path: root/drivers/ata/ata_generic.c
2007-02-09libata: add another IRQ calls (libata drivers)Akira Iguchi
This patch is against each libata driver. Two IRQ calls are added in ata_port_operations. - irq_on() is used to enable interrupts. - irq_ack() is used to acknowledge a device interrupt. In most drivers, ata_irq_on() and ata_irq_ack() are used for irq_on and irq_ack respectively. In some drivers (ex: ahci, sata_sil24) which cannot use them as is, ata_dummy_irq_on() and ata_dummy_irq_ack() are used. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: convert to iomapTejun Heo
Convert libata core layer and LLDs to use iomap. * managed iomap is used. Pointer to pcim_iomap_table() is cached at host->iomap and used through out LLDs. This basically replaces host->mmio_base. * if possible, pcim_iomap_regions() is used Most iomap operation conversions are taken from Jeff Garzik <jgarzik@pobox.com>'s iomap branch. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09libata: update libata LLDs to use devresTejun Heo
Update libata LLDs to use devres. Core layer is already converted to support managed LLDs. This patch simplifies initialization and fixes many resource related bugs in init failure and detach path. For example, all converted drivers now handle ata_device_add() failure gracefully without excessive resource rollback code. As most resources are released automatically on driver detach, many drivers don't need or can do with much simpler ->{port|host}_stop(). In general, stop callbacks are need iff port or host needs to be given commands to shut it down. Note that freezing is enough in many cases and ports are automatically frozen before being detached. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-24libata: set_mode, Fix the FIXMEAlan
When set_mode() changed ->set_mode didn't adapt. This makes the needed changes and removes the relevant FIXME case. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-03[PATCH] libata: kill unnecessary sht->max_sectors initializationsTejun Heo
sht->max_sectors is overrided unconditionally in ->slave_configure. There's no reason to set it to any value. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-12-01[PATCH] PATA libata: suspend/resume simple casesAlan
This patch adds the suspend/resume callbacks for drivers which don't need any additional help (beyond the pci resume quirk patch I posted earlier anyway). Also bring version numbers back inline with master copies. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-01[PATCH] pci_module_init-convertion-in-ata_genericc fixAlan Cox
Acked-by: Alan Cox <alan@redhat.com> but please apply as follows to keep revision id straight Cc: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-01[PATCH] pci_module_init convertion in ata_generic.cHenrik Kretzschmar
pci_module_init convertion in ata_generic.c. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-29[PATCH] libata: add missing sht->slave_destroyTejun Heo
Many LLDs are missing sht->slave_destroy. The method is mandatory to support device warm unplugging (echo 1 > /sys/.../delete). Without it, libata might access released scsi device. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-09-27[libata] Don't use old-EH ->eng_timeout() hook when not neededJeff Garzik
The PATA driver set got converted to the new error handling setup, but the old hooks were accidentally left in place. Now, removed. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-31[libata #pata-drivers] Trim trailing whitespace.Jeff Garzik
2006-08-29[libata] Add a bunch of PATA drivers.Jeff Garzik
The vast majority of drivers and changes are from Alan Cox. Albert Lee contributed and maintains pata_pdc2027x. Adrian Bunk, Andrew Morton, and Tejun Heo contributed various minor fixes and updates. Signed-off-by: Jeff Garzik <jeff@garzik.org>
