path: root/drivers/acpi/executer/exdump.c
2007-05-09ACPICA: LindentLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2007-05-09Revert "ACPICA: fix AML mutex re-entrancy"Len Brown
This reverts commit c0d127b56937c3e72c2b1819161d2f6718eee877. These changes to AML locking were made to allow Notify handlers to be called on the stack and not deadlock. However, that scheme turns out to be flawed and was reverted by the previous commit, so this commit restores the locking to it previous design. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-15ACPICA: fix AML mutex re-entrancyAlexey Starikovskiy
ACPI AML supports "serialized" methods which are protected by an implicit mutex. The mutex is re-entrant for that AML thread to allow recursion. However, Linux implements notify() by creating a new AML thread. So for systems where notify() re-enters a serialized method, deadlock results. The fix is to use the Linux thread_id as the key to allowing re-entrancy, not the AML thread pointer. http://bugzilla.kernel.org/show_bug.cgi?id=5534 Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update debug output routines for data structure changesBob Moore
2006-06-28ACPI: ACPICA 20060623Bob Moore
Implemented a new acpi_spinlock type for the OSL lock interfaces. This allows the type to be customized to the host OS for improved efficiency (since a spinlock is usually a very small object.) Implemented support for "ignored" bits in the ACPI registers. According to the ACPI specification, these bits should be preserved when writing the registers via a read/modify/write cycle. There are 3 bits preserved in this manner: PM1_CONTROL[0] (SCI_EN), PM1_CONTROL[9], and PM1_STATUS[11]. http://bugzilla.kernel.org/show_bug.cgi?id=3691 Implemented the initial deployment of new OSL mutex interfaces. Since some host operating systems have separate mutex and semaphore objects, this feature was requested. The base code now uses mutexes (and the new mutex interfaces) wherever a binary semaphore was used previously. However, for the current release, the mutex interfaces are defined as macros to map them to the existing semaphore interfaces. Fixed several problems with the support for the control method SyncLevel parameter. The SyncLevel now works according to the ACPI specification and in concert with the Mutex SyncLevel parameter, since the current SyncLevel is a property of the executing thread. Mutual exclusion for control methods is now implemented with a mutex instead of a semaphore. Fixed three instances of the use of the C shift operator in the bitfield support code (exfldio.c) to avoid the use of a shift value larger than the target data width. The behavior of C compilers is undefined in this case and can cause unpredictable results, and therefore the case must be detected and avoided. (Fiodor Suietov) Added an info message whenever an SSDT or OEM table is loaded dynamically via the Load() or LoadTable() ASL operators. This should improve debugging capability since it will show exactly what tables have been loaded (beyond the tables present in the RSDT/XSDT.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14[ACPI] ACPICA 20060317Bob Moore
Implemented the use of a cache object for all internal namespace nodes. Since there are about 1000 static nodes in a typical system, this will decrease memory use for cache implementations that minimize per-allocation overhead (such as a slab allocator.) Removed the reference count mechanism for internal namespace nodes, since it was deemed unnecessary. This reduces the size of each namespace node by about 5%-10% on all platforms. Nodes are now 20 bytes for the 32-bit case, and 32 bytes for the 64-bit case. Optimized several internal data structures to reduce object size on 64-bit platforms by packing data within the 64-bit alignment. This includes the frequently used ACPI_OPERAND_OBJECT, of which there can be ~1000 static instances corresponding to the namespace objects. Added two new strings for the predefined _OSI method: "Windows 2001.1 SP1" and "Windows 2006". Split the allocation tracking mechanism out to a separate file, from utalloc.c to uttrack.c. This mechanism appears to be only useful for application-level code. Kernels may wish to not include uttrack.c in distributions. Removed all remnants of the obsolete ACPI_REPORT_* macros and the associated code. (These macros have been replaced by the ACPI_ERROR and ACPI_WARNING macros.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-04-01ACPI: ACPICA 20060310Bob Moore
