path: root/drivers/acpi/ec.c
2014-09-13ACPI / EC: Add support to disallow QR_EC to be issued when SCI_EVT isn't setLv Zheng
commit 3afcf2ece453e1a8c2c6de19cdf06da3772a1b08 upstream. There is a platform refusing to respond QR_EC when SCI_EVT isn't set (Acer Aspire V5-573G). Currently, we rely on the behaviour that the EC firmware can respond something (for example, 0x00 to indicate "no outstanding events") to QR_EC even when SCI_EVT is not set, but the reporter has complained about AC/battery pluging/unpluging and video brightness change delay on that platform. This is because the work item that has issued QR_EC has to wait until timeout in this case, and the _Qxx method evaluation work item queued after QR_EC one is delayed. It sounds reasonable to fix this issue by: 1. Implementing SCI_EVT sanity check before issuing QR_EC in the EC driver's main state machine. 2. Moving QR_EC issuing out of the work queue used by _Qxx evaluation to a seperate IRQ handling thread. This patch fixes this issue using solution 1. By disallowing QR_EC to be issued when SCI_EVT isn't set, we are able to handle such platform in the EC driver's main state machine. This patch enhances the state machine in this way to survive with such malfunctioning EC firmware. Note that this patch can also fix CLEAR_ON_RESUME quirk which also relies on the assumption that the platforms are able to respond even when SCI_EVT isn't set. Fixes: c0d653412fc8 ACPI / EC: Fix race condition in ec_transaction_completed() Link: https://bugzilla.kernel.org/show_bug.cgi?id=82611 Reported-and-tested-by: Alexander Mezin <mezin.alexander@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Fix race condition in ec_transaction_completed()Lv Zheng
commit c0d653412fc8450370167a3268b78fc772ff9c87 upstream. There is a race condition in ec_transaction_completed(). When ec_transaction_completed() is called in the GPE handler, it could return true because of (ec->curr == NULL). Then the wake_up() invocation could complete the next command unexpectedly since there is no lock between the 2 invocations. With the previous cleanup, the IBF=0 waiter race need not be handled any more. It's now safe to return a flag from advance_condition() to indicate the requirement of wakeup, the flag is returned from a locked context. The ec_transaction_completed() is now only invoked by the ec_poll() where the ec->curr is ensured to be different from NULL. After cleaning up, the EVT_SCI=1 check should be moved out of the wakeup condition so that an EVT_SCI raised with (ec->curr == NULL) can trigger a QR_SC command. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Remove duplicated ec_wait_ibf0() waiterLv Zheng
commit 9b80f0f73ae1583c22325ede341c74195847618c upstream. After we've added the first command byte write into advance_transaction(), the IBF=0 waiter is duplicated with the command completion waiter implemented in the ec_poll() because: If IBF=1 blocked the first command byte write invoked in the task context ec_poll(), it would be kicked off upon IBF=0 interrupt or timed out and retried again in the task context. Remove this seperate and duplicate IBF=0 waiter. By doing so we can reduce the overall number of times to access the EC_SC(R) status register. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Add asynchronous command byte write supportLv Zheng
commit f92fca0060fc4dc9227342d0072d75df98c1e5a5 upstream. Move the first command byte write into advance_transaction() so that all EC register accesses that can affect the command processing state machine can happen in this asynchronous state machine advancement function. The advance_transaction() function then can be a complete implementation of an asyncrhonous transaction for a single command so that: 1. The first command byte can be written in the interrupt context; 2. The command completion waiter can also be used to wait the first command byte's timeout; 3. In BURST mode, the follow-up command bytes can be written in the interrupt context directly, so that it doesn't need to return to the task context. Returning to the task context reduces the throughput of the BURST mode and in the worst cases where the system workload is very high, this leads to the hardware driven automatic BURST mode exit. In order not to increase memory consumption, convert 'done' into 'flags' to contain multiple indications: 1. ACPI_EC_COMMAND_COMPLETE: converting from original 'done' condition, indicating the completion of the command transaction. 2. ACPI_EC_COMMAND_POLL: indicating the availability of writing the first command byte. A new command can utilize this flag to compete for the right of accessing the underlying hardware. There is a follow-up bug fix that has utilized this new flag. The 2 flags are important because it also reflects a key concept of IO programs' design used in the system softwares. Normally an IO program running in the kernel should first be implemented in the asynchronous way. And the 2 flags are the most common way to implement its synchronous operations on top of the asynchronous operations: 1. POLL: This flag can be used to block until the asynchronous operations can happen. 2. COMPLETE: This flag can be used to block until the asynchronous operations have completed. By constructing code cleanly in this way, many difficult problems can be solved smoothly. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: - Adjust context - s/ec->lock/ec->curr_lock/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Don't count a SCI interrupt as a false oneFeng Tang
