path: root/drivers/acpi/acpica/tbxface.c
2015-07-01ACPICA: De-macroize calls to standard C library functionsBob Moore
ACPICA commit 3b1026e0bdd3c32eb6d5d313f3ba0b1fee7597b4 ACPICA commit 00f0dc83f5cfca53b27a3213ae0d7719b88c2d6b ACPICA commit 47d22a738d0e19fd241ffe4e3e9d4e198e4afc69 Across all of ACPICA. Replace C library macros such as ACPI_STRLEN with the standard names such as strlen. The original purpose for these macros is long since obsolete. Also cast various invocations as necessary. Bob Moore, Jung-uk Kim, Lv Zheng. Link: https://github.com/acpica/acpica/commit/3b1026e0 Link: https://github.com/acpica/acpica/commit/00f0dc83 Link: https://github.com/acpica/acpica/commit/47d22a73 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Jung-uk Kim <jkim@FreeBSD.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-06-23ACPICA: Linuxize: Reduce divergences for 20150616 releaseLv Zheng
This patch reduces source code differences between the Linux kernel and the ACPICA upstream so that the linuxized ACPICA 20150616 release can be applied with reduced human intervention. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-26ACPI: Introduce acpi_unload_parent_table() usages in Linux kernelLv Zheng
ACPICA has implemented acpi_unload_parent_table() which can exactly replace the acpi_get_id()/acpi_unload_table_id() implemented in Linux kernel. The acpi_unload_parent_table() has been unit tested in ACPICA simulation environment. This patch can also help to reduce the source code differences between Linux and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Tested-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-22ACPICA: take ACPI_MTX_INTERPRETER in acpi_unload_table_id()Octavian Purdila
acpi_tb_delete_namespace_by_owner() expects ACPI_MTX_INTERPRETER to be taken. This fixes the following issue: ACPI Error: Mutex [0x0] is not acquired, cannot release (20141107/utmutex-322) Call Trace: [<ffffffff81b0bd28>] dump_stack+0x4f/0x7b [<ffffffff81546bfc>] acpi_ut_release_mutex+0x47/0x67 [<ffffffff81542cf1>] acpi_tb_delete_namespace_by_owner+0x57/0x8d [<ffffffff81543ef1>] acpi_unload_table_id+0x3a/0x5e Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Table Manager: Misc cleanup and renames, no functional change.Bob Moore
Some various cleanups and renames. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Tables: Cleanup ACPI_TABLE_ORIGIN_xxx flags.Lv Zheng
This patch refines ACPI_TABLE_ORIGIN_xxx flags. No functional changes. The previous commits have introduced the following internal APIs: 1. acpi_tb_acquire_table: Acquire struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 2. acpi_tb_release_table: Release struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 3. acpi_tb_install_table: Make struct acpi_table_desc.Address not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 4. acpi_tb_uninstall_table: Make struct acpi_table_desc.Address NULL according to ACPI_TABLE_ORIGIN_xxx flags. 5. acpi_tb_validate_table: Make struct acpi_table_desc.Pointer not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 6. acpi_tb_invalidate_table: Make struct acpi_table_desc.Pointer NULL according to ACPI_TABLE_ORIGIN_xxx flags. It thus detects that the ACPI_TABLE_ORIGIN_UNKNOWN is redundant to ACPI_TABLE_ORIGIN_OVERRIDE. The ACPI_TABLE_ORIGIN_xxTERN_VIRTUAL flags are named as VIRTUAL in order not to confuse with x86 logical address, this patch also renames all "logical override" into "virtual override". Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Tables: Clean up split INSTALLED/VALIDATED table state logics.Lv Zheng
This patch is mainly a naming cleanup to clarify hidden logics, no functional changes. acpi_initialize_tables() is used by Linux to install table addresses for early boot steps. During this stage, table addresses are mapped by early_ioremap() mechanism which is different from the runtime IO mappings. Thus it is not safe for ACPICA to keep mapped pointers in struct acpi_table_desc structure during this stage. In order to support this in ACPICA, table states are divided into 1. "INSTALLED" (where struct acpi_table_desc.Pointer is always NULL) and 2. "VALIDATED" (where struct acpi_table_desc.Pointer is always not NULL). During acpi_initialize_tables(), table state are ensured to be "INSTALLED" but not "VALIDATED". This logic is ensured by the original code in very ambigious way. For example, currently acpi_tb_delete_table() is