path: root/drivers/ata/libahci.c
2016-01-11Merge branch 'for-4.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Mostly low level driver specific changes. Two changes are somewhat noteworthy. First, Dan's patchset to support per-port msix interrupt handling for ahci, which was tried last cycle but had to be backed out due to a couple issues, is back and seems to be working fine. Second, libata exception handling now uses usleep_range() instead of msleep() for sleeps < 20ms which can make things snappier in some corner cases" * 'for-4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata: skip debounce delay on link resume ata: ahci_brcmstb: disable DIPM support ata: ahci_brcmstb: enable support for ALPM drivers: libata-core: Use usleep_range() instead of msleep() for short sleeps (<20 ms) sata_sx4: correctly handling failed allocation ata: ahci_brcmstb: add support for MIPS-based platforms ahci: qoriq: Adjust the default register values on ls1021a ahci: qoriq: Update the default Rx watermark value ahci: qoriq: Adjust the default register values on ls1043a ahci: compile out msi/msix infrastructure ata: core: fix irq description on AHCI single irq systems ata: ahci_brcmstb: remove unused definitions ata: ahci_brcmstb: add a quirk for MIPS-based platforms ata: ahci_brcmstb: disable NCQ for MIPS-based platforms ata: sata_rcar: Remove obsolete platform_device_id entries sata_rcar: Add compatible string for r8a7795 ahci: kill 'intr_status' ahci: switch from 'threaded' to 'hardirq' interrupt handling ahci: per-port msix support
2015-12-07ahci: compile out msi/msix infrastructureDan Williams
Quoting Arnd: The AHCI driver is used for some on-chip devices that do not use PCI for probing, and it can be built even when CONFIG_PCI is disabled, but that now results in a build failure: ata/libahci.c: In function 'ahci_host_activate_multi_irqs': ata/libahci.c:2475:4: error: invalid use of undefined type 'struct msix_entry' ata/libahci.c:2475:21: error: dereferencing pointer to incomplete type 'struct msix_entry' Add ifdef CONFIG_PCI_MSI infrastructure to compile out the multi-msi and multi-msix code. Reported-by: Arnd Bergmann <arnd@arndb.de> Tested--by: Arnd Bergmann <arnd@arndb.de> [arnd: fix up pci enabled case] Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Fixes: d684a90d38e2 ("ahci: per-port msix support") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-11-30AHCI: Fix softreset failed issue of Port MultiplierXiangliang Yu
Current code doesn't update port value of Port Multiplier(PM) when sending FIS of softreset to device, command will fail if FBS is enabled. There are two ways to fix the issue: the first is to disable FBS before sending softreset command to PM device and the second is to update port value of PM when sending command. For the first way, i can't find any related rule in AHCI Spec. The second way can avoid disabling FBS and has better performance. Signed-off-by: Xiangliang Yu <Xiangliang.Yu@amd.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-11-16ahci: switch from 'threaded' to 'hardirq' interrupt handlingDan Williams
For high frequency I/O the overhead of threaded interrupts impacts performance. A quick out-of-the-box test (i.e. no affinity tuning) shows ~10% random read performance at ~20% less cpu. The cpu wins appear to be from reduced lock contention. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-11-16ahci: per-port msix supportDan Williams
Some AHCI controllers support per-port MSI-X vectors. At the same time the Linux AHCI driver needs to support one-off architectures that implement a single MSI-X vector for all ports. The heuristic for enabling AHCI ports becomes, in order of preference: 1/ per-port multi-MSI-X 2/ per-port multi-MSI 3/ single MSI 4/ single MSI-X 5/ legacy INTX This all depends on AHCI implementations with potentially broken MSI-X requesting less vectors than the number of ports. If this assumption is violated we will need to start explicitly white-listing AHCI-MSIX implementations. Reported-by: Ricardo Neri <ricardo.neri@intel.com> [ricardo: fix struct msix_entry handling] Reported-by: kernel test robot <ying.huang@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-10-31ahci: cleanup ahci_host_activate_multi_irqsDan Williams
With devm there is no need to explicitly free irqs on error. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-10-31ahci: ahci_host_activate: kill IRQF_SHAREDDan Williams
MSI messages are per-device, so there will never be another "shared" device in the interrupt chain. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-09-30ata: ahci: find eSATA ports and flag them as removableManuel Lauss
