It is reported by kernel build test systems that all ACPICA source
files in the kernel tree have incorrect label indentation. This
patch changes default indent option used in the release process to
fix this bug. Lv Zheng.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
After many years, different formatting for switch() has crept in.
This change makes every switch block identical. Chao Guan.
ACPICA bugzilla 997.
References: https://bugs.acpica.org/show_bug.cgi?id=997
Signed-off-by: Chao Guan <chao.guan@intel.com>
Includes all source headers and signons for the various tools.
This makes all comments consistent.
Maintenance for source code consistency.
Fixes issues like this:
i_aSL -> iASL
00-7_f -> 00-7F
local_fADT -> local_FADT
execute_oSI -> execute_OSI
Also, in function headers, the parameters are now translated to
lower case (with underscores if necessary.)
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Update all copyrights to 2012.
Always use 0x prefix for hex output, use %u for integer output
(all integers are unsigned.)
This type was introduced as the code was migrated from ACPI 1.0
(with 32-bit AML integers) to ACPI 2.0 (with 64-bit integers). It
is now obsolete and this change removes it from the ACPICA code
base, replaced by u64. The original typedef has been retained
for now for compatibility with existing device driver code.
Add 2010 copyright to all module headers and signons, including
the Linux header. This affects virtually every file in the ACPICA
core subsystem, iASL compiler, and all utilities.
Remove all instances of this obsolete macro, since it is now a
simple reference to ->common.type. There were about 150 invocations
of the macro across 41 files. ACPICA BZ 755.
http://www.acpica.org/bugzilla/show_bug.cgi?id=755
also, delete sleep/ and delete ACPI_CFLAGS from Makefile
