path: root/drivers/ata/ata_piix.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01libata: implement spurious irq handling for SFF and apply it to piixTejun Heo
Traditional IDE interface sucks in that it doesn't have a reliable IRQ pending bit, so if the controller raises IRQ while the driver is expecting it not to, the IRQ won't be cleared and eventually the IRQ line will be killed by interrupt subsystem. Some controllers have non-standard mechanism to indicate IRQ pending so that this condition can be detected and worked around. This patch adds an optional operation ->sff_irq_check() which will be called for each port from the ata_sff_interrupt() if an unexpected interrupt is received. If the operation returns %true, ->sff_check_status() and ->sff_irq_clear() will be cleared for the port. Note that this doesn't mark the interrupt as handled so it won't prevent IRQ subsystem from killing the IRQ if this mechanism fails to clear the spurious IRQ. This patch also implements ->sff_irq_check() for ata_piix. Note that this adds slight overhead to shared IRQ operation as IRQs which are destined for other controllers will trigger extra register accesses to check whether IDE interrupt is pending but this solves rare screaming IRQ cases and for some curious reason also helps weird BIOS related glitch on Samsung n130 as reported in bko#14314. http://bugzilla.kernel.org/show_bug.cgi?id=14314 * piix_base_ops dropped as suggested by Sergei. * Spurious IRQ detection doesn't kick in anymore if polling qc is in progress. This provides less protection but some controllers have possible data corruption issues if the wrong register is accessed while a command is in progress. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Johannes Stezenbach <js@sig21.net> Reported-by: Hans Werner <hwerner4@gmx.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01ata_piix: IDE Mode SATA patch for Intel Cougar Point DeviceIDsSeth Heasley
Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-01-12ata_piix: enable 32bit PIO on SATA piixTejun Heo
Commit 871af1210f13966ab911ed2166e4ab2ce775b99d enabled 32bit PIO for PATA piix but didn't for SATA. There's no reason not to use 32bit PIO on SATA piix. Enable it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03ata_piix: fix MWDMA handling on PIIX3Bartlomiej Zolnierkiewicz
Fix erroneous check for ap->udma_mask in do_pata_set_dmamode() resulting in controller not being programmed properly for MWDMA. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-08-31ata_piix: parallel scanning on PATA needs an extra lockingBartlomiej Zolnierkiewicz
Commit log for commit 517d3cc15b36392e518abab6bacbb72089658313 ("[libata] ata_piix: Enable parallel scan") says: This patch turns on parallel scanning for the ata_piix driver. This driver is used on most netbooks (no AHCI for cheap storage it seems). The scan is the dominating time factor in the kernel boot for these devices; with this flag it gets cut in half for the device I used for testing (eeepc). Alan took a look at the driver source and concluded that it ought to be safe to do for this driver. Alan has also checked with the hardware team. and it is all true but once we put all things together additional constraints for PATA controllers show up (some hardware registers have per-host not per-port atomicity) and we risk misprogramming the controller. I used the following test to check whether the issue is real: @@ -736,8 +736,20 @@ static void piix_set_piomode(struct ata_ (timings[pio][1] << 8); } pci_write_config_word(dev, master_port, master_data); - if (is_slave) + if (is_slave) { + if (ap->port_no == 0) { + u8 tmp = slave_data; + + while (slave_data == tmp) { + pci_read_config_byte(dev, slave_port, &tmp); + msleep(50); + } + + dev_printk(KERN_ERR, &dev->dev, "PATA parallel scan " + "race detected\n"); + } pci_write_config_byte(dev, slave_port, slave_data); + } /* Ensure the UDMA bit is off - it will be turned back on if UDMA is selected */ and it indeed triggered the error message. Lets fix all such races by adding an extra locking to ->set_piomode and ->set_dmamode methods for PATA controllers. [ Alan: would be better to take the host lock in libata-core for these cases so that we fix all the adapters in one swoop. "Looks fine as a temproary quickfix tho" ] Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28ata_piix: Add new short cable IDSteve Conklin
OriginalAuthor: Tony Espy <espy@canonical.com> Signed-off-by: Steve Conklin <sconklin@canonical.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-28ata_piix: Add new laptop short cable IDsSteve Conklin
OriginalAuthor: Michael Frey <michael.frey@canonical.com> Signed-off-by: Steve Conklin <sconklin@canonical.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10[libata] ata_piix: Enable parallel scanArjan van de Ven
This patch turns on parallel scanning for the ata_piix driver. This driver is used on most netbooks (no AHCI for cheap storage it seems). The scan is the dominating time factor in the kernel boot for these devices; with this flag it gets cut in half for the device I used for testing (eeepc). Alan took a look at the driver source and concluded that it ought to be safe to do for this driver. Alan has also checked with the hardware team. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10ata_piix: Remove stale commentAlan Cox