Tagged all external interfaces to the subsystem with the new ACPI_EXPORT_SYMBOL macro. This macro can be defined as necessary to assist kernel integration. For Linux, the macro resolves to the EXPORT_SYMBOL macro. The default definition is NULL. Added the ACPI_THREAD_ID type for the return value from acpi_os_get_thread_id(). This allows the host to define this as necessary to simplify kernel integration. The default definition is ACPI_NATIVE_UINT. Valery Podrezov fixed two interpreter problems related to error processing, the deletion of objects, and placing invalid pointers onto the internal operator result stack. http://bugzilla.kernel.org/show_bug.cgi?id=6028 http://bugzilla.kernel.org/show_bug.cgi?id=6151 Increased the reference count threshold where a warning is emitted for large reference counts in order to eliminate unnecessary warnings on systems with large namespaces (especially 64-bit.) Increased the value from 0x400 to 0x800. Due to universal disagreement as to the meaning of the 'c' in the calloc() function, the ACPI_MEM_CALLOCATE macro has been renamed to ACPI_ALLOCATE_ZEROED so that the purpose of the interface is 'clear'. ACPI_MEM_ALLOCATE and ACPI_MEM_FREE are renamed to ACPI_ALLOCATE and ACPI_FREE. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-31[ACPI] ACPICA 20060210Bob Moore
Removed a couple of extraneous ACPI_ERROR messages that appeared during normal execution. These became apparent after the conversion from ACPI_DEBUG_PRINT. Fixed a problem where the CreateField operator could hang if the BitIndex or NumBits parameter referred to a named object. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5359 Fixed a problem where a DeRefOf operation on a buffer object incorrectly failed with an exception. This also fixes a couple of related RefOf and DeRefOf issues. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5360 http://bugzilla.kernel.org/show_bug.cgi?id=5387 http://bugzilla.kernel.org/show_bug.cgi?id=5392 Fixed a problem where the AE_BUFFER_LIMIT exception was returned instead of AE_STRING_LIMIT on an out-of-bounds Index() operation. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5480 Implemented a memory cleanup at the end of the execution of each iteration of an AML While() loop, preventing the accumulation of outstanding objects. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5427 Eliminated a chunk of duplicate code in the object resolution code. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5336 Fixed several warnings during the 64-bit code generation. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051117Bob Moore
Fixed a problem in the AML parser where the method thread count could be decremented below zero if any errors occurred during the method parse phase. This should eliminate AE_AML_METHOD_LIMIT exceptions seen on some machines. This also fixed a related regression with the mechanism that detects and corrects methods that cannot properly handle reentrancy (related to the deployment of the new OwnerId mechanism.) Eliminated the pre-parsing of control methods (to detect errors) during table load. Related to the problem above, this was causing unwind issues if any errors occurred during the parse, and it seemed to be overkill. A table load should not be aborted if there are problems with any single control method, thus rendering this feature rather pointless. Fixed a problem with the new table-driven resource manager where an internal buffer overflow could occur for small resource templates. Implemented a new external interface, acpi_get_vendor_resource() This interface will find and return a vendor-defined resource descriptor within a _CRS or _PRS method via an ACPI 3.0 UUID match. (from Bjorn Helgaas) Removed the length limit (200) on string objects as per the upcoming ACPI 3.0A specification. This affects the following areas of the interpreter: 1) any implicit conversion of a Buffer to a String, 2) a String object result of the ASL Concatentate operator, 3) the String object result of the ASL ToString operator. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20051102Bob Moore
Modified the subsystem initialization sequence to improve GPE support. The GPE initialization has been split into two parts in order to defer execution of the _PRW methods (Power Resources for Wake) until after the hardware is fully initialized and the SCI handler is installed. This allows the _PRW methods to access fields protected by the Global Lock. This will fix systems where a NO_GLOBAL_LOCK exception has been seen during initialization. Fixed a regression with the ConcatenateResTemplate() ASL operator introduced in the 20051021 release. Implemented support for "local" internal ACPI object types within the debugger "Object" command and the acpi_walk_namespace() external interfaces. These local types include RegionFields, BankFields, IndexFields, Alias, and reference objects. Moved common AML resource handling code into a new file, "utresrc.c". This code is shared by both the Resource Manager and the AML Debugger. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-10[ACPI] ACPICA 20050930Bob Moore