If the AHCI ports' HPCP or ESP bits are set, the port should be considered external (e.g. eSATA) and is marked as removable. Userspace tools like udisks then treat it like an usb drive. With this patch applied, when I plug a drive into the esata port, KDE pops up a window asking what to do with the drives(s), just like it does for any random USB stick. Removability is indicated to the upper layers by way of the SCSI RMB bit, as I haven't found another way to signal userspace to treat a sata disk like any usb stick. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-06-25Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: - a number of libata core changes to better support NCQ TRIM. - ahci now supports MSI-X in single IRQ mode to support a new controller which doesn't implement MSI or INTX. - ahci now supports edge-triggered IRQ mode to support a new controller which for some odd reason did edge-triggered IRQ. - the usual controller support additions and changes. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (27 commits) libata: Do not blacklist Micron M500DC ata: ahci_mvebu: add suspend/resume support ahci, msix: Fix build error for !PCI_MSI ahci: Add support for Cavium's ThunderX host controller ahci: Add generic MSI-X support for single interrupts to SATA PCI driver libata: finally use __initconst in ata_parse_force_one() drivers: ata: add support for Ceva sata host controller devicetree:bindings: add devicetree bindings for ceva ahci ahci: added support for Freescale AHCI sata ahci: Store irq number in struct ahci_host_priv ahci: Move interrupt enablement code to a separate function Doc: libata: Fix spelling typo found in libata.xml ata:sata_nv - Change 1 to true for bool type variable. ata: add Broadcom AHCI SATA3 driver for STB chips Documentation: devicetree: add Broadcom SATA binding libata: Fix regression when the NCQ Send and Receive log page is absent ata: hpt366: fix constant cast warning ata: ahci_xgene: potential NULL dereference in probe ata: ahci_xgene: Add AHCI Support for 2nd HW version of APM X-Gene SoC AHCI SATA Host controller. libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch. ...
2015-06-03ahci: Store irq number in struct ahci_host_privRobert Richter
Currently, ahci supports only msi and intx. To also support msix the handling of the irq number need to be changed. The irq number for msix devices is taken from msi_list instead of pci_dev. Thus, the irq number of a device needs to be stored in struct ahci_host_priv now. This allows the host controller to be activated in a generic way. This change is only intended for ahci drivers. For that reason the irq number is stored in struct ahci_host_priv used only by ahci drivers. Thus, the ABI changes only for ahci_host_activate(), but existing ata drivers (about 50) are unaffected and keep unchanged. All users of ahci_host_activate() have been updated. While touching drivers/ata/libahci.c, doing a small code cleanup in ahci_port_start(). Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-10libahci: Add support to handle HOST_IRQ_STAT as edge trigger latch.Suman Tripathi
This patch adds the support to handle HOST_IRQ_STAT as edge trigger latch. Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-05-10libahci: Refactoring of ahci_single_irq_intr function.Suman Tripathi
This patch refactors the ahci_single_irq_intr function and also rename it to ahci_single_level_irq_intr as it handles a level triggered latch. Signed-off-by: Suman tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2015-04-25libata: Add helper to determine when PHY events should be ignoredGabriele Mazzotta
This is a preparation commit that will allow to add other criteria according to which PHY events should be dropped. Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2015-01-09ahci: Use dev_info() to inform about the lack of Device Sleep supportGabriele Mazzotta
According to the Serial ATA AHCI specification, Device Sleep is an optional feature and as such no errors should be printed if it's missing. Keep informing users, but use dev_info() instead of dev_err(). Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-10-27Revert "AHCI: Optimize single IRQ interrupt processing"Tejun Heo
This reverts commit 18dcf433f3ded61eb140a55e7048ec2fef79e723. IRQF_ONESHOT was missing from the conversion causing screaming interrupts problems on some setups and LKP detected measureable drop in IO performance. It looks like we'll first need to drop the threaded IRQ handling first before splitting locking. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alexander Gordeev <agordeev@redhat.com> Reported-by: kernel test robot <fengguang.wu@intel.com> Reported-by: Marc Zyngier <marc.zyngier@arm.com> Link: http://lkml.kernel.org/g/20141027021651.GF27038@yliu-dev.sh.intel.com Link: http://lkml.kernel.org/g/1414082970-20775-1-git-send-email-marc.zyngier@arm.com
2014-10-27Revert "AHCI: Do not acquire ata_host::lock from single IRQ handler"Tejun Heo
