On certain configurations (certain macbooks), even though all the
conditions for SIDPR access described in the datasheet are met,
actually reading those registers just returns 0 and have no effect on
write. Verify SIDPR is actually working before enabling it.
This is reported by Ryan Roth in bz#10512.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Ryan Roth <ryan.roth@ch2m.com>
The drive is directly soldered to the controller, so there is no cable at
all. Remove the 40-wire assumption so the drive can operate at max speed.
Before patch:
$ dd if=/dev/sda of=/dev/null bs=2M count=64 iflag=direct
134217728 bytes (134 MB) copied, 5.29612 s, 25.3 MB/s
After patch:
134217728 bytes (134 MB) copied, 3.94955 s, 34.0 MB/s
Signed-off-by: Dan McGee <dpmcgee@gmail.com>
Implement sata_std_hardreset(), which simply wraps around
sata_link_hardreset(). sata_std_hardreset() becomes new standard
hardreset method for sata_port_ops and sata_sff_hardreset() moves from
ata_base_port_ops to ata_sff_port_ops, which is where it really
belongs.
ata_is_builtin_hardreset() is added so that both
ata_std_error_handler() and ata_sff_error_handler() skip both builtin
hardresets if SCR isn't accessible.
piix_sidpr_hardreset() in ata_piix.c is identical to
sata_std_hardreset() in functionality and got replaced with the
standard function.
sata_sff_hardreset() contains link readiness wait logic which isn't
SFF specific. Move that part into sata_link_hardreset(), which now
takes two more parameters - @online and @check_ready. Both are
optional. The former is out parameter for link onlineness after
reset. The latter is used to wait for link readiness after hardreset.
Users of sata_link_hardreset() is updated to use new funtionality and
ahci_hardreset() is updated to use sata_link_hardreset() instead of
sata_sff_hardreset(). This doesn't really cause any behavior change.
SFF functions have confusing names. Some have sff prefix, some have
bmdma, some std, some pci and some none. Unify the naming by...
* SFF functions which are common to both BMDMA and non-BMDMA are
prefixed with ata_sff_.
* SFF functions which are specific to BMDMA are prefixed with
ata_bmdma_.
* SFF functions which are specific to PCI but apply to both BMDMA and
non-BMDMA are prefixed with ata_pci_sff_.
* SFF functions which are specific to PCI and BMDMA are prefixed with
ata_pci_bmdma_.
* Drop generic prefixes from LLD specific routines. For example,
bfin_std_dev_select -> bfin_dev_select.
The following renames are noteworthy.
ata_qc_issue_prot() -> ata_sff_qc_issue()
ata_pci_default_filter() -> ata_bmdma_mode_filter()
ata_dev_try_classify() -> ata_sff_dev_classify()
This rename is in preparation of separating SFF support out of libata
core layer. This patch strictly renames functions and doesn't
introduce any behavior difference.
ich6_sata_ahci and ich6_sata are identical. Kill ich6_sata_ahci and
drop _ahci postfixes from controller ids, which doesn't really mean
anything at this point.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
ata_piix when attached to ICH6M in AHCI mode doesn't provide any
benefit over using ahci and has detection problems. Don't let
ata_piix claim ICH6M if it's in AHCI mode.
This change makes ICH6R the only one which ata_piix can attach to even
when it's in ahci mode which is necessary as some devices don't work
properly under ahci mode. Drop PIIX_FLAG_AHCI and match the
controller directly so that piix_disable_ahci() is called only for it.
This change makes PIIX_SCC no longer used and it gets dropped too.
This fixes bz 9491.
Cc: Robert M. Albrecht <romal@gmx.de>
Currently reset methods are not specified directly in the
ata_port_operations table. If a LLD wants to use custom reset
methods, it should construct and use a error_handler which uses those
reset methods. It's done this way for two reasons.
First, the ops table already contained too many methods and adding
four more of them would noticeably increase the amount of necessary
boilerplate code all over low level drivers.
Second, as ->error_handler uses those reset methods, it can get
confusing. ie. By overriding ->error_handler, those reset ops can be
made useless making layering a bit hazy.
Now that ops table uses inheritance, the first problem doesn't exist
anymore. The second isn't completely solved but is relieved by
providing default values - most drivers can just override what it has
implemented and don't have to concern itself about higher level
callbacks. In fact, there currently is no driver which actually
modifies error handling behavior. Drivers which override
->error_handler just wraps the standard error handler only to prepare
the controller for EH. I don't think making ops layering strict has
any noticeable benefit.