invoked in some place to perform an uninstallation while it is invoked in other place to perform an invalidation. They happen to work just because no one enters the penalty where the 2 behaviours are not equivalent. The naming cleanups are made in this patch: A. For installation and validation: There is code setting struct acpi_table_desc.Pointer first and delete it immediately to keep the descriptor's state as "INSTALLED" during the installation. This patch implements this in more direct way. After applying it, struct acpi_table_desc.Pointer will never be set in acpi_tb_install_table() and acpi_tb_override_table() as they are the only functions invoked during acpi_initialize_tables(). This is achieved by: 1. Rename acpi_tb_verify_table() to acpi_tb_validate_table() to clarify this change. 2. Rename acpi_tb_table_override() to acpi_tb_override_table() to keep nameing consistencies as other APIs (verb. Table). 3. Stops setting struct acpi_table_desc.Pointer in acpi_tb_install_table() and acpi_tb_table_override(). 4. Introduce acpi_tb_acquire_table() to acquire the table pointer that is not maintained in the struct acpi_table_desc of the global root table list and rewrite acpi_tb_validate_table() using this new function to reduce redundancies. 5. Replace the table pointer using the overridden table pointer in acpi_tb_add_table(). As acpi_tb_add_table() is not invoked during early boot stage, tables returned from this functions should be "VALIDATED". As acpi_tb_override_table() is modified by this patch to return a "INSTALLED" but not "VALIDATED" descriptor, to keep acpi_tb_add_table() unchanged, struct acpi_table_desc.Pointer is filled in acpi_tb_add_table(). B. For invalidation and uninstallation: The original code invalidate table by invoking acpi_tb_delete_table() here and there, but actually this function should only be used to uninstall tables. This can work just because its invocations are equivalent to invalidation in some cases. This patch splits acpi_tb_delete_table() into acpi_tb_invalidate_table() and acpi_tb_uninstall_table() and cleans up the hidden logic using the new APIs. This is achieved by: 1. Rename acpi_tb_delete_table() to acpi_tb_uninstall_table() as it is mainly called before resetting struct acpi_table_desc.Address. Thus the table descriptor is in "not INSTALLED" state. This patch enforces this by setting struct acpi_table_desc.Address to NULL in this function. 2. Introduce acpi_tb_invalidate_table() to be the reversal of acpi_tb_validate_table() and invoke it in acpi_tb_uninstall_table(). 3. Introduce acpi_tb_release_table() to release the table pointer that is not maintained in acpi_gbl_root_table_list and rewrite acpi_tb_invalidate_table() using this new function to reduce redundancies. After cleaning up, the maintainability of the internal APIs are also improved: 1. acpi_tb_acquire_table: Acquire struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 2. acpi_tb_release_table: Release struct acpi_table_header according to ACPI_TABLE_ORIGIN_xxx flags. 3. acpi_tb_install_table: Make struct acpi_table_desc.Address not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 4. acpi_tb_uninstall_table: Make struct acpi_table_desc.Address NULL according to ACPI_TABLE_ORIGIN_xxx flags. 5. acpi_tb_validate_table: Make struct acpi_table_desc.Pointer not NULL according to ACPI_TABLE_ORIGIN_xxx flags. 6. acpi_tb_invalidate_table: Make struct acpi_table_desc.Pointer NULL according to ACPI_TABLE_ORIGIN_xxx flags. 7. acpi_tb_override_table: Replace struct acpi_table_desc.Address and struct acpi_table_desc.Flags. It only happens in "INSTALLED" state. The patch has been unit tested in acpi_exec by: 1. Initializing; 2. Executing exc_tbl ASLTS tests; 3. Executing "Load" command. So that all original acpi_tb_install_table() and acpi_tb_override_table() invocations are covered. Known Issues: 1. Cleanup acpi_tb_add_table() to Kill Code Redundancies Current implementation in acpi_tb_add_table() is not very clean, further patch can rewrite acpi_tb_add_table() with ordered acpi_tb_install_table(), acpi_tb_override_table() and acpi_tb_validate_table(). It is not done in this patch so that it is easy for the reviewers to understand the changes in this patch. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20ACPICA: Remove indent divergences to reduce maintenance overhead.Lv Zheng
