path: root/drivers/acpi/osl.c
2006-07-12[PATCH] Revert "ACPI: execute Notify() handlers on new thread"Len Brown
This effectively reverts commit b8d35192c55fb055792ff0641408eaaec7c88988 by reverts acpi_os_queue_for_execution() to what it was before that, except it changes the name to acpi_os_execute() to match ACPICA 20060512. Signed-off-by: Len Brown <len.brown@intel.com> [ The thread execution doesn't actually solve the bug it set out to solve (see http://bugzilla.kernel.org/show_bug.cgi?id=5534 for more details) because the new events can get caught behind the AML semaphore or other serialization. And when that happens, the notify threads keep on piling up until the system dies. ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10ACPI: acpi_os_allocate() fixesLen Brown
Replace acpi_in_resume with a more general hack to check irqs_disabled() on any kmalloc() from ACPI. While setting (system_state != SYSTEM_RUNNING) on resume seemed more general, Andrew Morton preferred this approach. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Make acpi_os_allocate() into an inline function to allow /proc/slab_allocators to work. Delete some memset() that could fault on allocation failure. Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-03Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (44 commits) ACPI: remove function tracing macros from drivers/acpi/*.c ACPI: add support for Smart Battery ACPI: handle battery notify event on broken BIOS ACPI: handle AC notify event on broken BIOS ACPI: asus_acpi: add S1N WLED control ACPI: asus_acpi: correct M6N/M6R display nodes ACPI: asus_acpi: add S1N WLED control ACPI: asus_acpi: rework model detection ACPI: asus_acpi: support L5D ACPI: asus_acpi: handle internal Bluetooth / support W5A ACPI: asus_acpi: support A4G ACPI: asus_acpi: support W3400N ACPI: asus_acpi: LED display support ACPI: asus_acpi: support A3G ACPI: asus_acpi: misc cleanups ACPI: video: Remove unneeded acpi_handle from driver. ACPI: thermal: Remove unneeded acpi_handle from driver. ACPI: power: Remove unneeded acpi_handle from driver. ACPI: pci_root: Remove unneeded acpi_handle from driver. ACPI: pci_link: Remove unneeded acpi_handle from driver. ...
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01Pull acpi_os_free into release branchLen Brown
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-28ACPI: ACPICA 20060623Bob Moore
Implemented a new acpi_spinlock type for the OSL lock interfaces. This allows the type to be customized to the host OS for improved efficiency (since a spinlock is usually a very small object.) Implemented support for "ignored" bits in the ACPI registers. According to the ACPI specification, these bits should be preserved when writing the registers via a read/modify/write cycle. There are 3 bits preserved in this manner: PM1_CONTROL[0] (SCI_EN), PM1_CONTROL[9], and PM1_STATUS[11]. http://bugzilla.kernel.org/show_bug.cgi?id=3691 Implemented the initial deployment of new OSL mutex interfaces. Since some host operating systems have separate mutex and semaphore objects, this feature was requested. The base code now uses mutexes (and the new mutex interfaces) wherever a binary semaphore was used previously. However, for the current release, the mutex interfaces are defined as macros to map them to the existing semaphore interfaces. Fixed several problems with the support for the control method SyncLevel parameter. The SyncLevel now works according to the ACPI specification and in concert with the Mutex SyncLevel parameter, since the current SyncLevel is a property of the executing thread. Mutual exclusion for control methods is now implemented with a mutex instead of a semaphore. Fixed three instances of the use of the C shift operator in the bitfield support code (exfldio.c) to avoid the use of a shift value larger than the target data width. The behavior of C compilers is undefined in this case and can cause unpredictable results, and therefore the case must be detected and avoided. (Fiodor Suietov) Added an info message whenever an SSDT or OEM table is loaded dynamically via the Load() or LoadTable() ASL operators. This should improve debugging capability since it will show exactly what tables have been loaded (beyond the tables present in the RSDT/XSDT.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-27ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...)Len Brown
2006-06-27ACPI: acpi_os_wait_semaphore(): silence complaintBjorn Helgaas
The ASL Acquire operator (17.5.1 in ACPI 3.0 spec) is allowed to time out and return True without acquiring the semaphore. There's no indication in the spec that this is an actual error, so this message should be debug-only, as the message for successful acquisition is. This used to be an ACPI_DEBUG_PRINT, but it was mis-classified as ACPI_DB_ERROR rather than ACPI_DB_MUTEX, so it got swept up in Thomas' recent patch to enable ACPI error messages even without CONFIG_ACPI_DEBUG. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060608Bob Moore
