path: root/drivers/acpi/acpica
2010-04-16Merge branch 'bugzilla-15749' into releaseLen Brown
2010-04-16ACPI: EC: Limit burst to 64 bitsAlexey Starikovskiy
access_bit_width field is u8 in ACPICA, thus 256 value written to it becomes 0, causing divide by zero later. Proper fix would be to remove access_bit_width at all, just because we already have access_byte_width, which is access_bit_width / 8. Limit access width to 64 bit for now. https://bugzilla.kernel.org/show_bug.cgi?id=15749 fixes regression caused by the fix for: https://bugzilla.kernel.org/show_bug.cgi?id=14667 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-06Merge branches 'battery', 'bugzilla-14667', 'bugzilla-15096', ↵Len Brown
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
2010-03-23ACPI / ACPICA: Do not check reference counters in acpi_ev_enable_gpe()Rafael J. Wysocki
acpi_ev_enable_gpe() should enable the GPE at the hardware level regardless of the value of the GPE's runtime reference counter. There are only two callers of acpi_ev_enable_gpe(), acpi_enable_gpe() and acpi_set_gpe(). The first one checks the GPE's runtime reference counter itself and only calls acpi_ev_enable_gpe() if it's equal to one, and the other one is supposed to enable the GPE unconditionally (if called with ACPI_GPE_ENABLE). This change fixes the problem in acpi_enable_wakeup_device() where the GPE will not be enabled for wakeup if it's runtime reference counter is zero, which is a regression from 2.6.33. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-17ACPI: EC: Allow multibyte access to ECAlexey Starikovskiy
http://bugzilla.kernel.org/show_bug.cgi?id=14667 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14Merge branches 'battery-2.6.34', 'bugzilla-10805', 'bugzilla-14668', ↵Len Brown
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-02-24ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
To fix a bug and address the reviewers' comments regarding the ACPI GPE refcounting patch, do the following additional changes: o Remove the second argument of acpi_ev_enable_gpe(), 'write_to_hardware', because it is not necessary any more. o Add the "bad parameter" test against 'type' in acpi_enable_gpe() and acpi_disable_gpe(). o Make acpi_enable_gpe() only check 'status' for runtime GPEs if acpi_ev_enable_gpe() was actually called. o Make acpi_disable_gpe() return 'status' returned by acpi_ev_disable_gpe() and fix a bug where ACPI_GPE_TYPE_WAKE and ACPI_GPE_TYPE_RUNTIME were exchanged by mistake. o Add comments explaining why acpi_set_gpe() is used by the ACPI EC driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI / ACPICA: Multiple system notify handlers per deviceRafael J. Wysocki
Currently it only is possible to install one system notify handler per namespace node, but this is not enough for PCI run-time power management, because we need to install power management notifiers for devices that already have hotplug notifiers installed. While in principle this could be handled at the PCI level, that would be suboptimal due to the way in which the ACPI-based PCI hotplug code is designed. For this reason, modify ACPICA so that it is possible to install more than one system notify handler per namespace node. Namely, make acpi_install_notify_handler(), acpi_remove_notify_handler() and acpi_ev_notify_dispatch() use a list of system notify handler objects associated with a namespace node. Make acpi_remove_notify_handler() call acpi_os_wait_events_complete() upfront to avoid a situation in which concurrent instance of acpi_remove_notify_handler() removes the handler from under us while we're waiting for the event queues to flush. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-16ACPICA: fix acpi_ex_release_mutex() commentBartlomiej Zolnierkiewicz
trivial, leftover from my NULL pointer dereference patch which got 'superseded' by commit fbc3be2 Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Disassembler: Remove obsolete "Integer64" field in parse objectBob Moore
This field is no longer needed. The "Integer" field is 64 bit and is sufficient. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) typeBob Moore
This type was introduced as the code was migrated from ACPI 1.0 (with 32-bit AML integers) to ACPI 2.0 (with 64-bit integers). It is now obsolete and this change removes it from the ACPICA code base, replaced by u64. The original typedef has been retained for now for compatibility with existing device driver code. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Predefined name repair: fix NULL package elementsBob Moore
For the predefined methods that return fixed-length packages (or subpackages), attempt repair for a NULL element. Create an Integer of value 0, a NULL String, or a zero-length buffer as appropriate. http://www.acpica.org/bugzilla/show_bug.cgi?id=818 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: AcpiGetDevices: Eliminate unnecessary _STA callsLin Ming
In the case where a specific _HID is requested, do not run _STA until a _HID match is found. This eliminates potentially dozens of _STA calls during a search for a particular device/HID. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update for new gcc-4 warning optionsBob Moore
