If a handler is installed for a GPE associated with an AML method and
such that it cannot wake up the system from sleep states, the GPE
remains enabled after the handler has been installed, although it
should be disabled in that case to avoid spurious execution of the
handler.
Fix this issue by making acpi_install_gpe_handler() disable GPEs
that were previously associated with AML methods and cannot wake up
the system from sleep states.
Analogously, make acpi_remove_gpe_handler() enable the GPEs that
are associated with AML methods after their handlers have been
removed and cannot wake up the system from sleep states. In addition
to that, fix a code ordering issue in acpi_remove_gpe_handler() that
renders the locking ineffective (ACPI_MTX_EVENTS is released
temporarily in the middle of the routine to wait for the completion
of events already in progress).
For this purpose introduce acpi_raw_disable_gpe() and
acpi_raw_enable_gpe() to be called with acpi_gbl_gpe_lock held
and rework acpi_disable_gpe() and acpi_enable_gpe(), respectively, to
use them. Also rework acpi_gpe_can_wake() to use
acpi_raw_disable_gpe() instead of calling acpi_disable_gpe() after
releasing the lock to avoid the possible theoretical race with
acpi_install_gpe_handler().
Cc: "Moore, Robert" <robert.moore@intel.com>
Cc: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Remove acpi_hw_write_gpe_enable_reg, it had been reduced down to a
single line of code, and called from only one place.
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
The GPE block initialization code in acpi_ev_initialize_gpe_block()
uses acpi_set_gpe() to make sure that the GPEs with nonzero
runtime counter will remain enabled, but since it already has
a struct acpi_gpe_event_info object for each GPE, it might use
the low-level GPE enabling function, acpi_clear_and_enable_gpe(),
for this purpose.
To make that happen, move acpi_clear_and_enable_gpe() to
drivers/acpi/acpica/evgpe.c and rename it to acpi_ev_enable_gpe(),
modify the two existing users of it accordingly and modify
acpi_ev_initialize_gpe_block() to use it instead of acpi_set_gpe()
and to check its return value.
After the previous patch that introduced acpi_gpe_wakeup() and
modified the ACPI suspend and wakeup code to use it, the third
argument of acpi_{enable|disable}_gpe() and the GPE wakeup
reference counter are not necessary any more. Remove them and
modify all of the users of acpi_{enable|disable}_gpe()
accordingly. Also drop GPE type constants that aren't used
any more.
Rename acpi_hw_gpe_register_bit to acpi_hw_get_gpe_register_bit
in order to be same with ACPICA code base.
ACPICA uses acpi_ev_enable_gpe() for enabling GPEs at the low level,
which is incorrect, because this function only enables the GPE if the
corresponding bit in its enable register's enable_for_run mask is set.
This causes acpi_set_gpe() to work incorrectly if used for enabling
GPEs that were not previously enabled with acpi_enable_gpe(). As a
result, among other things, wakeup-only GPEs are never enabled by
acpi_enable_wakeup_device(), so the devices that use them are unable
to wake up the system.
To fix this issue remove acpi_ev_enable_gpe() and its counterpart
acpi_ev_disable_gpe() and replace acpi_hw_low_disable_gpe() with
acpi_hw_low_set_gpe() that will be used instead to manipulate GPE
enable bits at the low level. Make the users of acpi_ev_enable_gpe()
and acpi_ev_disable_gpe() call acpi_hw_low_set_gpe() instead and
make sure that GPE enable masks are only updated by acpi_enable_gpe()
and acpi_disable_gpe() when GPE reference counters change from 0
to 1 and from 1 to 0, respectively.
In quite a few places ACPICA needs to compute a GPE enable mask with
only one bit, corresponding to a given GPE, set. Currently, that
computation is always open coded which leads to unnecessary code
duplication. Fix this by introducing a helper function for computing
one-bit GPE enable masks and using it where appropriate.