commit a3cd8d2789c2e265e09377f260e7d2ac9cec81bb upstream. Currently when advance_transaction() is called in EC interrupt handler, if there is nothing driver can do with the interrupt, it will be taken as a false one. But this is not always true, as there may be a SCI EC interrupt fired during normal read/write operation, which should not be counted as a false one. This patch fixes the problem. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Avoid race condition related to advance_transaction()Lv Zheng
commit 66b42b78bc1e816f92b662e8888c89195e4199e1 upstream. The advance_transaction() will be invoked from the IRQ context GPE handler and the task context ec_poll(). The handling of this function is locked so that the EC state machine are ensured to be advanced sequentially. But there is a problem. Before invoking advance_transaction(), EC_SC(R) is read. Then for advance_transaction(), there could be race condition around the lock from both contexts. The first one reading the register could fail this race and when it passes the stale register value to the state machine advancement code, the hardware condition is totally different from when the register is read. And the hardware accesses determined from the wrong hardware status can break the EC state machine. And there could be cases that the functionalities of the platform firmware are seriously affected. For example: 1. When 2 EC_DATA(W) writes compete the IBF=0, the 2nd EC_DATA(W) write may be invalid due to IBF=1 after the 1st EC_DATA(W) write. Then the hardware will either refuse to respond a next EC_SC(W) write of the next command or discard the current WR_EC command when it receives a EC_SC(W) write of the next command. 2. When 1 EC_SC(W) write and 1 EC_DATA(W) write compete the IBF=0, the EC_DATA(W) write may be invalid due to IBF=1 after the EC_SC(W) write. The next EC_DATA(R) could never be responded by the hardware. This is the root cause of the reported issue. Fix this issue by moving the EC_SC(R) access into the lock so that we can ensure that the state machine is advanced consistently. Link: https://bugzilla.kernel.org/show_bug.cgi?id=70891 Link: https://bugzilla.kernel.org/show_bug.cgi?id=63931 Link: https://bugzilla.kernel.org/show_bug.cgi?id=59911 Reported-and-tested-by: Gareth Williams <gareth@garethwilliams.me.uk> Reported-and-tested-by: Hans de Goede <jwrdegoede@fedoraproject.org> Reported-by: Barton Xu <tank.xuhan@gmail.com> Tested-by: Steffen Weber <steffen.weber@gmail.com> Tested-by: Arthur Chen <axchen@nvidia.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: - Adjust context - Use PREFIX in log message] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Ensure lock is acquired before accessing ec struct membersPuneet Kumar
commit 36b15875a7819a2ec4cb5748ff7096ad7bd86cbb upstream. A bug was introduced by commit b76b51ba0cef ('ACPI / EC: Add more debug info and trivial code cleanup') that erroneously caused the struct member to be accessed before acquiring the required lock. This change fixes it by ensuring the lock acquisition is done first. Found by Aaron Durbin <adurbin@chromium.org> Fixes: b76b51ba0cef ('ACPI / EC: Add more debug info and trivial code cleanup') References: http://crbug.com/319019 Signed-off-by: Puneet Kumar <puneetster@chromium.org> Reviewed-by: Aaron Durbin <adurbin@chromium.org> [olof: Commit message reworded a bit] Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-08-06ACPI / EC: Add more debug info and trivial code cleanupFeng Tang
commit b76b51ba0cef13980813373a548a12206e3cd3c9 upstream. Add more debug info for EC transaction debugging, like the interrupt status register value, the detail info of a EC transaction. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-06-09ACPI / EC: Process rather than discard events in acpi_ec_clearKieran Clancy
