path: root/drivers/acpi/osl.c
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-09ACPI: add const to acpi_check_resource_conflict()Jean Delvare
acpi_check_resource_conflict() doesn't change the resource it operates on, so the res parameter can be marked const. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-27ACPI: Clarify resource conflict messageJean Delvare
The message "ACPI: Device needs an ACPI driver" is misleading. The device _may_ need an ACPI driver, if the BIOS implemented a custom API for the device in question (which, AFAIK, can't be checked.) If not, then either a generic ACPI driver may be used (for example "thermal"), or nothing can be done (other than a white list). I propose to reword the message to: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver which I think is more correct. Comments and suggestions welcome. I also added a message warning about possible problems and system instability when users pass acpi_enforce_resources=lax, as suggested by Len. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Alan Jenkins <sourcejedi.lkml@googlemail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-24ACPI: remove cpumask_t usageBjorn Helgaas
set_cpus_allowed() is on the way out; replace it with set_cpus_allowed_ptr(). Reference: http://lkml.org/lkml/2008/11/6/448 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-19ACPI: remove null pointer checks in deferred execution pathBjorn Helgaas
Better to oops and learn about a bug than to silently cover it up. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19ACPI: simplify deferred execution pathBjorn Helgaas
We had two functions, acpi_os_execute_deferred() and acpi_os_execute_hp_deferred() that differed only in that the latter did acpi_os_wait_events_complete(NULL) before executing the deferred function. This patch consolidates those two functions and uses a flag in the struct acpi_os_dpc to determine whether to do the wait. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: fix leak of acpi_os_validate_addressLin Ming
http://bugzilla.kernel.org/show_bug.cgi?id=13620 If the dynamic region is created and added to resource list over and over again, it has the potential to be a memory leak by growing the list every time. This patch fixes the memory leak, as below 1) add a new field "count" to struct acpi_res_list. When inserting, if the region(addr, len) is already in the resource list, we just increase "count", otherwise, the region is inserted with count=1. When deleting, the "count" is decreased, if it's decreased to 0, the region is deleted from the resource list. With "count", the region with same address and length can only be inserted to the resource list once, so prevent potential memory leak. 2) add a new function acpi_os_invalidate_address, which is called when region is deleted. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-02ACPI: bind workqueues to CPU 0 to avoid SMI corruptionBjorn Helgaas
On some machines, a software-initiated SMI causes corruption unless the SMI runs on CPU 0. An SMI can be initiated by any AML, but typically it's done in GPE-related methods that are run via workqueues, so we can avoid the known corruption cases by binding the workqueues to CPU 0. References: http://bugzilla.kernel.org/show_bug.cgi?id=13751 https://bugs.launchpad.net/bugs/157171 https://bugs.launchpad.net/bugs/157691 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-23ACPI: fix a deadlock in hotplug caseZhang Rui
we used to run the hotplug code in keventd_wq. But when hot removing the ACPI battery device, power_supply_unregister invokes flush_scheduled_work. This causes a deadlock. i.e 1. When dock is unplugged, all the hotplug code is run on kevent_wq. 2. the hotplug code removes all the child devices of dock device. 3. removing the child device may invoke flush_scheduled_work 4. flush_scheduled_work waits until all the work on kevent_wq to be finished, while this will never be true because the hotplug code is running on keventd_wq... Introduce a new workqueue for hotplug in this patch. http://bugzilla.kernel.org/show_bug.cgi?id=13533 Tested-by: Paul Martin <pm@debian.org> Tested-by: Vojtech Gondzala <vojtech.gondzala@gmail.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-21ACPI: add /sys/firmware/acpi/interrupts/sci_not counterLen Brown
This counter may prove useful in debugging some spurious interrupt issues seen in the field. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-02ACPI: acpi_enforce_resource=strict by defaultLuca Tettamanti
Enforce strict resource checking - disallowing access by native drivers to IO ports and memory regions claimed by ACPI firmware. The patch is mainly aimed to block native hwmon drivers from touching monitoring chips that ACPI thinks it own. If this causes a regression, boot with "acpi_enforce_resources=lax" which was the previous default. http://bugzilla.kernel.org/show_bug.cgi?id=12376 http://bugzilla.kernel.org/show_bug.cgi?id=12541 Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-16Revert "ACPI: make some IO ports off-limits to AML"Len Brown
This reverts commit 5ec5d38a1c8af255ffc481c81eef13e9155524b3. because it caused spurious dmesg warmings. We'll implement the check for off-limit ports in a more clever way in the future. http://bugzilla.kernel.org/show_bug.cgi?id=12758 Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-23acpi: add some missing section markersJeremy Fitzhardinge
early_acpi_os_unmap_memory() is an __init function, and acpi_os_unmap_memory() is allowed to access an __init function until acpi_gbl_permanent_mmap is set up. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-07Merge branches 'release', 'asus', 'bugzilla-12450', 'cpuidle', 'debug', ↵Len Brown
