path: root/drivers/acpi/tables.c
2014-11-27ACPI / table: Always count matched and successfully parsed entriesTomasz Nowicki
acpi_parse_entries() allows to traverse all available table entries (aka subtables) by passing max_entries parameter equal to 0, but since its count variable is only incremented if max_entries is not 0, the function always returns 0 for max_entries equal to 0. It would be more useful if it returned the number of entries matched instead, so make it increment count in that case too. Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-27ACPI / table: Add new function to get table entriesAshwin Chaugule
The acpi_table_parse() function has a callback that passes a pointer to a table_header. Add a new function which takes this pointer and parses its entries. This eliminates the need to re-traverse all the tables for each call. e.g. as in acpi_table_parse_madt() which is normally called after acpi_table_parse(). Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-17ACPI: use kstrto*() instead of simple_strto*()Christoph Jaeger
simple_strto*() are obsolete; use kstrto*() instead. Add proper error checking. Signed-off-by: Christoph Jaeger <christophjaeger@linux.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-06-01ACPI: Fix x86 regression related to early mapping size limitationLv Zheng
The following warning message is triggered: WARNING: CPU: 0 PID: 0 at mm/early_ioremap.c:136 __early_ioremap+0x11f/0x1f2() Modules linked in: CPU: 0 PID: 0 Comm: swapper Not tainted 3.15.0-rc1-00017-g86dfc6f3-dirty #298 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS SE5C600.86B.99.99.x036.091920111209 09/19/2011 0000000000000009 ffffffff81b75c40 ffffffff817c627b 0000000000000000 ffffffff81b75c78 ffffffff81067b5d 000000000000007b 8000000000000563 00000000b96b20dc 0000000000000001 ffffffffff300e0c ffffffff81b75c88 Call Trace: [<ffffffff817c627b>] dump_stack+0x45/0x56 [<ffffffff81067b5d>] warn_slowpath_common+0x7d/0xa0 [<ffffffff81067c3a>] warn_slowpath_null+0x1a/0x20 [<ffffffff81d4b9d5>] __early_ioremap+0x11f/0x1f2 [<ffffffff81d4bc5b>] early_ioremap+0x13/0x15 [<ffffffff81d2b8f3>] __acpi_map_table+0x13/0x18 [<ffffffff817b8d1a>] acpi_os_map_memory+0x26/0x14e [<ffffffff813ff018>] acpi_tb_acquire_table+0x42/0x70 [<ffffffff813ff086>] acpi_tb_validate_table+0x27/0x37 [<ffffffff813ff0e5>] acpi_tb_verify_table+0x22/0xd8 [<ffffffff813ff6a8>] acpi_tb_install_non_fixed_table+0x60/0x1c9 [<ffffffff81d61024>] acpi_tb_parse_root_table+0x218/0x26a [<ffffffff81d1b120>] ? early_idt_handlers+0x120/0x120 [<ffffffff81d610cd>] acpi_initialize_tables+0x57/0x59 [<ffffffff81d5f25d>] acpi_table_init+0x1b/0x99 [<ffffffff81d2bca0>] acpi_boot_table_init+0x1e/0x85 [<ffffffff81d23043>] setup_arch+0x99d/0xcc6 [<ffffffff81d1b120>] ? early_idt_handlers+0x120/0x120 [<ffffffff81d1bbbe>] start_kernel+0x8b/0x415 [<ffffffff81d1b120>] ? early_idt_handlers+0x120/0x120 [<ffffffff81d1b5ee>] x86_64_start_reservations+0x2a/0x2c [<ffffffff81d1b72e>] x86_64_start_kernel+0x13e/0x14d ---[ end trace 11ae599a1898f4e7 ]--- when installing the following table during early stage: ACPI: SSDT 0x00000000B9638018 07A0C4 (v02 INTEL S2600CP 00004000 INTL 20100331) The regression is caused by the size limitation of the x86 early IO mapping. The root cause is: 1. ACPICA doesn't split IO memory mapping and table mapping; 2. Linux x86 OSL implements acpi_os_map_memory() using a size limited fix-map mechanism during early boot stage, which is more suitable for only IO mappings. This patch fixes this issue by utilizing acpi_gbl_verify_table_checksum to disable the table mapping during early stage and enabling it again for the late stage. In this way, the normal code path is not affected. Then after the code related to the root cause is cleaned up, the early checksum verification can be easily re-enabled. A new boot parameter - acpi_force_table_verification is introduced for the platforms that require the checksum verification to stop loading bad tables. This fix also covers the checksum verification for the table overrides. Now large tables can also be overridden using the initrd override mechanism. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Reported-and-tested-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-02ACPI / tables: Replace printk with pr_*Hanjun Guo
This patch just does some cleanup to replace printk with pr_*, and introduces pr_fmt() to remove all PREFIXs in tables.c, no functional change. Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-06ACPI / tables: Return proper error codes from acpi_table_parse() and fix ↵tangchen
comment. The comment about return value of acpi_table_parse() is incorrect. This patch fix it. Since all callers only check if the function succeeded or not, this patch simplifies the semantics by returning -errno for all failure cases. This will also simply the comment. As suggested by Toshi Kani <toshi.kani@hp.com>, also change the stub in linux/acpi.h to return -ENODEV. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-06ACPI / tables: Check if id is NULL in acpi_table_parse()tangchen
strncmp() does not check if the params are NULL. In acpi_table_parse(), if @id is NULL, the kernel will panic. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-12-07ACPI / table: Replace '1' with specific error return valuesHanjun Guo
After commit 7f8f97c3cc (ACPI: acpi_table_parse() now returns success/fail, not count), acpi_table_parse() returns '1' when it is unable to find the table, but it should return a negative error code in that case. Make it return -ENODEV instead. Fix the same problem in acpi_table_init() analogously. Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org> [rjw: Subject and changelog] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-11ACPICA: Cleanup table handler naming conflicts.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 44 lines of 20121114 divergence.diff. There are naming conflicts between Linux and ACPICA on table handlers. This patch cleans up this conflicts to reduce the source code diff between Linux and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-10-06ACPI: Harden acpi_table_parse_entries() against BIOS bugFenghua Yu