commit 3eba563e280101209bad27d40bfc83ddf1489234 upstream. Address a regression caused by commit ad332c8a4533: (ACPI / EC: Clear stale EC events on Samsung systems) After the earlier patch, there was found to be a race condition on some earlier Samsung systems (N150/N210/N220). The function acpi_ec_clear was sometimes discarding a new EC event before its GPE was triggered by the system. In the case of these systems, this meant that the "lid open" event was not registered on resume if that was the cause of the wake, leading to problems when attempting to close the lid to suspend again. After testing on a number of Samsung systems, both those affected by the previous EC bug and those affected by the race condition, it seemed that the best course of action was to process rather than discard the events. On Samsung systems which accumulate stale EC events, there does not seem to be any adverse side-effects of running the associated _Q methods. This patch adds an argument to the static function acpi_ec_sync_query so that it may be used within the acpi_ec_clear loop in place of acpi_ec_query_unlocked which was used previously. With thanks to Stefan Biereigel for reporting the issue, and for all the people who helped test the new patch on affected systems. Fixes: ad332c8a4533 (ACPI / EC: Clear stale EC events on Samsung systems) References: https://lkml.kernel.org/r/532FE3B2.9060808@biereigel-wb.de References: https://bugzilla.kernel.org/show_bug.cgi?id=44161#c173 Reported-by: Stefan Biereigel <stefan@biereigel.de> Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com> Tested-by: Stefan Biereigel <stefan@biereigel.de> Tested-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Nicolas Porcel <nicolasporcel06@gmail.com> Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com> Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Tested-by: Giannis Koutsou <giannis.koutsou@gmail.com> Tested-by: Kieran Clancy <clancy.kieran@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-06-09ACPI / EC: Clear stale EC events on Samsung systemsKieran Clancy
commit ad332c8a45330d170bb38b95209de449b31cd1b4 upstream. A number of Samsung notebooks (530Uxx/535Uxx/540Uxx/550Pxx/900Xxx/etc) continue to log events during sleep (lid open/close, AC plug/unplug, battery level change), which accumulate in the EC until a buffer fills. After the buffer is full (tests suggest it holds 8 events), GPEs stop being triggered for new events. This state persists on wake or even on power cycle, and prevents new events from being registered until the EC is manually polled. This is the root cause of a number of bugs, including AC not being detected properly, lid close not triggering suspend, and low ambient light not triggering the keyboard backlight. The bug also seemed to be responsible for performance issues on at least one user's machine. Juan Manuel Cabo found the cause of bug and the workaround of polling the EC manually on wake. The loop which clears the stale events is based on an earlier patch by Lan Tianyu (see referenced attachment). This patch: - Adds a function acpi_ec_clear() which polls the EC for stale _Q events at most ACPI_EC_CLEAR_MAX (currently 100) times. A warning is logged if this limit is reached. - Adds a flag EC_FLAGS_CLEAR_ON_RESUME which is set to 1 if the DMI system vendor is Samsung. This check could be replaced by several more specific DMI vendor/product pairs, but it's likely that the bug affects more Samsung products than just the five series mentioned above. Further, it should not be harmful to run acpi_ec_clear() on systems without the bug; it will return immediately after finding no data waiting. - Runs acpi_ec_clear() on initialisation (boot), from acpi_ec_add() - Runs acpi_ec_clear() on wake, from acpi_ec_unblock_transactions() References: https://bugzilla.kernel.org/show_bug.cgi?id=44161 References: https://bugzilla.kernel.org/show_bug.cgi?id=45461 References: https://bugzilla.kernel.org/show_bug.cgi?id=57271 References: https://bugzilla.kernel.org/attachment.cgi?id=126801 Suggested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com> Reviewed-by: Lan Tianyu <tianyu.lan@intel.com> Reviewed-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Kieran Clancy <clancy.kieran@gmail.com> Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com> Tested-by: Dennis Jansen <dennis.jansen@web.de> Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com> Tested-by: San Zamoyski <san@plusnet.pl> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: - Adjust context - acpi_ec::mutex was called lock] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-10-26ACPI / EC: Add ASUSTEK L4R to quirk list in order to validate ECDTLan Tianyu
commit 524f42fab787a9510be826ce3d736b56d454ac6d upstream. The ECDT of ASUSTEK L4R doesn't provide correct command and data I/O ports. The DSDT provides the correct information instead. For this reason, add this machine to quirk list for ECDT validation and use the EC information from the DSDT. [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=60765 Reported-and-tested-by: Daniele Esposti <expo@expobrain.net> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-05-30ACPI / EC: Restart transaction even when the IBF flag setLan Tianyu