Completed a major overhaul of the Resource Manager code - specifically, optimizations in the area of the AML/internal resource conversion code. The code has been optimized to simplify and eliminate duplicated code, CPU stack use has been decreased by optimizing function parameters and local variables, and naming conventions across the manager have been standardized for clarity and ease of maintenance (this includes function, parameter, variable, and struct/typedef names.) All Resource Manager dispatch and information tables have been moved to a single location for clarity and ease of maintenance. One new file was created, named "rsinfo.c". The ACPI return macros (return_ACPI_STATUS, etc.) have been modified to guarantee that the argument is not evaluated twice, making them less prone to macro side-effects. However, since there exists the possibility of additional stack use if a particular compiler cannot optimize them (such as in the debug generation case), the original macros are optionally available. Note that some invocations of the return_VALUE macro may now cause size mismatch warnings; the return_UINT8 and return_UINT32 macros are provided to eliminate these. (From Randy Dunlap) Implemented a new mechanism to enable debug tracing for individual control methods. A new external interface, acpi_debug_trace(), is provided to enable this mechanism. The intent is to allow the host OS to easily enable and disable tracing for problematic control methods. This interface can be easily exposed to a user or debugger interface if desired. See the file psxface.c for details. acpi_ut_callocate() will now return a valid pointer if a length of zero is specified - a length of one is used and a warning is issued. This matches the behavior of acpi_ut_allocate(). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-30[ACPI] ACPICA 20050729 from Bob MooreRobert Moore
Implemented support to ignore an attempt to install/load a particular ACPI table more than once. Apparently there exists BIOS code that repeatedly attempts to load the same SSDT upon certain events. Thanks to Venkatesh Pallipadi. Restructured the main interface to the AML parser in order to correctly handle all exceptional conditions. This will prevent leakage of the OwnerId resource and should eliminate the AE_OWNER_ID_LIMIT exceptions seen on some machines. Thanks to Alexey Starikovskiy. Support for "module level code" has been disabled in this version due to a number of issues that have appeared on various machines. The support can be enabled by defining ACPI_ENABLE_MODULE_LEVEL_CODE during subsystem compilation. When the issues are fully resolved, the code will be enabled by default again. Modified the internal functions for debug print support to define the FunctionName parameter as a (const char *) for compatibility with compiler built-in macros such as __FUNCTION__, etc. Linted the entire ACPICA source tree for both 32-bit and 64-bit. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-29[ACPI] comment out prototypes for new unused debug routinesLen Brown
2005-07-14ACPICA 20050708 from Bob Moore <robert.moore@intel.com>Robert Moore
The use of the CPU stack in the debug version of the subsystem has been considerably reduced. Previously, a debug structure was declared in every function that used the debug macros. This structure has been removed in favor of declaring the individual elements as parameters to the debug functions. This reduces the cumulative stack use during nested execution of ACPI function calls at the cost of a small increase in the code size of the debug version of the subsystem. With assistance from Alexey Starikovskiy and Len Brown. Added the ACPI_GET_FUNCTION_NAME macro to enable the compiler-dependent headers to define a macro that will return the current function name at runtime (such as __FUNCTION__ or _func_, etc.) The function name is used by the debug trace output. If ACPI_GET_FUNCTION_NAME is not defined in the compiler-dependent header, the function name is saved on the CPU stack (one pointer per function.) This mechanism is used because apparently there exists no standard ANSI-C defined macro that that returns the function name. Alexey Starikovskiy redesigned and reimplemented the "Owner ID" mechanism used to track namespace objects created/deleted by ACPI tables and control method execution. A bitmap is now used to allocate and free the IDs, thus solving the wraparound problem present in the previous implementation. The size of the namespace node descriptor was reduced by 2 bytes as a result. Removed the UINT32_BIT and UINT16_BIT types that were used for the bitfield flag definitions within the headers for the predefined ACPI tables. These have been replaced by UINT8_BIT in order to increase the code portability of the subsystem. If the use of UINT8 remains a problem, we may be forced to eliminate bitfields entirely because of a lack of portability. Alexey Starikovksiy enhanced the performance of acpi_ut_update_object_reference. This is a frequently used function and this improvement increases the performance of the entire subsystem. Alexey Starikovskiy fixed several possible memory leaks and the inverse - premature object deletion. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA 20050617-0624 from Bob Moore <robert.moore@intel.com>Robert Moore