Converted the locking mutex used for the ACPI hardware to a spinlock. This change should eliminate all problems caused by attempting to acquire a semaphore at interrupt level, and it means that all ACPICA external interfaces that directly access the ACPI hardware can be safely called from interrupt level. Fixed a regression introduced in 20060526 where the ACPI device initialization could be prematurely aborted with an AE_NOT_FOUND if a device did not have an optional _INI method. Fixed an IndexField issue where a write to the Data Register should be limited in size to the AccessSize (width) of the IndexField itself. (BZ 433, Fiodor Suietov) Fixed problem reports (Valery Podrezov) integrated: - Allow store of ThermalZone objects to Debug object. http://bugzilla.kernel.org/show_bug.cgi?id=5369 http://bugzilla.kernel.org/show_bug.cgi?id=5370 Fixed problem reports (Fiodor Suietov) integrated: - acpi_get_table_header() doesn't handle multiple instances correctly (BZ 364) Removed four global mutexes that were obsolete and were no longer being used. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: execute Notify() handlers on new threadAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=5534 Thanks to Peter Wainwright for isolating the issue. Thanks to Andi Kleen and Bob Moore for feedback. Thanks to Richard Mace and others for testing. Updates by Konstantin Karasyov. Signed-off-by: Konstantin Karasyov <konstantin.a.karasyov@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14[ACPI] ACPICA 20060317Bob Moore
Implemented the use of a cache object for all internal namespace nodes. Since there are about 1000 static nodes in a typical system, this will decrease memory use for cache implementations that minimize per-allocation overhead (such as a slab allocator.) Removed the reference count mechanism for internal namespace nodes, since it was deemed unnecessary. This reduces the size of each namespace node by about 5%-10% on all platforms. Nodes are now 20 bytes for the 32-bit case, and 32 bytes for the 64-bit case. Optimized several internal data structures to reduce object size on 64-bit platforms by packing data within the 64-bit alignment. This includes the frequently used ACPI_OPERAND_OBJECT, of which there can be ~1000 static instances corresponding to the namespace objects. Added two new strings for the predefined _OSI method: "Windows 2001.1 SP1" and "Windows 2006". Split the allocation tracking mechanism out to a separate file, from utalloc.c to uttrack.c. This mechanism appears to be only useful for application-level code. Kernels may wish to not include uttrack.c in distributions. Removed all remnants of the obsolete ACPI_REPORT_* macros and the associated code. (These macros have been replaced by the ACPI_ERROR and ACPI_WARNING macros.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01ACPI: inline trivial acpi_os_get_thread_id()Len Brown
acpi_os_get_thread_id() is used only for debugging code that is not enabled on Linux, so stub it out. Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-26[PATCH] ACPI: clean up memory attribute checking for map/read/writeBjorn Helgaas
ia64 ioremap is now smart enough to use the correct memory attributes, so remove the EFI checks from osl.c. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[ACPI] ACPICA 20060127Bob Moore
Implemented support in the Resource Manager to allow unresolved namestring references within resource package objects for the _PRT method. This support is in addition to the previously implemented unresolved reference support within the AML parser. If the interpreter slack mode is enabled (true on Linux unless acpi=strict), these unresolved references will be passed through to the caller as a NULL package entry. http://bugzilla.kernel.org/show_bug.cgi?id=5741 Implemented and deployed new macros and functions for error and warning messages across the subsystem. These macros are simpler and generate less code than their predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION, ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_* macros. Implemented the acpi_cpu_flags type to simplify host OS integration of the Acquire/Release Lock OSL interfaces. Suggested by Steven Rostedt and Andrew Morton. Fixed a problem where Alias ASL operators are sometimes not correctly resolved. causing AE_AML_INTERNAL http://bugzilla.kernel.org/show_bug.cgi?id=5189 http://bugzilla.kernel.org/show_bug.cgi?id=5674 Fixed several problems with the implementation of the ConcatenateResTemplate ASL operator. As per the ACPI specification, zero length buffers are now treated as a single EndTag. One-length buffers always cause a fatal exception. Non-zero length buffers that do not end with a full 2-byte EndTag cause a fatal exception. Fixed a possible structure overwrite in the AcpiGetObjectInfo external interface. (With assistance from Thomas Renninger) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-08[PATCH] tpm: add bios measurement logKylene Jo Hall
According to the TCG specifications measurements or hashes of the BIOS code and data are extended into TPM PCRS and a log is kept in an ACPI table of these extensions for later validation if desired. This patch exports the values in the ACPI table through a security-fs seq_file. Signed-off-by: Seiji Munetoh <munetoh@jp.ibm.com> Signed-off-by: Stefan Berger <stefanb@us.ibm.com> Signed-off-by: Reiner Sailer <sailer@us.ibm.com> Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ACPI] fix acpi_os_wait_sempahore() finite timeout case (AE_TIME warning)Yu Luming
Before this fix, the finite timeout case behaved like the no-timeout (trylock) case. http://bugzilla.kernel.org/show_bug.cgi?id=4588 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-28[ACPI] fix osl.c build warningLen Brown
typecheck complains on i386 that u32 != unsigned long Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051021Bob Moore