This reverts commit 33fb0d01ce60fe4c0c12c4f0c134c5cdb818ac5a. 18dcf433f3de ("AHCI: Optimize single IRQ interrupt processing") is scheduled to be reverted. This is an optimization dependent on the mentioned commit. Revert it first. Signed-off-by: Tejun Heo <tj@kernel.org>
2014-10-06AHCI: Do not acquire ata_host::lock from single IRQ handlerAlexander Gordeev
There is no need to acquire ata_host::lock spinlock from hardware context single IRQ interrupt handler since the handler does not access host data that could be altered by concurrent processors. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: linux-ide@vger.kernel.org
2014-10-06AHCI: Optimize single IRQ interrupt processingAlexander Gordeev
Split interrupt service routine into hardware context handler and threaded context handler. That allows to protect ports with individual locks rather than with a single host-wide lock and move port interrupts handling out of the hardware interrupt context. Testing was done by transferring 8GB on two hard drives in parallel using command 'dd if=/dev/sd{a,b} of=/dev/null'. With lock_stat statistics I measured access times to ata_host::lock spinlock (since interrupt handler code is fully embraced with this lock). The average lock's holdtime decreased eight times while average waittime decreased two times. Both before and after the change the transfer time is the same, while 'perf record -e cycles:k ...' shows 1%-4% CPU time spent in ahci_single_irq_intr() routine before the update and not even sampled/shown ahci_single_irq_intr() after the update. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: linux-ide@vger.kernel.org
2014-10-06AHCI: Do not read HOST_IRQ_STAT reg in multi-MSI modeAlexander Gordeev
As described in AHCI v1.0 specification chapter 10.6.2.2 "Multiple MSI Based Messages" generation of interrupts is not controlled through the HOST_IRQ_STAT register. Considering MMIO access is expensive remove unnecessary reading and writing of HOST_IRQ_STAT register. Further, serializing access to the host data is no longer needed and the interrupt service routine can avoid competing on the host lock. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Suggested-by: "Jiang, Dave" <dave.jiang@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "Jiang, Dave" <dave.jiang@intel.com> Cc: linux-ide@vger.kernel.org
2014-10-06AHCI: Make few function names more descriptiveAlexander Gordeev
2014-10-06AHCI: Move host activation code into ahci_host_activate()Alexander Gordeev
Currently host activation done by calling either function ahci_host_activate() or ata_host_activate(). Consolidate the code by only calling ahci_host_activate() for all AHCI devices. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: linux-ide@vger.kernel.org
2014-10-06AHCI: Move ahci_host_activate() function to libahci.cAlexander Gordeev
This update is a prerequisite for consolidation of AHCI host activation code within ahci_host_activate() function. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: linux-ide@vger.kernel.org
2014-07-30ata: libahci_platform: move port_map parameters into the AHCI structureAntoine Ténart
This patch moves force_port_map and mask_port_map into the ahci_host_priv structure. This allows to modify them into the AHCI framework. This is needed by the new dt bindings representing ports as the port_map mask is computed automatically. Parameters modifying force_port_map, mask_port_map and flags have been removed from the ahci_platform_init_host() function, and inputs in the ahci_host_priv structure are now directly filed. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-07-08libahci: export ahci_qc_issue() and ahci_start_fix_rx()Suman Tripathi
The subsequent patch will make use of them. Signed-off-by: Loc Ho <lho@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-06-09Merge branch 'for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata updates from Tejun Heo: "Nothing too interesting - another ahci platform driver variant, additional controller support, minor fixes and cleanups" * 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: Add Device ID for HighPoint RocketRaid 642L ata: ep93xx: use dmaengine_prep_slave_sg api instead of internal callback ahci: add PCI ID for Marvell 88SE91A0 SATA Controller sata_fsl: remove check for CONFIG_MPC8315_DS ahci: add support for Hisilicon sata libahci_platform: add host_flags parameter in ahci_platform_init_host() ata: ahci: append new hflag AHCI_HFLAG_NO_FBS ata: use CONFIG_PM_SLEEP instead of CONFIG_PM where applicable in host drivers ata: ahci_mvebu: new driver for Marvell Armada 380 AHCI interfaces Documentation: dt-bindings: reformat and order list of ahci-platform compatibles libata-sff: remove dead code ata: SATL compliance for Inquiry Product Revision pata_octeon_cf: use devm_kzalloc() to allocate cf_port
2014-05-14ata: ahci: append new hflag AHCI_HFLAG_NO_FBSKefeng Wang