ACPICA 20050617: Moved the object cache operations into the OS interface layer (OSL) to allow the host OS to handle these operations if desired (for example, the Linux OSL will invoke the slab allocator). This support is optional; the compile time define ACPI_USE_LOCAL_CACHE may be used to utilize the original cache code in the ACPI CA core. The new OSL interfaces are shown below. See utalloc.c for an example implementation, and acpiosxf.h for the exact interface definitions. Thanks to Alexey Starikovskiy. acpi_os_create_cache acpi_os_delete_cache acpi_os_purge_cache acpi_os_acquire_object acpi_os_release_object Modified the interfaces to acpi_os_acquire_lock and acpi_os_release_lock to return and restore a flags parameter. This fits better with many OS lock models. Note: the current execution state (interrupt handler or not) is no longer passed to these interfaces. If necessary, the OSL must determine this state by itself, a simple and fast operation. Thanks to Alexey Starikovskiy. Fixed a problem in the ACPI table handling where a valid XSDT was assumed present if the revision of the RSDP was 2 or greater. According to the ACPI specification, the XSDT is optional in all cases, and the table manager therefore now checks for both an RSDP >=2 and a valid XSDT pointer. Otherwise, the RSDT pointer is used. Some ACPI 2.0 compliant BIOSs contain only the RSDT. Fixed an interpreter problem with the Mid() operator in the case of an input string where the resulting output string is of zero length. It now correctly returns a valid, null terminated string object instead of a string object with a null pointer. Fixed a problem with the control method argument handling to allow a store to an Arg object that already contains an object of type Device. The Device object is now correctly overwritten. Previously, an error was returned. ACPICA 20050624: Modified the new OSL cache interfaces to use ACPI_CACHE_T as the type for the host-defined cache object. This allows the OSL implementation to define and type this object in any manner desired, simplifying the OSL implementation. For example, ACPI_CACHE_T is defined as kmem_cache_t for Linux, and should be defined in the OS-specific header file for other operating systems as required. Changed the interface to AcpiOsAcquireObject to directly return the requested object as the function return (instead of ACPI_STATUS.) This change was made for performance reasons, since this is the purpose of the interface in the first place. acpi_os_acquire_object is now similar to the acpi_os_allocate interface. Thanks to Alexey Starikovskiy. Modified the initialization sequence in acpi_initialize_subsystem to call the OSL interface acpi_osl_initialize first, before any local initialization. This change was required because the global initialization now calls OSL interfaces. Restructured the code base to split some files because of size and/or because the code logically belonged in a separate file. New files are listed below. utilities/utcache.c /* Local cache interfaces */ utilities/utmutex.c /* Local mutex support */ utilities/utstate.c /* State object support */ parser/psloop.c /* Main AML parse loop */ Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-13ACPICA from Bob Moore <robert.moore@intel.com>Robert Moore
Implemented support for PCI Express root bridges -- added support for device PNP0A08 in the root bridge search within AcpiEvPciConfigRegionSetup. acpi_ev_pci_config_region_setup(). The interpreter now automatically truncates incoming 64-bit constants to 32 bits if currently executing out of a 32-bit ACPI table (Revision < 2). This also affects the iASL compiler constant folding. (Note: as per below, the iASL compiler no longer allows 64-bit constants within 32-bit tables.) Fixed a problem where string and buffer objects with "static" pointers (pointers to initialization data within an ACPI table) were not handled consistently. The internal object copy operation now always copies the data to a newly allocated buffer, regardless of whether the source object is static or not. Fixed a problem with the FromBCD operator where an implicit result conversion was improperly performed while storing the result to the target operand. Since this is an "explicit conversion" operator, the implicit conversion should never be performed on the output. Fixed a problem with the CopyObject operator where a copy to an existing named object did not always completely overwrite the existing object stored at name. Specifically, a buffer-to-buffer copy did not delete the existing buffer. Replaced "interrupt_level" with "interrupt_number" in all GPE interfaces and structs for consistency. Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