This patch makes ->prereset, ->softreset, ->hardreset, ->postreset and
their PMP counterparts propoer ops. Default ops are provided in the
base ops tables and drivers are converted to override individual reset
methods instead of creating custom error_handler.
* ata_std_error_handler() doesn't use sata_std_hardreset() if SCRs
aren't accessible. sata_promise doesn't need to use separate
error_handlers for PATA and SATA anymore.
* softreset is broken for sata_inic162x and sata_sx4. As libata now
always prefers hardreset, this doesn't really matter but the ops are
forced to NULL using ATA_OP_NULL for documentation purpose.
* pata_hpt374 needs to use different prereset for the first and second
PCI functions. This used to be done by branching from
hpt374_error_handler(). The proper way to do this is to use
separate ops and port_info tables for each function. Converted.
libata lets low level drivers build ata_port_operations table and
register it with libata core layer. This allows low level drivers
high level of flexibility but also burdens them with lots of
boilerplate entries.
This becomes worse for drivers which support related similar
controllers which differ slightly. They share most of the operations
except for a few. However, the driver still needs to list all
operations for each variant. This results in large number of
duplicate entries, which is not only inefficient but also error-prone
as it becomes very difficult to tell what the actual differences are.
This duplicate boilerplates all over the low level drivers also make
updating the core layer exteremely difficult and error-prone. When
compounded with multi-branched development model, it ends up
accumulating inconsistencies over time. Some of those inconsistencies
cause immediate problems and fixed. Others just remain there dormant
making maintenance increasingly difficult.
To rectify the problem, this patch implements ata_port_operations
inheritance. To allow LLDs to easily re-use their own ops tables
overriding only specific methods, this patch implements poor man's
class inheritance. An ops table has ->inherits field which can be set
to any ops table as long as it doesn't create a loop. When the host
is started, the inheritance chain is followed and any operation which
isn't specified is taken from the nearest ancestor which has it
specified. This operation is called finalization and done only once
per an ops table and the LLD doesn't have to do anything special about
it other than making the ops table non-const such that libata can
update it.
libata provides four base ops tables lower drivers can inherit from -
base, sata, pmp, sff and bmdma. To avoid overriding these ops
accidentaly, these ops are declared const and LLDs should always
inherit these instead of using them directly.
After finalization, all the ops table are identical before and after
the patch except for setting .irq_handler to ata_interrupt in drivers
which didn't use to. The .irq_handler doesn't have any actual effect
and the field will soon be removed by later patch.
* sata_sx4 is still using old style EH and currently doesn't take
advantage of ops inheritance.
libata lets low level drivers build scsi_host_template and register it
to the SCSI layer. This allows low level drivers high level of
flexibility but also burdens them with lots of boilerplate entries.
This patch implements SHT initializers which can be used to initialize
all the boilerplate entries in a sht. Three variants of them are
implemented - BASE, BMDMA and NCQ - for different types of drivers.
Note that entries can be overriden by putting individual initializers
after the helper macro.
All sht tables are identical before and after this patch.
Over the time, port info, ops and sht structures developed quite a bit
of inconsistencies. This patch updates drivers.
* Enable/disable_pm callbacks added to all ahci ops tables.
* Every driver for SFF controllers now uses ata_sff_port_start()
instead of ata_port_start() unless the driver has custom
implementation.
* Every driver for SFF controllers now uses ata_pci_default_filter()
unless the driver has custom implementation.
* Removed an odd port_info->sht initialization from ata_piix.c.
Likely a merge byproduct.
* A port which has ATA_FLAG_SATA set doesn't need to set cable_detect
to ata_cable_sata(). Remove it from via and mv port ops.
* Some drivers had unnecessary .max_sectors initialization which is
ignored and was missing .slave_destroy callback. Fixed.
* Removed unnecessary sht initializations port_info's.
* Removed onsolete scsi device suspend/resume callbacks from
pata_bf54x.
* No reason to set ata_pci_default_filter() and bmdma functions for
PIO-only drivers. Remove those callbacks and replace
ata_bmdma_irq_clear with ata_noop_irq_clear.
* pata_platform sets port_start to ata_dummy_ret0. port_start can
just be set to NULL.
* sata_fsl supports NCQ but was missing qc_defer. Fixed.
* pata_rb600_cf implements dummy port_start. Removed.
During the last step of hibernation in the "platform" mode (with the
help of ACPI) we use the suspend code, including the devices'
->suspend() methods, to prepare the system for entering the ACPI S4
system sleep state.
