All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Commit da8aeb92 re-poked the battery on resume, but Linus reports that
it broke his eee and partially reverted it in b23fffd7. Unfortunately
this also results in my x201s giving crack values until the sysfs files
are poked again. In the revert message, it was suggested that we poke it
from a PM notifier, so let's do that.
With this in place, I haven't noticed the units going nutty on my
gnome-power-manager across a dozen suspends or so...
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Len Brown <len.brown@intel.com>
This partially reverts commit da8aeb92d4853f37e281f11fddf61f9c7d84c3cd
("ACPI / Battery: Update information on info notification and resume"),
which causes a hang on resume on at least some machines.
This bug was bisected on an ASUS EeePC 901, which hangs at resume time
if we do that "acpi_battery_refresh(battery)" in the battery resume
function.
Rafael suspects we'll still need to refresh the sysfs files upon resume,
but that that can be done from a PM notifier (that will run after
thawing user space).
Bisected-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Len Brown <len.brown@intel.com>
A notification event 0x81 from an ACPI battery device requires us to
re-read the battery information structure. Follow this requirement
and remove and re-create the battery's attibutes in sysfs so that
they reflect the reporting units used by the battery at the moment
(those units may actually change sometimes at run time, which happens
on some Thinkpads).
The approach used in this patch was suggested by Matthew Garrett.
Reported-by: Matthew Garrett <mjg@redhat.com>
sysfs I/F for ACPI power devices, including AC and Battery,
has been working in upstream kenrel since 2.6.24, Sep 2007.
In 2.6.37, we made the sysfs I/F always built in and this option
disabled by default.
Now, we plan to remove this option and the ACPI power procfs
interface in 2.6.39.
First, update the feature-removal-schedule to announce this change.
Second, add runtime warnings in ACPI AC/Battery/SBS driver, so that
users will notice this change even if "make oldconfig" is used.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
The function acpi_battery_get_property() is called by the
power supply framework's function power_supply_show_property()
implementing the sysfs interface for power supply devices as the
ACPI battery driver's ->get_property() callback. Thus it is supposed
to return error code if the value of the given property is unknown.
Unfortunately, however, it returns 0 in those cases and puts a
wrong (negative) value into the intval field of the
union power_supply_propval object provided by
power_supply_show_property(). In consequence, wrong negative
values are read by user space from the battery's sysfs files.
Fix this by making acpi_battery_get_property() return -ENODEV
for properties with unknown values (-ENODEV is returned, because
power_supply_uevent() returns with error for any other error code
returned by power_supply_show_property()).
Reported-and-tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
According to the ACPI spec, some kinds of primary battery can
report percentage battery remaining capacity directly to OS.
In this case, it reports the LastFullChargedCapacity == 100,
BatteryPresentRate = 0xFFFFFFFF, and BatteryRemaingCapacity a
percentage value, which actually means RemainingBatteryPercentage.
Now we found some battery follows this rule even if it's a rechargeable.
https://bugzilla.kernel.org/show_bug.cgi?id=15979
Handle these batteries correctly in ACPI battery driver
so that they won't break userspace.
Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com>
ACPI AC/Battery/SBS driver has different kernel option for procfs and sysfs I/F.
This patch,
1. Change CONFIG_ACPI_PROCFS_POWER to 'n' by default so that we can remove it in the next release or two.
2. Remove CONFIG_ACPI_SYSFS_POWER and always build in the sysfs I/F of these drivers.
ACPI batteries can report in units of either current or energy. Right
now we expose the current_now file even if the battery is reporting
energy units, resulting in a file that should contain mA instead
containing mW. Don't expose this value unless the battery is reporting
current.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
When battery is hot-added, we should not invoke power_supply_changed
in acpi_battery_notify, because it has been invoked in acpi_battery_update,
and battery->bat.changed_work is queued in keventd already.
https://bugzilla.kernel.org/show_bug.cgi?id=16244
Acked-by: Alexey Starikovskiy <astarikovskiy@sude.de>
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
Calling kobject_uevent() directly is a layering violation. In
particular, it means we'll miss updating the generic LED trigger.
Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Disabling CONFIG_ACPI_SYSFS_POWER changes the behaviour of
acpi_battery_update(). It will call acpi_battery_get_info()
even if the battery is not present. I haven't noticed this
causing any problem, but it does look like a bad idea.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
acpi_integer is now obsolete and removed from the ACPICA code base,
replaced by u64.
