path: root/drivers/acpi
2006-01-20[ACPI] delete message "**** SET: Misaligned resource pointer:"Len Brown
This check, added in ACPICA 20051021, was overly paranoid. Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-16Revert "[ACPI] fix pnpacpi regression resulting from ACPICA 20051117"Len Brown
This reverts ed349a8a0a780ed27e2a765f16cee54d9b63bfee commit.
2006-01-07[ACPI] acpi_memhotplug.c build fixKAMEZAWA Hiroyuki
drivers/acpi/acpi_memhotplug.c: In function `acpi_memory_get_device_resources': drivers/acpi/acpi_memhotplug.c:101: error: structure has no member named `attribute' drivers/acpi/acpi_memhotplug.c:103: error: structure has no member named `attribute' drivers/acpi/acpi_memhotplug.c: In function `acpi_memory_disable_device': drivers/acpi/acpi_memhotplug.c:253: warning: unused variable `attr' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-07Pull pnpacpi into acpica branchLen Brown
2006-01-05[ACPI] fix pnpacpi regression resulting from ACPICA 20051117Len Brown
In ACPICA 20051117, acpi_walk_resources() started sending ACPI_RESOURCE_TYPE_END_TAG to the callback routine which wasn't prepared for it, causing _CRS to fail and PnPACPI to not recognize any devices: pnp: ACPI device : hid PNP0C02 pnp: PnPACPI: unknown resource type 7 pnp: PnPACPI: METHOD_NAME__CRS failure for PNP0c02 Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-28[ACPI] fix osl.c build warningLen Brown
typecheck complains on i386 that u32 != unsigned long Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-28[ACPI] ACPICA 20051216Bob Moore
Implemented optional support to allow unresolved names within ASL Package objects. A null object is inserted in the package when a named reference cannot be located in the current namespace. Enabled via the interpreter slack flag which Linux has enabled by default (acpi=strict to disable slack). This should eliminate AE_NOT_FOUND exceptions seen on machines that contain such code. Implemented an optimization to the initialization sequence that can improve boot time. During ACPI device initialization, the _STA method is now run if and only if the _INI method exists. The _STA method is used to determine if the device is present; An _INI can only be run if _STA returns present, but it is a waste of time to run the _STA method if the _INI does not exist. (Prototype and assistance from Dong Wei) Implemented use of the C99 uintptr_t for the pointer casting macros if it is available in the current compiler. Otherwise, the default (void *) cast is used as before. Fixed some possible memory leaks found within the execution path of the Break, Continue, If, and CreateField operators. (Valery Podrezov) Fixed a problem introduced in the 20051202 release where an exception is generated during method execution if a control method attempts to declare another method. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-22Pull bug3410 into release branchLen Brown
2005-12-22Pull owner_id into release branchLen Brown
2005-12-22[ACPI] fix build warning from owner_id patchLen Brown
2005-12-22[ACPI] fix passive cooling regressionThomas Renninger
Return logic was inverted. Going for changing the return value to not return zero as it is makes more sense regarding the naming of the function (cpu_has_cpufreq()). http://bugzilla.kernel.org/show_bug.cgi?id=3410 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-21[ACPI] increase owner_id limit to 64 from 32Alex Williamson
This is an interim patch until changes in an updated ACPICA core increase the limit to 255. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-14Auto-update from upstreamLen Brown
2005-12-12[PATCH] ACPI: fix sleeping whilst atomic warnings on resumeDave Jones
This has been broken for months. On resume, we call acpi_pci_link_set() with interrupts off, so we get a warning when we try to do a kmalloc of non atomic memory. The actual allocation is just 2 long's (plus extra byte for some reason I can't fathom), so a simple conversion to GFP_ATOMIC is probably the safest way to fix this. The error looks like this.. Debug: sleeping function called from invalid context at mm/slab.c:2486 in_atomic():0, irqs_disabled():1 [<c0143f6c>] kmem_cache_alloc+0x40/0x56 [<c0206a2e>] acpi_pci_link_set+0x3f/0x17f [<c0206f96>] irqrouter_resume+0x1e/0x3c [<c0239bca>] __sysdev_resume+0x11/0x6b [<c0239e88>] sysdev_resume+0x34/0x52 [<c023de21>] device_power_up+0x5/0xa Signed-off-by: Dave Jones <davej@redhat.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-10[ACPI] ACPICA 20051202Bob Moore
Modified the parsing of control methods to no longer create namespace objects during the first pass of the parse. Objects are now created only during the execute phase, at the moment the namespace creation operator is encountered in the AML (Name, OperationRegion, CreateByteField, etc.) This should eliminate ALREADY_EXISTS exceptions seen on some machines where reentrant control methods are protected by an AML mutex. The mutex will now correctly block multiple threads from attempting to create the same object more than once. Increased the number of available Owner Ids for namespace object tracking from 32 to 255. This should eliminate the OWNER_ID_LIMIT exceptions seen on some machines with a large number of ACPI tables (either static or dynamic). Enhanced the namespace dump routine to output the owner ID for each namespace object. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051117Bob Moore