But at least for some devices the operations performed by the
->suspend() callback in that case must be different from its operations
during regular suspend.
For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and
pass it to the device drivers' ->suspend() methods during the last phase
of hibernation, so that they can distinguish this case and handle it as
appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a
special way and need to handle PM_EVENT_HIBERNATE in the same way.
These changes are necessary to fix a hibernation regression related
to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488).
Acked-by: Pavel Machek <pavel@ucw.cz>
Tested-by: Jeff Chua <jeff.chua.linux@gmail.com>
drivers/ata/ata_piix.c:1655:8: warning: symbol 'rc' shadows an earlier one
drivers/ata/ata_piix.c:1616:6: originally declared here
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch fixes the following section mismatches:
<-- snip -->
WARNING: drivers/ata/built-in.o(.text+0x15072): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_sata_map()
WARNING: drivers/ata/built-in.o(.text+0x150dd): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_pcs()
WARNING: drivers/ata/built-in.o(.text+0x150e5): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_init_sidpr()
WARNING: drivers/ata/built-in.o(.text+0x15107): Section mismatch in reference from the function piix_init_one() to the function .devinit.text:piix_check_450nx_errata()
<-- snip -->
Signed-off-by: Adrian Bunk <bunk@kernel.org>
piix_merge_scr() can become static.
This patch adds the Intel ICH10 IDE mode SATA Controller DeviceID's.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
For ICH8, SCRs can be accessed using index and data register pair
located at BAR 5. This patch implements support for it such that PHY
status, errors and hardreset are available for those controllers.
This is the only case where two devices on a PATA channel have access
to SCRs and creates a unique problem of mapping two SCRs to one link.
Note that this is different from PMP case in that they aren't quite
separate links - e.g. softreset resets both devices.
This problem is worked around by merging the SCR values. To upper
layer, it looks like there is a single link with one set of SCRs but
with two devices. This works well enough for PHY event, error
reporting and hardreset.
Supporting hardreset is important because in rare cases SATA devices
fail to recover without it after PHY errors.
ata_piix requires more configuration during initialization than most
other SFF compliant controllers and one-go initialzation with
ata_pci_one() is too rigid.
This patch converts ata_piix to use two step prepare - activate
initialization used by other more advanced controllers. This
conversion brings the happy side effect of enabling PCI device before
accessing PCI configuration registers. Other than that, there
shouldn't be any behavior change.
Kill PIIX_FLAG_SCR, PIIX_PORT_ENABLED and PIIX_PORT_PRESENT. These
are unused.
Separate controller IDs into a separate enum as Jeff requested.
Add Toshiba Satellite R20 and Tecra M6 to broken suspend list. Matt
Piermarini reported and provided the M6 patch. This is from OSDL bug 7780.
Signed-off-by: Peter Schwenke <peter@bluetoad.com.au>
Cc: Matt Piermarini <mattpiermarini@yahoo.com>
Acked-by: Tejun Heo <htejun@gmail.com>
VMware ich4 emulation incorrectly sets DMA_ERR on TF error. Ignore
it.
Add Toshiba Tecra M4 to broken suspend list. This is from OSDL
bugzilla bug 7780.
Add more toshiba laptops to broken suspend list. This is from OSDL
bugzilla bug 7780.
tj: re-formatted patch and added description and SOB.
Should use ioread* as discussed previously
Signed-off-by: Alan Cox <alan@redhat.com>
ICH8 and 9 use two SFF controllers to show 6 SATA ports. The first
controllre hosts the first 4 ports while the second one hosts the last
2. The PCS register of the first controller encompasses the first
four ports or all six ports depending on configuration while PCS of
the second controller controls the last two ports. Using 0xf for the
first controller and 0x3 for the second controller always result in
the correct configuration.
ICH8M on apple macbook pro occasionally locks up completely during PCS
initialization if ports other than the first one are enabled. Add a
separate controller ID and only enable the first port.
tj: commit description added and patch updated to fit with the
previous controller ID update.
Signed-off-by: Thomas Rohwer <tr@tng.de>
Move piix_pata_mwdma to top, rename ich9_2port_sata to ich8_2port_sata
for consistency and use automatically incremented values instead of
assigning fixed values to ease adding new controller IDs.
Satellite U205 has alternate product name where the satellite part is
all capatalized. Add it to the blacklist.
This is reported by Ross Patterson in kernel bugzilla bug #7780.
Cc: Ross Patterson <me@rpatterson.net>
Please warmly welcome the PRO variant of Satellite U200 to the broken
suspend list.