Combined mode pci quirk hacks went away - so the table to keep in sync no longer exists. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-10ata_piix: Turn on hotplugging support for older chipsAlan Cox
We can't do this for the later ones as they have all sorts of magic boot time stuff that needs reviewing and the like. However we can do it for the older ones and it turns out we need to as some IBM docking stations have a second PIIX series device in them and without this change you can't use it very well Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-06-05ata_piix: Add HP Compaq nc6000 to the broken poweroff listVille Syrjala
HP Compaq nc6000 suffers from the double disk spindown issue. Add it to the broken poweroff DMI list. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-11ata_piix: The Sony TZ90 needs the cable type hardcodingAlan Cox
The Sony TZ90 needs the cable type hardcoding. See bug #12734 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-05-11ata_piix: ICH7 does not support correct MWDMA timingsAlan Cox
See Errata documentation. The recommended workaround is to use PIO4 instead which will we automatically do by flagging this mode not available. Signed-off-by: Alan Cox <alan.cox@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-06ata_piix: VGN-BX297XP wants the controller power up on suspendTejun Heo
Sony VGN-BX297XP fails suspend if the controller is powered down when calling into ACPI suspend. Add the machine to piix_broken_suspend list. This problem was reported by GNUtoo@no-log.org on bko#10293. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: GNUtoo@no-log.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] convert drivers to use ata.h mode mask definesErik Inge Bolsø
No functional changes in this patch. Signed-off-by: Erik Inge Bolsø <knan-lkml@anduin.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-13ata_piix: add workaround for Samsung DB-P70Tejun Heo
Samsung DB-P70 somehow botched the first ICH9 SATA port. The board doesn't expose the first port but somehow SStatus reports link online while failing SRST protocol leading to repeated probe failures and thus long boot delay. Because the BIOS doesn't carry any identifying DMI information, the port can't be blacklisted safely. Fortunately, the controller does have subsystem vendor and ID set. It's unclear whether the subsystem IDs are used only for the board but it can be safely worked around by disabling SIDPR access and just using SRST works around the problem. Even when the workaround is triggered on an unaffected board the only side effect will be missing SCR access. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Joseph Jang <josephjang@gmail.com> Reported-by: Jonghyon Sohn <mrsohn@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA PIIX: Blacklist system that spins off disks during ACPI power offRafael J. Wysocki
Some notebooks from HP have the problem that their BIOSes attempt to spin down hard drives before entering ACPI system states S4 and S5. This leads to a yo-yo effect during system power-off shutdown and the last phase of hibernation when the disk is first spun down by the kernel and then almost immediately turned on and off by the BIOS. This, in turn, may result in shortening the disk's life times. To prevent this from happening we can blacklist the affected systems using DMI information. Blacklist HP 2510p that uses the ata_piix driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08libata: Add 32bit PIO supportAlan Cox
This matters for some controllers and in one or two cases almost doubles PIO performance. Add a bmdma32 operations set we can inherit and activate it for some controllers Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-08ata_piix: save, use saved and restore IOCFGTejun Heo
Certain ACPI implementations mess up IOCFG on _STM making libata detect cable type incorrectly after a suspend/resume cycle. This patch makes ata_piix save IOCFG on attach, use the saved value for things which aren't dynamic and restore it on detach so that the next driver also gets the BIOS initialized value. This patch contains the following changes. * makes ich_pata_cable_detect() use saved_iocfg. * make piix_iocfg_bit18_quirk() take @host and use saved_iocfg. * hpriv allocation moved upwards to save iocfg before doing anything else. This fixes bz#11879. Andreas Mohr reported and diagnosed the problem. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andreas Mohr <andi@lisas.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-29[libata] ata_piix: cleanup dmi strings checkingJiri Slaby
Commit ATA: piix, fix pointer deref on suspend fixed a possible oops in an ugly manner. Use newly introduced dmi_match() to make the code pretty again. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk> Cc: Tejun Heo <tj@kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-09ATA: piix, fix pointer deref on suspendJiri Slaby
