path: root/drivers/acpi/acpica/hwgpe.c
2013-06-16ACPICA: Standardize all switch() blocksChao Guan
After many years, different formatting for switch() has crept in. This change makes every switch block identical. Chao Guan. ACPICA bugzilla 997. References: https://bugs.acpica.org/show_bug.cgi?id=997 Signed-off-by: Chao Guan <chao.guan@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Remove some extraneous newlines in ACPI_ERROR type callsBob Moore
These macros/functions automatically insert a newline, so the format string should not contain a newline at the end. (This allows these functions to add information to the end of the output line.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-10ACPICA: Cleanup coding style to reduce differences between Linux and ACPICA.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 314 lines of 20121018 divergence.diff. ACPICA core uses ()'s on return statements. This is a known and committed differences from Linux standard coding style. This patch cleans up the Linux side ACPICA code to use this codying style in order to reduce the source code differences between Linux and ACPICA. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: ACPICA core: Cleanup empty lines at file start and endBob Moore
Maintenance for source code consistency. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix indent caused divergences.Lv Zheng
New version of "indent" program will generate different outputs that will lead to the divergences between the Linux and the ACPICA. This patch fixes such divergences caused by the "indent" program. The version of the "indent" used for this patch is "GNU indent 2.2.11". This patch will not affect the generated vmlinux binary. This will decrease 581 lines of 20120913 divergence.diff. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-09-21ACPICA: GPE support: Remove extraneous parameter from low-level function.Feng Tang
The gpe_register_info argument is no longer needed, reduce it to make code simpler. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22ACPICA: Support for custom ACPICA build for ACPI 5 reduced hardwareBob Moore
Add ACPI_REDUCED_HARDWARE flag that removes all hardware-related code (about 10% code, 5% static data). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update all copyrights to 2012Bob Moore
Update all copyrights to 2012. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2011-01-12ACPICA: Misc comments to minimize code divergenceLin Ming
Modify/add some comments to minimize ACPICA/linux GPE code divergence. Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Rename some function and variable namesLin Ming
Some function and variable names are renamed to be consistent with ACPICA code base. acpi_raw_enable_gpe -> acpi_ev_add_gpe_reference acpi_raw_disable_gpe -> acpi_ev_remove_gpe_reference acpi_gpe_can_wake -> acpi_setup_gpe_for_wake acpi_gpe_wakeup -> acpi_set_gpe_wake_mask acpi_update_gpes -> acpi_update_all_gpes acpi_all_gpes_initialized -> acpi_gbl_all_gpes_initialized acpi_handler_info -> acpi_gpe_handler_info ... Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Remove obsolete GPE functionBob Moore
Remove acpi_hw_write_gpe_enable_reg, it had been reduced down to a single line of code, and called from only one place. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Rename acpi_hw_gpe_register_bitLin Ming
Rename acpi_hw_gpe_register_bit to acpi_hw_get_gpe_register_bit in order to be same with ACPICA code base. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-12ACPI / ACPICA: Avoid writing full enable masks to GPE registersRafael J. Wysocki
ACPICA uses acpi_hw_write_gpe_enable_reg() to re-enable a GPE after an event signaled by it has been handled. However, this function writes the entire GPE enable mask to the GPE's enable register which may not be correct. Namely, if one of the other GPEs in the same register was previously enabled by acpi_enable_gpe() and subsequently disabled using acpi_set_gpe(), acpi_hw_write_gpe_enable_reg() will re-enable it along with the target GPE. To fix this issue rework acpi_hw_write_gpe_enable_reg() so that it calls acpi_hw_low_set_gpe() with a special action value, ACPI_GPE_COND_ENABLE, that will make it only enable the GPE if the corresponding bit in its register's enable_for_run mask is set. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-12ACPI / ACPICA: Fix low-level GPE manipulation codeRafael J. Wysocki
ACPICA uses acpi_ev_enable_gpe() for enabling GPEs at the low level, which is incorrect, because this function only enables the GPE if the corresponding bit in its enable register's enable_for_run mask is set. This causes acpi_set_gpe() to work incorrectly if used for enabling GPEs that were not previously enabled with acpi_enable_gpe(). As a result, among other things, wakeup-only GPEs are never enabled by acpi_enable_wakeup_device(), so the devices that use them are unable to wake up the system. To fix this issue remove acpi_ev_enable_gpe() and its counterpart acpi_ev_disable_gpe() and replace acpi_hw_low_disable_gpe() with acpi_hw_low_set_gpe() that will be used instead to manipulate GPE enable bits at the low level. Make the users of acpi_ev_enable_gpe() and acpi_ev_disable_gpe() call acpi_hw_low_set_gpe() instead and make sure that GPE enable masks are only updated by acpi_enable_gpe() and acpi_disable_gpe() when GPE reference counters change from 0 to 1 and from 1 to 0, respectively. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-11ACPI / ACPICA: Use helper function for computing GPE masksRafael J. Wysocki
In quite a few places ACPICA needs to compute a GPE enable mask with only one bit, corresponding to a given GPE, set. Currently, that computation is always open coded which leads to unnecessary code duplication. Fix this by introducing a helper function for computing one-bit GPE enable masks and using it where appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update for new gcc-4 warning optionsBob Moore
Added several new options for the gcc-4 generation, and updated the source accordingly. This includes some code restructuring to eliminate unreachable code, elimination of some gotos, elimination of unused return values, and some additional casting. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-27ACPICA: Add 64-bit support to acpi_read and acpi_writeBob Moore
Needed by drivers for new ACPi tables. Internal versions of these functions still use 32-bit max transfers, in order to minimize disruption and stack use for the standard ACPI registers (FADT-based). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: Formatting update - no functional changesBob Moore
Split long lines, update comments. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