commit 28fe5c825f8e15744d04c7c1b8df197950923ecd upstream. The EC driver works abnormally with IBF flag always set. IBF means "The host has written a byte of data to the command or data port, but the embedded controller has not yet read it". If IBF is set in the EC status and not cleared, this will cause all subsequent EC requests to fail with a timeout error. Change the EC driver so that it doesn't refuse to restart a transaction if IBF is set in the status. Also increase the number of transaction restarts to 5, as it turns out that 2 is not sufficient in some cases. This bug happens on several different machines (Asus V1S, Dell Latitude E6530, Samsung R719, Acer Aspire 5930G, Sony Vaio SR19VN and others). [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=14733 References: https://bugzilla.kernel.org/show_bug.cgi?id=15560 References: https://bugzilla.kernel.org/show_bug.cgi?id=15946 References: https://bugzilla.kernel.org/show_bug.cgi?id=42945 References: https://bugzilla.kernel.org/show_bug.cgi?id=48221 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-30ACPI: EC: Add a quirk for CLEVO M720T/M730T laptopFeng Tang
commit 67bfa9b60bd689601554526d144b21d529f78a09 upstream. By enlarging the GPE storm threshold back to 20, that laptop's EC works fine with interrupt mode instead of polling mode. https://bugzilla.kernel.org/show_bug.cgi?id=45151 Reported-and-Tested-by: Francesco <trentini@dei.unipd.it> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-30ACPI: EC: Make the GPE storm threshold a module parameterFeng Tang
commit a520d52e99b14ba7db135e916348f12f2a6e09be upstream. The Linux EC driver includes a mechanism to detect GPE storms, and switch from interrupt-mode to polling mode. However, polling mode sometimes doesn't work, so the workaround is problematic. Also, different systems seem to need the threshold for detecting the GPE storm at different levels. ACPI_EC_STORM_THRESHOLD was initially 20 when it's created, and was changed to 8 in 2.6.28 commit 06cf7d3c7 "ACPI: EC: lower interrupt storm threshold" to fix kernel bug 11892 by forcing the laptop in that bug to work in polling mode. However in bug 45151, it works fine in interrupt mode if we lift the threshold back to 20. This patch makes the threshold a module parameter so that user has a flexible option to debug/workaround this issue. The default is unchanged. This is also a preparation patch to fix specific systems: https://bugzilla.kernel.org/show_bug.cgi?id=45151 Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-05-29Merge branch 'ec-cleanup' into releaseLen Brown
Conflicts: drivers/platform/x86/compal-laptop.c
2011-05-29Merge branches 'acpica', 'aml-custom', 'bugzilla-16548', 'bugzilla-20242', ↵Len Brown
'd3-cold', 'ec-asus' and 'thermal-fix' into release
2011-05-29ACPI EC: remove redundant codeZhang Rui
ec->handle is set in ec_parse_device(), so don't bother to set it again. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-29ACPI EC: enable MSI workaround for Quanta laptopsZhang Rui
Enable MSI workaround for Quanta laptops. https://bugzilla.kernel.org/show_bug.cgi?id=20242 Tested-by: Jan-Matthias Braun <jan_braun@gmx.net> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-04-25ACPI: EC: add another DMI check for ASUS hardwarePeter Collingbourne
Commit 0adf3c746a73684b3f8c2821a584e1db998f61e9 introduced a regression by making the ECDT validation test for ASUS hardware more restrictive. The previous test used the dmi_name_in_vendors function which searches a number of DMI fields, while the new test checked only the BIOS vendor, which is known to not match on an ASUS F5GL laptop which requires ECDT validation. Add a rule to ec_dmi_table based on an alternative DMI pattern for ASUS hardware as found elsewhere in the kernel. Signed-off-by: Peter Collingbourne <peter@pcc.me.uk> Signed-off-by: Len Brown <len.brown@intel.com>
2011-04-01ACPI EC: remove dead codeThomas Renninger
static void acpi_ec_gpe_query(void *ec_cxt); -> The function is right above this declaration -> not needed. poll_force is also not used, cleaned up in ec.c and its users: compal-laptop and msi-laptop. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Implicit notify supportLin Ming
This feature provides an automatic device notification for wake devices when a wakeup GPE occurs and there is no corresponding GPE method or handler. Rather than ignoring such a GPE, an implicit AML Notify operation is performed on the parent device object. This feature is not part of the ACPI specification and is provided for Windows compatibility only. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: New GPE handler callback definitionLin Ming
The new GPE handler callback has 2 additional parameters, gpe_device and gpe_number. typedef u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context); Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-09ACPI: EC: Add another dmi match entry for MSI hardwareAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=15418 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> cc: stable@kernel.org Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-22ACPI: Make Embedded Controller command timeout delay configurableThomas Renninger
