path: root/drivers/acpi/pci_bind.c
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2005-09-03[ACPI] add static to function definitionsAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-06-27[PATCH] acpi bridge hotadd: Export the interface to get PCI id for an ACPI ↵Rajesh Shah
handle Export an acpi interface to get PCI domain/bus/devfn information from the corresponding namespace handle. Used by acpiphp code to transpate the device handle of the hot-plugged root bridge to the corresponding pci location information. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
