path: root/drivers/acpi/dispatcher/dswexec.c
2008-04-23ACPICA: update Intel copyrightLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Implemented full argument resolution support for the BankValue ↵Lin Ming
argument to BankField Previously, only constants were supported, now any TermArg may be used. http://www.acpica.org/bugzilla/show_bug.cgi?id=387 http://www.acpica.org/bugzilla/show_bug.cgi?id=393 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Implemented full support for deferred execution for the TermArg ↵Lin Ming
string arguments for DataTableRegion This enables forward references and full operand resolution for the three string arguments. Similar to OperationRegion deferred argument execution.) http://www.acpica.org/bugzilla/show_bug.cgi?id=430 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Fixes a problem with control method references within packagesBob Moore
Completes the package changes started with version 20071019. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: changed order of interpretation of operand objectsBob Moore
The interpreter now evaluates operands in the order that they appear (both in the AML and ASL), instead of in reverse order. This previously caused subtle incompatibilities with the MS interpreter as well as being non-intuitive. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-22ACPICA: Several fixes for internal method result stackBob Moore
fixes STACK_OVERFLOW exception on nested method calls. internal bugzilla 262 and 275. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update copyright to 2007.Bob Moore
Added 2007 copyright to all module headers and signons. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and the utilities. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: Update interpreter error paths to always report the errorBob Moore
2006-07-09ACPI: ACPICA 20060707Bob Moore
Added the ACPI_PACKED_POINTERS_NOT_SUPPORTED macro to support C compilers that do not allow the initialization of address pointers within packed structures - even though the hardware itself may support misaligned transfers. Some of the debug data structures are packed by default to minimize size. Added an error message for the case where acpi_os_get_thread_id() returns zero. A non-zero value is required by the core ACPICA code to ensure the proper operation of AML mutexes and recursive control methods. The DSDT is now the only ACPI table that determines whether the AML interpreter is in 32-bit or 64-bit mode. Not really a functional change, but the hooks for per-table 32/64 switching have been removed from the code. A clarification to the ACPI specification is forthcoming in ACPI 3.0B. Fixed a possible leak of an Owner ID in the error path of tbinstal.c acpi_tb_init_table_descriptor() and migrated all table OwnerID deletion to a single place in acpi_tb_uninstall_table() to correct possible leaks when using the acpi_tb_delete_tables_by_type() interface (with assistance from Lance Ortiz.) Fixed a problem with Serialized control methods where the semaphore associated with the method could be over-signaled after multiple method invocations. Fixed two issues with the locking of the internal namespace data structure. Both the Unload() operator and acpi_unload_table() interface now lock the namespace during the namespace deletion associated with the table unload (with assistance from Linn Crosetto.) Fixed problem reports (Valery Podrezov) integrated: - Eliminate unnecessary memory allocation for CreateXxxxField http://bugzilla.kernel.org/show_bug.cgi?id=5426 Fixed problem reports (Fiodor Suietov) integrated: - Incomplete cleanup branches in AcpiTbGetTableRsdt (BZ 369) - On Address Space handler deletion, needless deactivation call (BZ 374) - AcpiRemoveAddressSpaceHandler: validate Device handle parameter (BZ 375) - Possible memory leak, Notify sub-objects of Processor, Power, ThermalZone (BZ 376) - AcpiRemoveAddressSpaceHandler: validate Handler parameter (BZ 378) - Minimum Length of RSDT should be validated (BZ 379) - AcpiRemoveNotifyHandler: return AE_NOT_EXIST if Processor Obj has no Handler (BZ (380) - AcpiUnloadTable: return AE_NOT_EXIST if no table of specified type loaded (BZ 381) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-28ACPI: ACPICA 20060623Bob Moore
Implemented a new acpi_spinlock type for the OSL lock interfaces. This allows the type to be customized to the host OS for improved efficiency (since a spinlock is usually a very small object.) Implemented support for "ignored" bits in the ACPI registers. According to the ACPI specification, these bits should be preserved when writing the registers via a read/modify/write cycle. There are 3 bits preserved in this manner: PM1_CONTROL[0] (SCI_EN), PM1_CONTROL[9], and PM1_STATUS[11]. http://bugzilla.kernel.org/show_bug.cgi?id=3691 Implemented the initial deployment of new OSL mutex interfaces. Since some host operating systems have separate mutex and semaphore objects, this feature was requested. The base code now uses mutexes (and the new mutex interfaces) wherever a binary semaphore was used