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Acer Aspire 8930G laptops (and possibly others) report the battery current
as a 16-bit signed negative when it is charging. It also reports it as
0x10000 when the current is 0. This patch adds a quirk for this which
takes the absolute value of the reported current cast to an s16. This is
a DSDT bug present in the latest BIOS revision (the EC register is 16 bits
signed and the DSDT attempts to take the 16-bit two's complement of this,
which works for discharge but not charge. It also breaks zero values
because a 32-bit register is used and the high bits aren't thrown away).
I've enabled this for all Acer systems which report in mA units. This
should be safe since it won't break compliant systems unless they report a
current above 32A, which is insane. The patch also detects the valid
32-bit value -1, which indicates unknown status, and does not attempt the
fix in that case (note that this does not conflict with 16-bit -1, which
is 65535 as read normally and gets translated to 1mA).
Signed-off-by: Hector Martin <hector@marcansoft.com>
Linux/ACPI core files using internal.h all PREFIX "ACPI: ",
however, not all ACPI drivers use/want it -- and they
should not have to #undef PREFIX to define their own.
Add GPL commment to internal.h while we are there.
This does not change any actual console output,
asside from a whitespace fix.
drivers/acpi/battery.c:841: warning: label ‘end’ defined but not used
This patch adds a .notify() method. The presence of .notify() causes
Linux/ACPI to manage event handlers and notify handlers on our behalf,
so we don't have to install and remove them ourselves.
This driver apparently relies on seeing ALL notify events, not just
device-specific ones (because it used ACPI_ALL_NOTIFY). We use the
ACPI_DRIVER_ALL_NOTIFY_EVENTS driver flag to request all events.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
CC: Alexey Starikovskiy <alexey.y.starikovskiy@linux.intel.com>
This reverts commit 5d38258ec026921a7b266f4047ebeaa75db358e5, since the
underlying problem got fixed properly in the previous commit ("async:
Fix module loading async-work regression").
Cc: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
> BUG: unable to handle kernel NULL pointer dereference at (null)
What happens is that the battery module's init sections are being freed
before the async callback (which was marked __init) has run. This theory
is supported by the fact that the bad RIP value is a vmalloc address.
The immediate fix is to make this a non-init call.
(A better long-term fix is of course to wait with init-section unloading
until a module's async initcalls have been run, which would allow us to
discard this function which is still only run once, after all. Perhaps a
new async_initcall() function for the async/module API, if this is needed
for other modules in the future?)
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Alessandro Suardi <alessandro.suardi@gmail.com>
Tested-by: Rafael J. Wysocki <rjw@sisk.pl>
arch/x86/kernel/cpu/cpufreq/longhaul.c
drivers/acpi/Makefile
The battery driver tends to take quite some time to initialize
(100ms-300ms is quite typical).
This patch initializes the batter driver asynchronously, so that other
things in the kernel can initialize in parallel to this 300 msec.
As part of this, the battery driver had to move to the back
of the ACPI init order (hence the Makefile change).
Without this move, the next ACPI driver would just block
on the ACPI/devicee layer semaphores until the battery driver was
done anyway, not gaining any boot time.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy
as correctly noted at bug #12454. Someone can lookup entry with NULL
->owner, thus not pinning enything, and release it later resulting
in module refcount underflow.
We can keep ->owner and supply it at registration time like ->proc_fops
and ->data.
But this leaves ->owner as easy-manipulative field (just one C assignment)
and somebody will forget to unpin previous/pin current module when
switching ->owner. ->proc_fops is declared as "const" which should give
some thoughts.
->read_proc/->write_proc were just fixed to not require ->owner for
protection.
rmmod'ed directories will be empty and return "." and ".." -- no harm.
And directories with tricky enough readdir and lookup shouldn't be modular.
We definitely don't want such modular code.
Removing ->owner will also make PDE smaller.
So, let's nuke it.
Kudos to Jeff Layton for reminding about this, let's say, oversight.
http://bugzilla.kernel.org/show_bug.cgi?id=12454
ACPI has smart batteries, which work in units of energy and measure
rate of (dis)charge as power, thus it is not appropriate to export it
as a current_now. Current_now will still be exported to allow
for userland applications to match.
On hardware like the T61 it can take a couple of seconds for the battery
to start charging after the power is connected, and we incorrectly tell
userspace that we are fully charged, and then go back to charging.
Only mark a battery as fully charged when the preset charge matches either
the last full charge, or the design charge.
http://bugzilla.kernel.org/show_bug.cgi?id=12632
Signed-off-by: Richard Hughes <hughsient@gmail.com>
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
update of battery info fields is required.