For all GPEs, including FADT-based and GPE Block Devices, execute
any _PRW methods in the new table, and process any _Lxx/_Exx GPE
methods in the new table. Any runtime GPE that is referred to
by an _Lxx/_Exx method in the new table is immediately enabled.
ACPICA BZ 833.
http://www.acpica.org/bugzilla/show_bug.cgi?id=833
We have ported Rafael's major GPE changes
(ACPI: Use GPE reference counting to support shared GPEs) into ACPICA code base.
But the port and Rafael's original patch have some differences, so we made
below patch to make linux GPE code consistent with ACPICA code base.
Most changes are about comments and coding styles.
Other noticeable changes are based on:
Rafael: Reduce code duplication related to GPE lookup
https://patchwork.kernel.org/patch/86237/
Rafael: Always use the same lock for GPE locking
https://patchwork.kernel.org/patch/90471/
A new field gpe_count in struct acpi_gpe_block_info to record the number
of individual GPEs in block.
Rename acpi_ev_save_method_info to acpi_ev_match_gpe_method.
Signed-off-by: Robert Moore <robert.moore@intel.com>
Always use 0x prefix for hex output, use %u for integer output
(all integers are unsigned.)
acpi_ev_enable_gpe() should enable the GPE at the hardware level
regardless of the value of the GPE's runtime reference counter.
There are only two callers of acpi_ev_enable_gpe(), acpi_enable_gpe()
and acpi_set_gpe(). The first one checks the GPE's runtime
reference counter itself and only calls acpi_ev_enable_gpe() if it's
equal to one, and the other one is supposed to enable the GPE
unconditionally (if called with ACPI_GPE_ENABLE).
This change fixes the problem in acpi_enable_wakeup_device() where
the GPE will not be enabled for wakeup if it's runtime reference
counter is zero, which is a regression from 2.6.33.
Reported-by: Robert Moore <robert.moore@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: replace acpi_integer by u64
ACPICA: Update version to 20100121.
ACPICA: Remove unused uint32_struct type
ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object
ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type
ACPICA: Predefined name repair: fix NULL package elements
ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls
ACPICA: Update all ACPICA copyrights and signons to 2010
ACPICA: Update for new gcc-4 warning options
To fix a bug and address the reviewers' comments regarding the ACPI
GPE refcounting patch, do the following additional changes:
o Remove the second argument of acpi_ev_enable_gpe(),
'write_to_hardware', because it is not necessary any more.
o Add the "bad parameter" test against 'type' in
acpi_enable_gpe() and acpi_disable_gpe().
o Make acpi_enable_gpe() only check 'status' for runtime GPEs if
acpi_ev_enable_gpe() was actually called.
o Make acpi_disable_gpe() return 'status' returned by
acpi_ev_disable_gpe() and fix a bug where ACPI_GPE_TYPE_WAKE
and ACPI_GPE_TYPE_RUNTIME were exchanged by mistake.
o Add comments explaining why acpi_set_gpe() is used by the ACPI EC
driver.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
ACPI GPEs may map to multiple devices. The current GPE interface
only provides a mechanism for enabling and disabling GPEs, making
it difficult to change the state of GPEs at runtime without extensive
cooperation between devices.
Add an API to allow devices to indicate whether or not they want
their device's GPE to be enabled for both runtime and wakeup events.
Remove the old GPE type handling entirely, which gets rid of various
quirks, like the implicit disabling with GPE type setting. This
requires a small amount of rework in order to ensure that non-wake
GPEs are enabled by default to preserve existing behaviour.
Based on patches from Matthew Garrett <mjg@redhat.com>.
Add 2010 copyright to all module headers and signons, including
the Linux header. This affects virtually every file in the ACPICA
core subsystem, iASL compiler, and all utilities.
Needed by drivers for new ACPi tables. Internal versions of
these functions still use 32-bit max transfers, in order to
minimize disruption and stack use for the standard ACPI registers
(FADT-based).
Split long lines, update comments.
also, delete sleep/ and delete ACPI_CFLAGS from Makefile