The divergences in the ACPICA files makes it difficult to maintain linuxize ACPICA table commits. This patch reduces such divergences before applying table manager commits so that human interventions of patch rebasing can be reduced. Signed-off-by: Lv Zheng <lv.zheng@intel.com> [rjw: Subject] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Add __init for ACPICA initializers/finalizers.Lv Zheng
This patch adds __init to the ACPICA documented initializers: acpi_initialize_tables() acpi_initialize_subsystem() acpi_load_tables() acpi_enable_subsystem() acpi_initialize_objects() and to acpi_reallocate_root_table(), acpi_find_root_pointer() which are also meant to be called only during initialization. This patch adds __init to the ACPICA documented finalizer: acpi_terminate() as this finalizer is only called in __init function now. This change helps to reduce source code differences between ACPICA upstream and Linux. [rjw: Changelog] Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Deploy ACPI_EXPORT_SYMBOL_INIT for main ACPICA initialization ↵Lv Zheng
interfaces. This changes can reduce source code differences between Linux and ACPICA upstream to help improving the release automation. The side effect of applying this patch in Linux is: 1. Some ACPICA initialization/termination APIs are no longer exported in Linux, these include: acpi_load_tables acpi_initialize_subsystem acpi_enable_subsystem acpi_initialize_objects acpi_terminate 2. This patch does not affect the following APIs as they are currently not marked with ACPI_EXPORT_SYMBOL in Linux: acpi_reallocate_root_table acpi_initialize_tables Such functions should not be exported as they are internal to ACPI subsystem in Linux, and will only be invoked inside of ACPI subsystem's initialization routines marked with __init and termination routines marked with __exit. While on other OSPMs, such functions may still need to be exported. Thus this patch adds the configurability for ACPICA, so that it leaves OSPMs to determine if the __init/__exit marked functions should be exported or not. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Linuxize: Change indentation of C labels.Lv Zheng
It is reported by kernel build test systems that all ACPICA source files in the kernel tree have incorrect label indentation. This patch changes default indent option used in the release process to fix this bug. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Add EXPORT_ACPI_INTERFACES macro to external interface modules.Lv Zheng
For Linux, there are no functional changes/binary generation differences introduced by this patch. This change adds a new macro to all files that contain external ACPICA interfaces. It can be detected and used by the host (via the host-specific header) for any special processing required for such modules. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-12ACPICA: Fix for some comments/headersTang Chen
No functional change. Includes parameter rename from Tang Chen. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2013-01-11ACPICA: Cleanup table handler naming conflicts.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 44 lines of 20121114 divergence.diff. There are naming conflicts between Linux and ACPICA on table handlers. This patch cleans up this conflicts to reduce the source code diff between Linux and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-10ACPICA: Cleanup source to reduce differences between Linux and ACPICA.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 389 lines of 20121018 divergence.diff. This patch reduces source code diff caused by the simple code maintenance work: 1. Deletion of the unused include files. 2. Deletion of the deprecated codes blocks. 3. Repositioning of the code blocks. 4. Replacing the values with the well defined macros. 5. Replacing the types with the equivalent types. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Audit/update for ACPICA return macros and debug depth counterBob Moore
1) Ensure that all functions that use the various TRACE macros also use the appropriate ACPICA return macros. 2) Ensure that all normal return statements surround the return expression (value) with parens. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-21ACPICA: Table Manager: Merge duplicate code (root table)Lv Zheng
Merge/remove duplicate code in the root table resize functions One function is external, the other is internal. Lv Zheng, ACPICA BZ 846: https://acpica.org/bugzilla/show_bug.cgi?id=846 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-08-20ACPI: export symbol acpi_get_table_with_sizeAlex Deucher