Hi, I've found this issue in the mmotm 2008-12-02-17-08. -- Commit ata_piix: add borked Tecra M4 to broken suspend list introduced DMI variables checking, but they can be null, so that we possibly dereference null. Check if they are null and avoid checks in that case. Solves: BUG: unable to handle kernel NULL pointer dereference at 0000000000000000 IP: [<ffffffff8043da97>] piix_pci_device_suspend+0x117/0x230 Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Jeff Garzik <jgarzik@redhat.com> Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-01ata_piix: add borked Tecra M4 to broken suspend listTejun Heo
Tecra M4 sometimes forget what it is and reports bogus data via DMI which makes the machine evade broken suspend matching and thus fail suspend/resume. This patch updates piix_broken_suspend() such that it can match such case. As the borked DMI data is a bit generic, matching many entries to make the match more specific is necessary. As the usual DMI matching is limited to four entries, this patch uses hard coded manual matching. This is reported by Alexandru Romanescu. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Alexandru Romanescu <a_romanescu@yahoo.co.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31ATA: remove excess kernel-doc notationRandy Dunlap
Remove excess kernel-doc function parameter notation from drivers/ata/: Warning(drivers/ata/libata-core.c:1622): Excess function parameter or struct member 'fn' description in 'ata_pio_queue_task' Warning(drivers/ata/libata-core.c:4655): Excess function parameter or struct member 'err_mask' description in 'ata_qc_complete' Warning(drivers/ata/ata_piix.c:751): Excess function parameter or struct member 'udma' description in 'do_pata_set_dmamode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ata: Switch all my stuff to a common addressAlan Cox
2008-09-29ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
This patch updates the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29ata_piix: add Hercules EC-900 mini-notebook to ich_laptop short cable listHerton Ronaldo Krzesinski
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29ata_piix: drop merged SCR access and use slave_link insteadTejun Heo
Now that libata has slave_link, there's no need to keep ugly merged SCR access. Drop it and use slave_link instead. This results in simpler code and much better separate link handling for master and slave. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-13ata: duplicate variable sparse warningStephen Hemminger
drivers/ata/ata_piix.c:1502:7: warning: symbol 'rc' shadows an earlier one Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22ata_piix: IDE Mode SATA patch for Intel Ibex Peak DeviceIDsSeth Heasley
This patch adds the Intel Ibex Peak (PCH) IDE mode SATA Controller DeviceIDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-31ata_piix: subsys 106b:00a3 is apple ich8m tooTejun Heo
Subsys 106b:00a3 also is the weird apple ich8m which chokes when the latter two ports are accessed, add it. Reported by Felipe Sere. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Felipe Sere <dodofxp@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-18ata_piix: add TECRA M4 to broken suspend listTejun Heo
TOSHIBA also used "TECRA M4" in additon to "Tecra M4", add it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-04[libata] ata_piix: more acer short cable quirksColin Ian King
Add ICH6 on ACER Aspire 1694WLMi to list of laptops that use short cables rather than 80 wire OriginalAuthor: Tiago Sousa OriginalLocation: http://launchpadlibrarian.net/11627664/new.ich_laptop.short.cables.diff Bug: #187121 Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-30ata_piix: fix macbook ich8m problemsTejun Heo
ICH8M on macbooks are peculiar in that some of them lock up when the second port is enabled, some return bogus values on SIDPR access while yet others hang on SIDPR access. Also, the ich8m_apple_sata entry was wrongly added below generic ich8m entry making it virtually useless. This patch works around macbook ich8m problems by * moving ich8m_apple_sata entry above generic ich8m entry * dropping PIIX_FLAG_SIDPR from ich8m_apple_sata * adding subsystem 106b:00a1 as ich8m_apple_sata Reported and tested by MATSUBAYASHI. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: MATSUBAYASHI 'Shaolin' Kohji <shaolin@rhythmaning.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-06ata_piix: verify SIDPR access before enabling itTejun Heo
On certain configurations (certain macbooks), even though all the conditions for SIDPR access described in the datasheet are met, actually reading those registers just returns 0 and have no effect on write. Verify SIDPR is actually working before enabling it. This is reported by Ryan Roth in bz#10512. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Ryan Roth <ryan.roth@ch2m.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ata_piix: add Asus Eee 701 controller to short cable listDan McGee