Implemented support for the EM64T and other x86_64 processors. This essentially entails recognizing that these processors support non-aligned memory transfers. Previously, all 64-bit processors were assumed to lack hardware support for non-aligned transfers. Completed conversion of the Resource Manager to nearly full table-driven operation. Specifically, the resource conversion code (convert AML to internal format and the reverse) and the debug code to dump internal resource descriptors are fully table-driven, reducing code and data size and improving maintainability. The OSL interfaces for Acquire and Release Lock now use a 64-bit flag word on 64-bit processors instead of a fixed 32-bit word. (Alexey Starikovskiy) Implemented support within the resource conversion code for the Type-Specific byte within the various ACPI 3.0 *WordSpace macros. Fixed some issues within the resource conversion code for the type-specific flags for both Memory and I/O address resource descriptors. For Memory, implemented support for the MTP and TTP flags. For I/O, split the TRS and TTP flags into two separate fields. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-07[PATCH] drivers/acpi: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use msecs_to_jiffies() instead of direct HZ division to avoid rounding errors. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-03[ACPI] add static to function definitionsAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-25[ACPI] delete CONFIG_ACPI_PCILen Brown
Delete the ability to build an ACPI kernel that does not include PCI support. When such a machine is created and it requires a tuned kernel, send a patch. http://bugzilla.kernel.org/show_bug.cgi?id=1364 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-15Merge 'acpi-2.6.12' branch into to-akpmLen Brown
2005-08-15Merge to-linus-stable into to-akpmLen Brown
2005-08-15[ACPI] re-enable platform-specific hotkey drivers by defaultLuming Yu
When both platform-specific and generic drivers exist, enable generic over-ride with "acpi_generic_hotkey". http://bugzilla.kernel.org/show_bug.cgi?id=4953 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-08-04/home/lenb/src/to-akpm branch 'acpi-2.6.12'Len Brown
2005-08-03[ACPI] S3 resume: avoid kmalloc() might_sleep oops symptomDavid Shaohua Li
ACPI now uses kmalloc(...,GPF_ATOMIC) during suspend/resume. http://bugzilla.kernel.org/show_bug.cgi?id=3469 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA 20050617-0624 from Bob Moore <robert.moore@intel.com>Robert Moore
ACPICA 20050617: Moved the object cache operations into the OS interface layer (OSL) to allow the host OS to handle these operations if desired (for example, the Linux OSL will invoke the slab allocator). This support is optional; the compile time define ACPI_USE_LOCAL_CACHE may be used to utilize the original cache code in the ACPI CA core. The new OSL interfaces are shown below. See utalloc.c for an example implementation, and acpiosxf.h for the exact interface definitions. Thanks to Alexey Starikovskiy. acpi_os_create_cache acpi_os_delete_cache acpi_os_purge_cache acpi_os_acquire_object acpi_os_release_object Modified the interfaces to acpi_os_acquire_lock and acpi_os_release_lock to return and restore a flags parameter. This fits better with many OS lock models. Note: the current execution state (interrupt handler or not) is no longer passed to these interfaces. If necessary, the OSL must determine this state by itself, a simple and fast operation. Thanks to Alexey Starikovskiy. Fixed a problem in the ACPI table handling where a valid XSDT was assumed present if the revision of the RSDP was 2 or greater. According to the ACPI specification, the XSDT is optional in all cases, and the table manager therefore now checks for both an RSDP >=2 and a valid XSDT pointer. Otherwise, the RSDT pointer is used. Some ACPI 2.0 compliant BIOSs contain only the RSDT. Fixed an interpreter problem with the Mid() operator in the case of an input string where the resulting output string is of zero length. It now correctly returns a valid, null terminated string object instead of a string object with a null pointer. Fixed a problem with the control method argument handling to allow a store to an Arg object that already contains an object of type Device. The Device object is now correctly overwritten. Previously, an error was returned. ACPICA 20050624: Modified the new OSL cache interfaces to use ACPI_CACHE_T as the type for the host-defined cache object. This allows the OSL implementation to define and type this object in any manner desired, simplifying the OSL implementation. For example, ACPI_CACHE_T is defined as kmem_cache_t for Linux, and should be defined in the OS-specific header file for other operating systems as required. Changed the interface to AcpiOsAcquireObject to directly return the requested object as the function return (instead of ACPI_STATUS.) This change was made for performance reasons, since this is the purpose of the interface in the first place. acpi_os_acquire_object is now similar to the acpi_os_allocate interface. Thanks to Alexey Starikovskiy. Modified the initialization sequence in acpi_initialize_subsystem to call the OSL interface acpi_osl_initialize first, before any local initialization. This change was required because the global initialization now calls OSL interfaces. Restructured the code base to split some files because of size and/or because the code logically belonged in a separate file. New files are listed below. utilities/utcache.c /* Local cache interfaces */ utilities/utmutex.c /* Local mutex support */ utilities/utstate.c /* State object support */ parser/psloop.c /* Main AML parse loop */ Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] generic Hot Key supportLuming Yu
See Documentation/acpi-hotkey.txt Use cmdline "acpi_specific_hotkey" to enable legacy platform specific drivers. http://bugzilla.kernel.org/show_bug.cgi?id=3887 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