We need it in the radeon drm module to fetch and verify the vbios image on UEFI systems. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2012-07-17ACPICA: AcpiSrc: Fix some translation issues for Linux conversionBob Moore
Fixes issues like this: i_aSL -> iASL 00-7_f -> 00-7F local_fADT -> local_FADT execute_oSI -> execute_OSI Also, in function headers, the parameters are now translated to lower case (with underscores if necessary.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-17ACPICA: Add new ACPI table load/unload external interfacesBob Moore
Add acpi_load_table and acpi_unload_parent_table to support host-directed dynamic table load/unload. Intended to support hotplug addition and removal of SSDTs. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-17ACPICA: Split file: tbxface.c -> tbxfload.cBob Moore
Split out the table load functions in preparation for addition of new interfaces. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update all copyrights to 2012Bob Moore
Update all copyrights to 2012. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-10-31acpi: add export.h to files using THIS_MODULE/EXPORT_SYMBOLPaul Gortmaker
These files were relying on module.h to come in via the path in an include/acpi header file, but we don't want to have instances of module.h being included from include/* files if it can be avoided. Have the files include export.h instead. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-05-06ACPICA: Clarify/rename some root table descriptor fieldsBob Moore
Original fields were not very descriptive and led to maintenance problems. New fields should help to understand the existing code. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Update DSDT copy/detection.Bob Moore
Move initialization of DSDT pointer. Emit address of DSDT in the dump of both table headers (good/bad DSDT). Now handles the case where the root table can be reallocated, which would invalidate the original pointer. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Add subsystem option to force copy of DSDT to local memoryLin Ming
Optionally copy the entire DSDT to local memory (instead of simply mapping it.) There are some BIOSs that corrupt or replace the original DSDT, creating the need for this option. Default is FALSE, do not copy the DSDT. https://bugzilla.kernel.org/show_bug.cgi?id=14679 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Add detection of corrupted/replaced DSDTLin Ming
This change adds support to detect a DSDT that has been corrupted and/or replaced from outside the OS (by firmware). This is typically catastrophic for the system, but has been seen on some machines. https://bugzilla.kernel.org/show_bug.cgi?id=14679 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Fix for acpi_reallocate_root_table for incorrect root table copyAlexey Starikovskiy
When copying the root table to the new allocation, the length used was incorrect. The new size was used instead of the current table size, meaning too much data was copied. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Formatting update - no functional changesBob Moore
Split some long lines. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Remove extraneous parameter in table managerBob Moore
Removed the Flags parameter from several internal functions since it was not being used. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Allow OS override of all ACPI tablesBob Moore
Previously, the table override mechanism was implemented for the DSDT only. Now, any table in the RSDT/XSDT can be replaced by the host OS. (including the DSDT). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-09acpi/x86: introduce __apci_map_table, v4Yinghai Lu
to prevent wrongly overwriting fixmap that still want to use. ACPI used to rely on low mappings being all linearly mapped and grew a habit: it never really unmapped certain kinds of tables after use. This can cause problems - for example the hypothetical case when some spurious access still references it. v2: remove prev_map and prev_size in __apci_map_table v3: let acpi_os_unmap_memory() call early_iounmap too, so remove extral calling to early_acpi_os_unmap_memory v4: fix typo in one acpi_get_table_with_size calling Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