Parsing acpi table entries may fall into an infinite loop on a buggy BIOS which has entry length=0 in acpi table. Instead of kernel hang with few failure clue which leads to heavy lifting debug effort, this patch hardens kernel boot by booting into non NUMA mode. The debug info left in log buffer helps people identify the issue. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14ACPI: delete the "acpi=ht" boot optionLen Brown
acpi=ht was important in 2003 -- before ACPI was universally deployed and enabled by default in the major Linux distributions. At that time, there were a fair number of people who or chose to, or needed to, run with acpi=off, yet also wanted access to Hyper-threading. Today we find that many invocations of "acpi=ht" are accidental, and thus is it possible that it is doing more harm than good. In 2.6.34, we warn on invocation of acpi=ht. In 2.6.35, we delete the boot option. Signed-off-by: Len Brown <len.brown@intel.com>
2010-02-18ACPI: fix "acpi=ht" boot optionLen Brown
We broke "acpi=ht" in 2.6.32 by disabling MADT parsing for acpi=disabled. e5b8fc6ac158f65598f58dba2c0d52ba3b412f52 This also broke systems which invoked acpi=ht via DMI blacklist. acpi=ht is a really ugly hack, but restore it for those that still use it. http://bugzilla.kernel.org/show_bug.cgi?id=14886 Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28ACPI: check acpi_disabled in acpi_table_parse() and acpi_table_parse_entries()Len Brown
Allow consumers of the acpi_table_parse()/acpi_table_parse_entries() API to gracefully handle the acpi_disabled=1 case via return value rather than checking the global flag themselves. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03x86, ACPI: add support for x2apic ACPI extensionsSuresh Siddha
All logical processors with APIC ID values of 255 and greater will have their APIC reported through Processor X2APIC structure (type-9 entry type) and all logical processors with APIC ID less than 255 will have their APIC reported through legacy Processor Local APIC (type-0 entry type) only. This is the same case even for NMI structure reporting. The Processor X2APIC Affinity structure provides the association between the X2APIC ID of a logical processor and the proximity domain to which the logical processor belongs. For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device() objects in the ACPI namespace. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-06ACPI: disable ACPI cleanly when bad RSDP foundLen Brown
When ACPI is disabled in the BIOS of this VIA C3 box, it invalidates the RSDP, which Linux notices: ACPI Error (tbxfroot-0218): A valid RSDP was not found [20080926] Bug Linux neglected to disable ACPI at that stage, and later scribbled on smp_found_config: ACPI: No APIC-table, disabling MPS But this box doesn't run well in legacy PIC mode, it needed IOAPIC mode to perform correctly: http://lkml.org/lkml/2009/2/5/39 So exit ACPI mode cleanly when we first detect that it is hopeless. Signed-off-by: Len Brown <len.brown@intel.com>
2008-08-21acpi: add checking for NULL early paramCyrill Gorcunov
The early_param handling function could recieve NULL pointer as argument in case if user didn't enter parameter value. So we have to be ready for a such situation and do check for NULL pointer if needed. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2007-03-30Revert "ACPI: parse 2nd MADT by default"Len Brown
This reverts commit 09fe58356d148ff66901ddf639e725ca1a48a0af. http://bugzilla.kernel.org/show_bug.cgi?id=8283 Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-15ACPI: parse 2nd MADT by defaultLen Brown
http://bugzilla.kernel.org/show_bug.cgi?id=7465 Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-11ACPI: Add support to parse 2nd MADTLen Brown
When a BIOS bug presents multiple APIC/MADTs, Linux currently uses the 1st and ignores the 2nd. But some machines work better if we use the 2nd. http://bugzilla.kernel.org/show_bug.cgi?id=7465 Add a warning and boot parameter "acpi_apic_instance=2" to allow parsing the 2nd. No change to default behaviour in this patch. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-16Pull fluff into release branchLen Brown
Conflicts: arch/x86_64/pci/mmconfig.c drivers/acpi/bay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-13ACPI: acpi_table_parse_madt_family() is not MADT specificLen Brown
acpi_table_parse_madt_family() is also used to parse SRAT entries. So re-name it to acpi_table_parse_entries(), and re-name the madt-specific variables within it accordingly. cosmetic only. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-13ACPI: acpi_madt_entry_handler() is not MADT specificLen Brown
acpi_madt_entry_handler() is also used for the SRAT, so re-name it acpi_table_entry_handler(). cosmetic only. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-13ACPI: acpi_table_parse() now returns success/fail, not countLen Brown
Returning count for tables that are supposed to be unique was useless and confusing. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Remove duplicate table definitions (non-conflicting)Alexey Starikovskiy
2007-02-02ACPICA: Remove duplicate table managerAlexey Starikovskiy
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2006-10-14ACPI: Remove unnecessary from/to-void* and to-void casts in drivers/acpiJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-26[PATCH] EFI fixesTolentino, Matthew E
Here's a patch that fixes EFI boot for x86 on 2.6.16-rc5-mm3. The off-by-one is admittedly my fault, but the other two fix up the rest. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30[ACPI] reduce kernel size: move 5BK .bss to 2.5KB .init.dataLen Brown
put __initdata on sdt_entry[], as it is accessed only by __init functions. http://bugzilla.kernel.org/show_bug.cgi?id=1311 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