Here and then there show up machines which need higher timeout values. Finding this on affected machines can be cumbersome, because ACPI_EC_DELAY is a compile option -> make it configurable via boot param. This can even be provided writable at runtime via: /sys/modules/acpi/parameters/ec_delay Known machines where this helps: Some HP machines where for whatever reasons specific EC accesses take very long at resume from S3 (in _WAK function). The AE_TIME error is passed upwards and the ACPI interpreter will not execute the rest of the _WAK function which results in not properly initialized devices/variables with different side-effects. Afaik, on some MSI machines this helped as well. If this param is needed there probably are underlying problems like: - EC firmware bug - A kernel EC driver bug - An ACPI interpreter behavior (e.g. timings when specific EC accesses happen and how) which the EC does not like - ... which should get evaluated further, but often are nasty or impossible to fix from OS side. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-07Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits) ACPI / ACPICA: Simplify acpi_ev_initialize_gpe_block() ACPI / ACPICA: Fail acpi_gpe_wakeup() if ACPI_GPE_CAN_WAKE is unset ACPI / ACPICA: Do not execute _PRW methods during initialization ACPI: Fix bogus GPE test in acpi_bus_set_run_wake_flags() ACPICA: Update version to 20100702 ACPICA: Fix for Alias references within Package objects ACPICA: Fix lint warning for 64-bit constant ACPICA: Remove obsolete GPE function ACPICA: Update debug output components ACPICA: Add support for WDDT - Watchdog Descriptor Table ACPICA: Drop acpi_set_gpe ACPICA: Use low-level GPE enable during GPE block initialization ACPI / EC: Do not use acpi_set_gpe ACPI / EC: Drop suspend and resume routines ACPICA: Remove wakeup GPE reference counting which is not used ACPICA: Introduce acpi_gpe_wakeup() ACPICA: Rename acpi_hw_gpe_register_bit ACPICA: Update version to 20100528 ACPICA: Add signatures for undefined tables: ATKG, GSCI, IEIT ACPICA: Optimization: Reduce the number of namespace walks ...
2010-08-03acpi ec: Fix possible double io port registrationThomas Renninger
which will result in a harmless but ugly WARN message on some machines. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: mjg59@srcf.ucam.org CC: platform-driver-x86@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: astarikovskiy@suse.de CC: akpm@linux-foundation.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Register EC io ports in /proc/ioportsThomas Renninger
Formerly these have been exposed through /proc/.. Better register them where all IO ports should get registered and scream loud if someone else claims to use them. EC data and command port typically should show up like this then: ... 0060-0060 : keyboard 0062-0062 : EC data 0064-0064 : keyboard 0066-0066 : EC command 0070-0071 : rtc0 ... Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Provide /sys/kernel/debug/ec/...Thomas Renninger
This patch provides the same information through debugfs, which previously was provided through /proc/acpi/embedded_controller/*/info This is the gpe the EC is connected to and whether the global lock gets used. The io ports used are added to /proc/ioports in another patch. Beside the fact that /proc/acpi is deprecated for quite some time, this info is not needed for applications and thus can be moved to debugfs instead of a public interface like /sys. Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-03ACPI: Remove /proc/acpi/embedded_controller/..Thomas Renninger
Other patches in this series add the same info to /sys/... and /proc/ioports. The info removed should never have been used in an application, eventually someone read it manually. /proc/acpi is deprecated for more than a year anyway... Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: platform-driver-x86@vger.kernel.org Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-07-06ACPI / EC: Do not use acpi_set_gpeRafael J. Wysocki
The EC driver is the last user of acpi_set_gpe() and since it is guaranteed that the EC GPE will not be shared, acpi_disable_gpe() and acpi_enable_gpe() may be used for disabling the GPE temporarilty if a GPE storm is detected and re-enabling it during EC transactions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPI / EC: Drop suspend and resume routinesRafael J. Wysocki
The suspend and resume routines provided by the EC driver are not really necessary, because the handler of the GPE disabled by them is not going to be executed after suspend_device_irqs() and before resume_device_irqs() anyway. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Remove wakeup GPE reference counting which is not usedRafael J. Wysocki
After the previous patch that introduced acpi_gpe_wakeup() and modified the ACPI suspend and wakeup code to use it, the third argument of acpi_{enable|disable}_gpe() and the GPE wakeup reference counter are not necessary any more. Remove them and modify all of the users of acpi_{enable|disable}_gpe() accordingly. Also drop GPE type constants that aren't used any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-01Merge branches 'bugzilla-14668' and 'misc-2.6.35' into releaseLen Brown
2010-05-28ACPI / EC / PM: Fix names of functions that block/unblock EC transactionsRafael J. Wysocki