Append AHCI_HFLAG_NO_FBS to force turning off FBS flag. Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Signed-off-by: Kefeng Wang <kefeng.wang@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-04-24ahci: disable DEVSLP for Intel ValleyviewJacob Pan
On Intel Valleyview SoC, SATA device sleep is not reliable. When DEVSLP is attempted on certain SSDs, port_devslp write would fail and result in malfunction of AHCI controller. AHCI controller may be not shown in PCI enumeration after reset. Complete power source removal may be required to recover from this failure. So we blacklist this device and override host device reported capabilities such that device LPM will only attempt slumber but not DEVSLP. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-03-26ata: remove superfluous castsJoe Perches
Unreferenced casts of void * types are unnecessary so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-22libahci: Allow drivers to override start_engineHans de Goede
Allwinner A10 and A20 ARM SoCs have an AHCI sata controller which needs a special register to be poked before starting the DMA engine. This register gets reset on an ahci_stop_engine call, so there is no other place then ahci_start_engine where this poking can be done. This commit allows drivers to override ahci_start_engine behavior for use by the Allwinner AHCI driver (and potentially other drivers in the future). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-19ata: libahci: replace obsolete simple_strtoul() with kstrtouint()Daeseok Youn
Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-19ata: libahci: make ahci_pmp_retry_softreset() as staticDaeseok Youn
sparse says: drivers/ata/libahci.c:1390:5: warning: symbol 'ahci_pmp_retry_softreset' was not declared. Should it be static? Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-13ata: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: linux-ide@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-12-14drivers: ata: Mark the function as static in libahci.cRashika Kheria
This patch marks the function ahci_port_intr() and ahci_hw_port_interrupt() as static in libahci.c because they are not used outside this file. Thus, it also eliminates the following warnings in libahci.c: drivers/ata/libahci.c:1767:6: warning: no previous prototype for ‘ahci_port_intr’ [-Wmissing-prototypes] drivers/ata/libahci.c:1800:6: warning: no previous prototype for ‘ahci_hw_port_interrupt’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2013-11-13Merge branch 'for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata changes from Tejun Heo: "Nothing too interesting. Only two minor fixes in libata core. Most changes are specific to hardware which isn't too common" * 'for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: Add Device IDs for Intel Wildcat Point-LP sata_rcar: Convert to clk_prepare/unprepare drivers/libata: Set max sector to 65535 for Slimtype DVD A DS8A9SH drive libata: Add some missing command descriptions sata_highbank: clear whole array in highbank_initialize_phys() ahci: disabled FBS prior to issuing software reset libata: Fix display of sata speed ahci: imx: setup power saving methods ata_piix: minor typo and a printk fix ahci: Changing two module params with static and __read_mostly
2013-10-27ahci: disabled FBS prior to issuing software resetxiangliang yu
Tested with Marvell 88se9125, attached with one port mulitplier(5 ports) and one disk, we will get following boot log messages if using current code: ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 330) ata8.15: Port Multiplier 1.2, 0x1b4b:0x9715 r160, 5 ports, feat 0x1/0x1f ahci 0000:03:00.0: FBS is enabled ata8.00: hard resetting link ata8.00: SATA link down (SStatus 0 SControl 330) ata8.01: hard resetting link ata8.01: SATA link down (SStatus 0 SControl 330) ata8.02: hard resetting link ata8.02: SATA link down (SStatus 0 SControl 330) ata8.03: hard resetting link ata8.03: SATA link up 6.0 Gbps (SStatus 133 SControl 133) ata8.04: hard resetting link ata8.04: failed to resume link (SControl 133) ata8.04: failed to read SCR 0 (Emask=0x40) ata8.04: failed to read SCR 0 (Emask=0x40) ata8.04: failed to read SCR 1 (Emask=0x40) ata8.04: failed to read SCR 0 (Emask=0x40) ata8.03: native sectors (2) is smaller than sectors (976773168) ata8.03: ATA-8: ST3500413AS, JC4B, max UDMA/133 ata8.03: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata8.03: configured for UDMA/133 ata8.04: failed to IDENTIFY (I/O error, err_mask=0x100) ata8.15: hard resetting link ata8.15: SATA link up 6.0 Gbps (SStatus 133 SControl 330) ata8.15: Port Multiplier vendor mismatch '0x1b4b' != '0x133' ata8.15: PMP revalidation failed (errno=-19) ata8.15: hard resetting link ata8.15: SATA link up 6.0 Gbps (SStatus 133 SControl 330) ata8.15: Port Multiplier vendor mismatch '0x1b4b' != '0x133' ata8.15: PMP revalidation failed (errno=-19) ata8.15: limiting SATA link speed to 3.0 Gbps ata8.15: hard