path: root/drivers/acpi/acpica/exresolv.c
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31ACPICA: Linuxize: Change indentation of C labels.Lv Zheng
It is reported by kernel build test systems that all ACPICA source files in the kernel tree have incorrect label indentation. This patch changes default indent option used in the release process to fix this bug. Lv Zheng. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-16ACPICA: Standardize all switch() blocksChao Guan
After many years, different formatting for switch() has crept in. This change makes every switch block identical. Chao Guan. ACPICA bugzilla 997. References: https://bugs.acpica.org/show_bug.cgi?id=997 Signed-off-by: Chao Guan <chao.guan@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2012-11-15ACPICA: Remove extra spaces after periods within commentsBob Moore
This makes all comments consistent. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: ACPICA core: Cleanup empty lines at file start and endBob Moore
Maintenance for source code consistency. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-07-17ACPICA: AcpiSrc: Fix some translation issues for Linux conversionBob Moore
Fixes issues like this: i_aSL -> iASL 00-7_f -> 00-7F local_fADT -> local_FADT execute_oSI -> execute_OSI Also, in function headers, the parameters are now translated to lower case (with underscores if necessary.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-07-17ACPICA: Fix some comment fieldsBob Moore
No functional change. Fixes some typos and linux divergences. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update all copyrights to 2012Bob Moore
Update all copyrights to 2012. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-04-20ACPICA: Standardize integer output for ACPICA warnings/errorsBob Moore
Always use 0x prefix for hex output, use %u for integer output (all integers are unsigned.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-26ACPICA: Remove ACPI_GET_OBJECT_TYPE macroBob Moore
Remove all instances of this obsolete macro, since it is now a simple reference to ->common.type. There were about 150 invocations of the macro across 41 files. ACPICA BZ 755. http://www.acpica.org/bugzilla/show_bug.cgi?id=755 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