'ec', 'misc', 'printk' and 'processor' into release
2009-02-07ACPI: add missing KERN_* constants to printksFrank Seidel
According to kerneljanitors todo list all printk calls (beginning a new line) should have an according KERN_* constant. Those are the missing peaces here for the acpi subsystem. Signed-off-by: Frank Seidel <frank@f-seidel.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-03ACPI: make some IO ports off-limits to AMLLen Brown
ACPICA exports acpi_os_validate_address() so the OS can prevent BIOS AML from accessing specified addresses. Start using this interface to prevent AML from accessing some well known IO addresses that the OS "owns". Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPI: osl.c: replace return_ACPI_STATUS with returnLin Ming
return_ACPI_STATUS is an internal acpica function, replace it with return. acpi_gbl_permanent_mmap moved from acglobal.h to acpixf.h for external use Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-27ACPI: delete OSI(Linux) DMI dmesg spamLen Brown
Linux will continue to ignore OSI(Linux), except for a white-list containing a few systems. So delete the black-list, and stop soliciting user-feedback on the console. Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'ull' into testLen Brown
Conflicts: drivers/acpi/bay.c drivers/acpi/dock.c drivers/ata/libata-acpi.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22Merge branch 'dock' into testLen Brown
Conflicts: drivers/acpi/osl.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22ACPI: replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printkLin Ming
ACPI_DB_ERROR and ACPI_DB_WARN were removed from ACPICA core. So replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printk(KERN_ERR PREFIX ...) and ACPI_DEBUG_PRINT((ACPI_DB_WARN, ...) with printk(KERN_WARNING PREFIX ...) We do not use ACPI_ERROR/ACPI_WARNING since they're not exported, see ------------------------------------------------------------- commit 6468463abd7051fcc29f3ee7c931f9bbbb26f5a4 Author: Len Brown <len.brown@intel.com> Date: Mon Jun 26 23:41:38 2006 -0400 ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...) Signed-off-by: Len Brown <len.brown@intel.com> ------------------------------------------------------------- Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-11ACPI: Change acpi_evaluate_integer to support 64-bit on 32-bit kernelsMatthew Wilcox
As of version 2.0, ACPI can return 64-bit integers. The current acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms. Change the argument to take a pointer to an acpi_integer so we support 64-bit integers on all platforms. lenb: replaced use of "acpi_integer" with "unsigned long long" lenb: fixed bug in acpi_thermal_trips_update() Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-09-23ACPI: fix hotplug raceZhang Rui
The hotplug notification handler and drivers' notification handler all run in one workqueue. Before hotplug removes an acpi device, the device driver's notification handler is already be recorded to run just after global notification handler. After hotplug notification handler runs, acpica will notice a NULL notification handler and crash. So now we run run hotplug in another workqueue and wait for all acpi notication handlers finish. This was found in battery hotplug, but actually all hotplug can be affected. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29flush kacpi_notify_wq before removing notify handlerZhang Rui
Flush kacpi_notify_wq before notify handler is removed, this can fix a bug which the deferred notify handler is executed after the notify_handler has already been removed. http://bugzilla.kernel.org/show_bug.cgi?id=9772 Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-17Add down_timeout and change ACPI to use itMatthew Wilcox
ACPI currently emulates a timeout for semaphores with calls to down_trylock and sleep. This produces horrible behaviour in terms of fairness and excessive wakeups. Now that we have a unified semaphore implementation, adding a real down_trylock is almost trivial. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-03-15ACPI: Remove ACPI_CUSTOM_DSDT_INITRD optionLinus Torvalds
This essentially reverts commit 71fc47a9adf8ee89e5c96a47222915c5485ac437 ("ACPI: basic initramfs DSDT override support"), because the code simply isn't ready. It did ugly things to the init sequence to populate the rootfs image early, but that just ended up showing other problems with the whole approach. The fact is, the VFS layer simply isn't initialized this early, and the relevant ACPI code should either run much later, or this shouldn't be done at all. For 2.6.25, we'll just pick the latter option. We can revisit this concept later if necessary. Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Renninger <trenn@suse.de> Cc: Eric Piel <eric.piel@tremplin-utc.net> Cc: Len Brown <len.brown@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Markus Gaugusch <dsdt@gaugusch.at> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-11ACPI: Fix a duplicate log levelJean Delvare
2008-02-14Merge branches 'release', 'dmi', 'idle' and 'misc' into releaseLen Brown
2008-02-14ACPI: DMI: quirk for FSC ESPRIMO Mobile V5505Len Brown
http://bugzilla.kernel.org/show_bug.cgi?id=9939 Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-14ACPI: static acpi_find_dsdt_initrd()Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-14ACPI: static acpi_no_initrd_override_setup()Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-13acpi: fix acpi_os_read_pci_configuration() misuse of raw_pci_read()Linus Torvalds