Fixed a problem in the AML parser where the method thread count could be decremented below zero if any errors occurred during the method parse phase. This should eliminate AE_AML_METHOD_LIMIT exceptions seen on some machines. This also fixed a related regression with the mechanism that detects and corrects methods that cannot properly handle reentrancy (related to the deployment of the new OwnerId mechanism.) Eliminated the pre-parsing of control methods (to detect errors) during table load. Related to the problem above, this was causing unwind issues if any errors occurred during the parse, and it seemed to be overkill. A table load should not be aborted if there are problems with any single control method, thus rendering this feature rather pointless. Fixed a problem with the new table-driven resource manager where an internal buffer overflow could occur for small resource templates. Implemented a new external interface, acpi_get_vendor_resource() This interface will find and return a vendor-defined resource descriptor within a _CRS or _PRS method via an ACPI 3.0 UUID match. (from Bjorn Helgaas) Removed the length limit (200) on string objects as per the upcoming ACPI 3.0A specification. This affects the following areas of the interpreter: 1) any implicit conversion of a Buffer to a String, 2) a String object result of the ASL Concatentate operator, 3) the String object result of the ASL ToString operator. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051102Bob Moore
Modified the subsystem initialization sequence to improve GPE support. The GPE initialization has been split into two parts in order to defer execution of the _PRW methods (Power Resources for Wake) until after the hardware is fully initialized and the SCI handler is installed. This allows the _PRW methods to access fields protected by the Global Lock. This will fix systems where a NO_GLOBAL_LOCK exception has been seen during initialization. Fixed a regression with the ConcatenateResTemplate() ASL operator introduced in the 20051021 release. Implemented support for "local" internal ACPI object types within the debugger "Object" command and the acpi_walk_namespace() external interfaces. These local types include RegionFields, BankFields, IndexFields, Alias, and reference objects. Moved common AML resource handling code into a new file, "utresrc.c". This code is shared by both the Resource Manager and the AML Debugger. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051021Bob Moore
Implemented support for the EM64T and other x86_64 processors. This essentially entails recognizing that these processors support non-aligned memory transfers. Previously, all 64-bit processors were assumed to lack hardware support for non-aligned transfers. Completed conversion of the Resource Manager to nearly full table-driven operation. Specifically, the resource conversion code (convert AML to internal format and the reverse) and the debug code to dump internal resource descriptors are fully table-driven, reducing code and data size and improving maintainability. The OSL interfaces for Acquire and Release Lock now use a 64-bit flag word on 64-bit processors instead of a fixed 32-bit word. (Alexey Starikovskiy) Implemented support within the resource conversion code for the Type-Specific byte within the various ACPI 3.0 *WordSpace macros. Fixed some issues within the resource conversion code for the type-specific flags for both Memory and I/O address resource descriptors. For Memory, implemented support for the MTP and TTP flags. For I/O, split the TRS and TTP flags into two separate fields. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-06Pull release into acpica branchLen Brown
2005-12-06Auto-update from upstreamLen Brown
2005-12-05Pull 5165 into release branchLen Brown
2005-12-05[ACPI] correct earlier SMP deep C-states on HT patchDavid Shaohua Li
http://bugzilla.kernel.org/show_bug.cgi?id=5165 Change polarity of test for PLVL2_UP flag. Skip promotion/demotion code when not needed. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-02Add missing "local_irq_enable()" to C2/C3 exit logicLinus Torvalds
Silly bug crept in with the C2/C3 TIF_POLLING_NRFLAG fixes. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-02[PATCH] Fix TIF_POLLING_NRFLAG in ACPI idle routinesNick Piggin
Commit 64c7c8f88559624abdbe12b5da6502e8879f8d28 broke the ACPI C2 and C3 sleep states, because it left TIF_POLLING_NRFLAG active even though those states do not actually poll the reschedule flag at all. As a result, the CPU wouldn't get sent an IPI when it was to be woken up, and would only notice that it had runnable processes on the next timer tick. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01Pull 3410 into release branchLen Brown
2005-12-01Pull 5452 into release branchLen Brown
2005-12-01Pull 5571 into release branchLen Brown
2005-11-30[ACPI] fix 2.6.13 boot hang regression on HT box w/ broken BIOSVenkatesh Pallipadi
http://bugzilla.kernel.org/show_bug.cgi?id=5452 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] Fix Null pointer deref in video/lcd/brightnessThomas Renninger
http://bugzilla.kernel.org/show_bug.cgi?id=5571 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Yu Luming <luming.yu@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] Allow return to active cooling mode once passive mode is enteredThomas Renninger
http://bugzilla.kernel.org/show_bug.cgi?id=3410 https://bugzilla.novell.com/show_bug.cgi?id=131543 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Yu Luming <luming.yu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-11-30[ACPI] delete "default y" on Kconfig for ibm_acpi extras driverBorislav Petkov
Signed-off-by: Borislav Petkov <petkov@uni-muenster.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] IA64 build: blacklist.c is used only on X86Al Viro
Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Len Brown <len.brown@intel.com> (cherry picked from ef4611613657dfb8af8d336f2f61f08cfcdc9d8a commit)
2005-11-30Pull 5165 into release branchLen Brown
2005-11-30[ACPI] fix HP nx8220 boot hang regressionThomas Renninger
This patch reverts the acpi_bus_find_driver() return value check that came in via the PCI tree via 3fb02738b0fd36f47710a2bf207129efd2f5daa2 [PATCH] acpi bridge hotadd: Allow ACPI .add and .start operations to be done independently This particular change broke booting of some HP/Compaq laptops unless acpi=noirq is used. http://bugzilla.kernel.org/show_bug.cgi?id=5221 https://bugzilla.novell.com/show_bug.cgi?id=116763 Signed-off-by: Thomas Renninger <trenn@suse.de> Cc: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] Add support for FADT P_LVL2_UP flagVenkatesh Pallipadi
which tells us if C2 is valid for UP-only, or SMP. As there is no separate bit for C3, use P_LVL2_UP bit to cover both C2 and C3. http://bugzilla.kernel.org/show_bug.cgi?id=5165 Signed-off-by: Venkatesh Pallipadi<venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> (cherry picked from 28b86b368af3944eb383078fc5797caf2dc8ce44 commit)
2005-11-30[ACPI] Prefer _CST over FADT for C-state capabilitiesVenkatesh Pallipadi
Note: This ACPI standard compliance may cause regression on some system, if they have _CST present, but _CST value is bogus. "nocst" module parameter should workaround that regression. http://bugzilla.kernel.org/show_bug.cgi?id=5165 Signed-off-by: Venkatesh Pallipadi<venkatesh.pallipadi@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> (cherry picked from 883baf7f7e81cca26f4683ae0d25ba48f094cc08 commit)
2005-11-18Fix ACPI processor power block initializationLinus Torvalds
Properly clear the memory, and set "pr->flags.power" only if a C2 or deeper state is valid (to make the code match both the comment and previous behaviour). This fixes a boot-time lockup reported by Maneesh Soni when using "maxcpus=1". Acked-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] pciehp: clean-up how we request control of hotplug hardwarerajesh.shah@intel.com
This patch further tweaks how we request control of hotplug controller hardware from BIOS. We first search the ACPI namespace corresponding to a specific hotplug controller looking for an _OSC or OSHP method. On failure, we successively move to the ACPI parent object, till we hit the highest level host bridge in the hierarchy. This allows for different types of BIOS's which place the _OSC/OSHP methods at various places in the acpi namespace, while still not encroaching on the namespace of some other root level host bridge. This patch also introduces a new load time option (pciehp_force) that allows us to bypass all _OSC/OSHP checking. Not supporting these methods seems to be be the most common ACPI firmware problem we've run into. This will still _not_ allow the pciehp driver to work correctly if the BIOS really doesn't support pciehp (i.e. if it doesn't generate a hotplug interrupt). Use this option with caution. Some BIOS's may deliberately not build any _OSC/OSHP methods to make sure it retains control the hotplug hardware. Using the pciehp_force parameter for such systems can lead to two separate entities trying to control the same hardware. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: misc remaining driversJesper Juhl
This is the remaining misc drivers/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in misc files in drivers/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Acked-by: Roland Dreier <rolandd@cisco.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <len.brown@intel.com> Acked-by: "Antonino A. Daplas" <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] drivers/acpi: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use msecs_to_jiffies() instead of direct HZ division to avoid rounding errors. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce .valid callback for pm_opsShaohua Li
Add pm_ops.valid callback, so only the available pm states show in /sys/power/state. And this also makes an earlier states error report at enter_state before we do actual suspend/resume. Signed-off-by: Shaohua Li<shaohua.li@intel.com> Acked-by: Pavel Machek<pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug: move section_mem_map alloc to sparse.cDave Hansen
This basically keeps up from having to extern __kmalloc_section_memmap(). The vaddr_in_vmalloc_area() helper could go in a vmalloc header, but that header gets hard to work with, because it needs some arch-specific macros. Just stick it in here for now, instead of creating another header. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Lion Vollnhals <webmaster@schiggl.de> Signed-off-by: Jiri Slaby <xslaby@fi.muni.cz> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-19[PATCH] `unaligned access' in acpi get_root_bridge_busnr()Peter Chubb
In drivers/acpi/glue.c the address of an integer is cast to the address of an unsigned long. This breaks on systems where a long is larger than an int --- for a start the int can be misaligned; for a second the assignment through the pointer will overwrite part of the next variable. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Acked-by: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-17[PATCH] Fix /proc/acpi/events around suspendPavel Machek
Fix -EIO on /proc/acpi/events after suspends. This actually breaks suspending by power button in many setups. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[ACPI] clean up ACPICA 20050916's rscalc typedef syntaxLen Brown
