path: root/drivers/acpi/thermal.c
2006-07-10Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: ACPI_DOCK: Initialize the atomic notifier list ACPI: acpi_os_allocate() fixes ACPI: SBS: fix initialization, sem2mutex ACPI: add 'const' to several ACPI file_operations ACPI: delete some defaults from ACPI Kconfig ACPI: "Device `[%s]' is not power manageable" make message debug only ACPI: ACPI_DOCK Kconfig Revert "Revert "ACPI: dock driver"" ACPI: acpi_os_get_thread_id() returns current ACPI: ACPICA 20060707
2006-07-10[PATCH] ACPI: fix fan/thermal resumeKonstantin Karasyov
Daniel Ritz <daniel.ritz-ml@swissonline.ch> says: The acpi driver suspend/resume patches that went in recently caused a regression on my box (toshiba tecra 8000 laptop): after resume from swsusp the fan turns on keeping blowing cold air out of my notebook. before the patches, the fan was off and would only make noise when required. it's the same thing described in bugzilla.kernel.org #5000. the acpi suspend/resume patches or at least parts of them originate in this bug. now the last patch in the report (attach id 8438) actually fixes the problem - for me and the reporter. this is a trimmed down version of that patch. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Cc: Len Brown <len.brown@intel.com> Cc: Sanjoy Mahajan <sanjoy@mrao.cam.ac.uk> Cc: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10ACPI: add 'const' to several ACPI file_operationsArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: thermal: Remove unneeded acpi_handle from driver.Patrick Mochel
Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: thermal: Use acpi_device's handle instead of driver'sPatrick Mochel
2006-06-30ACPI: thermal: add struct acpi_device to struct acpi_thermal.Patrick Mochel
- Use it instead of acpi_bus_get_device() where we can.. Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-27ACPI: un-export ACPI_WARNING() -- use printk(KERN_WARNING...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-15Pull bugzilla-5000 into release branchLen Brown
2006-06-15Pull trivial2 into release branchLen Brown
2006-06-15Pull trivial into release branchLen Brown
2006-06-14ACPI: execute Notify() handlers on new threadAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=5534 Thanks to Peter Wainwright for isolating the issue. Thanks to Andi Kleen and Bob Moore for feedback. Thanks to Richard Mace and others for testing. Updates by Konstantin Karasyov. Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-05-15ACPI: create acpi_thermal_resume()Konstantin Karasyov
http://bugzilla.kernel.org/show_bug.cgi?id=4364 Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-05-13ACPI: fix memory leak in acpi_thermal_add() error pathVasily Averin
Signed-off-by: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-31[ACPI] fix possible acpi thermal leak in failure pathDave Jones
Coverity: #601 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] Allow return to active cooling mode once passive mode is enteredThomas Renninger
http://bugzilla.kernel.org/show_bug.cgi?id=3410 https://bugzilla.novell.com/show_bug.cgi?id=131543 Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Yu Luming <luming.yu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