The raw_pci_read() interface (as the raw_pci_ops->read() before it) unconditionally fills in a 32-bit integer return value regardless of the size of the operation requested. So claiming to take a "void *" is wrong, as is passing in a pointer to just a byte variable. Noticed by pageexec when enabling -fstack-protector (which needs other patches too to actually work, but that's a separate issue). Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-10Change pci_raw_ops to pci_raw_read/writeMatthew Wilcox
We want to allow different implementations of pci_raw_ops for standard and extended config space on x86. Rather than clutter generic code with knowledge of this, we make pci_raw_ops private to x86 and use it to implement the new raw interface -- raw_pci_read() and raw_pci_write(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07ACPI: add newline to printkLen Brown
2008-02-07Merge branches 'release' and 'dsdt-override' into releaseLen Brown
2008-02-07ACPI: update intrd DSDT override console messagesLen Brown
also, address some checkpatch.pl violations Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: Add "acpi_no_initrd_override" kernel parameterÉric Piel
The acpi_no_initrd_override parameter permits to disable the load of an ACPI table from the initramfs. Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release' and 'fluff' into releaseLen Brown
Conflicts: drivers/acpi/scan.c include/linux/acpi.h Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: misc cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - drivers/acpi/bay.c:dev_attr_eject - drivers/acpi/bay.c:dev_attr_present - drivers/acpi/dock.c:dev_attr_docked - drivers/acpi/dock.c:dev_attr_flags - drivers/acpi/dock.c:dev_attr_uid - drivers/acpi/dock.c:dev_attr_undock - drivers/acpi/pci_bind.c:acpi_pci_unbind() - drivers/acpi/pci_link.c:acpi_link_lock - drivers/acpi/sbs.c:acpi_sbs_callback() - drivers/acpi/sbshc.c:acpi_smbus_transaction() - drivers/acpi/sleep/main.c:acpi_sleep_prepare() - #if 0 the following unused global functions: - drivers/acpi/numa.c:acpi_unmap_pxm_to_node() - remove the following unused EXPORT_SYMBOL's: - acpi_register_gsi - acpi_unregister_gsi - acpi_strict - acpi_bus_receive_event - register_acpi_bus_type - unregister_acpi_bus_type - acpi_os_printf - acpi_os_sleep - acpi_os_stall - acpi_os_read_pci_configuration - acpi_os_create_semaphore - acpi_os_delete_semaphore - acpi_os_wait_semaphore - acpi_os_signal_semaphore - acpi_os_signal - acpi_pci_irq_enable - acpi_get_pxm Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07Merge branches 'release' and 'hwmon-conflicts' into releaseLen Brown
2008-02-07Merge branches 'release' and 'stats' into releaseLen Brown
2008-02-07Merge branches 'release', 'misc' and 'misc-2.6.25' into releaseLen Brown
2008-02-07Merge branches 'release' and 'gpe-ack' into releaseLen Brown
2008-02-07Merge branches 'release' and 'dmi' into releaseLen Brown
2008-02-07Merge branches 'release', 'bugzilla-6217', 'bugzilla-6629', 'bugzilla-6933', ↵Len Brown
'bugzilla-7186', 'bugzilla-8269', 'bugzilla-8570', 'bugzilla-9139', 'bugzilla-9277', 'bugzilla-9341', 'bugzilla-9444', 'bugzilla-9614', 'bugzilla-9643' and 'bugzilla-9644' into release
2008-02-07ACPI: Export acpi_check_resource_conflictThomas Renninger
Export acpi_check_resource_conflict(), sometimes drivers already have a struct resource at hand so no need to use the wrappers to build a new one. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: track opregion names to avoid driver resource conflicts.Thomas Renninger
Small ACPICA extension to be able to store the name of operation regions in osl.c later In ACPI, AML can define accesses to IO ports and System Memory by Operation Regions. Those are not registered as done by PNPACPI using resource templates (and _CRS/_SRS methods). The IO ports and System Memory regions may get accessed by arbitrary AML code. When native drivers are accessing the same resources bad things can happen (e.g. a critical shutdown temperature of 3000 C every 2 months or so). It is not really possible to register the operation regions via request_resource, as they often overlap with pnp or other resources (e.g. statically setup IO resources below 0x100). This approach stores all Operation Region declarations (IO and System Memory only) at ACPI table parse time. It offers a similar functionality like request_region and let drivers which are known to possibly use the same IO ports and Memory which are also often used by ACPI (hwmon and i2c) check for ACPI interference. A boot parameter acpi_enforce_resources=strict/lax/no is provided, which is default set to lax: - strict: let conflicting drivers fail to load with an error message - lax: let conflicting driver work normal with a warning message - no: no functional change at all Depending on the feedback and the kind of interferences we see, this should be set to strict at later time. Goal of this patch set is: - Identify ACPI interferences in bug reports (very hard to reproduce and to identify) - Find BIOSes for that an ACPI driver should exist for specific HW instead of a native one. - stability in general Provide acpi_check_{mem_}region. Drivers can additionally check against possible ACPI interference by also invoking this shortly before they call request_region. If -EBUSY is returned, the driver must not load. Use acpi_enforce_resources=strict/lax/no options to: - strict: let conflicting drivers fail to load with an error message - lax: let conflicting driver work normal with a warning message - no: no functional change at all Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Len Brown <lenb@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
