path: root/drivers/acpi/tables.c
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting)Alexey Starikovskiy
Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table managerAlexey Starikovskiy
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-26[PATCH] EFI fixesTolentino, Matthew E
Here's a patch that fixes EFI boot for x86 on 2.6.16-rc5-mm3. The off-by-one is admittedly my fault, but the other two fix up the rest. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30[ACPI] reduce kernel size: move 5BK .bss to 2.5KB .init.dataLen Brown
put __initdata on sdt_entry[], as it is accessed only by __init functions. http://bugzilla.kernel.org/show_bug.cgi?id=1311 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
