commit 5d42b0fa25df7ef2f575107597c1aaebe2407d10 upstream.
ACPICA BZ 1077. David Binderman.
References: https://bugs.acpica.org/show_bug.cgi?id=1077
Signed-off-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
It is reported by kernel build test systems that all ACPICA source
files in the kernel tree have incorrect label indentation. This
patch changes default indent option used in the release process to
fix this bug. Lv Zheng.
This change adds and deploys "safe" versions of strcpy and strcat that
ensure that the target buffer does not overflow. These safe functions
are only helpful for processing user input and command lines. For most
ACPICA code however, the required buffer length is precisely calculated
before buffer allocation, so the use of these functions is unnecessary.
ACPICA BZ 1043.
This change only applies to the ACPICA utilities and the debugger, none
of which are not shipped with the kernel yet, so the kernel's behavior
remains unchanged after it.
References: https://bugs.acpica.org/show_bug.cgi?id=1043
Was 256 bytes max. The original purpose of this constraint was to
limit the amount of debug output. However, the string function in
question (UtPrintString) is now used for the disassembler also,
where 256 bytes is insufficient. Reported by RehabMan@GitHub.
Acked-by: Len Brown <len.brown@intel.com>
Clean up the interface by making the input argument a char *
string instead of a UINT32 name. This is easier to use for all
callers and eliminates casting to *(UINT32*)
After many years, different formatting for switch() has crept in.
This change makes every switch block identical. Chao Guan.
ACPICA bugzilla 997.
References: https://bugs.acpica.org/show_bug.cgi?id=997
Signed-off-by: Chao Guan <chao.guan@intel.com>
Includes all source headers and signons for the various tools.
Created logical splits for eight new files. Improves modularity
and configurability.