previously. However, for the current release, the mutex interfaces are defined as macros to map them to the existing semaphore interfaces. Fixed several problems with the support for the control method SyncLevel parameter. The SyncLevel now works according to the ACPI specification and in concert with the Mutex SyncLevel parameter, since the current SyncLevel is a property of the executing thread. Mutual exclusion for control methods is now implemented with a mutex instead of a semaphore. Fixed three instances of the use of the C shift operator in the bitfield support code (exfldio.c) to avoid the use of a shift value larger than the target data width. The behavior of C compilers is undefined in this case and can cause unpredictable results, and therefore the case must be detected and avoided. (Fiodor Suietov) Added an info message whenever an SSDT or OEM table is loaded dynamically via the Load() or LoadTable() ASL operators. This should improve debugging capability since it will show exactly what tables have been loaded (beyond the tables present in the RSDT/XSDT.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060526Bob Moore
Restructured, flattened, and simplified the internal interfaces for namespace object evaluation - resulting in smaller code, less CPU stack use, and fewer interfaces. (With assistance from Mikhail Kouzmich) Fixed a problem with the CopyObject operator where the first parameter was not typed correctly for the parser, interpreter, compiler, and disassembler. Caused various errors and unexpected behavior. Fixed a problem where a ShiftLeft or ShiftRight of more than 64 bits produced incorrect results with some C compilers. Since the behavior of C compilers when the shift value is larger than the datatype width is apparently not well defined, the interpreter now detects this condition and simply returns zero as expected in all such cases. (BZ 395) Fixed problem reports (Valery Podrezov) integrated: - Update String-to-Integer conversion to match ACPI 3.0A spec http://bugzilla.kernel.org/show_bug.cgi?id=5329 Allow interpreter to handle nested method declarations http://bugzilla.kernel.org/show_bug.cgi?id=5361 Fixed problem reports (Fiodor Suietov) integrated: - acpi_terminate() doesn't free debug memory allocation list objects (BZ 355) - After Core Subsystem shutdown, acpi_subsystem_status() returns AE_OK (BZ 356) - acpi_os_unmap_memory() for RSDP can be invoked inconsistently (BZ 357) - Resource Manager should return AE_TYPE for non-device objects (BZ 358) - Incomplete cleanup branch in AcpiNsEvaluateRelative (BZ 359) - Use acpi_os_free() instead of ACPI_FREE in acpi_rs_set_srs_method_data (BZ 360) - Incomplete cleanup branch in acpi_ps_parse_aml (BZ 361) - Incomplete cleanup branch in acpi_ds_delete_walk_state (BZ 362) - acpi_get_table_header returns AE_NO_ACPI_TABLES until DSDT is loaded (BZ 365) - Status of the Global Initialization Handler call not used (BZ 366) - Incorrect object parameter to Global Initialization Handler (BZ 367) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-03-31[ACPI] ACPICA 20060210Bob Moore
Removed a couple of extraneous ACPI_ERROR messages that appeared during normal execution. These became apparent after the conversion from ACPI_DEBUG_PRINT. Fixed a problem where the CreateField operator could hang if the BitIndex or NumBits parameter referred to a named object. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5359 Fixed a problem where a DeRefOf operation on a buffer object incorrectly failed with an exception. This also fixes a couple of related RefOf and DeRefOf issues. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5360 http://bugzilla.kernel.org/show_bug.cgi?id=5387 http://bugzilla.kernel.org/show_bug.cgi?id=5392 Fixed a problem where the AE_BUFFER_LIMIT exception was returned instead of AE_STRING_LIMIT on an out-of-bounds Index() operation. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5480 Implemented a memory cleanup at the end of the execution of each iteration of an AML While() loop, preventing the accumulation of outstanding objects. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5427 Eliminated a chunk of duplicate code in the object resolution code. From Valery Podrezov. http://bugzilla.kernel.org/show_bug.cgi?id=5336 Fixed several warnings during the 64-bit code generation. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-31[ACPI] ACPICA 20060127Bob Moore
