path: root/drivers/acpi/utils.c
2006-08-16ACPI: avoid irqrouter_resume might_sleep oops on resume from S4Len Brown
__might_sleep+0x8e/0x93 acpi_os_wait_semaphore+0x50/0xa3 acpi_ut_acquire_mutex+0x28/0x6a acpi_ns_get_node+0x46/0x88 acpi_ns_evaluate+0x2d/0xfc acpi_rs_set_srs_method_data+0xc5/0xe1 acpi_set_current_resources+0x31/0x3f acpi_pci_link_set+0xfc/0x1a5 irqrouter_resume+0x48/0x5f and __might_sleep+0x8e/0x93 kmem_cache_alloc+0x2a/0x8f acpi_evaluate_integer+0x32/0x96 acpi_bus_get_status+0x30/0x84 acpi_pci_link_set+0x12a/0x1a5 irqrouter_resume+0x48/0x5f http://bugzilla.kernel.org/show_bug.cgi?id=6810 Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-27ACPI: un-export ACPI_WARNING() -- use printk(KERN_WARNING...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-05-13ACPI: fix potential memory leak in acpi_evaluate_integer() error pathVasily Averin
Signed-off-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