resetting link ata8.15: SATA link up 3.0 Gbps (SStatus 123 SControl 320) ata8.15: Port Multiplier vendor mismatch '0x1b4b' != '0x133' ata8.15: PMP revalidation failed (errno=-19) ata8.15: failed to recover PMP after 5 tries, giving up ata8.15: Port Multiplier detaching ata8.03: disabled ata8.00: disabled ata8: EH complete The reason is that current detection code doesn't follow AHCI spec: First,the port multiplier detection process look like this: ahci_hardreset(link, class, deadline) if (class == ATA_DEV_PMP) { sata_pmp_attach(dev) /* will enable FBS */ sata_pmp_init_links(ap, nr_ports); ata_for_each_link(link, ap, EDGE) { sata_std_hardreset(link, class, deadline); if (link_is_online) /* do soft reset */ ahci_softreset(link, class, deadline); } } But, according to chapter 9.3.9 in AHCI spec: Prior to issuing software reset, software shall clear PxCMD.ST to '0' and then clear PxFBS.EN to '0'. The patch test ok with kernel 3.11.1. tj: Patch white space contaminated, applied manually with trivial updates. Signed-off-by: Xiangliang Yu <yuxiangl@marvell.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-10-15libahci: fix turning on LEDs in ahci_start_port()Lukasz Dorau
If EM Transmit bit is busy during init ata_msleep() is called. It is wrong - msleep() should be used instead of ata_msleep(), because if EM Transmit bit is busy for one port, it will be busy for all other ports too, so using ata_msleep() causes wasting tries for another ports. The most common scenario looks like that now (six ports try to transmit a LED meaasege): - port #0 tries for the 1st time and succeeds - ports #1-5 try for the 1st time and sleeps - port #1 tries for the 2nd time and succeeds - ports #2-5 try for the 2nd time and sleeps - port #2 tries for the 3rd time and succeeds - ports #3-5 try for the 3rd time and sleeps - port #3 tries for the 4th time and succeeds - ports #4-5 try for the 4th time and sleeps - port #4 tries for the 5th time and succeeds - port #5 tries for the 5th time and sleeps At this moment port #5 wasted all its five tries and failed to initialize. Because there are only 5 (EM_MAX_RETRY) tries available usually only five ports succeed to initialize. The sixth port and next ones usually will fail. If msleep() is used instead of ata_msleep() the first port succeeds to initialize in the first try and next ones usually succeed to initialize in the second try. tj: updated comment Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-10-15ahci: imx: setup power saving methodsRichard Zhu
In order to save power consumption as much as possible. * Disable sata phy internal pll reference clock when sysetem enter into suspend mode, enable it after resume. * Setup module parameter used to enable imx ahci test power down mode(PDDQ) or not, when there is no device detected on the port * minor modifications: - The format of the copyright is changed, because that the original one can't pass fsl internal patch reivew without the character '(c)'. - Exports ahci_platform_ops and ahci_error_handler(). NOTE: * The hot-plug can't be supported when PDDQ mode is ever enabled. * module parameter usage how-to: - default: enable PDDQ mode when no device detected. - add "ahci-imx.hotplug=1" into kernel command line if your don't want to enable PDDQ mode when no device detected on the port. tj: Slightly updated description and comments. Signed-off-by: Richard Zhu <r65037@freescale.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-09-22ahci: Changing two module params with static and __read_mostlyChuansheng Liu
Here module parameters ahci_em_messages and devslp_idle_timeout can be set as static and __read_mostly. Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-02Merge branch 'libata/for-3.10-fixes' into libata/for-3.11Tejun Heo
libata/for-3.10-fixes never got submitted during v3.10 cycle. Merge it into for-3.11 so that it can be routed together with other changes scheduled for v3.11. Three trivial conflicts in drivers/ata/sata_rcar.c. All are caused by 1b20f6a9ad ("sata_rcar: add 'base' local variable to some functions") conflicting with logic updates in for-3.10-fixes. The offending commit simply adds local variable @base on functions which dereferences sata_rcar_priv->base multiple times. The resolutions are trivial - applying s/priv->base/base/ in the conflicting logic updates. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-24AHCI: use ATA_BUSYSergei Shtylyov
ahci_hardreset() and ahci_p5wdh_hardreset() use bare numbers for the BSY bit of the ATA status register, despite it's #define'd in <linux/ata.h>. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-06-09ahci: remove pmp link online check in FBS EHShane Huang
ata_link_online() check in ahci_error_intr() is unnecessary, it should be removed otherwise may lead to lockup with FBS enabled PMP. http://marc.info/?l=linux-ide&m=137050421603272&w=2 Reported-by: Yu Liu <liuyu.ac@gmail.com> Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-06-06ahci: make ahci_transmit_led_message into a function pointerMark Langsdorf