Implemented support in the Resource Manager to allow unresolved namestring references within resource package objects for the _PRT method. This support is in addition to the previously implemented unresolved reference support within the AML parser. If the interpreter slack mode is enabled (true on Linux unless acpi=strict), these unresolved references will be passed through to the caller as a NULL package entry. http://bugzilla.kernel.org/show_bug.cgi?id=5741 Implemented and deployed new macros and functions for error and warning messages across the subsystem. These macros are simpler and generate less code than their predecessors. The new macros ACPI_ERROR, ACPI_EXCEPTION, ACPI_WARNING, and ACPI_INFO replace the ACPI_REPORT_* macros. Implemented the acpi_cpu_flags type to simplify host OS integration of the Acquire/Release Lock OSL interfaces. Suggested by Steven Rostedt and Andrew Morton. Fixed a problem where Alias ASL operators are sometimes not correctly resolved. causing AE_AML_INTERNAL http://bugzilla.kernel.org/show_bug.cgi?id=5189 http://bugzilla.kernel.org/show_bug.cgi?id=5674 Fixed several problems with the implementation of the ConcatenateResTemplate ASL operator. As per the ACPI specification, zero length buffers are now treated as a single EndTag. One-length buffers always cause a fatal exception. Non-zero length buffers that do not end with a full 2-byte EndTag cause a fatal exception. Fixed a possible structure overwrite in the AcpiGetObjectInfo external interface. (With assistance from Thomas Renninger) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-20[ACPI] ACPICA 20060113Bob Moore
Added 2006 copyright. At SuSE's suggestion, enabled all error messages without enabling function tracing, ie with CONFIG_ACPI_DEBUG=n Replaced all instances of the ACPI_DEBUG_PRINT macro invoked at the ACPI_DB_ERROR and ACPI_DB_WARN debug levels with the ACPI_REPORT_ERROR and ACPI_REPORT_WARNING macros, respectively. This preserves all error and warning messages in the non-debug version of the ACPICA code (this has been referred to as the "debug lite" option.) Over 200 cases were converted to create a total of over 380 error/warning messages across the ACPICA code. This increases the code and data size of the default non-debug version by about 13K. Added ACPI_NO_ERROR_MESSAGES flag to enable deleting all messages. The size of the debug version remains about the same. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-12-28[ACPI] ACPICA 20051216Bob Moore
Implemented optional support to allow unresolved names within ASL Package objects. A null object is inserted in the package when a named reference cannot be located in the current namespace. Enabled via the interpreter slack flag which Linux has enabled by default (acpi=strict to disable slack). This should eliminate AE_NOT_FOUND exceptions seen on machines that contain such code. Implemented an optimization to the initialization sequence that can improve boot time. During ACPI device initialization, the _STA method is now run if and only if the _INI method exists. The _STA method is used to determine if the device is present; An _INI can only be run if _STA returns present, but it is a waste of time to run the _STA method if the _INI does not exist. (Prototype and assistance from Dong Wei) Implemented use of the C99 uintptr_t for the pointer casting macros if it is available in the current compiler. Otherwise, the default (void *) cast is used as before. Fixed some possible memory leaks found within the execution path of the Break, Continue, If, and CreateField operators. (Valery Podrezov) Fixed a problem introduced in the 20051202 release where an exception is generated during method execution if a control method attempts to declare another method. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
2005-07-12ACPICA 20050408 from Bob MooreRobert Moore
Fixed three cases in the interpreter where an "index" argument to an ASL function was still (internally) 32 bits instead of the required 64 bits. This was the Index argument to the Index, Mid, and Match operators. The "strupr" function is now permanently local (acpi_ut_strupr), since this is not a POSIX-defined function and not present in most kernel-level C libraries. References to the C library strupr function have been removed from the headers. Completed the deployment of static functions/prototypes. All prototypes with the static attribute have been moved from the headers to the owning C file. ACPICA 20050329 from Bob Moore An error is now generated if an attempt is made to create a Buffer Field of length zero (A CreateField with a length operand of zero.) The interpreter now issues a warning whenever executable code at the module level is detected during ACPI table load. This will give some idea of the prevalence of this type of code. Implemented support for references to named objects (other than control methods) within package objects. Enhanced package object output for the debug object. Package objects are now completely dumped, showing all elements. Enhanced miscellaneous object output for the debug object. Any object can now be written to the debug object (for example, a device object can be written, and the type of the object will be displayed.) The "static" qualifier has been added to all local functions across the core subsystem. The number of "long" lines (> 80 chars) within the source has been significantly reduced, by about 1/3. Cleaned up all header files to ensure that all CA/iASL functions are prototyped (even static functions) and the formatting is consistent. Two new header files have been added, acopcode.h and acnames.h. Removed several obsolete functions that were no longer used. Signed-off-by: Len Brown <len.brown@intel.com>