The drive is directly soldered to the controller, so there is no cable at all. Remove the 40-wire assumption so the drive can operate at max speed. Before patch: $ dd if=/dev/sda of=/dev/null bs=2M count=64 iflag=direct 134217728 bytes (134 MB) copied, 5.29612 s, 25.3 MB/s After patch: $ dd if=/dev/sda of=/dev/null bs=2M count=64 iflag=direct 134217728 bytes (134 MB) copied, 3.94955 s, 34.0 MB/s Signed-off-by: Dan McGee <dpmcgee@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17libata: implement and use sata_std_hardreset()Tejun Heo
Implement sata_std_hardreset(), which simply wraps around sata_link_hardreset(). sata_std_hardreset() becomes new standard hardreset method for sata_port_ops and sata_sff_hardreset() moves from ata_base_port_ops to ata_sff_port_ops, which is where it really belongs. ata_is_builtin_hardreset() is added so that both ata_std_error_handler() and ata_sff_error_handler() skip both builtin hardresets if SCR isn't accessible. piix_sidpr_hardreset() in ata_piix.c is identical to sata_std_hardreset() in functionality and got replaced with the standard function. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: move generic hardreset code from sata_sff_hardreset() to ↵Tejun Heo
sata_link_hardreset() sata_sff_hardreset() contains link readiness wait logic which isn't SFF specific. Move that part into sata_link_hardreset(), which now takes two more parameters - @online and @check_ready. Both are optional. The former is out parameter for link onlineness after reset. The latter is used to wait for link readiness after hardreset. Users of sata_link_hardreset() is updated to use new funtionality and ahci_hardreset() is updated to use sata_link_hardreset() instead of sata_sff_hardreset(). This doesn't really cause any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: rename SFF functionsTejun Heo
SFF functions have confusing names. Some have sff prefix, some have bmdma, some std, some pci and some none. Unify the naming by... * SFF functions which are common to both BMDMA and non-BMDMA are prefixed with ata_sff_. * SFF functions which are specific to BMDMA are prefixed with ata_bmdma_. * SFF functions which are specific to PCI but apply to both BMDMA and non-BMDMA are prefixed with ata_pci_sff_. * SFF functions which are specific to PCI and BMDMA are prefixed with ata_pci_bmdma_. * Drop generic prefixes from LLD specific routines. For example, bfin_std_dev_select -> bfin_dev_select. The following renames are noteworthy. ata_qc_issue_prot() -> ata_sff_qc_issue() ata_pci_default_filter() -> ata_bmdma_mode_filter() ata_dev_try_classify() -> ata_sff_dev_classify() This rename is in preparation of separating SFF support out of libata core layer. This patch strictly renames functions and doesn't introduce any behavior difference. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17ata_piix: kill ich6_sata_ahci and clean upTejun Heo
ich6_sata_ahci and ich6_sata are identical. Kill ich6_sata_ahci and drop _ahci postfixes from controller ids, which doesn't really mean anything at this point. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17ata_piix: don't attach to ICH6M in ahci modeTejun Heo
ata_piix when attached to ICH6M in AHCI mode doesn't provide any benefit over using ahci and has detection problems. Don't let ata_piix claim ICH6M if it's in AHCI mode. This change makes ICH6R the only one which ata_piix can attach to even when it's in ahci mode which is necessary as some devices don't work properly under ahci mode. Drop PIIX_FLAG_AHCI and match the controller directly so that piix_disable_ahci() is called only for it. This change makes PIIX_SCC no longer used and it gets dropped too. This fixes bz 9491. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Robert M. Albrecht <romal@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-04-17libata: make reset related methods proper port operationsTejun Heo
Currently reset methods are not specified directly in the ata_port_operations table. If a LLD wants to use custom reset methods, it should construct and use a error_handler which uses those reset methods. It's done this way for two reasons. First, the ops table already contained too many methods and adding four more of them would noticeably increase the amount of necessary boilerplate code all over low level drivers. Second, as ->error_handler uses those reset methods, it can get confusing. ie. By overriding ->error_handler, those reset ops can be made useless making layering a bit hazy. Now that ops table uses inheritance, the first problem doesn't exist anymore. The second isn't completely solved but is relieved by providing default values - most drivers can just override what it has implemented and don't have to concern itself about higher level callbacks. In fact, there currently is no driver which actually modifies error handling behavior. Drivers which override ->error_handler just wraps the standard error handler only to prepare the controller for EH. I don't think making ops layering strict has any noticeable benefit. This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and their PMP counterparts propoer ops. Default ops are provided in the base ops tables and drivers are converted to override individual reset methods instead of creating custom error_handler. * ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs aren't accessible. sata_promise doesn't need to use separate error_handlers for PATA and SATA anymore. * softreset is broken for sata_inic162x and sata_sx4. As libata now always prefers hardreset, this doesn't really matter but the ops are forced to NULL using ATA_OP_NULL for documentation purpose. * pata_hpt374 needs to use different prereset for the first and second PCI functions. This used to be done by branching from hpt374_error_handler(). The proper way to do this is to use separate ops and port_info tables for each function. Converted. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use ops inheritanceTejun Heo
