path: root/drivers/acpi/acpica/psparse.c
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Fix issues/fault with automatic "serialized" method supportLin Ming
History: This support changes a method to "serialized" on the fly if the method generates an AE_ALREADY_EXISTS error, indicating the possibility that it cannot handle reentrancy. This fix repairs a couple of issues seen in the field, especially on machines with many cores. 1) Delete method children only upon the exit of the last thread, so as to not delete objects out from under running threads. 2) Set the "serialized" bit for the method only upon the exit of the last thread, so as to not cause deadlock when running threads attempt to exit. 3) Cleanup the use of the AML "MethodFlags" and internal method flags so that there is no longer any confustion between the two. Reported-by: Dana Myers <dana.myers@oracle.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-24ACPICA: Deploy new create integer interface where appropriateBob Moore
Simplifies creation of simple integer objects. ACPICA BZ 823. http://www.acpica.org/bugzilla/show_bug.cgi?id=823 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
