length checks are missing and if the output buffer is passed in as sglist, nothing works. This patch adds a static buffer ata_scsi_rbuf which is sufficiently large to handle the larges output from simulated commands (4k currently), let all simulte functions write to the buffer and removes all length checks as we know that there always is enough buffer space. Copying in (for ATAPI inquiry fix up) and out are handled by sg_copy_to/from_buffer() behind ata_scsi_rbuf_get/put() interface which handles sglist properly. This patch is inspired from buffer length check fix patch from Petr Vandrovec. Updated to use sg_copy_to/from_buffer() as suggested by FUJITA Tomonori. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Petr Vandrovec <petr@vmware.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29libata-scsi: clean up inquiry / mode sense related functionsTejun Heo
* make ata_scsiop_*() static * make ata_scsi_set_sense() static and move it above its users * make ata_scsi_rbuf_fill() static * kill unused ata_scsi_badcmd() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (137 commits) [SCSI] iscsi: bidi support for iscsi_tcp [SCSI] iscsi: bidi support at the generic libiscsi level [SCSI] iscsi: extended cdb support [SCSI] zfcp: Fix error handling for blocked unit for send FCP command [SCSI] zfcp: Remove zfcp_erp_wait from slave destory handler to fix deadlock [SCSI] zfcp: fix 31 bit compile warnings [SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commands [SCSI] bsg: remove minor in struct bsg_device [SCSI] bsg: use better helper list functions [SCSI] bsg: replace kobject_get with blk_get_queue [SCSI] bsg: takes a ref to struct device in fops->open [SCSI] qla1280: remove version check [SCSI] libsas: fix endianness bug in sas_ata [SCSI] zfcp: fix compiler warning caused by poking inside new semaphore (linux-next) [SCSI] aacraid: Do not describe check_reset parameter with its value [SCSI] aacraid: Fix down_interruptible() to check the return value [SCSI] sun3_scsi_vme: add MODULE_LICENSE [SCSI] st: rename flush_write_buffer() [SCSI] tgt: use KMEM_CACHE macro [SCSI] initio: fix big endian problems for auto request sense ...
2008-04-18libata: fix boot panic with SATAPI devices on non-SFF HBAsJames Bottomley
The kernel now panics reliably on boot if you have a SATAPI device connected. The problem was introduced by the libata merge trying to pull out all the SFF code into a separate module. Unfortunately, if you're a satapi device you usually need to call atapi_request_sense, which has a bare invocation of a SFF callback which is NULL on non-SFF HBAs. Fix this by making the call conditional. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