Create a new ata_port_operations function pointer called transmit_led_message and give it the default value of ahci_transmit_led_message. This allows AHCI controllers with non-standard LED interfaces to use the existing em_ interface. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-22AHCI: Make distinct names for ports in /proc/interruptsAlexander Gordeev
Currently all interrupts assigned to AHCI ports show up in '/proc/interrupts' as 'ahci'. This fix adds port numbers as suffixes and hence makes the descriptions distinct. Reported-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-14libata: update "Maintained by:" tagsTejun Heo
Jeff moved on to a greener pasture. s/Maintained by: Jeff Garzik/Maintained by: Tejun Heo/g Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com>
2013-01-24AHCI: Support multiple MSIsAlexander Gordeev
Take advantage of multiple MSIs implementation on x86 - on systems with IRQ remapping AHCI ports not only get assigned separate MSI vectors - but also separate IRQs. As result, interrupts generated by different ports could be serviced on different CPUs rather than on a single one. In cases when number of allocated MSIs is less than requested the Sharing Last MSI mode does not get used, no matter implemented in hardware or not. Instead, the driver assumes the advantage of multiple MSIs is negated and falls back to the single MSI mode as if MRSM bit was set (some Intel chips implement this strategy anyway - MRSM bit gets set even if the number of allocated MSIs exceeds the number of implemented ports). Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/15bf7ee314dd55f21ec7d2a01c47613cd8190a7c.1353324359.git.agordeev@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-14[libata] replace sata_settings with devslp_timingShane Huang
NCQ capability was used to check availability of SATA Settings page from Identify Device Data Log, which contains DevSlp timing variables. It does not work on some HDDs and leads to error messages. IDENTIFY word 78 bit 5(Hardware Feature Control) can't work either because it is only the sufficient condition of Identify Device data log, not the necessary condition. This patch replaced ata_device->sata_settings with ->devslp_timing to only save DevSlp timing variables(8 bytes), instead of the whole SATA Settings page(512 bytes). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=51881 Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Shane Huang <shane.huang@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-12-14ahci: convert ata_link_printk() to ata_link_warn()Wei Yongjun
Using ata_link_warn() instead of ata_link_printk(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-09-13ahci: implement aggressive SATA device sleep supportShane Huang
Device Sleep is a feature as described in AHCI 1.3.1 Technical Proposal. This feature enables an HBA and SATA storage device to enter the DevSleep interface state, enabling lower power SATA-based systems. Aggressive Device Sleep enables the HBA to assert the DEVSLP signal as soon as there are no commands outstanding to the device and the port specific Device Sleep idle timer has expired. This enables autonomous entry into the DevSleep interface state without waiting for software in power sensitive systems. This patch enables Aggressive Device Sleep only if both host controller and device support it. Tested on AMD reference board together with Device Sleep supported device sample. Signed-off-by: Shane Huang <shane.huang@amd.com> Reviewed-by: Aaron Lu <aaron.lwe@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-08-17ahci: un-staticize ahci_dev_classifyRob Herring
Make ahci_dev_classify available to the ahci platform driver for custom hard reset function. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2012-03-13ahci: add AHCI_HFLAG_DELAY_ENGINE host flagBrian Norris
The following commit was intended to fix problems with specific AHCI controller(s) that would become bricks if the AHCI specification was not followed strictly (that is, if ahci_start_engine() was called while the controller was in the wrong state): commit 7faa33da9b7add01db9f1ad92c6a5d9145e940a7 ahci: start engine only during soft/hard resets However, some devices currently have issues with that fix, so we must implement a flag that delays the ahci_start_engine() call only for specific controllers. This commit simply introduces the flag, without enabling it in any driver. Note that even when AHCI_HFLAG_DELAY_ENGINE is not enabled, this patch does not constitue a full revert to commit 7faa33da; there is still a change in behavior to the ahci_port_suspend() failure path. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: stable@kernel.org