Original patch is from Yann Chachkoff. Patch reformatted and
forwarded by Tejun Heo.
Signed-off-by: Yann Chachkoff <yann.chachkoff@myrealbox.com>
Keeping the list in sync with the old IDE driver
Tackle the relatively sane complaints of checkpatch --file.
The vast majority is indentation and whitespace changes, the rest are
* #include fixes
* printk KERN_xxx prefix addition
* BSS/initializer cleanups
This patch adds a port map for ICH9 and ICH8 SATA controllers that have only 2 ports available in that mode.
Reported by Andreas Messer.
This patch removes some incorrect formatting spaces and replaces them with tabs.
Use a form of array init that is less fragile, less sensitive to trivial
typos and ordering mismatches.
It was always set to ata_port_disable(). Removed the hook, and replaced
the very few ap->ops->port_disable() callsites with direct calls to
ata_port_disable().
* ->irq_ack() is redundant to what the irq handler already
performs... chk-status + irq-clear. Furthermore, it is only
called in one place, when screaming-irq-debugging is enabled,
so we don't want to bother with a hook just for that.
* ata_dummy_irq_on() is only ever used in drivers that have
no callpath reaching ->irq_on(). Remove .irq_on hook from
those drivers, and the now-unused ata_dummy_irq_on()
There is another outstanding issue with ata_piix.c. Intel has never
officially supported anything faster than PATA 100MB/s.
But, the ata_piix.c driver "define" the ICH5 & ICH7 as UDMA6 (aka 133MB/s)
capable. [ Well, no one has probably noticed it before, because there is bug
in do_pata_set_dmamode... Just look at
libata_atapiix_enable_real_udma133.patch and you'll see what wrong with it. ]
Here are Intel's datasheets for the affected chipsets: ICH5 Datasheet:
http://www.intel.com/design/chipsets/datashts/252516.htm (See note on page
183: "... the ICH5 supports reads at the maximum rate of 100MB/s.")
ICH7 Datasheet: http://www.intel.com/design/chipsets/datashts/307013.htm (See
first note on page 190: "... the ICH7 supports reads at the maximum rate of
100MB/s.")
They are two different ways to deal with it:
- Either -
1. replace all ich_pata_133 with ich_pata_100.
(libata_atapiix_disable_udma6.diff - diff from 2.6.22 )
- Or -
2. keep all ich_pata_133 and fix the bug in "do_pata_set_dmamode".
(libata_atapiix_enable_real_udma133.patch - diff from 2.6.22) If there are
any concerns about the safety of the patch patch:
http://lkml.org/lkml/2007/7/6/292 (It was already tested by an Intel
employee, but I guess a bit more user input is necessary here... )
This patch implements 1.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Tejun Heo <htejun@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Make reset methods and related functions deal with ata_link instead of
ata_port.
* ata_do_reset()
* ata_eh_reset()
* all prereset/reset/postreset methods and related functions
This patch introduces no behavior change.
Three main sets of changes:
1) dmi_get_system_info() return value should have been marked const,
since callers should not be changing that data.
2) const-ify DMI internals, since DMI firmware tables should,
whenever possible, be marked const to ensure we never ever write to
that data area.
3) const-ify DMI API, to enable marking tables const where possible
in low-level drivers.
And if we're really lucky, this might enable some additional
optimizations on the part of the compiler.
The bulk of the changes are #2 and #3, which are interrelated. #1 could
have been a separate patch, but it was so small compared to the others,
it was easier to roll it into this changeset.
There's a different version of DMI table for TECRA M3 where it has
proper vendor and product name entry. Add the entry to the broken
suspend list.
Angus Turnbull reported and provided initial patch.
Cc: Angus Turnbull <angus@twinhelix.com>
If you don't terminate a list, bad things happen...
Bump the versions for drivers that were modified, but had not already
had a version number bump.
Some notebooks need bit18 of IOCFG to be cleared for the drive bay to
work even though the bit is NOOP according to the datasheet. This
patch implement IOCFG bit18 quirk and apply it to Clevo M570U.
http://bugzilla.kernel.org/show_bug.cgi?id=8051
Cc: D. Angelis <dangelis@beta-cae.gr>
Satellite U200 also shares the problem. Add it to the broken suspend
list. Original patch from John Schember.
Cc: John Schember <john@nachtimwald.com>
Resend trying to remove 8-bit characters in the email.
This patch adds the Intel Tolapai IDE mode SATA controller DID's.
Add TECRA M7 to broken suspend list. Reported by Marie Koreen.
Cc: Marie Koreen <kbug@koreen.com>