The names of the functions used for blocking/unblocking EC transactions during suspend/hibernation suggest that the transactions are suspended and resumed by them, while in fact they are disabled and enabled. Rename the functions (and the flag used by them) to better reflect what they really do. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28ACPI / EC / PM: Fix race between EC transactions and system suspendRafael J. Wysocki
There still is a race that may result in suspending the system in the middle of an EC transaction in progress, which leads to problems (like the kernel thinking that the ACPI global lock is held during resume while in fact it's not). To remove the race condition, modify the ACPI platform suspend and hibernate callbacks so that EC transactions are blocked right after executing the _PTS global control method and are allowed to happen again right after the low-level wakeup. Introduce acpi_pm_freeze() that will disable GPEs, wait until the event queues are empty and block EC transactions. Use it wherever GPEs are disabled in preparation for switching local interrupts off. Introduce acpi_pm_thaw() that will allow EC transactions to happen again and enable runtime GPEs. Use it to balance acpi_pm_freeze() wherever necessary. In addition to that use acpi_ec_resume_transactions_early() to unblock EC transactions as early as reasonably possible during resume. Also unblock EC transactions in acpi_hibernation_finish() and in the analogous suspend routine to make sure that the EC transactions are enabled in all error paths. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=14668 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-20ACPI: EC: Use kmemdupJulia Lawall
Use kmemdup when some other buffer is immediately copied into the allocated region. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; statement S; @@ - to = \(kmalloc\|kzalloc\)(size,flag); + to = kmemdup(from,size,flag); if (to==NULL || ...) S - memcpy(to, from, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-06Merge branches 'battery', 'bugzilla-14667', 'bugzilla-15096', ↵Len Brown
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-17ACPI: EC: Allow multibyte access to ECAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=14667 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14Merge branches 'battery-2.6.34', 'bugzilla-10805', 'bugzilla-14668', ↵Len Brown
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
2010-03-08ACPI / EC / PM: Close race between EC and resume from hibernationRafael J. Wysocki
There is a race between resume from hibernation and the EC driver that may result in restoring the hibernation image in the middle of an EC transaction in progress, which in turn may lead to unpredictable behavior of the platform. To remove that race condition, add a helpers for suspending and resuming EC transactions in a safe way to be executed by the ACPI platform hibernate pre-restore and restore cleanup callbacks. http://bugzilla.kernel.org/show_bug.cgi?id=14668 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-02-24ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
To fix a bug and address the reviewers' comments regarding the ACPI GPE refcounting patch, do the following additional changes: o Remove the second argument of acpi_ev_enable_gpe(), 'write_to_hardware', because it is not necessary any more. o Add the "bad parameter" test against 'type' in acpi_enable_gpe() and acpi_disable_gpe(). o Make acpi_enable_gpe() only check 'status' for runtime GPEs if acpi_ev_enable_gpe() was actually called. o Make acpi_disable_gpe() return 'status' returned by acpi_ev_disable_gpe() and fix a bug where ACPI_GPE_TYPE_WAKE and ACPI_GPE_TYPE_RUNTIME were exchanged by mistake. o Add comments explaining why acpi_set_gpe() is used by the ACPI EC driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-15ACPI: EC: Add wait for irq stormAlexey Starikovskiy
Merge of poll and irq modes accelerated EC transaction, so that keyboard starts to suffer again. Add msleep(1) into transaction path for the storm to allow keyboard controller to do its job. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14747 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-15ACPI: SBS: Move SBS HC callback to faster Notify queueAlexey Starikovskiy
SBS transactions should happen in Notify work queue, to not create a dead lock with GPE execution accessing SBS devices. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-24ACPI: EC: Accelerate query executionAlexey Starikovskiy
Split EC query handling into acknowledge and execution phase. This allows much smaller pending query lattency and lowers chances of EC going "wild" and losing events. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14858 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-24Merge branches 'bugzilla-14446', 'bugzilla-14753' and 'bugzilla-14824' into ↵Len Brown
release
2009-12-22ACPI: EC: Fix MSI DMI detectionAlexey Starikovskiy
MSI strings should be ORed, not ANDed. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14446 cc: stable@kernel.org Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
