ACPI_USE_LOCAL_CACHE will never be defined by the Linux kernel,
and thus utcache.c will always be dead code.
Signed-off-by: Len Brown <len.brown@intel.com>
acpi.h now includes only the "public" acpica headers. All other
acpica headers are "private" and should not be included by acpica
users. One new file, accommon.h is used to include the commonly
used private headers for acpica code generation. Future plans
are to move all private headers to a new subdirectory.
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Added 2007 copyright to all module headers and signons. This affects
virtually every file in the ACPICA core subsystem, iASL compiler,
and the utilities.
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com>
Debugger: Enhanced the Statistics/Memory command to emit the
total (maximum) memory used during execution, as well as the
maximum memory consumed by each of the various object types.
Removed a device initialization optimization introduced in
20051216 where the _STA method was not run unless an _INI
was also present for the same device. This optimization
could cause problems because it could allow _INI methods
to be run within a not-present device subtree (If a
not-present device had no _INI, _STA would not be run,
the not-present status would not be discovered, and the
children of the device would be incorrectly traversed.)
Implemented a new _STA optimization where namespace
subtrees that do not contain _INI are identified and
ignored during device initialization. Selectively running
_STA can significantly improve boot time on large machines
(with assistance from Len Brown.)
Implemented support for the device initialization case
where the returned _STA flags indicate a device not-present
but functioning. In this case, _INI is not run, but the
device children are examined for presence, as per the
ACPI specification.
Implemented an additional change to the IndexField support
in order to conform to MS behavior. The value written to
the Index Register is not simply a byte offset, it is a
byte offset in units of the access width of the parent
Index Field. (Fiodor Suietov)
Defined and deployed a new OSL interface,
acpi_os_validate_address(). This interface is called during
the creation of all AML operation regions, and allows
the host OS to exert control over what addresses it will
allow the AML code to access. Operation Regions whose
addresses are disallowed will cause a runtime exception
when they are actually accessed (will not affect or abort
table loading.)
acpi_os_validate_interface(). This interface allows the host OS
to match the various "optional" interface/behavior strings
for the _OSI predefined control method as appropriate
(with assistance from Bjorn Helgaas.)
Restructured and corrected various problems in the
exception handling code paths within DsCallControlMethod
and DsTerminateControlMethod in dsmethod (with assistance
from Takayoshi Kochi.)
Modified the Linux source converter to ignore quoted string
literals while converting identifiers from mixed to lower
case. This will correct problems with the disassembler
and other areas where such strings must not be modified.
The ACPI_FUNCTION_* macros no longer require quotes around
the function name. This allows the Linux source converter
to convert the names, now that the converter ignores
quoted strings.
Implemented the use of a cache object for all internal
namespace nodes. Since there are about 1000 static nodes
in a typical system, this will decrease memory use for
cache implementations that minimize per-allocation overhead
(such as a slab allocator.)
Removed the reference count mechanism for internal
namespace nodes, since it was deemed unnecessary. This
reduces the size of each namespace node by about 5%-10%
on all platforms. Nodes are now 20 bytes for the 32-bit
case, and 32 bytes for the 64-bit case.
Optimized several internal data structures to reduce
object size on 64-bit platforms by packing data within
the 64-bit alignment. This includes the frequently used
ACPI_OPERAND_OBJECT, of which there can be ~1000 static
instances corresponding to the namespace objects.
Added two new strings for the predefined _OSI method:
"Windows 2001.1 SP1" and "Windows 2006".
Split the allocation tracking mechanism out to a separate
file, from utalloc.c to uttrack.c. This mechanism appears
to be only useful for application-level code. Kernels may
wish to not include uttrack.c in distributions.
Removed all remnants of the obsolete ACPI_REPORT_* macros
and the associated code. (These macros have been replaced
by the ACPI_ERROR and ACPI_WARNING macros.)
Tagged all external interfaces to the subsystem with the
new ACPI_EXPORT_SYMBOL macro. This macro can be defined
as necessary to assist kernel integration. For Linux,
the macro resolves to the EXPORT_SYMBOL macro. The default
definition is NULL.
Added the ACPI_THREAD_ID type for the return value from
acpi_os_get_thread_id(). This allows the host to define this
as necessary to simplify kernel integration. The default
definition is ACPI_NATIVE_UINT.
Valery Podrezov fixed two interpreter problems related
to error processing, the deletion of objects, and placing
invalid pointers onto the internal operator result stack.
http://bugzilla.kernel.org/show_bug.cgi?id=6028
http://bugzilla.kernel.org/show_bug.cgi?id=6151
Increased the reference count threshold where a warning is
emitted for large reference counts in order to eliminate
unnecessary warnings on systems with large namespaces
(especially 64-bit.) Increased the value from 0x400
to 0x800.
Due to universal disagreement as to the meaning of the
'c' in the calloc() function, the ACPI_MEM_CALLOCATE
macro has been renamed to ACPI_ALLOCATE_ZEROED so that the
purpose of the interface is 'clear'. ACPI_MEM_ALLOCATE and
ACPI_MEM_FREE are renamed to ACPI_ALLOCATE and ACPI_FREE.
Removed a couple of extraneous ACPI_ERROR messages that
appeared during normal execution. These became apparent
after the conversion from ACPI_DEBUG_PRINT.