Acked-by: Andy Neitzke <neitzke@ias.edu>
Signed-off-by: Alexey Starikovskiy <astarikovskiy <at> suse.de>
This reverts commit 558073dd56707864f09d563b64e7c37c021e89d2, along with
the failed try to fix the regression it caused ("ACPI: Fix ACPI battery
regression introduced by commit 558073"), which just made things worse.
Commit aaad077638be1a25871bcae5e43952d6b63abfca (that failed "Fix ACPI
battery regression") got the voltage conversion confused, and fixed the
problem with Rafael's battery monitor apparently just by mistake.
So revert them both, getting us back to the 2.6.27 state in this, and
let's revisit it when people understand what's going on.
Noted-by: Paul Martin <pm@debian.org>
Requested-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Alexey Starikovskiy <astarikovskiy@suse.de>
Commit 558073dd56707864f09d563b64e7c37c021e89d2 ("ACPI: battery: Convert
discharge energy rate to current properly") caused the battery subsystem
to report wrong values of the remaining time on battery power and the
time until fully charged on Toshiba Portege R500 (and presumably on
other boxes too).
Fix the issue by correcting the conversion from mW to mA.
ACPI battery interface reports its state either in mW or in mA, and
discharge rate in your case is reported in mW. power_supply interface
does not have such a parameter, so current_now parameter is used
for all cases. But in case of mW, reported discharge should
be converted into mA.
Tested-by: Ferenc Wagner <wferi@niif.hu>
Move all the component definitions for drivers to a single shared place,
include/acpi/acpi_drivers.h.
This patch is part of a larger patch series which will remove
the "char bus_id[20]" name string from struct device. The device
name is managed in the kobject anyway, and without any size
limitation, and just needlessly copied into "struct device".
To set and read the device name dev_name(dev) and dev_set_name(dev)
must be used. If your code uses static kobjects, which it shouldn't
do, "const char *init_name" can be used to statically provide the
name the registered device should have. At registration time, the
init_name field is cleared, to enforce the use of dev_name(dev) to
access the device name at a later time.
We need to get rid of all occurrences of bus_id in the entire tree
to be able to enable the new interface. Please apply this patch,
and possibly convert any remaining remaining occurrences of bus_id.
We want to submit a patch to -next, which will remove bus_id from
"struct device", to find the remaining pieces to convert, and finally
switch over to the new api, which will remove the 20 bytes array
and does no longer have a size limitation.
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
MAINTAINERS
arch/x86/kernel/acpi/boot.c
arch/x86/kernel/acpi/sleep.c
drivers/acpi/Kconfig
drivers/pnp/Makefile
drivers/pnp/quirks.c
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs
attribute->owner unnecessary. But the field was left in the structure to
ease the merge. It's been over a year since that change and it is now
time to start killing attribute->owner along with its users - one arch at
a time!
This patch is attempt #1 to get rid of attribute->owner only for
CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on
as and when possible - avr32 will be the next since that is something I
can test. Compile (make allyesconfig / make allmodconfig / custom config)
and boot tested.
akpm: the idea is that we put the declaration of sttribute.owner inside
`#ifndef CONFIG_X86'. But that proved to be too ambitious for now because
new usages kept on turning up in subsystem trees.
[akpm: remove the ifdef for now]
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Catch attempts to use of acpi_driver_data on pointers of wrong type.
akpm: rewritten to use proper C typechecking and remove the
"function"-used-as-lvalue thing.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Add correct ->owner to proc_fops to fix reading/module unloading race.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Acer BIOS has a bug which is exposed when a dead battery is present.
The package template that is used to describe battery status is
over-written with sane values when the battery is live.
But when the batter is dead, a bogus reference in the template
is used. In this case, Linux returns a fault, when instead
it should simply return that it doesn't know the missing value.
http://bugzilla.kernel.org/show_bug.cgi?id=8573
http://bugzilla.kernel.org/show_bug.cgi?id=10202
egrep serial /proc/acpi/battery/BAT0/info
serial number: 32090
serial number can tell you from the imminent danger
of beeing set on fire.
Signed-off-by: maximilian attems <max@stro.at>
Reference: http://bugzilla.kernel.org/show_bug.cgi?id=9494
At least some systems report technology information with trailing spaces:
{pts/1}% cat -E /var/tmp/bat/2.6.23 | grep type
battery type: Li-ION $
Use strncasecmp to compare model string to skip trailing part
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