Added several new options for the gcc-4 generation, and updated the source accordingly. This includes some code restructuring to eliminate unreachable code, elimination of some gotos, elimination of unused return values, and some additional casting. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15Merge branch 'acpica' into releaseLen Brown
2009-12-15ACPICA: Move check for valid Thread ID structureDan Carpenter
This change moves the check for a valid Thread ID structure up a few lines to insure that the check is made before the structure is actually used. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Predefined name repair: automatically remove null package elementsBob Moore
This change will automatically remove embedded and trailing NULL package elements from returned package objects that are defined to containe a variable number of sub-packages. The driver is then presented with a package with no null elements to deal with. ACPICA BZ 819. http://www.acpica.org/bugzilla/show_bug.cgi?id=819 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Module-level code: enable _REG execution in same scopeLin Ming
This change enables the execution of _REG methods that appear in the same scope as the module-level code, in resonse to an operation region declaration within the module-level code. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Conditionally perform complex per-predefined-name repairsBob Moore
Only attempt the "complex" repairs (package sorting, buffer expansion) if the previous "generic" validation and repair was successful. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Update function headers and comments, no functional changeBob Moore
Update comments for repair of _FDE and _GTM methods. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Remove messages if predefined repair(s) are successfulBob Moore
Repair mechanism was considered too wordy. Now, messages are only unconditionally emitted if the return object cannot be repaired. Existing messages for successful repairs were converted to ACPI_DEBUG_PRINT messages for now. ACPICA BZ 827. http://www.acpica.org/bugzilla/show_bug.cgi?id=827 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Move Package-to-Buffer repair code into common ToBuffer functionBob Moore
Move code specific to _FDE and _GTM into the generic repair code. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Fix mutex errors when running _REG methodsBob Moore
Fixes a problem where mutex errors can occur when running a _REG method that is in the same scope as a method-defined operation region or an operation region under a module-level IF block. This is rare, so the problem has not been seen before. ACPICA BZ 826. http://www.acpica.org/bugzilla/show_bug.cgi?id=826 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Update function headers, no functional changeBob Moore
Fixed a few errors with the headers in utcopy.c Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Add more conversions to predefined name repair moduleBob Moore
This change enhances the automatic repairs/conversions for predefined name return values to make Integers, Strings, and Buffers fully interchangeable. Also, a Buffer can be converted to a Package of Integers if necessary. The nsrepair.c module was completely restructured. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Update internal namespace node/handle interfacesBob Moore
This change deletes the unnecessary acpi_ns_convert_entry_to_handle interface and renames the acpi_ns_map_handle_to_node interface to acpi_ns_validate_handle. ACPICA BZ 798. http://www.acpica.org/bugzilla/show_bug.cgi?id=798 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Add repair for bad _FDE/_GTM buffersBob Moore
The expected return value for both names is a Buffer of 5 DWORDS. This repair fixes two possible problems (both seen in the field): A package of integers is returned, or a buffer of BYTEs is returned. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Fix two additional Scope override error messagesBob Moore
These messages were using the internal path for the message instead of using the node name. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Fix two Scope type error messagesBob Moore
Both messages incorrectly used the internal Path string instead of the node name. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Fix possible memory leak for module-level code executionLin Ming
An object can be leaked for each block of executed module-level code if the interpreter slack mode is enabled. The change deletes any implicitly returned object in this case. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-09Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPICA: Update version to 20091112. ACPICA: Add additional module-level code support ACPICA: Deploy new create integer interface where appropriate ACPICA: New internal utility function to create Integer objects ACPICA: Add repair for predefined methods that must return sorted lists ACPICA: Fix possible fault if return Package objects contain NULL elements ACPICA: Add post-order callback to acpi_walk_namespace ACPICA: Change package length error message to an info message ACPICA: Reduce severity of predefined repair messages, Warning to Info ACPICA: Update version to 20091013 ACPICA: Fix possible memory leak for Scope ASL operator ACPICA: Remove possibility of executing _REG methods twice ACPICA: Add repair for bad _MAT buffers ACPICA: Add repair for bad _BIF/_BIX packages