libata lets low level drivers build ata_port_operations table and register it with libata core layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This becomes worse for drivers which support related similar controllers which differ slightly. They share most of the operations except for a few. However, the driver still needs to list all operations for each variant. This results in large number of duplicate entries, which is not only inefficient but also error-prone as it becomes very difficult to tell what the actual differences are. This duplicate boilerplates all over the low level drivers also make updating the core layer exteremely difficult and error-prone. When compounded with multi-branched development model, it ends up accumulating inconsistencies over time. Some of those inconsistencies cause immediate problems and fixed. Others just remain there dormant making maintenance increasingly difficult. To rectify the problem, this patch implements ata_port_operations inheritance. To allow LLDs to easily re-use their own ops tables overriding only specific methods, this patch implements poor man's class inheritance. An ops table has ->inherits field which can be set to any ops table as long as it doesn't create a loop. When the host is started, the inheritance chain is followed and any operation which isn't specified is taken from the nearest ancestor which has it specified. This operation is called finalization and done only once per an ops table and the LLD doesn't have to do anything special about it other than making the ops table non-const such that libata can update it. libata provides four base ops tables lower drivers can inherit from - base, sata, pmp, sff and bmdma. To avoid overriding these ops accidentaly, these ops are declared const and LLDs should always inherit these instead of using them directly. After finalization, all the ops table are identical before and after the patch except for setting .irq_handler to ata_interrupt in drivers which didn't use to. The .irq_handler doesn't have any actual effect and the field will soon be removed by later patch. * sata_sx4 is still using old style EH and currently doesn't take advantage of ops inheritance. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: implement and use SHT initializersTejun Heo
libata lets low level drivers build scsi_host_template and register it to the SCSI layer. This allows low level drivers high level of flexibility but also burdens them with lots of boilerplate entries. This patch implements SHT initializers which can be used to initialize all the boilerplate entries in a sht. Three variants of them are implemented - BASE, BMDMA and NCQ - for different types of drivers. Note that entries can be overriden by putting individual initializers after the helper macro. All sht tables are identical before and after this patch. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-04-17libata: normalize port_info, port_operations and sht tablesTejun Heo
Over the time, port info, ops and sht structures developed quite a bit of inconsistencies. This patch updates drivers. * Enable/disable_pm callbacks added to all ahci ops tables. * Every driver for SFF controllers now uses ata_sff_port_start() instead of ata_port_start() unless the driver has custom implementation. * Every driver for SFF controllers now uses ata_pci_default_filter() unless the driver has custom implementation. * Removed an odd port_info->sht initialization from ata_piix.c. Likely a merge byproduct. * A port which has ATA_FLAG_SATA set doesn't need to set cable_detect to ata_cable_sata(). Remove it from via and mv port ops. * Some drivers had unnecessary .max_sectors initialization which is ignored and was missing .slave_destroy callback. Fixed. * Removed unnecessary sht initializations port_info's. * Removed onsolete scsi device suspend/resume callbacks from pata_bf54x. * No reason to set ata_pci_default_filter() and bmdma functions for PIO-only drivers. Remove those callbacks and replace ata_bmdma_irq_clear with ata_noop_irq_clear. * pata_platform sets port_start to ata_dummy_ret0. port_start can just be set to NULL. * sata_fsl supports NCQ but was missing qc_defer. Fixed. * pata_rb600_cf implements dummy port_start. Removed. Signed-off-by: Tejun Heo <htejun@gmail.com>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-15ata: fix sparse warning in ata_piix.cHarvey Harrison
drivers/ata/ata_piix.c:1655:8: warning: symbol 'rc' shadows an earlier one drivers/ata/ata_piix.c:1616:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