Fixed a problem where the CreateField operator could hang
if the BitIndex or NumBits parameter referred to a named
object. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5359
Fixed a problem where a DeRefOf operation on a buffer
object incorrectly failed with an exception. This also
fixes a couple of related RefOf and DeRefOf issues.
http://bugzilla.kernel.org/show_bug.cgi?id=5360
http://bugzilla.kernel.org/show_bug.cgi?id=5387
http://bugzilla.kernel.org/show_bug.cgi?id=5392
Fixed a problem where the AE_BUFFER_LIMIT exception was
returned instead of AE_STRING_LIMIT on an out-of-bounds
Index() operation. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5480
Implemented a memory cleanup at the end of the execution
of each iteration of an AML While() loop, preventing the
accumulation of outstanding objects. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5427
Eliminated a chunk of duplicate code in the object
resolution code. From Valery Podrezov.
http://bugzilla.kernel.org/show_bug.cgi?id=5336
Fixed several warnings during the 64-bit code generation.
Added 2006 copyright.
At SuSE's suggestion, enabled all error messages
without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n
Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at
the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with
the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros,
respectively. This preserves all error and warning messages
in the non-debug version of the ACPICA code (this has been
referred to as the "debug lite" option.) Over 200 cases
were converted to create a total of over 380 error/warning
messages across the ACPICA code. This increases the code
and data size of the default non-debug version by about 13K.
Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages.
The size of the debug version remains about the same.
The use of the CPU stack in the debug version of the
subsystem has been considerably reduced. Previously, a
debug structure was declared in every function that used
the debug macros. This structure has been removed in
favor of declaring the individual elements as parameters
to the debug functions. This reduces the cumulative stack
use during nested execution of ACPI function calls at the
cost of a small increase in the code size of the debug
version of the subsystem. With assistance from Alexey
Starikovskiy and Len Brown.
Added the ACPI_GET_FUNCTION_NAME macro to enable the
compiler-dependent headers to define a macro that will
return the current function name at runtime (such as
__FUNCTION__ or _func_, etc.) The function name is used
by the debug trace output. If ACPI_GET_FUNCTION_NAME
is not defined in the compiler-dependent header, the
function name is saved on the CPU stack (one pointer per
function.) This mechanism is used because apparently there
exists no standard ANSI-C defined macro that that returns
the function name.
Alexey Starikovskiy redesigned and reimplemented the
"Owner ID" mechanism used to track namespace objects
created/deleted by ACPI tables and control method
execution. A bitmap is now used to allocate and free the
IDs, thus solving the wraparound problem present in the
previous implementation. The size of the namespace node
descriptor was reduced by 2 bytes as a result.
Removed the UINT32_BIT and UINT16_BIT types that were used
for the bitfield flag definitions within the headers for
the predefined ACPI tables. These have been replaced by
UINT8_BIT in order to increase the code portability of
the subsystem. If the use of UINT8 remains a problem,
we may be forced to eliminate bitfields entirely because
of a lack of portability.
Alexey Starikovksiy enhanced the performance of
acpi_ut_update_object_reference. This is a frequently used
function and this improvement increases the performance
of the entire subsystem.
Alexey Starikovskiy fixed several possible memory leaks
and the inverse - premature object deletion.
ACPICA 20050617:
Moved the object cache operations into the OS interface
layer (OSL) to allow the host OS to handle these operations
if desired (for example, the Linux OSL will invoke the
slab allocator). This support is optional; the compile
time define ACPI_USE_LOCAL_CACHE may be used to utilize
the original cache code in the ACPI CA core. The new OSL
interfaces are shown below. See utalloc.c for an example
implementation, and acpiosxf.h for the exact interface
definitions. Thanks to Alexey Starikovskiy.
acpi_os_create_cache
acpi_os_delete_cache
acpi_os_purge_cache
acpi_os_acquire_object
acpi_os_release_object
Modified the interfaces to acpi_os_acquire_lock and
acpi_os_release_lock to return and restore a flags
parameter. This fits better with many OS lock models.
Note: the current execution state (interrupt handler
or not) is no longer passed to these interfaces. If
necessary, the OSL must determine this state by itself, a
simple and fast operation. Thanks to Alexey Starikovskiy.
Fixed a problem in the ACPI table handling where a valid
XSDT was assumed present if the revision of the RSDP
was 2 or greater. According to the ACPI specification,
the XSDT is optional in all cases, and the table manager
therefore now checks for both an RSDP >=2 and a valid
XSDT pointer. Otherwise, the RSDT pointer is used.
Some ACPI 2.0 compliant BIOSs contain only the RSDT.
Fixed an interpreter problem with the Mid() operator in the
case of an input string where the resulting output string
is of zero length. It now correctly returns a valid,
null terminated string object instead of a string object
with a null pointer.
Fixed a problem with the control method argument handling
to allow a store to an Arg object that already contains an
object of type Device. The Device object is now correctly
overwritten. Previously, an error was returned.
ACPICA 20050624:
Modified the new OSL cache interfaces to use ACPI_CACHE_T
as the type for the host-defined cache object. This allows
the OSL implementation to define and type this object in
any manner desired, simplifying the OSL implementation.
For example, ACPI_CACHE_T is defined as kmem_cache_t for
Linux, and should be defined in the OS-specific header
file for other operating systems as required.
Changed the interface to AcpiOsAcquireObject to directly
return the requested object as the function return (instead
of ACPI_STATUS.) This change was made for performance
reasons, since this is the purpose of the interface in the
first place. acpi_os_acquire_object is now similar to the
acpi_os_allocate interface. Thanks to Alexey Starikovskiy.
Modified the initialization sequence in
acpi_initialize_subsystem to call the OSL interface
acpi_osl_initialize first, before any local initialization.
This change was required because the global initialization
now calls OSL interfaces.
Restructured the code base to split some files because
of size and/or because the code logically belonged in a
separate file. New files are listed below.
utilities/utcache.c /* Local cache interfaces */
utilities/utmutex.c /* Local mutex support */
utilities/utstate.c /* State object support */
parser/psloop.c /* Main AML parse loop */