2009-11-24ACPICA: Silence the warning about _BIF returning the bufferAlexey Starikovskiy
_BIF was returning buffer instead of a string since day 1 of ACPI. Adding a warning for that is noble, but people don't like when someone cries wolf in a production system. Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14379 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add additional module-level code supportLin Ming
This change will execute module-level code that is not at the root of the namespace (under a Device object, etc.). ACPICA BZ 762. http://www.acpica.org/bugzilla/show_bug.cgi?id=762 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Deploy new create integer interface where appropriateBob Moore
Simplifies creation of simple integer objects. ACPICA BZ 823. http://www.acpica.org/bugzilla/show_bug.cgi?id=823 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: New internal utility function to create Integer objectsBob Moore
acpi_ut_create_integer_object. This function (when deployed) should simplify some of the object creation code. ACPICA BZ 823. http://www.acpica.org/bugzilla/show_bug.cgi?id=823 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add repair for predefined methods that must return sorted listsBob Moore
This change will repair (by sorting) packages returned by _ALR, _PSS, and _TSS. Drivers can now assume that the packages are correctly sorted. Adds one new file, nsrepair2.c. ACPICA BZ 784. http://www.acpica.org/bugzilla/show_bug.cgi?id=784 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Fix possible fault if return Package objects contain NULL elementsBob Moore
For predefined name validation. Also adds a warning if a NULL element is followed by any non-null elements. ACPICA BZ 813, 814. http://www.acpica.org/bugzilla/show_bug.cgi?id=813 http://www.acpica.org/bugzilla/show_bug.cgi?id=814 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add post-order callback to acpi_walk_namespaceLin Ming
The existing interface only has a pre-order callback. This change adds an additional parameter for a post-order callback which will be more useful for bus scans. ACPICA BZ 779. Also update the external calls to acpi_walk_namespace. http://www.acpica.org/bugzilla/show_bug.cgi?id=779 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Change package length error message to an info messageBob Moore
This message happens when the package element list is longer than the declared length of the package. Changed to an info message because this condition is not actually an error. It is caused by the BIOS attempting to truncate the package on the fly by adjusting the package element count at the start of the package definition. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Reduce severity of predefined repair messages, Warning to InfoBob Moore
Since the object was successfully repaired, a Warning is too severe. Reduced to Info for now. We may eventually change these messages to debug-only. ACPICA BZ 812. http://www.acpica.org/bugzilla/show_bug.cgi?id=812 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Fix possible memory leak for Scope ASL operatorLin Ming
Using Scope(\) to change the scope to the root could cause a single object memory leak. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Remove possibility of executing _REG methods twiceLin Ming
If a custom address space handler is installed by the host before the "initialize operation regions" phase of the ACPICA initialization, any _REG methods for that address space could be executed twice. This change fixes the problem. ACPICA BZ 427. http://www.acpica.org/bugzilla/show_bug.cgi?id=427 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add repair for bad _MAT buffersLin Ming
_MAT can inadvertently return an Integer instead of a Buffer if the return value has been read from a Field whose width is less than or equal to the global integer width (32 or 64 bits). ACPICA BZ 810. http://www.acpica.org/bugzilla/show_bug.cgi?id=810 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Add repair for bad _BIF/_BIX packagesBob Moore
Add a repair for the "Oem Information" field which is often mistakenly returned as an integer. It should always be a string. ACPICA BZ 807. http://www.acpica.org/bugzilla/show_bug.cgi?id=807 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-05ACPICA: avoid "Info: mapping multiple BARs. Your kernel is fine."Bob Moore
Ensure that memory mappings created for operation regions do not cross page boundaries. Crossing a page boundary while mapping regions can cause warnings if the pages have different attributes. Such regions are probably BIOS bugs, and this is the workaround. http://bugzilla.kernel.org/show_bug.cgi?id=14445 [Kernel summit hacking hour] Signed-off-by: Bob Moore <robert.moore@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-20x86: Trivial whitespace cleanupsFelipe Contreras
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Vegard Nossum <vegardno@ifi.uio.no> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alok N Kataria <akataria@vmware.com> Cc: "Tan Wei Chong" <wei.chong.tan@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Bob Moore <robert.moore@intel.com> LKML-Reference: <1253137123-18047-2-git-send-email-felipe.contreras@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
